3 Replies Latest reply on Dec 19, 2015 7:22 AM by daniv26905224
    I just switched from PC to Mac.
    daniv26905224
      When I try to open my LR catalog (saved on an external hard drive) I get the message: "Lightroom cannot open with this catalog, or on a volume on which Lightroom cannot save changes
        • 1. Re: I just switched from PC to Mac.
          Just Shoot Me Adobe Community Professional
          Your external drive is formatted in the Windows NTFS format which OS X, the Apple Mac Operating system, can READ From but can NOT Write to.
          You will need either another external drive or enough space on your internal Mac hard drive to Copy all the folders and files from your current external drive and then Format that external to the Mac OS X format, Mac OS Extended (Journaled), and then Copy and or move those folders and files back onto your current external drive.
          If you use another external drive make sure it is formatted either in the Mac format or the Windows FAT32 format or the MS Ext32 format.
          99% of all external drives sold today are pre-formatted in the Windows NTFS format. So if you use another external you must first format it to what I have listed above before you try to copy or move files to it from your new Mac.
          • 2. Re: I just switched from PC to Mac.
            NOTE I said Copy your folders and file from your present external. Don't try to Move them as to Move any file it is first copied to the new location then Deleted from the old, original, location. Since OS X can Write to NTFS formatted drive, which is needed to delete files the Move will fail.
            • 3. Re: I just switched from PC to Mac.
              daniv26905224 Level 1
              Thank you so much!
