3 Replies Latest reply on Jan 1, 2016 7:51 PM by EliMonroy37
    crash
    EliMonroy37
      I recently emptied disk cache and cleaned database & cache and now I can only get about 2 seconds of preview (spacebar) or rendering and it crashes, what can I do? Any help is appreciated. Here are my settings:
      Enable Disk Cache (checked)
      Max Disk Cache Size: 23GB
      Memory
      Installed RAM: 16 GB
      RAM reserved for other applications: 5GB
      RAM available for AE: 11GB
      Reduce cache size when system is low on memory (not checked)
      OS: Windows 10
      AE version: 13.6.0.165
        • 1. Re: crash
          Nobody can tell you anything without things like the actual crash logs and info on what's going on in your comps.
          Working with your Operating System’s Tools | Mylenium's Error Code Database
          Mylenium
          • 2. Re: crash
            EliMonroy37 Level 1
            Mylenium, thank you very much for your link.  I have followed the instructions on it and below i have pasted the information on my system and the crash.
            A little background on the project I'm working on and is now crashing after a few seconds of rendering:  This is a 2.5 min video that i work on every week (it's always worked before and just recently started crashing when trying to render).  The reason i work on this same project every week is it is the church announcements video.  It is basically a template that i update with different slides and text and talent, but the structure remains the same (about 30 layers, 7 pre-comps of about 5 layers each no longer than 20 seconds each).  The fanciest effect i got going is the Key Light (which i do see has been included in the crash report).  I must include that i did recently change my graphics card to the GeForce GTX 660 Ti and so far it has worked fine with anything else.  Other than that, the crashing started happening as I mentioned before, after i cleaned cache in the preferences menu of AE as well as the database.  I have also increased the Max Disk Cache Size to now 50GB and I also migrated the Cache folder and the Conformed Media Cache Database and Cache folders to a secondary internal hardrive 1TB (recently installed for this very project and has been working fine).  The current work around i have been doing is rendering with the work area 10 seconds worth of video (seems to be about the max it will do).  Later i will import all these little segments into Premier and paste them in a series and then render the whole video (royal pain btw).
            Please let me know if there is anything else I should include.  Any help will be greatly appreciated.
            System
            Processor: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz 3.80GHz
            Installed memory (RAM): 16.0 GB
            System type: 64-bit Operating Systemx x64-based processor
            Graphics Card:
            NVIDIA GeForce GTX 660 Ti
            from event viewer:
            Fault bucket 120376225772, type 4
            Event Name: APPCRASH
            Response: Not available
            Cab Id: 0
            Problem signature:
            P1: AfterFX.exe
            P2: 13.6.1.6
            P3: 566a97aa
            P4: KeylightPro.AEX
            P5: 0.0.0.0
            P6: 5550be0a
            P7: c0000005
            P8: 00000000000d10ef
            P9:
            P10:
            C:\Users\eliskywalker\AppData\Local\Temp\WERFD76.tmp.WERInternalMetadata.xml
            These files may be available here:
            C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_AfterFX.exe_9d9a7d688cce95c579 4792b761f86f572af455f_86d1646f_b1b906dc
            Analysis symbol:
            Rechecking for solution: 0
            Report Id: 66ebf084-7633-4cac-ba63-a3b33ae07ed5
            Report Status: 1
            Hashed bucket: e31e7da034b6b96b0ba86de33e9add38
            • 3. Re: crash
              EliMonroy37 Level 1
              Good and bad news, reading through other threads i started disabling effects in my project and seeing if it would crash.  When I disabled Key Light 1.2, i was able to hit the  preview (space bar) and pretty much previewed the whole project without it crashing at full resolution.  So i guess we have found the culprit.  However, this is probably the worst outcome possible for my project.  The whole video is based on keying a green screen for the talent used through out.  I am attempting to use other key effects, but Key Light is just SO MUCH better at doing the fine tuning needed for my green screen.  I just can't believe that I can't use it in AE.  In fact, the whole reason I'm using AE and not just Premier is because of this very effect.  Any help or suggestions will be much appreciated.
