6 Replies Latest reply on Feb 23, 2016 12:37 PM by vesuvius_007
    Color Management - After Effects CC 13.6.1
      After Effects CC version 13.6.1 is no longer letting us change settings on Quicktime movs under Interpret Footate>Main>Color Management.  The embedded profile for all Quicktime movs I've tested is listed as REC 709, and none of the options below that can be modified.  In previous versions, the embedded profile was listed as "None" for the same files and the options below could be adjusted.  I've tried several different test files and it seems that AE is seeing all Quicktime movs with REC 709 embedded profile, regardless of how it was exported, and will not allow that to be changed.  This is obviously causing us some workflow issues.  Is this a bug, or am I doing something wrong?  Thanks for any input.
