5 Replies Latest reply on Dec 22, 2015 3:45 AM by jonathann67223665
    Can I console.log from inside a click event in Edge Animate?
    jonathann67223665
      I am trying to work out why my console.log command throws an event handler error when I put it into a click event.
      My Javascript is not good enough to know if this is specific to Edge, or a more global JS thing.
      Here is my code:
      (function($, Edge, compId){
      var Composition = Edge.Composition, Symbol = Edge.Symbol; // aliases for commonly used Edge classes
      //Edge symbol: 'stage'
      (function(symbolName) {
      Symbol.bindSymbolAction(compId, symbolName, "creationComplete", function(sym, e) {
      // insert code to be run when the symbol is created here
      var want = true;
      console.log(want);
      //Edge binding end
      Symbol.bindElementAction(compId, symbolName, "${Rectangle}", "click", function(sym, e) {
      // insert code for mouse click here
      console.log(want);
        //Edge binding end
      })("stage");
      //Edge symbol end:'stage'
      })(window.jQuery || AdobeEdge.$, AdobeEdge, "EDGE-26284910");
      The first console.log after creationComplete works fine, the next one in the click event does not work, and I have no idea why. Can anyone enlighten me?
        • 1. Re: Can I console.log from inside a click event in Edge Animate?
          joel_pau Level 5
          It would be long to explain: javascript variable and function scopes.
          You have to understand that variables are available inside their own panel. I mean code panel.
          Your "want" variable is local and not global because you set: var want = true;
          If you want a global variable, you have to use: sym.setVariable("want", true);
          Now you can call it within another code panel using: sym.getVariable("want");
          console.log( sym.getVariable("want") ); // it returns true
          //Edge binding end
          console.log(sym.getVariable("want") ); // it returns true, so a conditional statement can be:
          if (sym.getVariable("want")) { console.log ("want=true") } else { console.log ("want=false") }
            //Edge binding end
          })("stage");
          • 2. Re: Can I console.log from inside a click event in Edge Animate?
            joel_pau Level 5
            I must specify that your case has one and only one symbol ("Stage").
            Between symbols, you have to add: sym.getComposition().getStage()
            I resume:
            • Within one symbol: sym.setVariable() and sym.getVariable();
            • Between symbols: sym.getComposition().getStage().setVariable() and sym.getComposition().getStage().getVariable()
            • 3. Re: Can I console.log from inside a click event in Edge Animate?
              jonathann67223665 Level 1
              Thanks, that does make sense. Am I right in thinking then that in usual JS code I could have declared the var at the top and used it wherever I wanted later on? This problem is only Edge-specific, ie that the code panels have their own sacrosanct scope that you have to break free from in order to grasp previously-defined variables?
              • 4. Re: Can I console.log from inside a click event in Edge Animate?
                joel_pau Level 5
                jonathann67223665 a écrit:
                1) Am I right in thinking then that in usual JS code I could have declared the var at the top and used it wherever I wanted later on?
                Yes, but where is the top and how to get it?
                // Stage top is here. You get it press the "full code button" or "Stage".
                var want = true;
                console.log(want); //it returns true
                //Edge binding end
                  //Edge binding end
                })("stage");
                2) This problem is only Edge-specific, ie that the code panels have their own sacrosanct scope that you have to break free from in order to grasp previously-defined variables?
                Yes and no.
                Yes and there is an overturn. You set sym.want = true inside a panel. So we have following code:
                sym.want = true;
                console.log(sym.want); //it returns true
                //Edge binding end
                  //Edge binding end
                })("stage");
                No because it's general javascript: javascript closures.
                Findings:
                Take a look at
                1) javascript scope ==> Demystifying JavaScript Variable Scope and Hoisting
                2) javascript closures ==> JavaScript Function Closures
                3) module pattern  ==> https://learn.jquery.com/code-organization/concepts/
                • 5. Re: Can I console.log from inside a click event in Edge Animate?
                  Thanks a lot, I appreciate the help.
