2 Replies Latest reply on Jan 14, 2016 8:31 AM by Mark Lindberg
    Overflow leader
    AgustinFC
      I am trying to use the Overflow leader as described in following guide:
      LiveCycle ES2 * Adobe LiveCycle Designer ES2
      My problem is that the header to be repeated is dynamic. I mean, my scenario should be something like this:
      Page1:
                Header1
      Content1
      Page2:
                Header2
      Content2 (overflow)
      Page3:
                Header2
      Content2 (cont)
      I am not able to populate the Headers. I tried with referenced object, using javascript, but it fails.
      Any help with this issue?
      Thanks in advance,
      Kind regards,
      Agustín.
        • 1. Re: Overflow leader
          AgustinFC Level 1
          Is there any way to get the same dinamyc header when content overflows?
          Thanks in advance,
          Agustín.
          • 2. Re: Overflow leader
            Mark Lindberg Level 2
            Agustin,
            I have had success using a 'regular' subform as the Overflow Leader.
            In the initialize event, I set the subform as hidden.
            This subform is defined at the same level in the hierarchy as the flowing main subform.
            In the Layout:Ready event, I test the xfa.layout.page(this) property, and if > 1 - set presence as visible.
            Reference the subform as the Overflow Leader in the Pagination Properties of your flowing subform.
            I use global bindings on the fields within the overflow leader so that the data is in sync with the XML payload being merged with the template.
            Initialize:
            this.presence = "hidden";
            Layout:Ready:
            if ( xfa.layout.page(this) > 1 )
                this.presence = "visible";
            else
            Hope this helps
            Mark
