2 Replies Latest reply on Dec 21, 2015 7:05 AM by 1234jaime
    Could I hide a symbol with the name of a variable...?
    1234jaime
      I try to explain it ...
      All I want to do is assign a string( the name of the symbol) to a same variable in several symbols :
      var simbolo = "entrantes_sym";
      var simbolo ="postres_sym";
      And then hide this symbol with the new variable created :
      sym.getComposition().getStage().$(simbolo).hide();
      but don't work... help please!!!!!
        • 1. Re: Could I hide a symbol with the name of a variable...?
          joel_pau Level 5
          Your code is correct. I just check.
          Is the browser console empty?
          It can be:
          var simbolo = "aName";
          sym.getComposition().getStage().getSymbol(simbolo).getSymbolElement().hide();
          or
          • 2. Re: Could I hide a symbol with the name of a variable...?
            1234jaime Level 1
            Solved!!!!!!!! uuffffff...........
            I have several symbols on stage called :
            entrantes_sym
            postres_sym
            platos_sym
            and i declare  the same variable in all stage symbols :
            var simbolo = "postres_sym";
            sym.setVariable("simbolo", simbolo);
            then inside of symbol called swipe_sym i put this code :
            var stage = sym.getParentSymbol();
            var sym2 = stage.getVariable("simbolo");
            sym.getComposition().getStage().$(sym2).hide();
            swipe_sym symbol is a child symbol of all the stage symbols.
            and the code works in all the symbols with only a few lines of code...
            Thanks.
