2 Replies Latest reply on Dec 18, 2015 9:26 AM by johnrellis
    Lightroom 4 - Images disappear
    sherylw36883523
      I have rated images as 1 with the star system. When I click on the 1 star to only look at the rated images, all pictures disappear. This happens if I rate the images as 2 as well. However, If i rate the images as 3 or higher, it works as it should. Any help?
        • 1. Re: Lightroom 4 - Images disappear
          Tanuj Sandal Adobe Employee
          Hi sherylw36883523,
          Please click on " All Photographs" in the Library Module from the Catalog Panel.
          And then use the Star Filter from Attribute .
          Regards,
          Tanuj
          • 2. Re: Lightroom 4 - Images disappear
            johnrellis Most Valuable Participant
            1. In Library mode verify that the image you think you've rated 1 star actually has 1 star.  Select the image and then look in the Metadata panel on the right:
            2. Select All Photographs and then filter by 1 star.
            3. If neither 1 nor 2 address the issue, post three full-resolution screenshots of the LR window, one with no filter stars selected, one with 1 star selected, and one with 3 selected.  Note that you can't reply to the email and attache the screenshots -- you have to come to the Web and insert them using the camera icon at the top of the editing window.
