7 Replies Latest reply on Dec 20, 2015 3:07 PM by boo radley 2013
    Move layer to cursor
    boo radley 2013 Level 3
      Hi, I'm not sure this belongs in the scripting section so maybe I can ask in both this section and the main section.
      I'm looking to find a way to move a particular layer to the cursor. SO in other words, imagine you're working on a document with several layers, and you're really zoomed in. I want to be able to select the layer I wish to move by clicking on it in the layers panel, then perhaps run the script (or other method), which will then move that layer in question to wherever the cursor is at that moment. This eliminates the need to zoom way out, click on the layer in the panel, then move it to where I was working, then zoom way back in again. Just imagine that the layer I wish to move contains just a little color dab/pallet thing that I made to sample colors from. I don't want to have to keep zooming out, pull that layer over to where I was zoomed in and then zoom back in again to keep working. I hope this makes sense.
      Is there a stock way to do this in photoshop or is it a more complicated (or impossible) thing to do?
      Thanks!
        • 1. Re: Move layer to cursor
          I know of  no way to find out the mouse cursor location in a Photoshop Script.  You can use to color sampler tool to mark up tp 10 location in a Photoshop document.  But I do not think it posible to get the mouse coursor position in a Photoshop script.
          You can also set a selection and align layers to the selection. Set guides and align layers to guides
          http://www.mouseprints.net/old/dpr/FitImageToGuides.jsx
          http://www.mouseprints.net/old/dpr/RotateLayerAbout.jsx
          • 2. Re: Move layer to cursor
            thanks, JJ. If I could mark the cursor's location with the color sampler tool, would I then be able to move the layer in question to its x,y location?
            • 3. Re: Move layer to cursor
              c.pfaffenbichler Level 9
              The ColorSamplers’ position can even be evaluated with DOM code, calculating the necessary offset to translate the Layer should not be a problem.
              // 2015, use it at your own risk;
              #target photoshop
              if (app.documents.length > 0) {
              var myDocument = app.activeDocument;
              var theArray = new Array;
              for (var m = 0; m < myDocument.colorSamplers.length; m++) {
              theArray.push(myDocument.colorSamplers[m].position)
              alert (theArray.join("\n"));
              • 4. Re: Move layer to cursor
                DBarranca Level 4
                in case you need more than 10 x/y locations, you can do the same with the Count tool.
                Davide
                • 5. Re: Move layer to cursor
                  thanks guys, yes c.pfaffenbichler, the script returns the x y coordinates of the color sampler point successully. very useful. I also managed to work out another way to do it. It's useful for painters if they want to pull over their little swatch pallet to the exact location they're painting at when zoomed in really close. (not the Swatches Panel, but a manual swatch pallet that they might have sketched out themselves)
                  1. Ensure the layer you wish to move is the active layer
                  2. Create any sort of a selection using the lasso tool at the exact area you're working in. Can be any size, anywhere on your document as long as it's close to where you're working.
                  3. Select the Move Tool.
                  4. In the options bar, there are now little icons. Click on the "Align Horizontal Centers" icon, and then click on the "Align Vertical Centers" icon. The layer now moves to the selection.
                  A bit of a task to be honest, but it's a little easier than zooming way out, dragging the layer in question to where you were just working, and then zooming way back in again.
                  • 6. Re: Move layer to cursor
                    Its 1 target layers to be aligned, 2 make a selection to align the layers to  and 4 the two align steps. 3 the move tool is not required.   And 4 is a simple key press. You just need to record the two align steps into an action and assign a shortcut like F2 to the action.
                    Step 1 menu Layer>Align Layers to Selection>Vertical Center
                    Step 2 menu Layer>Align Layers to Selection>Horizontal Center
                    • 7. Re: Move layer to cursor
                      Awesome!! Thanks JJ! I thought we had to select the move tool for it to work. Now that it's unnecssary, everything is running even better. It's an extra step we didn't need
