Before I could read a book on my computer, but not get it to my Letto frontlight. Now I can´t do that.
Hi Inez,
You will likely need to manually delete the activation file to get this error cleared. Please follow these instructions:
You must have administration authority.
On Windows it can be found here:
Open Windows Registry by using the command prompt and typing 'regedit' or by opening the start menu and searching for 'regedit'.
Search for the following folder:
HKEY_CURRENT_USER\Software\Adobe\Adept\Activation
The 'Activation' folder can be entirely deleted.
On Mac it can be found here:
In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
~/Library/Application Support/Adobe/Digital Editions/
Delete the activation.dat file within the 'Digital Editions' folder.
Restart ADE and it should be deactivated at this point. You should be good to sign back in.
Thanks! Now it´s working!
I had to delete the map Adept.Then I had to download the book again. In All items mark the book, press the rightclick and copy to Bookshelf Letto.
