1 Reply Latest reply on Feb 4, 2009 4:55 PM by r u a computer guy?
    Need Help With FW4
    Grim107
      I wanted to add noise to a picture, so I looked at a tutorial online. The only problem is that it says to go to the Property Inspector. Where is that? I can't find it anywhere! Thanks.
        • 1. Re: Need Help With FW4
          r u a computer guy? Level 1
          >See WINDOW in the top menu
          >Make sure "Properties" is checked (4th box down)
          >A long box will appear at the bottom of your screen with 2 tabs
          >Make sure you are on the "Properties" tab
          >Select your picture. *This is important* What shows in this tab is dependent on what you do or don't have selected. Cool if you know it, not so much if you don't.
          >Near the middle there is a "Filters" label with a "+" next to it. Click on that and Noise is listed in the pop-up with some other stuff.
