3 Replies Latest reply on Dec 24, 2015 8:59 AM by dj_paige
    Starting a week or two ago LR on my mac book pro is crashing regularly, very annoying. This never happened before, whats the deal?
    bmp69
      Lightroom version: CC 2015.3 [ 1052427 ]
      License: Creative Cloud
      Operating system: Mac OS 10
      Version: 10.10 [5]
      Application architecture: x64
      Logical processor count: 8
      Processor speed: 2.5 GHz
      Built-in memory: 16,384.0 MB
      Real memory available to Lightroom: 16,384.0 MB
      Real memory used by Lightroom: 659.1 MB (4.0%)
      Virtual memory used by Lightroom: 2,555.3 MB
      Memory cache size: 68.2 MB
      Maximum thread count used by Camera Raw: 8
      Camera Raw SIMD optimization: SSE2,AVX,AVX2
      Displays: 1) 2560x1440
      Graphics Processor Info:
      NVIDIA GeForce GT 750M OpenGL Engine
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 4.1 NVIDIA-10.4.2 310.41.35f01
      Renderer: NVIDIA GeForce GT 750M OpenGL Engine
      LanguageVersion: 4.10
      Application folder: /Applications/Adobe Lightroom
      Library Path: /Users/williammetcalf1/Pictures/Lightroom/Lightroom Catalog.lrcat
      Settings Folder: /Users/williammetcalf1/Library/Application Support/Adobe/Lightroom
      Installed Plugins:
      1) Aperture/iPhoto Importer Plug-in
      2) Canon Tether Plugin
      3) ColorChecker Passport
      4) Facebook
      5) Flickr
      6) HDR Efex Pro 2
      7) Leica Tether Plugin
      8) Nikon Tether Plugin
      Config.lua flags: None
      AudioDeviceIOBlockSize: 512
      AudioDeviceName: Display Audio
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 44100
      Build: Uninitialized
      CoreImage: true
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: NVIDIA GeForce GT 750M OpenGL Engine
      GL_SHADING_LANGUAGE_VERSION: 1.20
      GL_STENCIL_BITS: 8
      GL_VENDOR: NVIDIA Corporation
      GL_VERSION: 2.1 NVIDIA-10.4.2 310.41.35f01
      GL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_bounds_test GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_point_sprite GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
        • 1. Re: Starting a week or two ago LR on my mac book pro is crashing regularly, very annoying. This never happened before, whats the deal?
          dj_paige Level 9
          Are there specific tasks in Lightroom that cause the program to crash? Or does it appear to be random?
          In Lightroom, please disable Graphics Acceleration and see if the problem goes away. In Preferences, click on the Performance tab and then uncheck the box
          • 2. Re: Starting a week or two ago LR on my mac book pro is crashing regularly, very annoying. This never happened before, whats the deal?
            bmp69 Level 1
            Date/Time:       2015-12-24 10:44:39 -0600
            OS Version:      10.10.5 (Build 14F1509)
            Architecture:    x86_64h
            Report Version:  21
            Command:         Lightroom
            Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
            Version:         Adobe Lightroom [1052427] (6.3)
            Parent:          launchd [1]
            PID:             4092
            Event:           hang
            Duration:        0.90s (process was unresponsive for 645 seconds before sampling)
            Steps:           10 (100ms sampling interval)
            Hardware model:  MacBookPro11,3
            Active cpus:     8
            Fan speed:       2157 rpm
            Timeline format: stacks are sorted chronologically
            Use -i and -heavy to re-report with count sorting
            Heaviest stack for the main thread of the target process:
              10  start + 1 (libdyld.dylib + 13769) [0x7fff94f0a5c9]
              10  main + 953 (Adobe Lightroom + 6569) [0x1078839a9]
              10  NSApplicationMain + 1832 (AppKit + 12868) [0x7fff8f843244]
              10  -[NSApplication run] + 594 (AppKit + 551667) [0x7fff8f8c6af3]
              10  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 (AppKit + 593496) [0x7fff8f8d0e58]
              10  _DPSNextEvent + 978 (AppKit + 596139) [0x7fff8f8d18ab]
              10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 205099) [0x7fff8f56c12b]
              10  ReceiveNextEventCommon + 431 (HIToolbox + 205546) [0x7fff8f56c2ea]
              10  RunCurrentEventLoopInMode + 235 (HIToolbox + 206191) [0x7fff8f56c56f]
              10  CFRunLoopRunSpecific + 296 (CoreFoundation + 465880) [0x7fff8ea61bd8]
              10  __CFRunLoopRun + 1814 (CoreFoundation + 468278) [0x7fff8ea62536]
              10  __CFRunLoopDoBlocks + 341 (CoreFoundation + 469493) [0x7fff8ea629f5]
              10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 526572) [0x7fff8ea708ec]
              10  ____CFXNotificationPostToken_block_invoke + 142 (CoreFoundation + 909198) [0x7fff8eacdf8e]
              10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 1180764) [0x7fff8eb1045c]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386804) [0x110849474]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386130) [0x1108491d2]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386327) [0x110849297]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6394893) [0x11084b40d]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 312381) [0x11027e43d]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 75776) [0x110244800]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 76664) [0x110244b78]
              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 346383) [0x11028690f]
              9  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 3389247) [0x11056d73f] (running)
            Process:         Adobe Lightroom (Lightroom) [4092]
            Parent:          launchd [1]
            UID:             502
            Task size:       790883 pages
            CPU Time:        0.902s
            Note:            Unresponsive for 645 seconds before sampling
            Note:            1 idle work queue threads omitted
              Thread 0x398c07     DispatchQueue 1     10 samples (1-10)   priority 42         cpu time 0.900s
              <frontmost, boosted, received importance donation from WindowServer [147], received importance donation from filecoordinationd [312], IO policy important>
              10  start + 1 (libdyld.dylib + 13769) [0x7fff94f0a5c9] 1-10
                10  main + 953 (Adobe Lightroom + 6569) [0x1078839a9] 1-10
                  10  NSApplicationMain + 1832 (AppKit + 12868) [0x7fff8f843244] 1-10
                    10  -[NSApplication run] + 594 (AppKit + 551667) [0x7fff8f8c6af3] 1-10
                      10  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 (AppKit + 593496) [0x7fff8f8d0e58] 1-10
                        10  _DPSNextEvent + 978 (AppKit + 596139) [0x7fff8f8d18ab] 1-10
                          10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 205099) [0x7fff8f56c12b] 1-10
                            10  ReceiveNextEventCommon + 431 (HIToolbox + 205546) [0x7fff8f56c2ea] 1-10
                              10  RunCurrentEventLoopInMode + 235 (HIToolbox + 206191) [0x7fff8f56c56f] 1-10
                                10  CFRunLoopRunSpecific + 296 (CoreFoundation + 465880) [0x7fff8ea61bd8] 1-10
                                  10  __CFRunLoopRun + 1814 (CoreFoundation + 468278) [0x7fff8ea62536] 1-10
                                    10  __CFRunLoopDoBlocks + 341 (CoreFoundation + 469493) [0x7fff8ea629f5] 1-10
                                      10  __CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK__ + 12 (CoreFoundation + 526572) [0x7fff8ea708ec] 1-10
                                        10  ____CFXNotificationPostToken_block_invoke + 142 (CoreFoundation + 909198) [0x7fff8eacdf8e] 1-10
                                          10  __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12 (CoreFoundation + 1180764) [0x7fff8eb1045c] 1-10
                                            10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386804) [0x110849474] 1-10
                                              10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386130) [0x1108491d2] 1-10
                                                10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6386327) [0x110849297] 1-10
                                                  10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 6394893) [0x11084b40d] 1-10
                                                    10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 312381) [0x11027e43d] 1-10
                                                      10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 75776) [0x110244800] 1-10
                                                        10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 76664) [0x110244b78] 1-10
                                                          10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 346383) [0x11028690f] 1-10
                                                            1  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 3389232) [0x11056d730] (running) 1
                                                            9  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 3389247) [0x11056d73f] (running) 2-10
              Thread 0x398c24     DispatchQueue 2     10 samples (1-10)   priority 47
              <frontmost, thread QoS user interactive, boosted, received importance donation from WindowServer [147], received importance donation from filecoordinationd [312], IO policy important>
              10  _dispatch_mgr_thread + 52 (libdispatch.dylib + 25198) [0x7fff9836026e] 1-10
                10  kevent64 + 10 (libsystem_kernel.dylib + 94770) [0x7fff96500232] 1-10
                 *10  ??? (kernel + 5987312) [0xffffff80007b5bf0] 1-10
              Thread 0x398c77     10 samples (1-10)   priority 31
              <frontmost, thread QoS legacy, boosted, received importance donation from WindowServer [147], received importance donation from filecoordinationd [312], IO policy important>
              10  thread_start + 13 (libsystem_pthread.dylib + 5101) [0x7fff91a6a3ed] 1-10
                10  _pthread_start + 176 (libsystem_pthread.dylib + 16343) [0x7fff91a6cfd7] 1-10
                  10  _pthread_body + 131 (libsystem_pthread.dylib + 16474) [0x7fff91a6d05a] 1-10
                    10  __NSThread__main__ + 1345 (Foundation + 257682) [0x7fff8ef78e92] 1-10
                      10  ??? (<B40C74A9-AB21-303C-8C73-67C01D2D2500> + 74682) [0x107a103ba] 1-10
                        10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 8631) [0x10789e1b7] 1-10
                          10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 41892) [0x1078a63a4] 1-10
                            10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 38890) [0x1078a57ea] 1-10
                              10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 41293) [0x1078a614d] 1-10
                                10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 99459) [0x1078b4483] 1-10
                                  10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 40591) [0x1078a5e8f] 1-10
                                    10  ??? (<B40C74A9-AB21-303C-8C73-67C01D2D2500> + 125131) [0x107a1c8cb] 1-10
                                      10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 8502) [0x10789e136] 1-10
                                              10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 136622) [0x1078bd5ae] 1-10
                                                10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 132728) [0x1078bc678] 1-10
                                                  10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 158677) [0x1078c2bd5] 1-10
                                                    10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff964ff136] 1-10
                                                     *10  psynch_cvcontinue + 0 (pthread + 26910) [0xffffff7f80de291e] 1-10
              Thread 0x398c7b     10 samples (1-10)   priority 31
              Thread 0x398cc7     10 samples (1-10)   priority 31
                                        10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 41276) [0x1078a613c] 1-10
                                            10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 17254) [0x1078a0366] 1-10
              Thread 0x398ccc     10 samples (1-10)   priority 31
                                                  10  ??? (<E81A69AA-3283-333F-B25F-9EF30B88D513> + 158822) [0x1078c2c66] 1-10
              Thread 0x398d01     10 samples (1-10)   priority 47         cpu time 0.001s
                    10  _NSEventThread + 137 (AppKit + 1414507) [0x7fff8f99956b] 1-10
                        10  __CFRunLoopRun + 1371 (CoreFoundation + 467835) [0x7fff8ea6237b] 1-10
                          10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 470708) [0x7fff8ea62eb4] 1-10
                            10  mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff964fa4de] 1-10
                             *10  ipc_mqueue_receive_continue + 0 (kernel + 1144832) [0xffffff8000317800] 1-10
              Thread 0x398d02     10 samples (1-10)   priority 31
              Thread 0x398d03     10 samples (1-10)   priority 31
              Thread 0x398d04     10 samples (1-10)   priority 30
              Thread 0x398d05     10 samples (1-10)   priority 63
                      10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 434 (CFNetwork + 37920) [0x7fff89820420] 1-10
              Thread 0x398d06     10 samples (1-10)   priority 31
              Thread 0x398d07     10 samples (1-10)   priority 31
                    10  ??? (<D633CDB7-C235-328A-98E5-11FE46B3D179> + 924666) [0x11b6c6bfa] 1-10
                      10  ??? (<D633CDB7-C235-328A-98E5-11FE46B3D179> + 564637) [0x11b66ed9d] 1-10
                        10  ??? (<D633CDB7-C235-328A-98E5-11FE46B3D179> + 571665) [0x11b670911] 1-10
                          10  ??? (<D633CDB7-C235-328A-98E5-11FE46B3D179> + 928670) [0x11b6c7b9e] 1-10
                            10  ??? (<D633CDB7-C235-328A-98E5-11FE46B3D179> + 934620) [0x11b6c92dc] 1-10
              Thread 0x398d08     10 samples (1-10)   priority 27
              Thread 0x398d09     10 samples (1-10)   priority 31
              Thread 0x398d0a     10 samples (1-10)   priority 31
              Thread 0x398d0b     10 samples (1-10)   priority 31
              Thread 0x398d49     10 samples (1-10)   priority 30
              Thread 0x398d4a     10 samples (1-10)   priority 30
              Thread 0x398d4b     10 samples (1-10)   priority 31
                    10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 122281) [0x11dea9da9] 1-10
                      10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 115336) [0x11dea8288] 1-10
                        10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 59679) [0x11de9a91f] 1-10
                          10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 56934) [0x11de99e66] 1-10
                            10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 110685) [0x11dea705d] 1-10
                              10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 110858) [0x11dea710a] 1-10
                                10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 111753) [0x11dea7489] 1-10
                                  10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 112482) [0x11dea7762] 1-10
                                    10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 96477) [0x11dea38dd] 1-10
                                      10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 96566) [0x11dea3936] 1-10
                                        10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 95384) [0x11dea3498] 1-10
                                          10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 116974) [0x11dea88ee] 1-10
                                            10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 117176) [0x11dea89b8] 1-10
                                              10  ??? (<4B0B878A-02F8-3EB1-89D5-4071034EDD0D> + 120317) [0x11dea95fd] 1-10
                                                10  __recvfrom + 10 (libsystem_kernel.dylib + 90938) [0x7fff964ff33a] 1-10
                                                 *10  hndl_unix_scall64 + 22 (kernel + 2311334) [0xffffff80004344a6] 1-10
                                                   *10  unix_syscall64 + 662 (kernel + 6599542) [0xffffff800084b376] 1-10
                                                     *10  recvfrom_nocancel + 234 (kernel + 6438218) [0xffffff8000823d4a] 1-10
                                                       *10  ??? (kernel + 6450187) [0xffffff8000826c0b] 1-10
                                                         *10  soreceive + 2319 (kernel + 6380511) [0xffffff8000815bdf] 1-10
                                                           *10  sbwait + 310 (kernel + 6412342) [0xffffff800081d836] 1-10
                                                             *10  msleep + 98 (kernel + 6139570) [0xffffff80007daeb2] 1-10
                                                               *10  ??? (kernel + 6140665) [0xffffff80007db2f9] 1-10
        *10  lck_mtx_sleep + 134 (kernel + 1272118) [0xffffff8000336936] 1-10
        *10  thread_block_reason + 175 (kernel + 1315119) [0xffffff800034112f] 1-10
        *10  ??? (kernel + 1325012) [0xffffff80003437d4] 1-10
        *10  machine_switch_context + 367 (kernel + 2172719) [0xffffff800041272f] 1-10
              Thread 0x398d4e     10 samples (1-10)   priority 30
              Thread 0x398d4f     10 samples (1-10)   priority 30
              Thread 0x398d50     10 samples (1-10)   priority 30
              Thread 0x398d51     10 samples (1-10)   priority 31
              Thread 0x398d52     10 samples (1-10)   priority 30
              Thread 0x398d74     10 samples (1-10)   priority 31
              Thread 0x398d7f     10 samples (1-10)   priority 31
              Thread 0x398d88     10 samples (1-10)   priority 47
                    10  __select + 10 (libsystem_kernel.dylib + 91130) [0x7fff964ff3fa] 1-10
                     *10  ??? (kernel + 6141040) [0xffffff80007db470] 1-10
              Thread 0x398eda     10 samples (1-10)   priority 31
              Thread 0x398f3a     10 samples (1-10)   priority 31
                    10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8346379) [0x117b7eb0b] 1-10
                      10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8367601) [0x117b83df1] 1-10
                        10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8173117) [0x117b5463d] 1-10
                          10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8276074) [0x117b6d86a] 1-10
                            10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 8174751) [0x117b54c9f] 1-10
                              10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 7952348) [0x117b1e7dc] 1-10
                                10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 7953956) [0x117b1ee24] 1-10
                                  10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 278 (Foundation + 592681) [0x7fff8efcab29] 1-10
              Thread 0x398f3b     10 samples (1-10)   priority 31
                              10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 7948578) [0x117b1d922] 1-10
                                10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 11838957) [0x117ed35ed] 1-10
                                  10  kevent + 10 (libsystem_kernel.dylib + 94746) [0x7fff9650021a] 1-10
              Thread 0x398f3e     10 samples (1-10)   priority 31
              Thread 0x398f40     10 samples (1-10)   priority 31
              Thread 0x398f41     10 samples (1-10)   priority 31
              Thread 0x398f42     10 samples (1-10)   priority 31
              Thread 0x398f43     10 samples (1-10)   priority 31
              Thread 0x398f44     10 samples (1-10)   priority 31
                        10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 14713878) [0x118191416] 1-10
                          10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 14713480) [0x118191288] 1-10
                                  10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 7948770) [0x117b1d9e2] 1-10
              Thread 0x398f45     10 samples (1-10)   priority 31
                        10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 14713891) [0x118191423] 1-10
                          10  ??? (<7E427337-65A2-3B49-AD70-9C9BE02F4C01> + 14713608) [0x118191308] 1-10
              Thread 0x398f46     10 samples (1-10)   priority 31
              Thread 0x398f47     10 samples (1-10)   priority 31
              Thread 0x398f48     10 samples (1-10)   priority 31
              Thread 0x398f49     10 samples (1-10)   priority 31
              Thread 0x398f4a     10 samples (1-10)   priority 31
              Thread 0x399573     10 samples (1-10)   priority 30
              Thread 0x399574     10 samples (1-10)   priority 30
              Thread 0x399575     10 samples (1-10)   priority 30
              Thread 0x399581     10 samples (1-10)   priority 31
              Thread 0x399584     10 samples (1-10)   priority 31
              Thread 0x39abbb     10 samples (1-10)   priority 30
              Thread 0x39d7b9     10 samples (1-10)   priority 31
              Thread 0x3a3579     10 samples (1-10)   priority 31
                    10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 57081) [0x109919ef9] 1-10
                      10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 156046) [0x10993218e] 1-10
                        10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 260855) [0x10994baf7] 1-10
                          10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 249602) [0x109948f02] 1-10
                            10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 258580) [0x10994b214] 1-10
                              10  ??? (Adobe Lightroom + 34179) [0x10788a583] 1-10
                                10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 4900) [0x10990d324] 1-10
                                  10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 153148) [0x10993163c] 1-10
                                    10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 184627) [0x109939133] 1-10
                                      10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 190358) [0x10993a796] 1-10
                                        10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 190956) [0x10993a9ec] 1-10
                                          10  ??? (<34A6D87D-661D-39E2-BD7D-80FB16812C1E> + 191088) [0x10993aa70] 1-10
              Thread 0x508ebf     10 samples (1-10)   priority 31
                    10  ??? (<D55439BC-3B97-35F3-8BAE-51CD37C43E68> + 209868) [0x1142fc3cc] 1-10
                      10  ??? (<D55439BC-3B97-35F3-8BAE-51CD37C43E68> + 97187) [0x1142e0ba3] 1-10
                        10  ??? (<D55439BC-3B97-35F3-8BAE-51CD37C43E68> + 209584) [0x1142fc2b0] 1-10
                          10  __semwait_signal + 10 (libsystem_kernel.dylib + 91274) [0x7fff964ff48a] 1-10
                           *10  semaphore_wait_continue + 0 (kernel + 1353536) [0xffffff800034a740] 1-10
              Thread 0x538231     10 samples (1-10)   priority 30
              Thread 0x538232     10 samples (1-10)   priority 30
              Thread 0x606dcf     10 samples (1-10)   priority 31
                    10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 1760161) [0x1103dfba1] 1-10
                      10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 237346) [0x11026bf22] 1-10
                        10  ??? (<BFFD28DE-64FB-375D-8C5F-9390628D42A7> + 1984187) [0x1104166bb] 1-10
              Binary Images:
                     0x107882000 -        0x107890fff  com.adobe.Lightroom6 Adobe Lightroom [1052427] (6.3) <43CBF5C7-6FD5-3BA9-8C2E-595ED7654A08>  /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/MacOS/Adobe Lightroom
                     0x10789c000 -                ???  ???                                                  <E81A69AA-3283-333F-B25F-9EF30B88D513>
                     0x1079fe000 -                ???  ???                                                  <B40C74A9-AB21-303C-8C73-67C01D2D2500>
                     0x10990c000 -                ???  ???                                                  <34A6D87D-661D-39E2-BD7D-80FB16812C1E>
                     0x110232000 -                ???  ???                                                  <BFFD28DE-64FB-375D-8C5F-9390628D42A7>
                     0x1142c9000 -                ???  ???                                                  <D55439BC-3B97-35F3-8BAE-51CD37C43E68>
                     0x117389000 -                ???  ???                                                  <7E427337-65A2-3B49-AD70-9C9BE02F4C01>
                     0x11b5e5000 -                ???  ???                                                  <D633CDB7-C235-328A-98E5-11FE46B3D179>
                     0x11de8c000 -                ???  ???                                                  <4B0B878A-02F8-3EB1-89D5-4071034EDD0D>
                  0x7fff89817000 -     0x7fff89a27fff  com.apple.CFNetwork 720.5.7 (720.5.7)                <A47D7DD2-5903-39D0-8D27-5A7E2D119D84>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x7fff8e9f0000 -     0x7fff8ed88fff  com.apple.CoreFoundation 6.9 (1153.18)               <5C0892B8-9691-341F-9279-CA3A74D59AA0>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff8ef3a000 -     0x7fff8f26bfff  com.apple.Foundation 6.9 (1154)                      <49EE64E1-9F53-35D1-A481-2EFE2789B254>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x7fff8f53a000 -     0x7fff8f83ffff  com.apple.HIToolbox 2.1.1 (758.7)                    <E3129A67-BDF9-333D-9C9C-A95C8F0EF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x7fff8f840000 -     0x7fff903c1fff  com.apple.AppKit 6.9 (1348.17)                       <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff91a69000 -     0x7fff91a72fff  libsystem_pthread.dylib (105.40.1)                   <ACE90967-ECD0-3251-AEEB-461E3C6414F7>  /usr/lib/system/libsystem_pthread.dylib
                  0x7fff94f07000 -     0x7fff94f0afff  libdyld.dylib (353.2.3)                              <CFBBE540-D503-3AFC-B5D6-644F1E69949B>  /usr/lib/system/libdyld.dylib
                  0x7fff964e9000 -     0x7fff96506fff  libsystem_kernel.dylib (2782.50.1)                   <1EE815DA-FF1B-3A53-AE9B-C98BD8177A9D>  /usr/lib/system/libsystem_kernel.dylib
                  0x7fff9835a000 -     0x7fff98384fff  libdispatch.dylib (442.50.1)                         <A61E703C-784A-3698-B513-75DD12AAD6DC>  /usr/lib/system/libdispatch.dylib
            *0xffffff7f80ddc000 - 0xffffff7f80de4fff  com.apple.kec.pthread 1.0 (1)                        <84126647-296D-3B12-9FF3-263679AF859C>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
            *0xffffff8000200000 - 0xffffff80009fffff  kernel (2782.50.1)                                   <06D286E3-A8A1-3BE7-A7EB-EAC6E0C69758>  /System/Library/Kernels/kernel
            Process:         ACCFinderSync [345]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex/Contents/MacOS/ACCFinderSync
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Dirty (allows idle exit)
            Task size:       2169 pages
            Process:         accountsd [273]
            Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean (allows idle exit)
            Task size:       921 pages
              Thread 0xbc9        DispatchQueue 1     10 samples (1-10)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy utility>
                10  ??? (accountsd + 2741) [0x10ce7dab5] 1-10
              Thread 0xbe0        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10ce7d000 -        0x10ce7dfff  accountsd (504.10)                     <04A110E1-7397-35CF-B77A-093318CEF5C8>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
            Process:         adb [3210]
            Path:            /Applications/Wacom Tablet.localized/Wacom Desktop Center.app/Contents/Resources/adb
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       132 pages
              Thread 0x37876d     10 samples (1-10)   priority 31
              <thread QoS legacy, IO policy important>
              10  __select + 10 (libsystem_kernel.dylib + 104526) [0x9a3d684e] 1-10
              Thread 0x37876e     10 samples (1-10)   priority 31
              10  mach_msg_trap + 10 (libsystem_kernel.dylib + 80334) [0x9a3d09ce] 1-10
              Thread 0x37876f     10 samples (1-10)   priority 31
              10  kevent64 + 10 (libsystem_kernel.dylib + 108750) [0x9a3d78ce] 1-10
              Binary Images:
                          0x1000 -            0x2ffff  adb                                <803A83D9-B10B-5A1B-0988-C8B267A218F2>  /Applications/Wacom Tablet.localized/Wacom Desktop Center.app/Contents/Resources/adb
                      0x9a3bd000 -         0x9a3dcfff  libsystem_kernel.dylib (2782.50.1) <20156462-5B58-3B51-8D05-A2F7195679D5>  /usr/lib/system/libsystem_kernel.dylib
            Process:         Adobe CEF Helper [468]
            Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
            Architecture:    i386
            Parent:          Creative Cloud [443]
            Responsible:     Creative Cloud [443]
            UID:             502
            Task size:       7900 pages
            Process:         Adobe CEF Helper [473]
            Architecture:    i386
            UID:             502
            Task size:       20607 pages
            Process:         Adobe Desktop Service [471]
            Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       28990 pages (-2)
            Process:         Adobe Installer [523]
            Path:            /Library/Application Support/Adobe/*/Adobe Installer
            Architecture:    i386
            Parent:          Adobe Desktop Service [471]
            Responsible:     Adobe Desktop Service [471]
            UID:             0
            Task size:       518 pages
              Thread 0x2a6f       10 samples (1-10)   priority 46
              <thread QoS user interactive, IO policy important>
              10  start + 53 (Adobe Installer + 3765) [0x7aeb5] 1-10
                10  ??? (Adobe Installer + 20430) [0x7efce] 1-10
                  10  ??? (Adobe Installer + 22651) [0x7f87b] 1-10
                    10  OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 171 (Adobe Installer + 76907) [0x8cc6b] 1-10
                      10  pthread_cond_wait$UNIX2003 + 71 (libsystem_pthread.dylib + 29992) [0x9882a528] 1-10
                        10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 103698) [0x9a3d6512] 1-10
              Thread 0x2a78       10 samples (1-10)   priority 46
              10  _dispatch_mgr_thread + 52 (libdispatch.dylib + 22726) [0x944428c6] 1-10
              Thread 0x2a79       10 samples (1-10)   priority 31
              10  __read + 10 (libsystem_kernel.dylib + 110038) [0x9a3d7dd6] 1-10
               *10  hndl_unix_scall + 216 (kernel + 2310552) [0xffffff8000434198] 1-10
                 *10  unix_syscall + 666 (kernel + 6598554) [0xffffff800084af9a] 1-10
                   *10  read_nocancel + 115 (kernel + 6207411) [0xffffff80007eb7b3] 1-10
                     *10  ??? (kernel + 6208074) [0xffffff80007eba4a] 1-10
                       *10  ??? (kernel + 3555649) [0xffffff8000564141] 1-10
                         *10  fifo_read + 135 (kernel + 3665415) [0xffffff800057ee07] 1-10
              Binary Images:
                         0x7a000 -            0x9efff  Adobe Installer                    <3A882BEC-70A0-3E24-B770-19C37897FA1A>  /Library/Application Support/Adobe/*/Adobe Installer
                      0x9443d000 -         0x94464fff  libdispatch.dylib (442.50.1)       <A4EA1B52-2597-36E9-BDE0-89B3D8B0C3E0>  /usr/lib/system/libdispatch.dylib
                      0x98823000 -         0x9882bfff  libsystem_pthread.dylib (105.40.1) <21849EF5-A3B6-34D4-A045-4A68A6C390A1>  /usr/lib/system/libsystem_pthread.dylib
            Process:         Adobe Lightroom Helper [4121]
            Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/Adobe Lightroom Helper.app/Contents/MacOS/Adobe Lightroom Helper
            Parent:          Adobe Lightroom (Lightroom) [4092]
            Responsible:     Adobe Lightroom (Lightroom) [4092]
            UID:             502
            Task size:       3076 pages
            Process:         AdobeCrashDaemon [4094]
            Path:            /Applications/Adobe Lightroom/Adobe Lightroom.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashDaemo n.app/Contents/MacOS/AdobeCrashDaemon
            UID:             502
            Task size:       419 pages
            Process:         AdobeCRDaemon [467]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/C ontents/MacOS/AdobeCRDaemon
            UID:             502
            Task size:       429 pages
            Process:         AdobeCRDaemon [479]
            Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app /Contents/MacOS/AdobeCRDaemon
            UID:             502
            Task size:       430 pages
            Process:         AdobeCRDaemon [483]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Co ntents/MacOS/AdobeCRDaemon
            Parent:          Core Sync [481]
            Responsible:     Core Sync [481]
            UID:             502
            Process:         AdobeIPCBroker [457]
            Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       2513 pages
            Process:         AdobeUpdateDaemon [77]
            Path:            /Library/Application Support/Adobe/*/AdobeUpdateDaemon
            Architecture:    i386
            Parent:          launchd [1]
            UID:             0
            Task size:       1142 pages
              Thread 0x269        10 samples (1-10)   priority 31
              <thread QoS legacy, timers coalesced, IO policy standard>
              10  start + 53 (AdobeUpdateDaemon + 3173) [0x68c65] 1-10
                10  ??? (AdobeUpdateDaemon + 4839) [0x692e7] 1-10
                  10  ??? (AdobeUpdateDaemon + 4249) [0x69099] 1-10
                    10  OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 171 (AdobeUpdateDaemon + 42283) [0x7252b] 1-10
              Thread 0x860        10 samples (1-10)   priority 31
              Thread 0x22a2       10 samples (1-10)   priority 31
              Thread 0x22bf       10 samples (1-10)   priority 31
              10  thread_start + 34 (libsystem_pthread.dylib + 3634) [0x98823e32] 1-10
                10  _pthread_start + 162 (libsystem_pthread.dylib + 15259) [0x98826b9b] 1-10
                  10  _pthread_body + 138 (libsystem_pthread.dylib + 15397) [0x98826c25] 1-10
                    10  listenerThread(void*) + 81 (AdobeUpdateDaemon + 447265) [0xd5321] 1-10
              Thread 0x22c0       10 samples (1-10)   priority 31
                    10  ??? (AdobeUpdateDaemon + 7569) [0x69d91] 1-10
                      10  ??? (AdobeUpdateDaemon + 7810) [0x69e82] 1-10
              Binary Images:
                         0x68000 -            0xfcfff  AdobeUpdateDaemon                  <8E71DED1-5428-3491-81A8-34C3DE1EEF7A>  /Library/Application Support/Adobe/*/AdobeUpdateDaemon
            Process:         AirPlayUIAgent [286]
            Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
            Parent:          launchd [1]
            UID:             502
            Task size:       1038 pages
              Thread 0xc58        DispatchQueue 1     10 samples (1-10)   priority 46
              <thread QoS user interactive, boosted, IO policy important>
              Thread 0xc86        DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0xcd0        10 samples (1-10)   priority 46
              Binary Images:
                     0x106c1b000 -        0x106c20fff  com.apple.AirPlayUIAgent 2.0 (215.18)  <1696F4E4-E7E7-3141-BCF7-D56C7ABF9DDD>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
            Process:         airportd [56]
            Path:            /usr/libexec/airportd
            Parent:          launchd [1]
            UID:             0
            Task size:       2749 pages
              Thread 0x254        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (airportd + 244408) [0x10c963ab8] 1-10
                  10  -[NSRunLoop(NSRunLoop) run] + 74 (Foundation + 1073743) [0x7fff8f04024f] 1-10
              Thread 0x44d        DispatchQueue 2     10 samples (1-10)   priority 4
                10  _dispatch_mgr_invoke + 176 (libdispatch.dylib + 26062) [0x7fff983605ce] 1-10
                  10  __select_nocancel + 10 (libsystem_kernel.dylib + 91154) [0x7fff964ff412] 1-10
              Thread 0x45a        10 samples (1-10)   priority 4
              Binary Images:
                     0x10c928000 -        0x10ca11fff  airportd (1030.71.6)                   <C0300690-DDD5-3430-B727-8D5D765814DD>  /usr/libexec/airportd
            Process:         amfid [145]
            Path:            /usr/libexec/amfid
            Parent:          launchd [1]
            UID:             0
            Task size:       1469 pages
              Thread 0x469        DispatchQueue 2     10 samples (1-10)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important>
              Thread 0x46a        DispatchQueue 11    10 samples (1-10)   priority 31
              10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 91970) [0x7fff964ff742] 1-10
              Binary Images:
                     0x10cf1e000 -        0x10cf1ffff  amfid (133.40.2)                   <375BF75D-A67D-300F-8777-402832437FC9>  /usr/libexec/amfid
            Process:         AppleCameraAssistant [309]
            Path:            /Library/CoreMediaIO/*/AppleCamera.plugin/Contents/Resources/AppleCameraAssistant
            Parent:          launchd [1]
            UID:             0
            Task size:       252 pages
              Thread 0xd28        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (AppleCameraAssistant + 147049) [0x106c38e69] 1-10
                  10  mach_msg_server + 468 (libsystem_kernel.dylib + 69472) [0x7fff964f9f60] 1-10
              Thread 0xd38        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0xd37        10 samples (1-10)   priority 31
                    10  ??? (AppleCameraAssistant + 147791) [0x106c3914f] 1-10
                      10  CFRunLoopRun + 97 (CoreFoundation + 1218161) [0x7fff8eb19671] 1-10
              Thread 0xd39        10 samples (1-10)   priority 31
                    10  ??? (AppleCameraAssistant + 124873) [0x106c337c9] 1-10
              Binary Images:
                     0x106c15000 -        0x106c4cfff  AppleCameraAssistant (5.36)            <798DBFE1-B992-3C7D-992F-4E0035DC81E0>  /Library/CoreMediaIO/*/AppleCamera.plugin/Contents/Resources/AppleCameraAssistant
            Process:         appleeventsd [51]
            Path:            /System/Library/CoreServices/appleeventsd
            Parent:          launchd [1]
            UID:             55
            Task size:       1073 pages
              Thread 0x820        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x821        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x1093c7000 -        0x1093c7fff  appleeventsd (681.7)               <FEB69291-B944-3BD3-978A-111C529A8663>  /System/Library/CoreServices/appleeventsd
            Process:         AppleIDAuthAgent [342]
            Path:            /System/Library/CoreServices/AppleIDAuthAgent
            Parent:          launchd [1]
            UID:             502
            Task size:       3677 pages
              Thread 0xeb3        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xeb5        DispatchQueue 26    10 samples (1-10)   priority 4
              10  start_wqthread + 13 (libsystem_pthread.dylib + 5085) [0x7fff91a6a3dd] 1-10
                10  _pthread_wqthread + 729 (libsystem_pthread.dylib + 15005) [0x7fff91a6ca9d] 1-10
                  10  _dispatch_worker_thread3 + 91 (libdispatch.dylib + 18972) [0x7fff9835ea1c] 1-10
                    10  _dispatch_root_queue_drain + 463 (libdispatch.dylib + 19439) [0x7fff9835ebef] 1-10
                      10  _dispatch_queue_invoke + 202 (libdispatch.dylib + 20528) [0x7fff9835f030] 1-10
                        10  _dispatch_queue_drain + 571 (libdispatch.dylib + 21436) [0x7fff9835f3bc] 1-10
                          10  _dispatch_source_invoke + 412 (libdispatch.dylib + 26939) [0x7fff9836093b] 1-10
                            10  _dispatch_source_latch_and_call + 721 (libdispatch.dylib + 58598) [0x7fff983684e6] 1-10
                              10  _dispatch_client_callout + 8 (libdispatch.dylib + 7795) [0x7fff9835be73] 1-10
                                10  _dispatch_after_timer_callback + 77 (libdispatch.dylib + 79520) [0x7fff9836d6a0] 1-10
                                    10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 22272) [0x7fff9835f700] 1-10
                                      10  ??? (AppleIDAuthAgent + 13302) [0x108ff43f6] 1-10
                                        10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 70962) [0x7fff964fa532] 1-10
              Thread 0xeb6        10 samples (1-10)   priority 4
              Thread 0xebf        10 samples (1-10)   priority 4
              Thread 0xec2        10 samples (1-10)   priority 4
              Thread 0xf00        10 samples (1-10)   priority 4
              Binary Images:
                     0x108ff1000 -        0x10902cfff  AppleIDAuthAgent (640.4)               <92574621-3BB0-3304-98C9-3136FFFA4E18>  /System/Library/CoreServices/AppleIDAuthAgent
            Process:         AppleSpell [469]
            Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       2732 pages
              Thread 0x221d       DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (AppleSpell + 5312) [0x108ed64c0] 1-10
                  10  -[NSSpellServer run] + 73 (Foundation + 1851064) [0x7fff8f0fdeb8] 1-10
              Thread 0x2220       DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x108ed5000 -        0x108fb8fff  com.apple.AppleSpell 2.2.3 (282)       <C1985DA2-E1F8-3D7C-97B1-738025FF8318>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
            Process:         apsd [76]
            Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
            Parent:          launchd [1]
            UID:             0
            Task size:       2852 pages
              Thread 0x268        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (apsd + 372483) [0x108d5af03] 1-10
              Thread 0x3eb        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x584        10 samples (1-10)   priority 63
              <timers coalesced, IO policy important>
              Thread 0xf72        10 samples (1-10)   priority 31
              Binary Images:
                     0x108d00000 -        0x108dc6fff  apsd (275.6)                           <686104E1-80C4-3121-9F25-3A4B1FB1E24A>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
            Process:         askpermissiond [268]
            Path:            /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       334 pages
              Thread 0xba1        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (askpermissiond + 49060) [0x10b5c3fa4] 1-10
              Thread 0xbca        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10b5b8000 -        0x10b5d0fff  askpermissiond (59)                    <8585971D-726E-3BA0-BFE0-49B2838518D5>  /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermiss iond
            Process:         aslmanager [3330]
            Path:            /usr/sbin/aslmanager
            Parent:          launchd [1]
            UID:             0
            Task size:       36 pages
              Thread 0x384880     10 samples (1-10)   priority 31
              Thread 0x384882     10 samples (1-10)   priority 31
              Binary Images:
                     0x107b09000 -        0x107b11fff  aslmanager (267)                   <3EDF73B0-7C83-3380-948A-966857D7ADD3>  /usr/sbin/aslmanager
            Process:         AssetCacheLocatorService [736]
            Path:            /System/Library/CoreServices/AssetCacheLocatorService
            Parent:          launchd [1]
            UID:             235
            Task size:       2612 pages
              Thread 0x8e57       DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 71 (AssetCacheLocatorService + 81892) [0x1060eafe4] 1-10
                  10  -[AssetCacheLocatorService start] + 518 (AssetCacheLocatorService + 10453) [0x1060d98d5] 1-10
              Thread 0x8e70       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x8e91       10 samples (1-10)   priority 4
              Thread 0x8e94       10 samples (1-10)   priority 4
              Binary Images:
                     0x1060d7000 -        0x1060f0fff  AssetCacheLocatorService (720.5.7)     <E42BC835-3D45-3887-B4AE-2EDD96AF245D>  /System/Library/CoreServices/AssetCacheLocatorService
            Process:         authd [108]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
            Parent:          launchd [1]
            UID:             0
            Task size:       938 pages
              Thread 0x34f        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x351        DispatchQueue 10    10 samples (1-10)   priority 4
                    10  _dispatch_root_queue_drain + 935 (libdispatch.dylib + 19911) [0x7fff9835edc7] 1-10
                          10  ??? (authd + 73508) [0x1004faf24] 1-10
                            10  au_sdev_read_aia + 557 (libbsm.0.dylib + 60012) [0x7fff9149aa6c] 1-10
                              10  fgetc + 52 (libsystem_c.dylib + 246700) [0x7fff90f7a3ac] 1-10
                                10  __srget + 14 (libsystem_c.dylib + 274112) [0x7fff90f80ec0] 1-10
                                  10  __srefill1 + 24 (libsystem_c.dylib + 273827) [0x7fff90f80da3] 1-10
                                    10  __read_nocancel + 10 (libsystem_kernel.dylib + 90890) [0x7fff964ff30a] 1-10
                                               *10  spec_read + 609 (kernel + 3669121) [0xffffff800057fc81] 1-10
                                                 *10  ??? (kernel + 5834740) [0xffffff80007907f4] 1-10
              Thread 0x374        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x1004e9000 -        0x100500fff  com.apple.authd 1.0 (57031.40.8)   <40AAB7D7-2132-39D0-9535-D95CC1CE18A9>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                  0x7fff90f3e000 -     0x7fff90fcafff  libsystem_c.dylib (1044.40.2)      <69158EFA-8270-30A1-BA02-4F74A4498147>  /usr/lib/system/libsystem_c.dylib
                  0x7fff9148c000 -     0x7fff9149cfff  libbsm.0.dylib (34)                <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB>  /usr/lib/libbsm.0.dylib
            Process:         autofsd [88]
            Path:            /usr/libexec/autofsd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       231 pages
              Thread 0x382        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x5bc        DispatchQueue 11    10 samples (1-10)   priority 31
              10  _dispatch_sig_thread + 45 (libdispatch.dylib + 22821) [0x7fff9835f925] 1-10
              Binary Images:
                     0x10ade9000 -        0x10adeafff  autofsd (246.10.1)                 <DD6CEE95-086D-3882-8966-0693B702B8A6>  /usr/libexec/autofsd
            Process:         awdd [72]
            Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
            Parent:          launchd [1]
            UID:             0
            Task size:       822 pages
              Thread 0x264        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (awdd + 14548) [0x10c7278d4] 1-10
              Thread 0x461        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10c724000 -        0x10c7c6fff  awdd (712.10)                          <C8409BE7-794E-3F60-B5F8-45AF903EC42B>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
            Process:         bird [339]
            Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
            Parent:          launchd [1]
            UID:             502
            Task size:       2934 pages
              Thread 0xde9        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (bird + 6197) [0x101c7d835] 1-10
              Thread 0xe45        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x1008       10 samples (1-10)   priority 4
              Thread 0x100b       10 samples (1-10)   priority 4
              Thread 0x103e       10 samples (1-10)   priority 4
              Binary Images:
                     0x101c7c000 -        0x101c7dfff  bird (321.10)                          <F883BC6B-D5C9-368C-9B47-10BC34902C7D>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
            Process:         blued [87]
            Path:            /usr/sbin/blued
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       1744 pages
              Thread 0x273        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (blued + 110574) [0x101991fee] 1-10
              Thread 0x3d1        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x537        10 samples (1-10)   priority 31
              Binary Images:
                     0x101977000 -        0x101a0dfff  blued (4306.4.3)                       <2C025BF6-0CA4-3F34-A6B3-D27D8B5B45EC>  /usr/sbin/blued
            Process:         CalendarAgent [261]
            Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
            Parent:          launchd [1]
            UID:             502
            Task size:       7687 pages
              Thread 0xb9a        DispatchQueue 1     10 samples (1-10)   priority 31
              <thread QoS legacy, boosted, timers coalesced, IO policy important>
                10  ??? (CalendarAgent + 6289) [0x105a77891] 1-10
              Thread 0xbd7        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0xc18        10 samples (1-10)   priority 63
              <boosted, timers coalesced, IO policy important>
              Thread 0xed5        10 samples (1-10)   priority 31
              Binary Images:
                     0x105a76000 -        0x105a77fff  CalendarAgent (316.1)                  <918815B9-181F-3CBA-B219-5715DE483BEC>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
            Process:         CallHistoryPluginHelper [361]
            Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
            Parent:          launchd [1]
            UID:             502
            Task size:       447 pages
              Thread 0x1035       DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (CallHistoryPluginHelper + 5595) [0x10fdb65db] 1-10
              Thread 0x1036       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10fdb5000 -        0x10fdb6fff  CallHistoryPluginHelper (405.2)        <BBF118D6-01A2-3089-B4C6-8A7ED4E8B793>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
            Process:         CallHistorySyncHelper [265]
            Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
            Parent:          launchd [1]
            UID:             502
            Task size:       814 pages
              Thread 0xb9e        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (CallHistorySyncHelper + 34483) [0x10a5606b3] 1-10
              Thread 0xbbd        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10a558000 -        0x10a56cfff  CallHistorySyncHelper (405.2)          <B16EDEC4-06E7-3786-9B90-497CEEADCAD1>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistorySyncHelper
            Process:         callservicesd [280]
            Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
            Parent:          launchd [1]
            UID:             502
            Task size:       2629 pages
              Thread 0xc24        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (callservicesd + 197791) [0x10629549f] 1-10
              Thread 0xc2d        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x106265000 -        0x1062acfff  callservicesd (420.21)                 <0B73C1FE-5606-329B-A7E1-C7FA9B21BCD9>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
            Process:         CalNCService [277]
            Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/XPCServices/CalNCSer vice.xpc/Contents/MacOS/CalNCService
            Parent:          launchd [1]
            Responsible:     CalendarAgent [261]
            UID:             502
            Task size:       2979 pages
              Thread 0xc01        DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 111 (CalNCService + 7583) [0x101a9bd9f] 1-10
                  10  -[NSXPCListener resume] + 163 (Foundation + 708570) [0x7fff8efe6fda] 1-10
                    10  xpc_main + 490 (libxpc.dylib + 98352) [0x7fff9050f030] 1-10
                      10  _xpc_objc_main + 751 (libxpc.dylib + 92414) [0x7fff9050d8fe] 1-10
              Thread 0xc0d        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x101a9a000 -        0x101aa3fff  com.apple.CalendarAgent.CalNCService 1.0 (316.1) <444446BE-CD7E-3B53-91B4-7767630A18E6>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/XPCServices/CalNCSer vice.xpc/Contents/MacOS/CalNCService
                  0x7fff904f7000 -     0x7fff9051ffff  libxpc.dylib (559.40.1)                          <5C829202-962E-3744-8B50-00D38CC88E84>  /usr/lib/system/libxpc.dylib
            Process:         cfprefsd [107]
            Path:            /usr/sbin/cfprefsd
            Parent:          launchd [1]
            UID:             0
            Task size:       1975 pages
              Thread 0x2f1        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x2f3        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x107a9c000 -        0x107a9cfff  cfprefsd (1153.18)                 <13F2A682-DE1A-30D8-9F5F-133C97A721A1>  /usr/sbin/cfprefsd
            Process:         cfprefsd [255]
            Parent:          launchd [1]
            UID:             502
            Task size:       6065 pages
            Note:            2 idle work queue threads omitted
              Thread 0xb34        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xb35        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x10bad3000 -        0x10bad3fff  cfprefsd (1153.18)                 <13F2A682-DE1A-30D8-9F5F-133C97A721A1>  /usr/sbin/cfprefsd
            Process:         cloudd [302]
            Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
            Parent:          launchd [1]
            UID:             502
            Task size:       4459 pages
              Thread 0xd02        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (cloudd + 10063) [0x1022d874f] 1-10
              Thread 0xd1d        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x96c8       10 samples (1-10)   priority 4
              Thread 0x96d9       10 samples (1-10)   priority 4
              Binary Images:
                     0x1022d6000 -        0x1022dafff  cloudd (283.67.4)                      <C4DF37DA-AA81-3A85-B8FC-F5F05B9763EC>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
            Process:         CloudKeychainProxy [307]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
            Parent:          launchd [1]
            UID:             502
            Task size:       584 pages
              Thread 0xd26        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (CloudKeychainProxy + 5887) [0x1072826ff] 1-10
              Thread 0xd2b        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x107281000 -        0x10728dfff  com.apple.security.cloudkeychainproxy3 1.0 (57031.40.8) <FB388A77-7A80-3B69-BB62-50E23DB455F4>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
            Process:         cloudpaird [442]
            Path:            /System/Library/CoreServices/cloudpaird
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       2611 pages
              Thread 0x1fba       DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (cloudpaird + 49124) [0x1014f5fe4] 1-10
              Thread 0x20ac       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x1014ea000 -        0x1014f9fff  cloudpaird (4306.4.3)                  <67BC0CF0-EC60-3164-9F22-EA0F9796418C>  /System/Library/CoreServices/cloudpaird
            Process:         cloudphotosd [562]
            Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
            Parent:          launchd [1]
            UID:             502
            Task size:       1772 pages
              Thread 0x3120       DispatchQueue 1     10 samples (1-10)   priority 4
              <thread QoS background, darwinbg, IO policy utility>
              Thread 0x3129       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x3148       10 samples (1-10)   priority 4
              Binary Images:
                     0x105d66000 -        0x105e3cfff  com.apple.cloudphotosd 1.0.1 (215.65.0) <4D2651AB-9BAD-38F0-917A-57A1A944E0FE>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
            Process:         ColorMunkiDisplayTray (ColorMunki Display Tray) [367]
            Path:            /Library/Application Support/Colormunki/*/ColorMunkiDisplayTray.app/Contents/MacOS/ColorMunkiDisplayTray
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       227417 pages
            CPU Time:        0.001s
            Process:         com.apple.AddressBook.InternetAccountsBridge [354]
            Path:            /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.Address Book.InternetAccountsBridge.xpc/Contents/MacOS/com.apple.AddressBook.InternetAccountsBridg e
            Parent:          launchd [1]
            UID:             502
            Task size:       323 pages
              Thread 0xf75        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xf76        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x106ba9000 -        0x106baafff  com.apple.AddressBook.InternetAccountsBridge 9.0 (1579) <EDA95366-BAC9-35E1-B7F2-8DE97A759DF2>  /System/Library/Frameworks/AddressBook.framework/Versions/A/XPCServices/com.apple.Address Book.InternetAccountsBridge.xpc/Contents/MacOS/com.apple.AddressBook.InternetAccountsBridg e
            Process:         com.apple.AmbientDisplayAgent [197]
            Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
            Parent:          launchd [1]
            UID:             0
            Task size:       1555 pages
              Thread 0x3a3701     DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 269 (com.apple.AmbientDisplayAgent + 5238) [0x10a5fc476] 1-10
              Thread 0x3a3726     DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x3a372a     10 samples (1-10)   priority 4
                    10  ??? (com.apple.AmbientDisplayAgent + 9007) [0x10a5fd32f] 1-10
              Binary Images:
                     0x10a5fb000 -        0x10a5fefff  com.apple.AmbientDisplayAgent 1.0 (1)  <6D12A516-9EF6-3845-894F-8865CB89479E>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
            Process:         com.apple.audio.DriverHelper [284]
            Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
            Parent:          launchd [1]
            Responsible:     coreaudiod [282]
            UID:             202
            Task size:       88 pages
              Thread 0xc48        10 samples (1-10)   priority 4
              Thread 0xc4a        10 samples (1-10)   priority 4
              Binary Images:
                     0x1035ed000 -        0x1035effff  com.apple.audio.DriverHelper 1.0 (1) <752BF129-3EC0-34E5-83FF-A6CDB782F745>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
            Process:         com.apple.BKAgentService [678]
            Path:            /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
            Parent:          launchd [1]
            UID:             502
            Task size:       530 pages
              Thread 0x7277       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x7279       DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x10258d000 -        0x1025f2fff  com.apple.BKAgentService 1.2 (704) <ECC83234-F10F-337F-A9B6-48071FF17AD5>  /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
            Process:         com.apple.CloudPhotosConfiguration [373]
            Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotoServicesConfiguration.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfigur ation.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
            Parent:          launchd [1]
            UID:             502
            Task size:       1157 pages
              Thread 0x10be       DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 24 (com.apple.CloudPhotosConfiguration + 8536) [0x1038f3158] 1-10
                  10  ??? (com.apple.CloudPhotosConfiguration + 8860) [0x1038f329c] 1-10
                    10  ??? (com.apple.CloudPhotosConfiguration + 9070) [0x1038f336e] 1-10
              Thread 0x10c6       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x1038f1000 -        0x103901fff  com.apple.CloudPhotosConfiguration 1.0.1 (215.65.0) <55E3DE13-0183-3565-A48C-714B7D3D6FCC>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotoServicesConfiguration.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfigur ation.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
            Process:         com.apple.cmio.registerassistantservice [1322]
            Path:            /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.re gisterassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
            Parent:          launchd [1]
            UID:             0
            Task size:       249 pages
              Thread 0xc48f3      DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 16 (com.apple.cmio.registerassistantservice + 4352) [0x105955100] 1-10
                  10  xpc_service_main + 413 (XPCService + 5568) [0x7fff947f05c0] 1-10
              Thread 0xc48f7      DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x105954000 -        0x105955fff  com.apple.cmio.registerassistantservice 1.0 (1) <4E3CBBEC-1330-327C-9B02-3A5E2C681AF8>  /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.re gisterassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
                  0x7fff947ef000 -     0x7fff947f5fff  com.apple.XPCService 2.0 (1)                    <AA4A5393-1F5D-3465-A417-0414B95DC052>  /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
            Process:         com.apple.CodeSigningHelper [208]
            Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
            Parent:          launchd [1]
            UID:             0
            Task size:       445 pages
              Thread 0x7ca        10 samples (1-10)   priority 4
              Thread 0x7cc        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x107cec000 -        0x107cedfff  com.apple.CodeSigningHelper 1.0 (1) <0C5255A6-877A-347D-A4C8-39807B1BF830>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
            Process:         com.apple.CommerceKit.TransactionService [739]
            Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
            Parent:          launchd [1]
            Responsible:     storeassetd [413]
            UID:             502
            Task size:       466 pages
              Thread 0x8e98       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x8e9a       DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x10e3b4000 -        0x10e42bfff  com.apple.CommerceKit.TransactionService 1.0 (1) <A1937C11-80A7-3658-AE98-FE3E7EAA8A36>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
            Process:         com.apple.ctkpcscd [149]
            Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
            Parent:          launchd [1]
            Responsible:     securityd [80]
            UID:             0
            Task size:       245 pages
              Thread 0x4dd        10 samples (1-10)   priority 4
              Thread 0x4e1        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x1095d1000 -        0x1095d9fff  com.apple.ctkpcscd 1.0 (1)         <3FD25F21-0339-31AC-A331-5EB0C2E7E219>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
            Process:         com.apple.dock.extra [353]
            Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
            Parent:          launchd [1]
            Responsible:     Dock [315]
            UID:             502
            Task size:       2100 pages
              Thread 0xf65        DispatchQueue 1     10 samples (1-10)   priority 46
                10  ??? (com.apple.dock.extra + 7840) [0x10f50bea0] 1-10
                    10  _xpc_objc_main + 793 (libxpc.dylib + 92456) [0x7fff9050d928] 1-10
              Thread 0xf69        DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0x1026       10 samples (1-10)   priority 46
              Binary Images:
                     0x10f50a000 -        0x10f50efff  com.apple.dock.extra 1.0 (1)           <A52D9E84-6FA3-3DC9-A84F-2642C4ED18D2>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
            Process:         com.apple.geod [970]
            Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
            Parent:          launchd [1]
            UID:             502
            Task size:       3539 pages
              Thread 0x63681      DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 771 (com.apple.geod + 47230) [0x10a1d487e] 1-10
              Thread 0x63685      DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x6368b      10 samples (1-10)   priority 4
                    10  _runNetworkThread + 445 (GeoServices + 2056528) [0x7fff94573150] 1-10
              Thread 0x6368d      10 samples (1-10)   priority 4
              Thread 0x6369c      10 samples (1-10)   priority 4
              Binary Images:
                     0x10a1c9000 -        0x10a1d7fff  com.apple.geod 1.0 (1077.0.18)         <93760CE6-FE8A-39DC-92C0-000B86E7CCC7>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                  0x7fff9437d000 -     0x7fff9467ffff  com.apple.GeoServices 1.0 (1077.0.18)  <2BBF8B44-DD46-3432-8C84-6D6AA004C233>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
            Process:         com.apple.GSSCred [2876]
            Path:            /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
            Parent:          launchd [1]
            UID:             0
            Task size:       235 pages
              Thread 0x258d6a     DispatchQueue 8     10 samples (1-10)   priority 20
              <thread QoS utility, timers coalesced, IO policy standard>
                          10  ??? (com.apple.GSSCred + 21929) [0x101adb5a9] 1-10
              Thread 0x258d6e     DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x258d6c     10 samples (1-10)   priority 31
              Binary Images:
                     0x101ad6000 -        0x101addfff  com.apple.GSSCred (398.40.1)       <DFB8F3C0-AEF4-3ECC-9C7C-DD62BDE82217>  /System/Library/Frameworks/GSS.framework/Helpers/com.apple.GSSCred
            Process:         com.apple.iCloudHelper [5847]
            Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
            Parent:          launchd [1]
            UID:             502
            Task size:       2065 pages
            Note:            3 idle work queue threads omitted
              Thread 0x604792     DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 167 (com.apple.iCloudHelper + 15671) [0x1047aad37] 1-10
              Thread 0x6047ae     DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x1047a7000 -        0x1047b9fff  com.apple.iCloudHelper 1.06 (217)      <F91FBEDA-2B17-36DA-B5C0-55AAB31EAB58>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
            Process:         com.apple.ifdreader [244]
            Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
            Parent:          launchd [1]
            UID:             0
            Task size:       177 pages
              Thread 0x928        DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 81 (com.apple.ifdreader + 3713) [0x10e58be81] 1-10
              Thread 0x94e        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10e58b000 -        0x10e590fff  com.apple.ifdreader 1.0 (1)            <6E6F8ECC-0539-3A6F-BB56-C7CF1660FB6F>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
            Process:         com.apple.InputMethodKit.UserDictionary [472]
            Path:            /System/Library/Frameworks/InputMethodKit.framework/Versions/A/XPCServices/com.apple.Inpu tMethodKit.UserDictionary.xpc/Contents/MacOS/com.apple.InputMethodKit.UserDictionary
            Parent:          launchd [1]
            UID:             502
            Task size:       558 pages
              Thread 0x223c       DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 116 (com.apple.InputMethodKit.UserDictionary + 6804) [0x10d6c9a94] 1-10
              Thread 0x223f       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10d6c8000 -        0x10d6d3fff  com.apple.InputMethodKit.UserDictionary 1.0 (1) <D3546409-547B-34DB-ABF3-080301C31BF9>  /System/Library/Frameworks/InputMethodKit.framework/Versions/A/XPCServices/com.apple.Inpu tMethodKit.UserDictionary.xpc/Contents/MacOS/com.apple.InputMethodKit.UserDictionary
            Process:         com.apple.internetaccounts [294]
            Path:            /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
            Parent:          launchd [1]
            UID:             502
            Task size:       3031 pages
              Thread 0xcd1        DispatchQueue 1     10 samples (1-10)   priority 46
                10  main + 252 (com.apple.internetaccounts + 6967) [0x105b47b37] 1-10
              Thread 0xcd2        DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0xd50        10 samples (1-10)   priority 46
              Binary Images:
                     0x105b46000 -        0x105b64fff  com.apple.internetaccounts 1.0 (1)     <243D65D2-F946-37F8-94A4-1C66377156AD>  /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/XPCServices/com.a pple.internetaccounts.xpc/Contents/MacOS/com.apple.internetaccounts
            Process:         com.apple.lakitu [388]
            Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.lakitu.xpc/Contents/MacOS/com.apple.lakitu
            Parent:          launchd [1]
            UID:             502
            Task size:       3289 pages
              Thread 0x11ef       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x11f0       10 samples (1-10)   priority 4
              Thread 0x11f4       10 samples (1-10)   priority 4
              Thread 0x3e20       10 samples (1-10)   priority 4
              Thread 0x3e24       10 samples (1-10)   priority 4
              Binary Images:
                     0x10dee1000 -        0x10def4fff  com.apple.lakitu 1.0 (1)               <F239FE71-C38B-3096-8AAC-DDABA8D16F12>  /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.lakitu.xpc/Contents/MacOS/com.apple.lakitu
            Process:         com.apple.notificationcenterui.WeatherSummary [459]
            Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
            Parent:          launchd [1]
            Responsible:     NotificationCenter (Notification Center) [435]
            UID:             502
            Task size:       269 pages
              Thread 0x21a3       DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 147 (com.apple.notificationcenterui.WeatherSummary + 6508) [0x101a5296c] 1-10
              Thread 0x21ab       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x101a51000 -        0x101a53fff  com.apple.notificationcenterui.WeatherSummary 1.0 (393.13) <5EBC0BA0-DD63-3B86-A9A9-8205D11E4C07>  /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
            Process:         com.apple.PerformanceAnalysis.animationperfd [344]
            Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/XPCServices/com.apple.Per formanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animation perfd
            Parent:          launchd [1]
            UID:             0
            Task size:       261 pages
              Thread 0xed6        10 samples (1-10)   priority 4
              Thread 0xed8        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x108706000 -        0x10870cfff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <843422DB-F2B4-3509-BB7B-2D2C7F042A51>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/XPCServices/com.apple.Per formanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animation perfd
            Process:         com.apple.sbd [308]
            Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Resources/com.apple.sbd
            Parent:          launchd [1]
            UID:             502
            Task size:       1460 pages
              Thread 0xd27        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (com.apple.sbd + 9227) [0x103f8c40b] 1-10
              Thread 0xd5c        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x103f8a000 -        0x103f99fff  com.apple.sbd (107.20.1)               <D33BD9AB-676B-3881-BD24-D141A7C29394>  /System/Library/PrivateFrameworks/CloudServices.framework/Resources/com.apple.sbd
            Process:         com.apple.speech.speechsynthesisd [928]
            Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.frame work/Resources/com.apple.speech.speechsynthesisd
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       344 pages
              Thread 0x4231d      DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (com.apple.speech.speechsynthesisd + 4925) [0x1021c833d] 1-10
              Thread 0x42320      DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x1021c7000 -        0x1021d7fff  com.apple.speech.speechsynthesisd (5.3.11) <B2A7FEF7-5050-39AA-84EB-C65992724396>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.frame work/Resources/com.apple.speech.speechsynthesisd
            Process:         com.apple.WeatherKitService [461]
            Path:            /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
            Parent:          launchd [1]
            UID:             502
            Task size:       2311 pages
              Thread 0x21bc       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x21be       10 samples (1-10)   priority 4
              Thread 0x21ca       10 samples (1-10)   priority 4
              Thread 0x21d2       10 samples (1-10)   priority 4
              Binary Images:
                     0x100a29000 -        0x100a47fff  com.apple.WeatherKitService 2.0 (147)  <942545CC-BBE9-3413-8C5C-C8FCD4E3B66E>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
            Process:         com.apple.wifi.proxy [347]
            Path:            /System/Library/CoreServices/Menu Extras/AirPort.menu/Contents/XPCServices/com.apple.wifi.proxy.xpc/Contents/MacOS/com.appl e.wifi.proxy
            Parent:          launchd [1]
            Responsible:     SystemUIServer [316]
            UID:             502
            Task size:       499 pages
              Thread 0xef0        DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 413 (com.apple.wifi.proxy + 6685) [0x10d1dda1d] 1-10
              Thread 0xef1        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10d1dc000 -        0x10d1e9fff  com.apple.wifi.proxy 1.0 (1)           <4B3FB65C-BD92-36EF-AF0A-C0C3A36B05E2>  /System/Library/CoreServices/Menu Extras/AirPort.menu/Contents/XPCServices/com.apple.wifi.proxy.xpc/Contents/MacOS/com.appl e.wifi.proxy
            Process:         configd [52]
            Path:            /usr/libexec/configd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       1382 pages
              Thread 0x250        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (configd + 4674) [0x1084a2242] 1-10
                  10  ??? (configd + 8462) [0x1084a310e] 1-10
              Thread 0x29d        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x2a2        10 samples (1-10)   priority 31
              Thread 0x2d4        10 samples (1-10)   priority 31
                    10  ??? (configd + 60769) [0x1084afd61] 1-10
              Thread 0x34b        10 samples (1-10)   priority 31
              Thread 0x362        10 samples (1-10)   priority 31
              Thread 0x381        10 samples (1-10)   priority 31
                    10  ??? (EAPOLController + 11735) [0x109691dd7] 1-10
              Binary Images:
                     0x1084a1000 -        0x1084d6fff  configd (699.40.2)                                          <B5F9F0A0-7FCA-3183-B774-609504BDCA17>  /usr/libexec/configd
                     0x10968f000 -        0x109694fff  com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0) <4AB49751-C9A3-3506-8C55-0150CB2DD93F>  /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
            Process:         Core Sync [481]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Core Sync.app/Contents/MacOS/Core Sync
            Parent:          launchd [1]
            UID:             502
            Task size:       3440 pages
            Process:         coreaudiod [282]
            Path:            /usr/sbin/coreaudiod
            Parent:          launchd [1]
            UID:             202
            Sudden Term:     Dirty
            Task size:       1368 pages
              Thread 0xc38        DispatchQueue 1     10 samples (1-10)   priority 63
                10  ??? (coreaudiod + 483709) [0x10e39017d] 1-10
              Thread 0xc3b        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0xcb3        10 samples (1-10)   priority 61
                    10  ??? (coreaudiod + 543457) [0x10e39eae1] 1-10
                      10  ??? (coreaudiod + 503689) [0x10e394f89] 1-10
              Binary Images:
                     0x10e31a000 -        0x10e3f5fff  coreaudiod (375.10)                    <B13B8EFE-E4B9-3098-BA78-FCA9255741F3>  /usr/sbin/coreaudiod
            Process:         coreduetd [68]
            Path:            /usr/libexec/coreduetd
            Architecture:    x86_64
            Parent:          launchd [1]
            UID:             0
            Task size:       2856 pages
              Thread 0x260        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (coreduetd + 147344) [0x10423ef90] 1-10
              Thread 0x3f7        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10421b000 -        0x10428efff  coreduetd (154.1.14)                   <95EA195F-0B15-370D-AC2E-81B5A12F9CB0>  /usr/libexec/coreduetd
            Process:         coreservicesd [103]
            Path:            /System/Library/CoreServices/coreservicesd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       9084 pages
              Thread 0x2c0        DispatchQueue 1     10 samples (1-10)   priority 31
                10  _CoreServicesServerMain + 721 (CarbonCore + 605314) [0x7fff8ab6ec82] 1-10
              Thread 0x2d3        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x36d        10 samples (1-10)   priority 31
              Thread 0x36e        10 samples (1-10)   priority 31
                    10  read + 10 (libsystem_kernel.dylib + 95874) [0x7fff96500682] 1-10
                             *10  ??? (kernel + 3655920) [0xffffff800057c8f0] 1-10
                               *10  ??? (kernel + 6140631) [0xffffff80007db2d7] 1-10
              Binary Images:
                     0x10689f000 -        0x10689ffff  coreservicesd (1108.6)                            <AB6CADDA-87BC-3574-8B0D-7424FB14337E>  /System/Library/CoreServices/coreservicesd
                  0x7fff8aadb000 -     0x7fff8adc2fff  com.apple.CoreServices.CarbonCore 1108.6 (1108.6) <8953580E-7857-33B2-AA64-98296830D3A8>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
            Process:         CoreServicesUIAgent [3999]
            Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
            Parent:          launchd [1]
            UID:             502
            Task size:       2204 pages
              Thread 0x397af5     DispatchQueue 1     10 samples (1-10)   priority 31
              Thread 0x397af6     DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x397afa     10 samples (1-10)   priority 37
              <thread QoS user initiated, IO policy important>
              Binary Images:
                     0x10b96b000 -        0x10b98ffff  com.apple.coreservices.uiagent 134.7 (134.7) <A8CF4852-8693-3703-9190-D19FFB5AA897>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
            Process:         corestoraged [246]
            Path:            /usr/libexec/corestoraged
            Parent:          launchd [1]
            UID:             0
            Task size:       280 pages
              Thread 0x936        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (corestoraged + 8168) [0x10c429fe8] 1-10
              Thread 0x946        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x10c428000 -        0x10c42ffff  corestoraged (471.30.1)                <FCD7CA9B-770D-34D9-B18D-D1F03FC75F67>  /usr/libexec/corestoraged
            Process:         coresymbolicationd [283]
            Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
            Parent:          launchd [1]
            UID:             0
            Task size:       316 pages
              Thread 0xc42        10 samples (1-10)   priority 4
              Thread 0xc44        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x102f2c000 -        0x102f35fff  coresymbolicationd (57020.2)       <D9DD49AF-5332-3067-9537-AF722CB07CC5>  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
            Process:         CrashReporterSupportHelper [290]
            Path:            /System/Library/CoreServices/CrashReporterSupportHelper
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       452 pages
              Thread 0xc9e        DispatchQueue 1     10 samples (1-10)   priority 4
              10  start + 1 (libdyld.dylib + 13769) [0x7fff94f0a5c9] 1-10
                10  ??? (CrashReporterSupportHelper + 9075) [0x10465e373] 1-10
                      10  CFRunLoopRunSpecific + 296 (CoreFoundation + 465880) [0x7fff8ea61bd8] 1-10
              Thread 0xca0        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10465c000 -        0x10465efff  CrashReporterSupportHelper (631)       <4AF9EF98-B382-3C76-AFD2-625B7729CDBE>  /System/Library/CoreServices/CrashReporterSupportHelper
            Process:         Creative Cloud [443]
            Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       15847 pages
            CPU Time:        0.004s
            Process:         ctkd [151]
            Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
            Parent:          launchd [1]
            UID:             0
            Task size:       236 pages
              Thread 0x543        10 samples (1-10)   priority 4
              Thread 0x546        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10b77d000 -        0x10b783fff  ctkd (22.20.4)                     <1E7E7628-D7C7-3D2F-8594-7DACEAB40E3B>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
            Process:         CVMCompiler [5959]
            Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Dirty
            Task size:       6726 pages
              Thread 0x60c457     DispatchQueue 11    10 samples (1-10)   priority 31
              Thread 0x60c458     DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x1036f0000 -        0x1036f4fff  CVMCompiler (79.1)                 <19E0A278-E949-365B-BB3C-62259DDB24D2>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
            Process:         CVMServer [195]
            Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       308 pages
              Thread 0x797        10 samples (1-10)   priority 31
              Thread 0x799        DispatchQueue 2     10 samples (1-10)   priority 31
              10  _dispatch_mgr_thread + 52 (libdispatch.dylib + 25198) [0x7fff9836026e] 1-10
                10  kevent64 + 10 (libsystem_kernel.dylib + 94770) [0x7fff96500232] 1-10
                 *10  ??? (kernel + 5987312) [0xffffff80007b5bf0] 1-10
              Binary Images:
                     0x102a50000 -        0x102a59fff  CVMServer (79.1)                   <28A968A4-A557-3C0B-9F2E-E45313EE1F92>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
            Process:         DataDetectorsDynamicData [1253]
            Path:            /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/XPCServices/Data DetectorsDynamicData.xpc/Contents/MacOS/DataDetectorsDynamicData
            Parent:          launchd [1]
            UID:             502
            Task size:       449 pages
              Thread 0xa8ca9      DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (DataDetectorsDynamicData + 6677) [0x109a0ca15] 1-10
              Thread 0xa8cbd      DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x109a0b000 -        0x109a0dfff  com.apple.DataDetectorsDynamicData 6.0 (396.1.2) <42E1333A-1BF8-3B0F-B80E-04DCE3B686F6>  /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/XPCServices/Data DetectorsDynamicData.xpc/Contents/MacOS/DataDetectorsDynamicData
            Process:         dbfseventsd [393]
            Path:            /Library/DropboxHelperTools/*/dbfseventsd
            Architecture:    i386
            Parent:          launchd [1]
            UID:             0
            Task size:       210 pages
              Thread 0x11c3       10 samples (1-10)   priority 31
              10  __read_nocancel + 10 (libsystem_kernel.dylib + 104246) [0x9a3d6736] 1-10
              Binary Images:
                          0x1000 -             0x8fff  dbfseventsd                        <6E6421C9-0E72-73AF-1821-754B84B964AF>  /Library/DropboxHelperTools/*/dbfseventsd
            Process:         dbfseventsd [394]
            Architecture:    i386
            Parent:          dbfseventsd [393]
            UID:             0
            Task size:       1183 pages
              Thread 0x11c4       10 samples (1-10)   priority 31
              <IO policy important>
              10  ??? (dbfseventsd + 30069) [0x8575] 1-10
                10  __select_nocancel + 10 (libsystem_kernel.dylib + 104554) [0x9a3d686a] 1-10
              Binary Images:
            Process:         dbfseventsd [1147]
            Architecture:    i386
            Parent:          dbfseventsd [394]
            UID:             502
            Task size:       106 pages
              Thread 0x9e1dd      10 samples (1-10)   priority 31
                       *10  ??? (kernel + 6232261) [0xffffff80007f18c5] 1-10
              Binary Images:
            Process:         deleted [321]
            Path:            /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
            Parent:          launchd [1]
            UID:             0
            Task size:       495 pages
              Thread 0xd95        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xda2        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x108066000 -        0x108070fff  deleted (17.20.4)                  <8CB5C42E-CA6E-3B0C-8219-FFAD953608D5>  /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
            Process:         diagnosticd [105]
            Path:            /usr/libexec/diagnosticd
            Parent:          launchd [1]
            UID:             0
            Task size:       524 pages (+10)
            CPU Time:        0.003s
              Thread 0x2df        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x2ef        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x103bde000 -        0x103be5fff  diagnosticd (72.20.1)              <61FE6402-4FC2-3675-AEEF-91357FB02746>  /usr/libexec/diagnosticd
            Process:         diagnostics_agent [447]
            Path:            /System/Library/CoreServices/diagnostics_agent
            Parent:          launchd [1]
            UID:             502
            Task size:       1169 pages
              Thread 0x1fbf       DispatchQueue 1     10 samples (1-10)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy throttle>
                10  ??? (diagnostics_agent + 21224) [0x108bc22e8] 1-10
                        10  __CFRunLoopRun + 1371 (CoreFoundation + 467835) [0x7fff8ea6237b] 1-10
                          10  __CFRunLoopServiceMachPort + 212 (CoreFoundation + 470708) [0x7fff8ea62eb4] 1-10
                            10  mach_msg_trap + 10 (libsystem_kernel.dylib + 70878) [0x7fff964fa4de] 1-10
                             *10  ipc_mqueue_receive_continue + 0 (kernel + 1144832) [0xffffff8000317800] 1-10
              Thread 0x2086       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x108bbd000 -        0x108bd8fff  diagnostics_agent (631)                <DE18DC42-8CCF-3A9E-B05C-540FAACED929>  /System/Library/CoreServices/diagnostics_agent
            Process:         DiskArbitrationAgent [2872]
            Path:            /System/Library/Frameworks/DiskArbitration.framework/Versions/A/Support/DiskArbitrationAg ent
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       309 pages
              Thread 0x258d4e     10 samples (1-10)   priority 31
              Thread 0x258d50     DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x10bed3000 -        0x10bed4fff  DiskArbitrationAgent (268)         <02F1CFFE-929F-3660-A0F7-589E35783AEF>  /System/Library/Frameworks/DiskArbitration.framework/Versions/A/Support/DiskArbitrationAg ent
            Process:         diskarbitrationd [65]
            Path:            /usr/libexec/diskarbitrationd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       532 pages
              Thread 0x25d        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (diskarbitrationd + 31903) [0x10302fc9f] 1-10
              Thread 0x2b6        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x103028000 -        0x10303efff  diskarbitrationd (268)                 <79E68552-828F-3E36-845C-8A9DBE84C9D6>  /usr/libexec/diskarbitrationd
            Process:         diskimages-helper [533]
            Path:            /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
            Parent:          launchd [1]
            UID:             0
            Task size:       408 pages
              Thread 0x2d8c       DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (diskimages-helper + 19279) [0x102a94b4f] 1-10
              Thread 0x2d8d       DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x2d95       10 samples (1-10)   priority 31
              <thread QoS legacy, IO policy important and passive>
              10  thread_start + 13 (libsystem_pthread.dylib + 5101) [0x7fff91a6a3ed] 1-10
                10  _pthread_start + 176 (libsystem_pthread.dylib + 16343) [0x7fff91a6cfd7] 1-10
                  10  _pthread_body + 131 (libsystem_pthread.dylib + 16474) [0x7fff91a6d05a] 1-10
                    10  __NSThread__main__ + 1345 (Foundation + 257682) [0x7fff8ef78e92] 1-10
                      10  ??? (diskimages-helper + 51970) [0x102a9cb02] 1-10
                        10  ??? (diskimages-helper + 54675) [0x102a9d593] 1-10
                          10  DI_kextDriveGetRequest + 44 (DiskImages + 117866) [0x7fff983a1c6a] 1-10
                            10  IOConnectCallStructMethod + 56 (IOKit + 27534) [0x7fff954cfb8e] 1-10
                              10  IOConnectCallMethod + 349 (IOKit + 27018) [0x7fff954cf98a] 1-10
                                10  io_connect_method + 381 (IOKit + 405868) [0x7fff9552c16c] 1-10
                                   *10  hndl_mach_scall64 + 22 (kernel + 2311366) [0xffffff80004344c6] 1-10
                                     *10  mach_call_munger64 + 410 (kernel + 2106138) [0xffffff800040231a] 1-10
                                       *10  mach_msg_overwrite_trap + 205 (kernel + 1196701) [0xffffff800032429d] 1-10
                                         *10  ipc_kmsg_send + 291 (kernel + 1128947) [0xffffff80003139f3] 1-10
                                           *10  ipc_kobject_server + 252 (kernel + 1240972) [0xffffff800032ef8c] 1-10
                                             *10  ??? (kernel + 1970951) [0xffffff80003e1307] 1-10
                                               *10  is_io_connect_method + 499 (kernel + 7335395) [0xffffff80008fede3] 1-10
                                                 *10  IOUserClient::externalMethod(unsigned int, IOExternalMethodArguments*, IOExternalMethodDispatch*, OSObject*, void*) + 857 (kernel + 7345785) [0xffffff8000901679] 1-10
                                                   *10  shim_io_connect_method_structureI_structureO + 290 (kernel + 7342706) [0xffffff8000900a72] 1-10
                                                     *10  IOHDIXHDDriveOutKernelUserClient::getRequest64(HDIRequestOOL64 const*, HDIRequestOOL64*) + 266 (IOHDIXController + 10884) [0xffffff7f818cba84] 1-10
                                                       *10  IOHDIXHDDriveOutKernel::getRequest(HDIRequestOOL64*, IOMemoryDescriptor*) + 31 (IOHDIXController + 6849) [0xffffff7f818caac1] 1-10
                                                         *10  ??? (kernel + 1355340) [0xffffff800034ae4c] 1-10
                                                           *10  thread_block_reason + 175 (kernel + 1315119) [0xffffff800034112f] 1-10
                                                             *10  ??? (kernel + 1325012) [0xffffff80003437d4] 1-10
                                                               *10  machine_switch_context + 367 (kernel + 2172719) [0xffffff800041272f] 1-10
              Binary Images:
                     0x102a90000 -        0x102adcfff  diskimages-helper (398)                     <A40992B6-EEB0-33D5-B530-D18EAD634F1D>  /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
                  0x7fff954c9000 -     0x7fff9553bfff  com.apple.framework.IOKit 2.0.2 (1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF>  /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x7fff98385000 -     0x7fff9845bfff  com.apple.DiskImagesFramework 10.10.5 (398) <37291661-BCB2-3F95-B446-5E5DB1D1E472>  /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
            *0xffffff7f818c9000 - 0xffffff7f818d4fff  com.apple.driver.DiskImages 10.10.5 (398)   <56385062-5400-34EA-9D84-6C920542420F>  /System/Library/Extensions/IOHDIXController.kext/Contents/MacOS/IOHDIXController
            Process:         diskimages-helper [2773]
            Parent:          launchd [1]
            UID:             0
              Thread 0x237e10     DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (diskimages-helper + 19279) [0x10c4a7b4f] 1-10
                  10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 278 (Foundation + 592681) [0x7fff8efcab29] 1-10
              Thread 0x237e11     DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x237e18     10 samples (1-10)   priority 31
                      10  ??? (diskimages-helper + 51970) [0x10c4afb02] 1-10
                        10  ??? (diskimages-helper + 54675) [0x10c4b0593] 1-10
              Binary Images:
                     0x10c4a3000 -        0x10c4effff  diskimages-helper (398)                     <A40992B6-EEB0-33D5-B530-D18EAD634F1D>  /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
            Process:         DiskUnmountWatcher [426]
            Path:            /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
              Thread 0x1f07       10 samples (1-10)   priority 4
               *10  ??? (kernel + 6141040) [0xffffff80007db470] 1-10
              Thread 0x1f09       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x102037000 -        0x102037fff  DiskUnmountWatcher (151)           <0C9FB070-4E5B-3770-9D35-FAE0252B6D4D>  /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
            Process:         displaypolicyd [86]
            Path:            /usr/libexec/displaypolicyd
            Parent:          launchd [1]
            UID:             244
            Task size:       221 pages
              Thread 0x272        10 samples (1-10)   priority 4
                10  ??? (displaypolicyd + 8655) [0x10c0b11cf] 1-10
              Thread 0x8a6        10 samples (1-10)   priority 4
              Thread 0xb66        10 samples (1-10)   priority 4
                    10  ??? (displaypolicyd + 31569) [0x10c0b6b51] 1-10
                      10  ??? (displaypolicyd + 27234) [0x10c0b5a62] 1-10
                        10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff964ff136] 1-10
                         *10  psynch_cvcontinue + 0 (pthread + 26910) [0xffffff7f80de291e] 1-10
              Thread 0xb67        10 samples (1-10)   priority 4
                    10  ??? (displaypolicyd + 32643) [0x10c0b6f83] 1-10
                      10  ??? (displaypolicyd + 31709) [0x10c0b6bdd] 1-10
              Thread 0xb68        10 samples (1-10)   priority 4
                    10  ??? (displaypolicyd + 72578) [0x10c0c0b82] 1-10
              Binary Images:
                     0x10c0af000 -        0x10c0ccfff  displaypolicyd (3.10.25)               <BB164A57-5CCC-35D5-B283-902C2F055FAC>  /usr/libexec/displaypolicyd
            Process:         distnoted [102]
            Path:            /usr/sbin/distnoted
            Parent:          launchd [1]
            UID:             241
            Task size:       1208 pages
              Thread 0x2b1        DispatchQueue 1     10 samples (1-10)   priority 31
              Thread 0x494        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x6104d9     10 samples (1-10)   priority 31
            *10  wq_unsuspend_continue + 0 (pthread + 18404) [0xffffff7f80de07e4] (suspended) 1-10
              Binary Images:
                     0x10e240000 -        0x10e248fff  distnoted (1153.18)                <65486E6E-F837-34D3-B738-FB675538803C>  /usr/sbin/distnoted
            Process:         distnoted [253]
            Parent:          launchd [1]
            UID:             502
            Task size:       5331 pages
            Note:            10 idle work queue threads omitted
              Thread 0xb31        DispatchQueue 1     10 samples (1-10)   priority 31
              Thread 0xb39        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x103987000 -        0x10398ffff  distnoted (1153.18)                <65486E6E-F837-34D3-B738-FB675538803C>  /usr/sbin/distnoted
            Process:         distnoted [500]
            Parent:          launchd [1]
            UID:             89
            Task size:       239 pages
              Thread 0x23fe       DispatchQueue 1     10 samples (1-10)   priority 31
              Thread 0x2402       DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x105ebe000 -        0x105ec6fff  distnoted (1153.18)                <65486E6E-F837-34D3-B738-FB675538803C>  /usr/sbin/distnoted
            Process:         Dock [315]
            Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
            Parent:          launchd [1]
            UID:             502
            Task size:       14162 pages
              Thread 0xd64        DispatchQueue 1     10 samples (1-10)   priority 47
              <frontmost, thread QoS user interactive, boosted, received importance donation from WindowServer [147], IO policy important>
                10  ??? (Dock + 23095) [0x107c4aa37] 1-10
              Thread 0xd6f        DispatchQueue 2     10 samples (1-10)   priority 47
              Thread 0xf5a        10 samples (1-10)   priority 31
              <frontmost, thread QoS legacy, boosted, received importance donation from WindowServer [147], IO policy important>
                    1  clock_sleep_trap + 10 (libsystem_kernel.dylib + 71142) [0x7fff964fa5e6] 1
                     *1  hndl_mach_scall64 + 22 (kernel + 2311366) [0xffffff80004344c6] 1
                       *1  mach_call_munger64 + 410 (kernel + 2106138) [0xffffff800040231a] 1
                         *1  clock_sleep_trap + 554 (kernel + 1218906) [0xffffff800032995a] 1
                           *1  thread_block_reason + 175 (kernel + 1315119) [0xffffff800034112f] 1
                             *1  ??? (kernel + 1325012) [0xffffff80003437d4] 1
                               *1  machine_switch_context + 367 (kernel + 2172719) [0xffffff800041272f] 1
                    9  ??? (Dock + 172724) [0x107c6f2b4] 2-10
                      9  __psynch_cvwait + 10 (libsystem_kernel.dylib + 90422) [0x7fff964ff136] 2-10
                       *9  psynch_cvcontinue + 0 (pthread + 26910) [0xffffff7f80de291e] 2-10
              Binary Images:
                     0x107c45000 -        0x107ec7fff  com.apple.dock 1.8 (1476.30)           <5094CDC8-3197-3228-9DEF-94530E97D1BB>  /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                  0x7fff8e9f0000 -     0x7fff8ed88fff  com.apple.CoreFoundation 6.9 (1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x7fff91a69000 -     0x7fff91a72fff  libsystem_pthread.dylib (105.40.1)     <ACE90967-ECD0-3251-AEEB-461E3C6414F7>  /usr/lib/system/libsystem_pthread.dylib
                  0x7fff94f07000 -     0x7fff94f0afff  libdyld.dylib (353.2.3)                <CFBBE540-D503-3AFC-B5D6-644F1E69949B>  /usr/lib/system/libdyld.dylib
                  0x7fff964e9000 -     0x7fff96506fff  libsystem_kernel.dylib (2782.50.1)     <1EE815DA-FF1B-3A53-AE9B-C98BD8177A9D>  /usr/lib/system/libsystem_kernel.dylib
                  0x7fff9835a000 -     0x7fff98384fff  libdispatch.dylib (442.50.1)           <A61E703C-784A-3698-B513-75DD12AAD6DC>  /usr/lib/system/libdispatch.dylib
            *0xffffff7f80ddc000 - 0xffffff7f80de4fff  com.apple.kec.pthread 1.0 (1)          <84126647-296D-3B12-9FF3-263679AF859C>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
            *0xffffff8000200000 - 0xffffff80009fffff  kernel (2782.50.1)                     <06D286E3-A8A1-3BE7-A7EB-EAC6E0C69758>  /System/Library/Kernels/kernel
            Process:         Dropbox [1130]
            Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
            Architecture:    i386
            Parent:          launchd [1]
            UID:             502
            Task size:       17709 pages
            Process:         EscrowSecurityAlert [583]
            Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Resources/EscrowSecurityAlert.a pp/Contents/MacOS/EscrowSecurityAlert
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean (allows idle exit)
            Task size:       953 pages
              Thread 0x3df3       DispatchQueue 1     10 samples (1-10)   priority 4
                10  NSApplicationMain + 1832 (AppKit + 12868) [0x7fff8f843244] 1-10
                  10  -[NSApplication run] + 594 (AppKit + 551667) [0x7fff8f8c6af3] 1-10
                    10  -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346 (AppKit + 593496) [0x7fff8f8d0e58] 1-10
                      10  _DPSNextEvent + 978 (AppKit + 596139) [0x7fff8f8d18ab] 1-10
                        10  _BlockUntilNextEventMatchingListInModeWithFilter + 71 (HIToolbox + 205099) [0x7fff8f56c12b] 1-10
                          10  ReceiveNextEventCommon + 431 (HIToolbox + 205546) [0x7fff8f56c2ea] 1-10
                            10  RunCurrentEventLoopInMode + 235 (HIToolbox + 206191) [0x7fff8f56c56f] 1-10
              Thread 0x3e01       DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x3e19       10 samples (1-10)   priority 4
                    10  _NSEventThread + 137 (AppKit + 1414507) [0x7fff8f99956b] 1-10
              Binary Images:
                     0x104c65000 -        0x104c6afff  com.apple.EscrowSecurityAlert 1.0 (1)  <B0216E47-1AE5-34AD-8697-651D42CB12D6>  /System/Library/PrivateFrameworks/CloudServices.framework/Resources/EscrowSecurityAlert.a pp/Contents/MacOS/EscrowSecurityAlert
                  0x7fff8f53a000 -     0x7fff8f83ffff  com.apple.HIToolbox 2.1.1 (758.7)      <E3129A67-BDF9-333D-9C9C-A95C8F0EF71C>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x7fff8f840000 -     0x7fff903c1fff  com.apple.AppKit 6.9 (1348.17)         <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
            Process:         filecoordinationd [312]
            Path:            /usr/sbin/filecoordinationd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       568 pages
              Thread 0xd54        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0xd55        DispatchQueue 11    10 samples (1-10)   priority 31
              Binary Images:
                     0x10388b000 -        0x103890fff  filecoordinationd (1154)           <9DA02FC9-2A2C-3FF5-8450-4CCEB1315A9D>  /usr/sbin/filecoordinationd
            Process:         Finder [317]
            Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Dirty
            Task size:       33051 pages
            Note:            1 idle work queue threads omitted
              Thread 0xd67        DispatchQueue 1     10 samples (1-10)   priority 46
                10  ??? (Finder + 25186) [0x109a79262] 1-10
              Thread 0xd82        DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0xeb9        10 samples (1-10)   priority 46
              Thread 0x40cfb      10 samples (1-10)   priority 55
              <boosted, IO policy important>
              Binary Images:
                     0x109a73000 -        0x109f7bfff  com.apple.finder 10.10.5 (10.10.5)     <3BB4CFA3-DFA6-3A9E-AF82-3DF5397AD298>  /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
            Process:         findmydeviced [155]
            Path:            /usr/libexec/findmydeviced
            Parent:          launchd [1]
            UID:             0
            Task size:       2853 pages
              Thread 0x578        DispatchQueue 1     10 samples (1-10)   priority 4
              <thread QoS background, darwinbg, timers coalesced, IO policy utility>
                10  ??? (findmydeviced + 37146) [0x1040d611a] 1-10
                  10  ??? (findmydeviced + 104739) [0x1040e6923] 1-10
              Thread 0x57e        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xcf7        10 samples (1-10)   priority 4
                      10  +[NSURLConnection(Loader) _resourceLoadLoop:] + 434 (CFNetwork + 37920) [0x7fff89820420] 1-10
              Thread 0xf74        10 samples (1-10)   priority 4
              10  __select + 10 (libsystem_kernel.dylib + 91130) [0x7fff964ff3fa] 1-10
              Binary Images:
                     0x1040cd000 -        0x10411bfff  findmydeviced (24.9)                   <1DBF7E8B-7036-3F24-8118-AAA8E2334D8B>  /usr/libexec/findmydeviced
                  0x7fff89817000 -     0x7fff89a27fff  com.apple.CFNetwork 720.5.7 (720.5.7)  <A47D7DD2-5903-39D0-8D27-5A7E2D119D84>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x7fff8ef3a000 -     0x7fff8f26bfff  com.apple.Foundation 6.9 (1154)        <49EE64E1-9F53-35D1-A481-2EFE2789B254>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
            Process:         fmfd [270]
            Path:            /usr/libexec/fmfd
            Parent:          launchd [1]
            UID:             502
            Task size:       2219 pages
              Thread 0xba3        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (fmfd + 27982) [0x10d6dad4e] 1-10
                  10  ??? (fmfd + 79775) [0x10d6e779f] 1-10
              Thread 0xbcb        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xc3a        10 samples (1-10)   priority 4
              Binary Images:
                     0x10d6d4000 -        0x10d715fff  fmfd (98.6)                            <BF74AB7E-4347-32EA-BFF7-CC058816136E>  /usr/libexec/fmfd
            Process:         fontd [303]
            Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       1718 pages
              Thread 0xd05        DispatchQueue 1     10 samples (1-10)   priority 4
                10  main_handler + 4440 (libATSServer.dylib + 529041) [0x7fff906b6291] 1-10
              Thread 0xd0a        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x616894     10 samples (1-10)   priority 4
              Binary Images:
                     0x10f55f000 -        0x10f562fff  fontd (375.4)                          <49C56448-A0C4-32B6-AB49-3E99A5EC02D4>  /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                  0x7fff90635000 -     0x7fff906ccfff  libATSServer.dylib (375.4)             <3F24CA96-51E2-3DB7-BA23-15A49E607C08>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
            Process:         fseventsd [47]
            Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/Support/fseventsd
            Parent:          launchd [1]
            UID:             0
            Task size:       1594 pages
              Thread 0x24b        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (fseventsd + 4613) [0x10a47f205] 1-10
              Thread 0x29f        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x29e        10 samples (1-10)   priority 49
                    10  ??? (fseventsd + 47242) [0x10a48988a] 1-10
                      10  ??? (fseventsd + 46008) [0x10a4893b8] 1-10
              Thread 0x2b3        10 samples (1-10)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important and passive>
                    10  ??? (fseventsd + 12816) [0x10a481210] 1-10
              Thread 0x2b4        10 samples (1-10)   priority 50
                     *10  hndl_unix_scall64 + 22 (kernel + 2311334) [0xffffff80004344a6] 1-10
                       *10  unix_syscall64 + 662 (kernel + 6599542) [0xffffff800084b376] 1-10
                         *10  read_nocancel + 115 (kernel + 6207411) [0xffffff80007eb7b3] 1-10
                           *10  ??? (kernel + 6208074) [0xffffff80007eba4a] 1-10
              Thread 0x2b5        10 samples (1-10)   priority 31
                    10  ??? (fseventsd + 31016) [0x10a485928] 1-10
              Thread 0x5df8aa     10 samples (1-10)   priority 31
                    10  ??? (fseventsd + 31090) [0x10a485972] 1-10
              Thread 0x5df951     10 samples (1-10)   priority 31
              Binary Images:
                     0x10a47e000 -        0x10a48dfff  fseventsd (1210.20.1)                  <B9298BBA-E12E-3861-8CE1-81A5B350321A>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/Support/fseventsd
            Process:         garcon [1158]
            Path:            /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Dirty (allows idle exit)
            Task size:       1343 pages
            Process:         hdiejectd [537]
            Path:            /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
            Parent:          launchd [1]
            UID:             0
            Task size:       197 pages
              Thread 0x2da8       DispatchQueue 1     10 samples (1-10)   priority 31
              <thread QoS legacy, timers coalesced, IO policy standard>
                10  ??? (hdiejectd + 4832) [0x1058152e0] 1-10
                  10  ??? (hdiejectd + 5656) [0x105815618] 1-10
                    10  ??? (hdiejectd + 6718) [0x105815a3e] 1-10
                      10  -[NSRunLoop(NSRunLoop) run] + 74 (Foundation + 1073743) [0x7fff8f04024f] 1-10
              Thread 0x2de4       10 samples (1-10)   priority 31
              Binary Images:
                     0x105814000 -        0x10581bfff  hdiejectd (398)                        <6E73B900-D0AA-3B83-8390-DA7F84D20D35>  /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
            Process:         helpd [5848]
            Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       1452 pages
              Thread 0x604f20     DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (helpd + 41486) [0x1049a220e] 1-10
              Thread 0x604f25     DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x104998000 -        0x1049a6fff  helpd (101.3)                          <EBBF1D6A-A092-3C7F-91A5-C4248558D7BF>  /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
            Process:         hidd [99]
            Path:            /usr/libexec/hidd
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       967 pages
              Thread 0x27f        DispatchQueue 1     10 samples (1-10)   priority 31
              <thread QoS legacy, IO policy important>
                10  ??? (hidd + 3885) [0x10df7df2d] 1-10
                  10  CFRunLoopRun + 97 (CoreFoundation + 1218161) [0x7fff8eb19671] 1-10
              Thread 0x2a5        DispatchQueue 2     10 samples (1-10)   priority 63
              Thread 0x2a6        10 samples (1-10)   priority 63
                    10  __IOHIDServiceRunLoopCompatibilityThread + 195 (IOKit + 229975) [0x7fff95501257] 1-10
              Thread 0x6164fe     10 samples (1-10)   priority 63
                    10  _dispatch_worker_thread + 122 (libdispatch.dylib + 25016) [0x7fff983601b8] 1-10
                       *10  semaphore_wait_continue + 0 (kernel + 1353536) [0xffffff800034a740] 1-10
              Thread 0x616bf1     10 samples (1-10)   priority 63
              Binary Images:
                     0x10df7d000 -        0x10df7dfff  hidd (606.40.1)                             <23F4BD1A-D6B2-35AA-9E0F-B524F024E3A9>  /usr/libexec/hidd
            Process:         iconservicesagent [64]
            Path:            /System/Library/CoreServices/iconservicesagent
            Parent:          launchd [1]
            UID:             0
            Task size:       234 pages
              Thread 0x701        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x703        DispatchQueue 11    10 samples (1-10)   priority 4
              10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 91970) [0x7fff964ff742] 1-10
              Binary Images:
                     0x109cb3000 -        0x109cb3fff  iconservicesagent (47.1)           <1D1BCBF1-4641-34C3-96AD-8AB94144A153>  /System/Library/CoreServices/iconservicesagent
            Process:         iconservicesagent [341]
            Parent:          launchd [1]
            UID:             502
            Task size:       843 pages
              Thread 0xea4        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xea6        DispatchQueue 11    10 samples (1-10)   priority 4
              Binary Images:
                     0x10f004000 -        0x10f004fff  iconservicesagent (47.1)           <1D1BCBF1-4641-34C3-96AD-8AB94144A153>  /System/Library/CoreServices/iconservicesagent
            Process:         iconservicesd [63]
            Path:            /System/Library/CoreServices/iconservicesd
            Parent:          launchd [1]
            UID:             240
            Task size:       507 pages
              Thread 0xeec        10 samples (1-10)   priority 4
              Thread 0xeee        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10fde7000 -        0x10fde7fff  iconservicesd (47.1)               <092416DB-7AA1-323B-82E0-39C44506949A>  /System/Library/CoreServices/iconservicesd
            Process:         identityservicesd [272]
            Path:            /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/iden tityservicesd
            Parent:          launchd [1]
            UID:             502
            Task size:       2975 pages
              Thread 0xbbc        DispatchQueue 1     10 samples (1-10)   priority 31
              <thread QoS legacy, timers coalesced, IO policy important>
                10  ??? (identityservicesd + 109306) [0x10e91aafa] 1-10
              Thread 0xbdc        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0xc25        10 samples (1-10)   priority 31
              Binary Images:
                     0x10e900000 -        0x10ecd0fff  com.apple.identityservicesd 10.0 (1000) <1D79AB89-D590-3E7C-B95F-E36CAE595AAC>  /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/iden tityservicesd
            Process:         Image Capture Extension [363]
            Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       9621 pages
              Thread 0x1050       DispatchQueue 1     10 samples (1-10)   priority 46
              <thread QoS user interactive, boosted, IO policy important>
              Thread 0x1056       DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0x1078       10 samples (1-10)   priority 46
              Thread 0x184f3      10 samples (1-10)   priority 46
              Thread 0x60c4bd     10 samples (1-10)   priority 31
              Binary Images:
                     0x102d3e000 -        0x102d84fff  com.apple.ImageCaptureExtension2 10.2 (10.2) <7FB37E38-8AA0-3027-8C8A-8130D8505EAF>  /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
            Process:         imagent [285]
            Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
            Parent:          launchd [1]
            UID:             502
            Task size:       2098 pages
              Thread 0xc4d        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (imagent + 34101) [0x104c01535] 1-10
              Thread 0xc50        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x104bf9000 -        0x104c22fff  com.apple.imagent 10.0 (1000)          <FA5103FC-4077-3F81-9295-2B2F4768B2C1>  /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
            Process:         IMDPersistenceAgent [287]
            Path:            /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgen t.xpc/Contents/MacOS/IMDPersistenceAgent
            Parent:          launchd [1]
            UID:             502
            Task size:       442 pages
              Thread 0xc5d        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (IMDPersistenceAgent + 5770) [0x10aaa968a] 1-10
              Thread 0xc8b        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10aaa8000 -        0x10aab9fff  com.apple.imdpersistence.IMDPersistenceAgent 10.0 (1000) <9A23B457-44E3-3B01-BB45-8E35884B3CCD>  /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgen t.xpc/Contents/MacOS/IMDPersistenceAgent
            Process:         installd [733]
            Path:            /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
            Parent:          launchd [1]
            UID:             0
            Task size:       350 pages
              Thread 0x8e05       DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (installd + 3531) [0x102b3edcb] 1-10
              Thread 0x8e06       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x102b3e000 -        0x102b3efff  installd (438)                         <B4D06745-CCA9-3900-9874-B5913DEF4152>  /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
            Process:         iTunesHelper (iTunes Helper) [365]
            Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
            Parent:          launchd [1]
            UID:             502
            Task size:       2677 pages
              Thread 0x105c       DispatchQueue 1     10 samples (1-10)   priority 46
              <thread QoS user interactive, IO policy important>
                10  ??? (iTunesHelper + 50500) [0x10c63b544] 1-10
              Thread 0x105d       DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0x1062       10 samples (1-10)   priority 46
              Binary Images:
                     0x10c62f000 -        0x10c64afff  com.apple.iTunesHelper 12.3.2 (12.3.2.35) <8E6EFF6E-149B-320E-971B-B9BB8CC777DC>  /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
            Process:         KernelEventAgent [97]
            Path:            /usr/sbin/KernelEventAgent
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       102 pages
              Thread 0x27d        10 samples (1-10)   priority 31
                10  main + 711 (KernelEventAgent + 4098) [0x106830002] 1-10
              Thread 0x2a0        10 samples (1-10)   priority 31
              Thread 0x2a1        10 samples (1-10)   priority 31
              Binary Images:
                     0x10682f000 -        0x106834fff  KernelEventAgent (91)                  <9E27CCCF-6B03-3064-B860-12C5DFCA0D7E>  /usr/sbin/KernelEventAgent
            Process:         kextd [46]
            Path:            /usr/libexec/kextd
            Parent:          launchd [1]
            UID:             0
            Task size:       2687 pages
              Thread 0x24a        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (kextd + 4079) [0x101e4ffef] 1-10
              Thread 0x2bd        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x101e4f000 -        0x101e6bfff  kextd (384.30.2)                       <FD291A26-C4A8-38A5-9432-D53B569BB8A2>  /usr/libexec/kextd
            Process:         Keychain Circle Notification [432]
            Path:            /System/Library/CoreServices/Keychain Circle Notification.app/Contents/MacOS/Keychain Circle Notification
            Parent:          launchd [1]
            UID:             502
            Task size:       993 pages
              Thread 0x1fb0       DispatchQueue 1     10 samples (1-10)   priority 31
              <thread QoS legacy, IO policy standard>
              Thread 0x1feb       DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x2079       10 samples (1-10)   priority 37
              <thread QoS user initiated, IO policy standard>
              Binary Images:
                     0x10b0e4000 -        0x10b0edfff  com.security.apple.Keychain-Circle-Notification 1.0 () <CE36A89B-A340-3456-8436-2604CDAB7C32>  /System/Library/CoreServices/Keychain Circle Notification.app/Contents/MacOS/Keychain Circle Notification
            Process:         LaterAgent [416]
            Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       941 pages
              Thread 0x1505       DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (LaterAgent + 4695) [0x10efa3257] 1-10
              Thread 0x1506       DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x151f       10 samples (1-10)   priority 37
              Binary Images:
                     0x10efa2000 -        0x10efadfff  com.apple.lateragent 1.0 (1)           <A0452A7B-5865-3841-B030-6DF2D2FFC611>  /System/Library/PrivateFrameworks/CommerceKit.framework/Resources/LaterAgent.app/Contents /MacOS/LaterAgent
            Process:         launchd [1]
            Path:            /sbin/launchd
            Parent:          kernel_task [0]
            UID:             0
            Task size:       3749 pages
              Thread 0x1c3        DispatchQueue 10    10 samples (1-10)   priority 31
              10  start_wqthread + 13 (libsystem_pthread.dylib + 5085) [0x7fff91a6a3dd] 1-10
                10  _pthread_wqthread + 729 (libsystem_pthread.dylib + 15005) [0x7fff91a6ca9d] 1-10
                  10  _dispatch_worker_thread3 + 91 (libdispatch.dylib + 18972) [0x7fff9835ea1c] 1-10
                    10  _dispatch_root_queue_drain + 935 (libdispatch.dylib + 19911) [0x7fff9835edc7] 1-10
                      10  _dispatch_client_callout + 8 (libdispatch.dylib + 7795) [0x7fff9835be73] 1-10
                        10  ??? (launchd + 190727) [0x1066db907] 1-10
                          10  au_sdev_read_aia + 557 (libbsm.0.dylib + 60012) [0x7fff9149aa6c] 1-10
                            10  fgetc + 52 (libsystem_c.dylib + 246700) [0x7fff90f7a3ac] 1-10
                              10  __srget + 14 (libsystem_c.dylib + 274112) [0x7fff90f80ec0] 1-10
                                10  __srefill1 + 24 (libsystem_c.dylib + 273827) [0x7fff90f80da3] 1-10
                                  10  __read_nocancel + 10 (libsystem_kernel.dylib + 90890) [0x7fff964ff30a] 1-10
                                           *10  ??? (kernel + 3555649) [0xffffff8000564141] 1-10
                                             *10  spec_read + 609 (kernel + 3669121) [0xffffff800057fc81] 1-10
                                               *10  ??? (kernel + 5834740) [0xffffff80007907f4] 1-10
                                                 *10  ??? (kernel + 6140665) [0xffffff80007db2f9] 1-10
                                                   *10  lck_mtx_sleep + 134 (kernel + 1272118) [0xffffff8000336936] 1-10
              Thread 0x1c4        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x1c8        DispatchQueue 11    10 samples (1-10)   priority 31
              10  _dispatch_sig_thread + 45 (libdispatch.dylib + 22821) [0x7fff9835f925] 1-10
              Thread 0x1c6        10 samples (1-10)   priority 31
              10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 70938) [0x7fff964fa51a] 1-10
              Binary Images:
                     0x1066ad000 -        0x1066eafff  launchd (559.40.1)                 <C0446878-E8D0-3461-A226-91FF1C2B2DA6>  /sbin/launchd
                  0x7fff90f3e000 -     0x7fff90fcafff  libsystem_c.dylib (1044.40.2)      <69158EFA-8270-30A1-BA02-4F74A4498147>  /usr/lib/system/libsystem_c.dylib
                  0x7fff9148c000 -     0x7fff9149cfff  libbsm.0.dylib (34)                <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB>  /usr/lib/libbsm.0.dylib
            Process:         launchservicesd [78]
            Path:            /System/Library/CoreServices/launchservicesd
            Parent:          launchd [1]
            UID:             0
            Task size:       3743 pages
              Thread 0x2a9        10 samples (1-10)   priority 31
              <thread QoS legacy, boosted, timers coalesced, IO policy important>
              Thread 0x2ab        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x10e1f4000 -        0x10e1fefff  launchservicesd (644.56)           <265B08DC-F7C9-3AB7-9B84-D941D8C4C9C3>  /System/Library/CoreServices/launchservicesd
            Process:         locationd [82]
            Path:            /usr/libexec/locationd
            Parent:          launchd [1]
            UID:             205
            Task size:       3904 pages
              Thread 0x26e        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (locationd + 165703) [0x10ed82747] 1-10
                  10  ??? (locationd + 18804) [0x10ed5e974] 1-10
                    10  ??? (locationd + 17587) [0x10ed5e4b3] 1-10
              Thread 0x4ce        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0x59b        10 samples (1-10)   priority 4
              Thread 0x59d        10 samples (1-10)   priority 4
              Thread 0x59f        10 samples (1-10)   priority 4
              Thread 0x5a0        10 samples (1-10)   priority 4
              10  kevent + 10 (libsystem_kernel.dylib + 94746) [0x7fff9650021a] 1-10
              Thread 0x1018       10 samples (1-10)   priority 4
              Thread 0x103f       10 samples (1-10)   priority 4
              Binary Images:
                     0x10ed5a000 -        0x10f19efff  locationd (1615.24)                    <E6A1B272-5762-3F69-9D0B-E046A930DD6B>  /usr/libexec/locationd
            Process:         logind [96]
            Path:            /System/Library/CoreServices/logind
            Parent:          launchd [1]
            UID:             0
            Task size:       305 pages
              Thread 0x27c        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (logind + 6595) [0x10adca9c3] 1-10
              Thread 0x29b        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x10adc9000 -        0x10adcffff  logind (23.3)                          <727B331E-D3A7-380E-AF94-6AEB80993202>  /System/Library/CoreServices/logind
            Process:         loginwindow [95]
            Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
            Parent:          launchd [1]
            UID:             502
            Task size:       5437 pages
              Thread 0x27b        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (loginwindow + 22755) [0x101f598e3] 1-10
              Thread 0x475        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x101f54000 -        0x101feefff  com.apple.loginwindow 10.4 (10.4)      <66748489-BF5B-3A2B-8A19-2711537A4BCB>  /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
            Process:         lsuseractivityd [352]
            Path:            /System/Library/CoreServices/lsuseractivityd
            Parent:          launchd [1]
            UID:             502
            Task size:       703 pages
              Thread 0xf5b        DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (lsuseractivityd + 10200) [0x1097f17d8] 1-10
              Thread 0xf5c        DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x1097ef000 -        0x109824fff  lsuseractivityd (644.56)               <D77926F9-5FE7-39CA-88BC-7DAE9004A730>  /System/Library/CoreServices/lsuseractivityd
            Process:         mapspushd [266]
            Path:            /System/Library/CoreServices/mapspushd
            Parent:          launchd [1]
            UID:             502
            Task size:       2930 pages
              Thread 0xb9f        DispatchQueue 1     10 samples (1-10)   priority 4
                10  main + 210 (mapspushd + 5856) [0x1049056e0] 1-10
                  10  -[MapsPushDaemonLocalProxy runServer] + 171 (mapspushd + 37274) [0x10490d19a] 1-10
              Thread 0xbb9        DispatchQueue 2     10 samples (1-10)   priority 4
              Thread 0xca5        10 samples (1-10)   priority 4
              Thread 0xd62        10 samples (1-10)   priority 4
              Binary Images:
                     0x104904000 -        0x104915fff  mapspushd (1844.0.15)                  <69691DD7-2D95-364D-A663-8B0A8511E8C7>  /System/Library/CoreServices/mapspushd
            Process:         MassStorageCamera [5117]
            Path:            /System/Library/Image Capture/Devices/MassStorageCamera.app/Contents/MacOS/MassStorageCamera
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       4592 pages
              Thread 0x52c16a     DispatchQueue 1     10 samples (1-10)   priority 46
                10  ICD_main + 24 (ICADevices + 53568) [0x101396140] 1-10
                  10  ICAApplicationMain + 399 (ICADevices + 7719) [0x10138ae27] 1-10
              Thread 0x52c182     DispatchQueue 2     10 samples (1-10)   priority 46
              Thread 0x52c196     10 samples (1-10)   priority 46
              Thread 0x52c19e     10 samples (1-10)   priority 46
              Binary Images:
                     0x10136d000 -        0x10137bfff  com.apple.MassStorageCamera 10.2 (10.2) <55FF7158-5B89-3830-BE6D-FA2C27DABD9F>  /System/Library/Image Capture/Devices/MassStorageCamera.app/Contents/MacOS/MassStorageCamera
                     0x101389000 -        0x1013b0fff  com.apple.ICADevices 10.2 (10.2)        <1B2CD1F5-103D-3F54-88C3-60046ED5AB5D>  /System/Library/Frameworks/ICADevices.framework/Versions/A/ICADevices
            Process:         mdflagwriter [505]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       130 pages
              Thread 0x2433       DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x2435       DispatchQueue 11    10 samples (1-10)   priority 31
              Binary Images:
                     0x105ca5000 -        0x105ca6fff  mdflagwriter (917.36)              <F0646B90-CE87-35DC-A1B4-1E33C445812D>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
            Process:         mdflagwriter [705]
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Clean
            Task size:       124 pages
              Thread 0x7983       DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x7985       DispatchQueue 11    10 samples (1-10)   priority 31
              Binary Images:
                     0x100f5e000 -        0x100f5ffff  mdflagwriter (917.36)              <F0646B90-CE87-35DC-A1B4-1E33C445812D>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdflagwriter
            Process:         mDNSResponder [91]
            Path:            /usr/sbin/mDNSResponder
            Parent:          launchd [1]
            UID:             65
            Sudden Term:     Clean
            Task size:       1907 pages
              Thread 0x277        DispatchQueue 1     10 samples (1-10)   priority 31
              10  start + 52 (mDNSResponder + 219252) [0x10bc19874] 1-10
                10  main + 2177 (mDNSResponder + 5170) [0x10bbe5432] 1-10
              Thread 0x48b        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x579        10 samples (1-10)   priority 31
              Thread 0x39a8       10 samples (1-10)   priority 63
              <timers coalesced, IO policy important>
              Thread 0x39aa       10 samples (1-10)   priority 31
              Binary Images:
                     0x10bbe4000 -        0x10bc96fff  mDNSResponder                          <991AE3FA-2B17-3448-8876-4D098EDA02CA>  /usr/sbin/mDNSResponder
            Process:         mds [59]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
            Parent:          launchd [1]
            UID:             0
            Task size:       17136 pages
              Thread 0x257        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (mds + 41145) [0x1024a20b9] 1-10
              Thread 0x474        DispatchQueue 2     10 samples (1-10)   priority 31
              Thread 0x4f7        10 samples (1-10)   priority 50
              Thread 0x61695b     10 samples (1-10)   priority 31
              Binary Images:
                     0x102498000 -        0x102608fff  mds (917.36)                           <4CE8228C-47BE-30D6-8F36-DF6D22A5AA58>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
            Process:         mds_stores [184]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
            Parent:          launchd [1]
            UID:             0
            Sudden Term:     Dirty
            Task size:       21751 pages
              Thread 0x705        DispatchQueue 1     10 samples (1-10)   priority 31
                10  ??? (mds_stores + 19319) [0x104834b77] 1-10
              Thread 0x706        DispatchQueue 2     10 samples (1-10)   priority 31
              Binary Images:
                     0x104830000 -        0x104875fff  mds_stores (917.36)                    <77169EA1-6AFA-3780-B4D7-873681EF12A7>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mds_stores
            Process:         mdworker [501]
            Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Parent:          launchd [1]
            UID:             89
            Sudden Term:     Dirty
              Thread 0x23ff       DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (mdworker + 34329) [0x10464c619] 1-10
              Thread 0x2406       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x104644000 -        0x1046a5fff  mdworker (917.36)                      <6ACB2C4C-448C-3CC6-962A-5069D6B7CF71>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [576]
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Dirty
            Task size:       1104 pages
              Thread 0x3a57       DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (mdworker + 34329) [0x103825619] 1-10
              Thread 0x3a5a       DispatchQueue 2     10 samples (1-10)   priority 4
              Binary Images:
                     0x10381d000 -        0x10387efff  mdworker (917.36)                      <6ACB2C4C-448C-3CC6-962A-5069D6B7CF71>  /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
            Process:         mdworker [5788]
            Parent:          launchd [1]
            UID:             502
            Sudden Term:     Clean
            Task size:       4259 pages
              Thread 0x5d7d20     DispatchQueue 1     10 samples (1-10)   priority 4
                10  ??? (mdworker + 34329) [0x101bc1619] 1-10
