8 Replies Latest reply on Jan 28, 2016 7:28 AM by Ken Binney
    Update crashes on startup, -WIN7-
    anthonys76161419
      I'm a broke ************ and I've been facing constant problems with this software upon startup. Simply uninstalling then reinstalling won't do the trick this time. Yes, it crashes. "Looking online for the solution" doesn't do jack ****, as expected. Was using this software in split screen it was acting tricky with form(s) so I decided to update to see if that would solve the problem. Nope.
        • 1. Re: Update crashes on startup, -WIN7-
          Ken Binney Level 6
          Sorry for your troubles.
          When you are finished ranting, could you kindly provide some useful information?
          What version did you upgrade from/to?
          When reinstalling, did you run the Cleaner Tool?
          Use the Adobe Creative Cloud Cleaner Tool to solve installation problems
          Have you rebuilt your Cache, Preferences or Personal Configuration folders?
          Deleting a corrupted cache file
          • 2. Re: Update crashes on startup, -WIN7-
            What do your Windows Event Logs tell you is causing the crash?
            Does the software crash with all sites?
            Does the software crash with all files?
            As a test, can you create a new blank file and work with it?
            ...it was acting tricky with form(s) so I decided to update to see if that would solve the problem.
            Did you check your code for errors?  If your code contains many errors that DW cannot reconcile, this can choke your software & cause it to become unresponsive.  Use the code validation tools below & fix reported errors.
            Nancy O.
            • 3. Re: Update crashes on startup, -WIN7-
              anthonys76161419 Level 1
              I just don't understand why such a prestigious product is populated with so many errors for me. It's already hard enough for me to get any motivation to do anything.
              1. Tell me how to find that out and I can tell you. AFAIK adobe doesn't have many updates for it's apps so I'm assuming I've upgraded from the previous version.
              2. I was not aware of that page. However I did follow through with the instructions to no avail.
              3. I followed the instructions on that and in my configurations folder the file required to be deleted was MIA.
              I'm trying all I can on my end and it still crashes on startup. Maybe this can help.
              EDIT: All the other applications I have installed are in working order. Problem is only with DW.
              http://i.imgur.com/hj7KhoH.png?1
              • 4. Re: Update crashes on startup, -WIN7-
                Which version and build # of DW do you have?  You'll find it under Help > About Dreamweaver.
                To see hidden files & folders, you must turn on HIDDEN files & folders in your Win Explorer.
                To see Windows Event Logs:
                Click on Win Start button Picture of the Start button.
                In the Search box, type Event Viewer,
                In the list of results, double-click Event Viewer.
                Nancy O.
                • 5. Re: Update crashes on startup, -WIN7-
                  Nancy, Dreamweaver INSTANTLY crashes on every startup. I am not able to click on help and tell you the version/build# that way.
                  When I checked, I had made sure that option was enabled.
                  Log Name:      Application
                  Source:        Application Error
                  Date:          12/19/2015 3:43:02 PM
                  Event ID:      1000
                  Task Category: (100)
                  Level:         Error
                  Keywords:      Classic
                  User:          N/A
                  Computer:      Champion-PC
                  Description:
                  Faulting application name: Dreamweaver.exe, version: 16.1.0.7851, time stamp: 0x56423c0c
                  Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
                  Exception code: 0xc0000005
                  Fault offset: 0x0000000000000000
                  Faulting process id: 0x16e8
                  Faulting application start time: 0x01d13aa63a1fb3c0
                  Faulting application path: C:\Program Files\Adobe\Adobe Dreamweaver CC 2015\Dreamweaver.exe
                  Faulting module path: unknown
                  Report Id: 7a624f62-a699-11e5-9846-086266310051
                  Event Xml:
                  <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
                    <System>
                      <Provider Name="Application Error" />
                      <EventID Qualifiers="0">1000</EventID>
                      <Level>2</Level>
                      <Task>100</Task>
                      <Keywords>0x80000000000000</Keywords>
                      <TimeCreated SystemTime="2015-12-19T21:43:02.000000000Z" />
                      <EventRecordID>40202</EventRecordID>
                      <Channel>Application</Channel>
                      <Computer>Champion-PC</Computer>
                      <Security />
                    </System>
                    <EventData>
                      <Data>Dreamweaver.exe</Data>
                      <Data>16.1.0.7851</Data>
                      <Data>56423c0c</Data>
                      <Data>unknown</Data>
                      <Data>0.0.0.0</Data>
                      <Data>00000000</Data>
                      <Data>c0000005</Data>
                      <Data>0000000000000000</Data>
                      <Data>16e8</Data>
                      <Data>01d13aa63a1fb3c0</Data>
                      <Data>C:\Program Files\Adobe\Adobe Dreamweaver CC 2015\Dreamweaver.exe</Data>
                      <Data>7a624f62-a699-11e5-9846-086266310051</Data>
                    </EventData>
                  </Event>
                  This is copied directly from the event viewer. Hope this is what you're looking for.
                  • 6. Re: Update crashes on startup, -WIN7-
                    BenPleysier Adobe Community Professional & MVP
                    Have a look at this solution Problems with launching Dreamweaver CC 2015
                    • 7. Re: Update crashes on startup, -WIN7-
                      Looks like I unintentionally created some sort of problem here.
                      I had the CC application downloaded onto another drive, and Dreamweaver onto my main drive. Although this DID NOT effect my other applications; it caused only Dreamweaver to always crash on startup. I had attempted to uninstall CC from my other drive but the computer would not let me, so I completely wiped it out and freshly installed it onto my main drive. Problem eliminated after that.
                      • 8. Re: Update crashes on startup, -WIN7-
                        Ken Binney Level 6
                        Thanks for following up -
