• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Library not found for -lstdc++ in adt on Windows 10
Explorer ,
Dec 19, 2015 Dec 19, 2015
I'm trying to pack ipa on Windows 10 with adt and i get an error:
ld: library not dound for -lstdc++
Compilation failed while executing : ld64
I am used AIR SDK 20 beta
How to fix it?
Thank you.
TOPICS
Development
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Hi ,
Can you let us know the command you are using to package the ipa?
Roshan
Adobe AIR
Votes
Translate
Translate
Report
Report
Explorer ,
Hi!
My  .bat script:
set AIR_SDK=C:\work\sdks\AIRSDK_20
set iOS_SDK=C:\work\sdks\iPhoneOS.sdk
set PROVISIONING_FILE=C:\work\~cert\FlashPressAll.mobileprovision
set KEYSTORE_FILE=C:\work\~cert\sertificate.p12
set KEYSTORE_PASSWORD=!Q2w3e4r5t
set ADT=%AIR_SDK%\bin\adt.bat
start %ADT% -package -target ipa-debug-interpreter ^
        -storetype pkcs12 -keystore %KEYSTORE_FILE% -storepass %KEYSTORE_PASSWORD% -provisioning-profile %PROVISIONING_FILE% ^
        example.ipa .\Main-app.xml .\Main.swf ^
        -platformsdk %iOS_SDK% ^
        -extdir ..\ane
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi, Thanks,
Can you try a simple hello world application without using -platformsdk ? Let us know the result.
-Roshan
Votes
Translate
Translate
Report
Report
Explorer ,
Without -platformsdk all good, ipa created.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Thank you,
We are looking into this issue. Will update as soon as we have the fix for it.
-Roshan
Adobe AIR
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jan 06, 2016 Jan 06, 2016
Hi ,
We investigated the issue and found that this issue will be encountered if the lib folder inside the PhoneOS.sdk\usr does not contain all the libraries.
Kindly verify if you have all the libs present there including the one with soft links (you can compare it with the Xcode if possible) .There should be a total of 169  files inside that folder if you are using 9.0 SDK.
Please recheck and let us know if you are still facing this issue.
-Roshan
Adobe AIR.
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 19, 2018 Apr 19, 2018
we have similar issue using latest iossdk 11
ld: library not dound for -lc++
We have to use platformsdk as on windows air sdk 29 still has issues signing ipa containing ios third party dynamic framework.
On mac air sdk works as expected but not on windows.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
as a solution we added needed libs from air sdk to iphone sdk folder
Votes
Translate
Translate
Report
Report
