8 Replies Latest reply on Dec 23, 2015 1:48 PM by Carl Von Stetten
    cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
    Lance-b Level 1
      Code
      Below is the script, the queries in the thread only use the variables on the cfthread call. The process works about 80% of the time and then I receive Java.util.concurrentmodificationexception on one of the threads, occasionally more than one.  Using CF 9,0,0,251028, but have tested with 9,0,2,282541 with the same issue.
      Any hekp is appreciated
      <cfquery name = "variables.Dts" datasource="#mydsn#">
      select
      to_char(next_day(to_date('#selDate#','mm/dd/yyyy')-56,'sat')+(level-1)*7-2,'mm/dd/yyyy') as thu,
      to_char(next_day(to_date('#selDate#','mm/dd/yyyy')-56,'sat')+(level-1)*7-1,'mm/dd/yyyy') as fri,
      to_char(next_day(to_date('#selDate#','mm/dd/yyyy')-56,'sat')+(level-1)*7,'mm/dd/yyyy') as sat
      from dual
      connect by  level <  9
      </cfquery>
      <!--- test --->
      <cfset qtr = 0>
      <cfset tname = ''>
      <cfloop query="variables.dts" >
      <cfset qtr += 1>
      <cfthread name="t#qtr#" action="run" sat2='#variables.dts.sat#' thu2='#variables.dts.thu#' selarea2='#selArea#' selDistrict2='#seldistrict#' qtr2='#qtr#' dsn="#mydsn#" >
      <cfquery name="variables.m#qtr2#" datasource="#dsn#" >
      </cfquery>
      </cfthread>
      <cfset tname &= 't#qtr#' & ','>
      </cfloop>
      <cfset qtr += 1>
      <cfthread name="t#qtr#" action="run" sat1='#variables.dts.sat#' fri1='#variables.dts.fri#' selarea1='#selArea#' selDistrict1='#seldistrict#' qtr1='#qtr#' dsn="#mydsn#">
      <cfquery name="variables.m#qtr1#" datasource="#dsn#" >
      </cfquery>
      </cfthread>
      </cfloop>
      <cfset tname = left(tname,len(tname)-1)>
      <cfthread action="join" name="#tname#" />
        • 1. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
          Carl Von Stetten Adobe Community Professional & MVP
          I moved this to the Advanced Techniques subforum because many of the more experienced ColdFusion community members hang out there.  If you don't get an answer, you might try joining the CFML Slack channel, as you can get access to more real-time community assistance.  I'll even put a link there to this thread to see if I can draw some attention.
          -Carl V. - Moderator
          • 2. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
            BKBK Adobe Community Professional & MVP
            What is your motivation for using threads? I cannot see any, yet the threads add a lot of complexity to the code.
            The database is an independent system. It should therefore be treated as a black-box which may have its own concurrency strategy, beyond Coldfusion's control. Before you know it, there are worms everywhere.
            Aside from that, if you replace <cfset tname &= 't#qtr#' & ','> with <cfset tname = listAppend(tname, 't#qtr#')> you will save yourself one line of code.
            • 3. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
              Lance-b Level 1
              Thank you for the reply
              The threads are being used to speed up the retrieval of the data.  It works well, I can shave minutes off the  total query time.  Each query returns the data of a single partition and is combined  in a  dbquery. It provides in a week analysis of selected facilities almost instantly.  It is exactly what is needed, if I can resolve the concurrentmodificationexception. Thank you for the listAppend suggestion, much more readable.
              • 4. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
                You have omitted some code (marked by ellipsis), so it is difficult to say.  In any case, the hint from the concurrentmodificationexception is that a thread th6, say, attempted to modify a variable variables.somevar while thread th7was still busy with it.
                As your threads are asynchronous, execution may already move to the second loop while threads of the first loop are still busy. Is that consistent with your business logic?
                • 5. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
                  Lance-b Level 1
                  I agree with your assessment and appreciate your time, I tried to  eliminate any access by the thread to local variables. I have added the complete code (below), if you have time to consider
                  The below code works most of the time , but occasionally a thread ( in this example t7) will reurn this error
                  T7
                  struct
                  ELAPSEDTIME    0
                  ERROR
                  struct
                  Message
                  StackTrace          java.util.ConcurrentModificationException at java.util.WeakHashMap$HashIterator.nextEntry(WeakHashMap.java:762) at java.util.WeakHashMap$EntryIterator.next(WeakHashMap.java:801) at java.util.WeakHashMap$EntryIterator.next(WeakHashMap.java:799) at java.util.HashMap.putAll(HashMap.java:523) at coldfusion.monitor.memory.MemoryTracker.getAllPrimitiveMap(MemoryTracker.java:92) at coldfusion.monitor.memory.MemoryTracker.getEstimatedMemory(MemoryTracker.java:117) at coldfusion.monitor.memory.MemoryCalculator.calculateMemory(MemoryCalculator.java:100) at coldfusion.monitor.memory.MemoryCalculator.calculateMemory(MemoryCalculator.java:30) at coldfusion.monitor.memory.MemoryTrackerProxy.onAddObject(MemoryTrackerProxy.java:277) at coldfusion.runtime.NeoPageContext.setVariableScope(NeoPageContext.java:1546) at coldfusion.runtime.NeoPageContext.SymTab_initializeForPage(NeoPageContext.java:963) at coldfusion.runtime.NeoPageContext.initializeWith(NeoPageContext.java:293) at coldfusion.thread.Task.run(Task.java:131) at coldfusion.scheduling.ThreadPool.run(ThreadPool.java:201) at coldfusion.scheduling.WorkerThread.run(WorkerThread.java:71)
                  TagContext
                  array
                  Type      java.util.ConcurrentModificationException
                  NAME   T7
                  OUTPUT
                  PRIORITY             NORMAL
                  STARTTIME         {ts '2015-12-20 19:06:13'}
                  STATUS                TERMINATED
                  ,'mm/dd/yyyy') start_the_clock_date,
                          sum(piece_cnt) AS BLUE_tot, sum(INCL_SVC_VAR_MINUS4_CNTINCL_SVC_VAR_MINUS3_CNTINCL_SVC_VAR_MINUS2_CNT) as blue,
                          0 AS ORANGE_tot, 0 as orange,hyb_svc_std_desc
                          from V_mstr a
                          inner join BI_MSTR_SVC_STD b
                          on b.ORGN_ENTERED = 'N'
                          and b.ML_CL_CODE= a.ML_CL_CODE
                          and b.SVC_STD = a.SVC_STD
                          INNER JOIN
                          V_facility c
                          ON c.fac_SEQ_ID = ORGN_FAC_SEQ_ID
                          inner join
                         (select distinct site_name as area_name,area,district_name,district
                         from v_hier) ad
                          on ad.district = c.district
                          where a.start_the_clock_date = to_date(
                  William R Lance
                  425.408.0855
                  425.482.0375 - Cell
                  Pacific Time Zone
                  T7
                  struct
                  ELAPSEDTIME    0
                  ERROR
                  struct
                  Message
                  TagContext
                  array
                  NAME   T7
                  OUTPUT
                  PRIORITY             NORMAL
                  STATUS                TERMINATED
                          from V_mstr a
                          inner join v_SVC_STD b
                          INNER JOIN
                          V_facility c
                          inner join
                         from v_hier) ad
                  • 7. Re: cfthread in cfloop, all variables passed in on the thread, intermittent java.util.concurrentmodificationexception.  cfloop is a query loop and each thread calls cfquery.  How do I find the error?
                    Lance-b Level 1
                    T7
                    struct
                    ELAPSEDTIME    0
                    ERROR
                    struct
                    Message
                    TagContext
                    array
                    NAME   T7
                    OUTPUT
                    PRIORITY             NORMAL
                    STATUS                TERMINATED
                            from V_mstr a
                            INNER JOIN
                            V_facility c
                            inner join
                           from v_hier) ad
