2 Replies Latest reply on Dec 18, 2015 12:28 PM by adamneer
    Has there been any progress on resolving the memory leak that renders After-Effects unusable in the Apple environment?
    larryl61814215 Level 1
      I purchased an AE template and I am unable to do any work due to the failure of some module to release memory.
      The details:
      iMac (27-inch, Late 2013)
      3.4GHz Intel Core i5 processor
      32GB 1600 MHz DDR3
      NVIDIA GeForce GRX 780M 4096MB
      Adobe After Effects CC
      2015.0 Release
      Version 13.5.0.347
      100% used of 32.0GB
      Disk Cache: Enabled
      Cache Size:500GB
      Default directories selected
      Reduce cache size when system is low on memory: Enabled.
      I am able to launch the program and then load the template I purchased, the Virtual Studio 2 After Effects template from Blue FX.  Once I attempt to do anything I see one of three messages stating "the Cached Preview needs 2 or more frames to playback" followed by a warning stating "fresh layer cache checkout failed", followed by an error "Unable to allocate enough memory to render the current frame.  Either decrease the memory requirements for the rendering of this frame, or install more RAM".
      I discovered the memory leak by observing The Memory Details form in which the Current Memory can be seen climbing until all of the system memory is consumed.  It appears that some module in the application is using, but never releasing, the system memory.
      I have opened an empty project with no template and added a clip that seems to run fine.  It could be an issue with the template and I will be contacting Blue FX to see if this is something on their end.
      Any help you can provide will be greatly appreciated.
      Thank you,
      Warren Henderson working with Larry Lasseter
