1 Reply Latest reply on Dec 26, 2015 8:45 AM by JFPhoton
    Premiere Crashes on El Capitan 10.11.2
    yunf35281515
      Premiere Pro CC 2015 frequently crashes on El Capitan 10.11.2 when copying large portion of data from CPU to GPU, when using it on a iMac 5K late 2014. I've written code myself to emulate the process and similar crashes happen. Is there a solution for this?
      In the crash log below, the AMDRadeonX4000GLDriver would hit a SIGABRT.
      Process:               Adobe Premiere Pro CC 2015 [5929]
      Path:                  /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/MacOS/Adobe Premiere Pro CC 2015
      Identifier:            com.adobe.AdobePremierePro
      Version:               9.1.0 (9.1.0)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Adobe Premiere Pro CC 2015 [5929]
      User ID:               501
      Date/Time:             2015-12-26 08:02:39.485 -0500
      OS Version:            Mac OS X 10.11.2 (15C50)
      Report Version:        11
      Anonymous UUID:        D20918D2-7E41-DDD0-679A-4AA5834EB6CB
      Sleep/Wake UUID:       CCC46C87-F11E-4D39-A4C0-C8E711311FAF
      Time Awake Since Boot: 10000 seconds
      Time Since Wake:       1700 seconds
      System Integrity Protection: disabled
      Crashed Thread:        8
      Exception Type:        EXC_CRASH (SIGABRT)
      Exception Codes:       0x0000000000000000, 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      Application Specific Information:
      abort() called
      Application Specific Signatures:
      Graphics hardware encountered an error and was reset: 0x0000000e
      Global Trace Buffer (reverse chronological seconds):
      3061.532334  CFNetwork                 0x00007fff9825ca5b TCP Conn 0x121d8a6f0 SSL Handshake DONE
      3061.597937  CFNetwork                 0x00007fff9825c937 TCP Conn 0x121d8a6f0 starting SSL negotiation
      3061.598038  CFNetwork                 0x00007fff9825b303 TCP Conn 0x121d8a6f0 complete. fd: 38, err: 0
      3061.598217  CFNetwork                 0x00007fff982e9b1d TCP Conn 0x121d8a6f0 event 1. err: 0
      3062.077632  CFNetwork                 0x00007fff9825a5d3 TCP Conn 0x121d8a6f0 started
      3095.694976  CFNetwork                 0x00007fff9825ca5b TCP Conn 0x1331e4c00 SSL Handshake DONE
      3095.759941  CFNetwork                 0x00007fff9825c937 TCP Conn 0x1331e4c00 starting SSL negotiation
      3095.760047  CFNetwork                 0x00007fff9825b303 TCP Conn 0x1331e4c00 complete. fd: 46, err: 0
      3095.760195  CFNetwork                 0x00007fff982e9b1d TCP Conn 0x1331e4c00 event 1. err: 0
      3095.826089  CFNetwork                 0x00007fff9825a5d3 TCP Conn 0x1331e4c00 started
      3095.892891  CFNetwork                 0x00007fff9825ca5b TCP Conn 0x12f2985e0 SSL Handshake DONE
      3095.993657  CFNetwork                 0x00007fff9825c937 TCP Conn 0x12f2985e0 starting SSL negotiation
      3095.993802  CFNetwork                 0x00007fff9825b303 TCP Conn 0x12f2985e0 complete. fd: 40, err: 0
      3095.993867  CFNetwork                 0x00007fff982e9b1d TCP Conn 0x12f2985e0 event 1. err: 0
      3096.091089  CFNetwork                 0x00007fff9825a5d3 TCP Conn 0x12f2985e0 started
      3096.231433  CFNetwork                 0x00007fff9825ca5b TCP Conn 0x118c36520 SSL Handshake DONE
      3096.440797  CFNetwork                 0x00007fff9825c937 TCP Conn 0x118c36520 starting SSL negotiation
      3096.440967  CFNetwork                 0x00007fff9825b303 TCP Conn 0x118c36520 complete. fd: 40, err: 0
      3096.440998  CFNetwork                 0x00007fff982e9b1d TCP Conn 0x118c36520 event 1. err: 0
      3096.594126  CFNetwork                 0x00007fff9825a5d3 TCP Conn 0x118c36520 started
      3134.463032  libsystem_trace.dylib     0x00007fff92d590fa dyld_image_header_containing_address(0x11c5e9d80) failed
      Thread 0:: Dispatch queue: com.apple.main-thread
      0   com.adobe.dvacore.framework   0x00000001002d5bb1 boost::shared_lock<dvacore::threads::AccessController>::try_lock() + 1
      1   com.adobe.dvacore.framework   0x00000001003f843a dvacore::utility::AllocatorManager<48ul, 4160ul, 66624ul, 1ul>::TrySimpleAllocate() + 42
      2   com.adobe.dvacore.framework   0x00000001003f7fdc dvacore::utility::AllocatorManager<48ul, 4160ul, 66624ul, 1ul>::DoAllocate() + 28
      3   com.adobe.dvacore.framework   0x00000001003f75f1 dvacore::utility::AllocatorManager<48ul, 4160ul, 66624ul, 1ul>::Allocate(unsigned long) + 337
      4   com.adobe.dvacore.framework   0x00000001003acdbd dvacore::utility::SmallBlockAllocator::Allocate(unsigned long) + 141
      5   com.adobe.dvaui.framework     0x00000001047ceb13 dvaui::drawbot::OSSupplier::NewBrush(dvaui::drawbot::ColorRGBA const&) const + 19
      6   com.adobe.UIFramework.framework 0x00000001054178df UIF::DC::DrawString(UIF::Font const&, ASL::ParamRect<int> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::ParamColor<RGBColor> const&, UIF::Align, UIF::VerticalAlignment, UIF::Truncate) + 239
      7   com.adobe.HandlerProject.framework 0x000000010cbda488 HandlerProject::ProjectPathView::PaintSelf(UIF::DC&) + 920
      8   com.adobe.UIFramework.framework 0x00000001054d78af UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 1039
      9   com.adobe.dvaui.framework     0x0000000104869406 dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 326
      10  com.adobe.dvaui.framework     0x00000001048696de dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 590
      11  com.adobe.dvaui.framework     0x0000000104869c65 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 821
      12  com.adobe.dvaui.framework     0x0000000104867b0f dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 47
      13  com.adobe.UIFramework.framework 0x00000001054d78ba UIF::SubViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 1050
      14  com.adobe.dvaui.framework     0x0000000104869406 dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 326
      15  com.adobe.dvaui.framework     0x00000001048696de dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 590
      16  com.adobe.dvaui.framework     0x0000000104869c65 dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 821
      17  com.adobe.dvaui.framework     0x0000000104867b0f dvaui::ui::UI_Node::UI_Draw(dvaui::drawbot::Drawbot*) const + 47
      18  com.adobe.UIFramework.framework 0x00000001054dfa12 UIF::TabViewImpl::UI_Draw(dvaui::drawbot::Drawbot*) const + 674
      19  com.adobe.dvaui.framework     0x00000001048ff382 void dvaui::drawbot::InvokeDrawbot<dvaui::ui::OS_View, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*>, NSView*>(dvaui::ui::OS_View const&, std::const_mem_fun1_ref_t<void, dvaui::ui::OS_View, dvaui::drawbot::Drawbot*> const&, dvaui::drawbot::SupplierInterface const&, NSView*, __HIShape const*, dvaui::drawbot::SurfaceInterface*, std::vector<dvacore::geom::RectT<int>, std::allocator<dvacore::geom::RectT<int> > >*, bool) + 946
      20  com.adobe.dvaui.framework     0x00000001048ee8eb dvaui::ui::OS_View::UI_HandlePlatformDrawEvent(dvaui::drawbot::SurfaceInterface*) + 379
      21  com.adobe.dvacore.framework   0x00000001001ece8c int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      22  com.adobe.Frontend.framework   0x00000001008c50b9 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 41
      23  com.adobe.dvacore.framework   0x00000001001ecf23 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 99
      24  com.adobe.dvacore.framework   0x00000001001ee480 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 160
      25  com.adobe.dvaui.framework     0x00000001048f90db -[DVAMacContainerView drawRect:] + 155
      26  com.apple.AppKit               0x00007fff825dfbd6 -[NSView _drawRect:clip:] + 3550
      27  com.apple.AppKit               0x00007fff825dcd21 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 3136
      28  com.apple.AppKit               0x00007fff825dd7b1 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 5840
      29  com.apple.AppKit               0x00007fff825dd7b1 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 5840
      30  com.apple.AppKit               0x00007fff825dd7b1 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 5840
      31  com.apple.AppKit               0x00007fff825dbc0c -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topVi ew:] + 334
      32  com.apple.AppKit               0x00007fff825d81ef -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2449
      33  com.apple.AppKit               0x00007fff82592971 -[NSView displayIfNeeded] + 1950
      34  com.apple.AppKit               0x00007fff8259219c -[NSWindow displayIfNeeded] + 232
      35  com.apple.AppKit               0x00007fff82d0e6da ___NSWindowGetDisplayCycleObserver_block_invoke6367 + 476
      36  com.apple.AppKit               0x00007fff829550d6 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke + 738
      37  com.apple.QuartzCore           0x00007fff92423b5d CA::Transaction::run_commit_handlers(CATransactionPhase) + 85
      38  com.apple.QuartzCore           0x00007fff922bdc7c CA::Context::commit_transaction(CA::Transaction*) + 160
      39  com.apple.QuartzCore           0x00007fff922bda24 CA::Transaction::commit() + 508
      40  com.apple.QuartzCore           0x00007fff922cc917 CA::Transaction::observer_callback(__CFRunLoopObserver*, unsigned long, void*) + 71
      41  com.apple.CoreFoundation       0x00007fff948ade37 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
      42  com.apple.CoreFoundation       0x00007fff948adda7 __CFRunLoopDoObservers + 391
      43  com.apple.CoreFoundation       0x00007fff9489f358 CFRunLoopRunSpecific + 328
      44  com.apple.HIToolbox           0x00007fff8e48f935 RunCurrentEventLoopInMode + 235
      45  com.apple.HIToolbox           0x00007fff8e48f677 ReceiveNextEventCommon + 184
      46  com.apple.HIToolbox           0x00007fff8e48f5af _BlockUntilNextEventMatchingListInModeWithFilter + 71
      47  com.apple.AppKit               0x00007fff8258f0ee _DPSNextEvent + 1067
      48  com.apple.AppKit               0x00007fff8295b943 -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
      49  com.apple.AppKit               0x00007fff82584fc8 -[NSApplication run] + 682
      50  com.adobe.Frontend.framework   0x000000010095045a FE::MacApplication::RunSelf() + 42
      51  com.adobe.Frontend.framework   0x000000010089df76 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 6614
      52  com.adobe.Frontend.framework   0x0000000100951d9e FE::AppMain(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 174
      53  com.adobe.Frontend.framework   0x0000000100952a65 FE::Run(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int) + 581
      54  com.adobe.AdobePremierePro     0x0000000100002152 main + 690
      55  com.adobe.AdobePremierePro     0x0000000100001e94 start + 52
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib         0x00007fff83239ff6 kevent_qos + 10
      1   libdispatch.dylib             0x00007fff8393c099 _dispatch_mgr_invoke + 216
      2   libdispatch.dylib             0x00007fff8393bd01 _dispatch_mgr_thread + 52
      Thread 2:: OGL Profiler
      0   libsystem_kernel.dylib         0x00007fff83233386 mach_msg_trap + 10
      1   libsystem_kernel.dylib         0x00007fff832327c7 mach_msg + 55
      2   com.apple.opengl               0x00007fff91ea1a73 glcDebugListener + 333
      3   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      4   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      5   libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 3:
      0   libsystem_kernel.dylib         0x00007fff83239fc6 kevent + 10
      1   com.adobe.dvatransport.framework 0x00000001012def91 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 241
      2   com.adobe.dvatransport.framework 0x00000001012deb6c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 284
      3   com.adobe.dvatransport.framework 0x00000001012de6d8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
      4   com.adobe.dvatransport.framework 0x00000001012cd1b2 SkyConnectionEnv::MainLoop() + 162
      5   com.adobe.dvatransport.framework 0x00000001012ccb49 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      6   com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      7   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      8   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      9   libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 4:
      0   libsystem_kernel.dylib         0x00007fff83238eb2 __psynch_cvwait + 10
      1   libsystem_pthread.dylib       0x00007fff820b6150 _pthread_cond_wait + 767
      2   com.adobe.dvatransport.framework 0x00000001012dec0b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 443
      4   com.adobe.dvatransport.framework 0x00000001012de47a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
      5   com.adobe.dvatransport.framework 0x00000001012df6e3 boost_asio_detail_posix_thread_function + 19
      6   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      7   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      8   libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 5:
      2   com.apple.CoreServices.CarbonCore 0x00007fff8aea5f2c TSWaitOnCondition + 108
      3   com.apple.CoreServices.CarbonCore 0x00007fff8aea612b TSWaitOnConditionTimedRelative + 171
      4   com.apple.CoreServices.CarbonCore 0x00007fff8ae7e5ce MPWaitOnQueue + 192
      5   com.adobe.dvacore.framework   0x00000001002e5998 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
      6   com.adobe.dvacore.framework   0x00000001002e2cf8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
      7   com.adobe.dvacore.framework   0x00000001002df6ea dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 202
      8   com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      9   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      10  libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      11  libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 6:
      2   com.adobe.GPUFoundation.framework 0x000000010a65ced6 void boost::condition_variable_any::wait<boost::unique_lock<boost::mutex> >(boost::unique_lock<boost::mutex>&) + 70
      3   com.adobe.GPUFoundation.framework 0x000000010a65a98e GF::Device::AcquireExclusiveAccess() + 126
      4   com.adobe.PlayerMediaCore.framework 0x000000013ba8b8bd AdobePlayer::PlayerDisplay::ApplicationLostFocus() + 381
      5   com.adobe.PlayerMediaCore.framework 0x000000013ba9fb8e AdobePlayer::PlayerMain::OnActivate(pmActivateRec const*) + 126
      6   com.adobe.PlayerMediaCore.framework 0x000000013baa5a0e PrPlayModule<AdobePlayer::PlayerMain>::PlayEntry(int, pmStdParms*, void*, void*) + 606
      7   com.adobe.PlayerMediaCore.framework 0x000000013baa57a0 xPlayEntry + 16
      8   com.adobe.PlayerHost.framework 0x00000001062425d1 ML::CallPlayerModuleGuarded(int (*)(int, pmStdParms*, void*, void*), int, pmStdParms*, void*, void*, int*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 273
      9   com.adobe.PlayerHost.framework 0x00000001062407d8 ML::PlayerModule::CallPlugin(int, void*, void*) + 152
      10  com.adobe.PlayerHost.framework 0x00000001062506c7 ML::VideoPlayer::OnPlayerThreadDeactivate(PrActivationEvent, boost::shared_ptr<dvacore::threads::Gate> const&) + 311
      11  com.adobe.PlayerHost.framework 0x0000000106246b94 ML::PlayModuleThreadQueue::ExecuteDeferredCall(ASL::ObjectPtr<ML::DeferredCallBase, ASL::AtomicValue>) + 340
      12  com.adobe.PlayerHost.framework 0x0000000106245c66 ML::PlayModuleThreadQueue::ServiceQueue() + 326
      13  com.adobe.dvacore.framework   0x00000001002e2d2a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 202
      14  com.adobe.dvacore.framework   0x00000001002df6ea dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 202
      15  com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      16  libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      17  libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      18  libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 7:
      Thread 8 Crashed:
      0   libsystem_kernel.dylib         0x00007fff83239002 __pthread_kill + 10
      1   libsystem_pthread.dylib       0x00007fff820b75c5 pthread_kill + 90
      2   libsystem_c.dylib             0x00007fff8611b787 __abort + 145
      3   libsystem_c.dylib             0x00007fff8611b6f6 abort + 144
      4   libGPUSupportMercury.dylib     0x00007fff920a3e5c gpusGenerateCrashLog + 158
      5   com.apple.AMDRadeonX4000GLDriver 0x000000011c31ee5c 0x11c2f9000 + 155228
      6   libGPUSupportMercury.dylib     0x00007fff920a4818 gpusQueueSubmitDataBuffers + 162
      7   com.apple.AMDRadeonX4000GLDriver 0x000000011c34acf8 0x11c2f9000 + 335096
      8   com.apple.AMDRadeonX4000GLDriver 0x000000011c34abde 0x11c2f9000 + 334814
      9   com.apple.AMDRadeonX4000GLDriver 0x000000011c34afa8 gldFlushQueue + 37
      10  com.apple.opencl               0x00007fff970ef8fa 0x7fff970e9000 + 26874
      11  com.apple.opencl               0x00007fff9710c5f2 clFlush + 135
      12  com.adobe.GPUFoundation.framework 0x000000010a6843ab GF::OpenCLCommandQueue::CopyHostToDevice(void*, void*, unsigned long, boost::shared_ptr<GF::Event>*, bool) + 139
      13  com.adobe.GPUFoundation.framework 0x000000010a6de7df GF::CopyToDevice(boost::shared_ptr<GF::Device> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame> const&, bool) + 1423
      14  com.adobe.RendererGPU.framework 0x000000011629ff14 RendererGPU::UploadNode::LoadMedia(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, bool, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 1748
      15  com.adobe.RendererGPU.framework 0x00000001162a14b8 RendererGPU::UploadNode::Process(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&) + 184
      16  com.adobe.RendererGPU.framework 0x00000001162892d8 RendererGPU::FilterNode::ProcessFrameOnDevice(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 1528
      17  com.adobe.RendererGPU.framework 0x0000000116268b3d RendererGPU::TransformRenderParamsBaseNode::ProcessFrameOnDevice(ASL::InterfaceRef<IRende rNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 77
      18  com.adobe.RendererGPU.framework 0x00000001163273dc RenderNodeBase::ProcessFrameOnDevice(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 76
      19  com.adobe.RendererGPU.framework 0x00000001162890c1 RendererGPU::FilterNode::ProcessFrameOnDevice(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 993
      20  com.adobe.RendererGPU.framework 0x0000000116292403 RendererGPU::SelectInputBaseNode::Process(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&) + 115
      21  com.adobe.RendererGPU.framework 0x000000011628f7c8 RendererGPU::MediaNode::Process(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&) + 24
      22  com.adobe.RendererGPU.framework 0x00000001162892d8 RendererGPU::FilterNode::ProcessFrameOnDevice(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 1528
      23  com.adobe.RendererGPU.framework 0x0000000116284968 RendererGPU::CompositorNode::Process(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&) + 1400
      24  com.adobe.RendererGPU.framework 0x00000001162892d8 RendererGPU::FilterNode::ProcessFrameOnDevice(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&) + 1528
      25  com.adobe.RendererGPU.framework 0x000000011627aabb RendererGPU::(anonymous namespace)::RendererGPU::ProduceFrame(ASL::InterfaceRef<IRenderNode, IRenderNode> const&, RenderParams const&, boost::shared_ptr<RenderResults> const&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, std::string*, ASL::ParamRect<int>) + 1435
      26  com.adobe.PlayerMediaCore.framework 0x000000013baab71b AdobePlayer::RenderRequest::ProduceFrame(ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, ASL::InterfaceRef<MF::IVideoFrame, MF::IVideoFrame>&, RenderParams const&, std::string*, ASL::ParamRect<int>) + 75
      27  com.adobe.PlayerMediaCore.framework 0x000000013ba90079 AdobePlayer::PlayerDisplay::PresentRenderRequestImpl(boost::shared_ptr<AdobePlayer::Rende rRequest> const&) + 2121
      28  com.adobe.PlayerMediaCore.framework 0x000000013ba93e41 AdobePlayer::PlayerDisplay::PresentLastCompletedRenderRequestImpl() + 1553
      29  com.adobe.dvacore.framework   0x00000001002e2d2a dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 202
      30  com.adobe.dvacore.framework   0x00000001002df6ea dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 202
      31  com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      32  libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      33  libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      34  libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 9:
      2   com.adobe.ImporterF65.framework 0x0000000131442906 void boost::condition_variable_any::wait<boost::mutex>(boost::mutex&) + 70
      3   com.adobe.ImporterF65.framework 0x0000000131454bb3 RequestManager::decodeFunc(void*) + 275
      4   com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      5   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      6   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      7   libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 10:
      Thread 11:
      0   libsystem_kernel.dylib         0x00007fff832333da semaphore_timedwait_trap + 10
      1   com.apple.CoreServices.CarbonCore 0x00007fff8ae7e7da MPWaitOnSemaphore + 77
      2   com.adobe.ImporterRED.framework 0x0000000132ec0dfe REDCORE::ConsumerProducer<R3DSDK::AsyncJob, R3DSDK::AsyncData>::DoWork(void*, void*, bool*) + 174
      3   com.adobe.ImporterRED.framework 0x0000000132e71588 REDCORE::Thread::ThreadFunc(void*) + 24
      4   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      5   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      6   libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 12:
      2   com.adobe.ImporterRED.framework 0x0000000132ec0bee REDCORE::ConsumerProducer<R3DSDK::AsyncJobPart, R3DSDK::AsyncData>::DoWork(void*, void*, bool*) + 174
      Thread 13:
      Thread 14:
      Thread 15:
      Thread 16:
      Thread 17:
      Thread 18:
      Thread 19:
      Thread 20:
      2   com.apple.CoreFoundation       0x00007fff948a0624 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation       0x00007fff9489faec __CFRunLoopRun + 1356
      4   com.apple.CoreFoundation       0x00007fff9489f338 CFRunLoopRunSpecific + 296
      5   com.apple.AVCVideoServices     0x000000012ce96db2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
      Thread 21:
      0   libsystem_kernel.dylib         0x00007fff83239206 __semwait_signal + 10
      1   libsystem_c.dylib             0x00007fff8613cd17 nanosleep + 199
      2   com.adobe.ScriptLayerPPro.framework 0x0000000107cd6a48 ScObjects::Thread::wait(unsigned int) + 56
      3   com.adobe.ScriptLayerPPro.framework 0x0000000107cba9cc ScObjects::BridgeTalkThread::run() + 252
      4   com.adobe.ScriptLayerPPro.framework 0x0000000107cd6505 ScObjects::Thread::go(void*) + 165
      Thread 22:
      0   libsystem_kernel.dylib         0x00007fff832390b6 __recvfrom + 10
      1   VulcanMessage5.dylib           0x000000011294b386 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
      2   VulcanMessage5.dylib           0x000000011294a5fd vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 21
      3   VulcanMessage5.dylib           0x00000001129499b8 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 82
      4   VulcanMessage5.dylib           0x00000001129498ee vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
      5   VulcanMessage5.dylib           0x0000000112944498 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 46
      6   VulcanMessage5.dylib           0x0000000112944936 vcfoundation::io::Serializer::InternalDeserialize() + 30
      7   VulcanMessage5.dylib           0x00000001129448dd vcfoundation::io::Serializer::Deserialize() + 9
      8   VulcanMessage5.dylib           0x0000000112948762 vcfoundation::ncomm::Connection::ReadIn() + 22
      9   VulcanMessage5.dylib           0x0000000112948489 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 37
      10  VulcanMessage5.dylib           0x000000011294810a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
      11  VulcanMessage5.dylib           0x000000011294805d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
      12  VulcanMessage5.dylib           0x000000011293ae66 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
      13  VulcanMessage5.dylib           0x000000011293b91f adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 1005
      14  VulcanMessage5.dylib           0x0000000112949288 vcfoundation::thread::AbstractThread::Run() + 50
      15  VulcanMessage5.dylib           0x000000011294ada9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
      Thread 23:
      1   libsystem_pthread.dylib       0x00007fff820b6186 _pthread_cond_wait + 821
      2   com.apple.CoreServices.CarbonCore 0x00007fff8aea6113 TSWaitOnConditionTimedRelative + 147
      3   com.apple.CoreServices.CarbonCore 0x00007fff8ae7e5ce MPWaitOnQueue + 192
      4   com.adobe.dvacore.framework   0x00000001002e5998 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 152
      5   com.adobe.dvacore.framework   0x00000001002e2cf8 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 152
      6   com.adobe.dvacore.framework   0x00000001002df6ea dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 202
      7   com.adobe.boost_threads.framework 0x0000000100170ee5 boost::(anonymous namespace)::thread_proxy(void*) + 133
      8   libsystem_pthread.dylib       0x00007fff820b5c13 _pthread_body + 131
      9   libsystem_pthread.dylib       0x00007fff820b5b90 _pthread_start + 168
      10  libsystem_pthread.dylib       0x00007fff820b3375 thread_start + 13
      Thread 24:
      2   com.adobe.headlights.LogSessionFramework 0x0000000100cc91ac boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
      3   com.adobe.headlights.LogSessionFramework 0x0000000100cc7a6e boost::this_thread::hiden::sleep_until(timespec const&) + 78
      4   com.adobe.headlights.LogSessionFramework 0x0000000100c70523 RealTimeProcessor::Sleep(int) + 243
      5   com.adobe.headlights.LogSessionFramework 0x0000000100c6eb32 RealTimeProcessor::WorkerThread() + 2660
      6   com.adobe.headlights.LogSessionFramework 0x0000000100cc6aca boost::(anonymous namespace)::thread_proxy(void*) + 138
      Thread 25:: com.apple.NSURLConnectionLoader
      5   com.apple.CFNetwork           0x00007fff982216e9 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
      6   com.apple.Foundation           0x00007fff944f4c6f __NSThread__start__ + 1351
      Thread 26:
      2   com.apple.CoreServices.CarbonCore 0x00007fff8aea2f5e TS_exception_listener_thread + 100
      Thread 27:: com.apple.CFSocket.private
      0   libsystem_kernel.dylib         0x00007fff83239176 __select + 10
      1   com.apple.CoreFoundation       0x00007fff948ec16a __CFSocketManager + 762
      Thread 28:: com.apple.NSEventThread
      5   com.apple.AppKit               0x00007fff8264e065 _NSEventThread + 149
      Thread 29:: Dispatch queue: com.apple.notify.background.local.notification
      2   libsystem_notify.dylib         0x00007fff8fc2bdca __notify_register_mach_port_block_invoke_3 + 89
      3   libdispatch.dylib             0x00007fff83941871 _dispatch_call_block_and_release + 12
      4   libdispatch.dylib             0x00007fff8393633f _dispatch_client_callout + 8
      5   libdispatch.dylib             0x00007fff8393af6f _dispatch_queue_drain + 754
      6   libdispatch.dylib             0x00007fff8394163b _dispatch_queue_invoke + 549
      7   libdispatch.dylib             0x00007fff8393633f _dispatch_client_callout + 8
      8   libdispatch.dylib             0x00007fff8393a1cf _dispatch_root_queue_drain + 1890
      9   libdispatch.dylib             0x00007fff83939a34 _dispatch_worker_thread3 + 91
      10  libsystem_pthread.dylib       0x00007fff820b568f _pthread_wqthread + 1129
      11  libsystem_pthread.dylib       0x00007fff820b3365 start_wqthread + 13
      Thread 30:
      5   com.apple.Foundation           0x00007fff9443b48d -[NSConnection run] + 149
      Thread 31:
      5   com.apple.Foundation           0x00007fff94343f86 -[NSConcreteTask waitUntilExit] + 205
      6   com.adobe.PlugPlug             0x000000010b133cf6 -[HtmlEngineMonitor monitorThreadProc] + 115
      7   com.apple.Foundation           0x00007fff944f4c6f __NSThread__start__ + 1351
      Thread 32:
      1   com.adobe.MediaFoundation.framework 0x000000010196694d MF::DirectoryChangeMonitor::(anonymous namespace)::EventQueueThreadProc(void*) + 525
      Thread 33:
      Thread 34:
      Thread 35:
      Thread 36:
      Thread 37:
      0   libsystem_kernel.dylib         0x00007fff832396de __workq_kernreturn + 10
      1   libsystem_pthread.dylib       0x00007fff820b5729 _pthread_wqthread + 1283
      2   libsystem_pthread.dylib       0x00007fff820b3365 start_wqthread + 13
      Thread 38:
      Thread 39:
      Thread 40:: com.apple.audio.IOThread.client
      2   com.apple.audio.CoreAudio     0x00007fff96f755ee HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
      3   com.apple.audio.CoreAudio     0x00007fff96f7557c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
      4   com.apple.audio.CoreAudio     0x00007fff96f73939 HALC_ProxyIOContext::IOWorkLoop() + 1149
      5   com.apple.audio.CoreAudio     0x00007fff96f733ee HALC_ProxyIOContext::IOThreadEntry(void*) + 88
      6   com.apple.audio.CoreAudio     0x00007fff96f732c3 HALB_IOThread::Entry(void*) + 75
      Thread 41:
      Thread 42:: Dispatch queue: NSCGSDisableUpdates
      2   com.apple.CoreGraphics         0x00007fff83ed0b0b _CGSReenableUpdateForConnection + 92
      3   com.apple.CoreGraphics         0x00007fff83ed07e1 CGSReenableUpdateToken + 532
      4   libdispatch.dylib             0x00007fff83941871 _dispatch_call_block_and_release + 12
      5   libdispatch.dylib             0x00007fff8393633f _dispatch_client_callout + 8
      6   libdispatch.dylib             0x00007fff8393af6f _dispatch_queue_drain + 754
      7   libdispatch.dylib             0x00007fff8394163b _dispatch_queue_invoke + 549
      8   libdispatch.dylib             0x00007fff8393633f _dispatch_client_callout + 8
      9   libdispatch.dylib             0x00007fff8393a1cf _dispatch_root_queue_drain + 1890
      10  libdispatch.dylib             0x00007fff83939a34 _dispatch_worker_thread3 + 91
      11  libsystem_pthread.dylib       0x00007fff820b568f _pthread_wqthread + 1129
      12  libsystem_pthread.dylib       0x00007fff820b3365 start_wqthread + 13
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:
      1   libdispatch.dylib             0x00007fff83941b9b _dispatch_semaphore_wait_slow + 149
      2   libdispatch.dylib             0x00007fff8393bc4f _dispatch_worker_thread + 148
      Thread 47:
      Thread 8 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x000070000083ed48  rdx: 0x0000000000000000
        rdi: 0x000000000000d103  rsi: 0x0000000000000006  rbp: 0x000070000083ed70  rsp: 0x000070000083ed48
         r8: 0x0000000000000000   r9: 0x0000000000989680  r10: 0x0000000008000000  r11: 0x0000000000000206
        r12: 0x0000000117851600  r13: 0x000000017efe8700  r14: 0x0000700000841000  r15: 0x0000000117851600
        rip: 0x00007fff83239002  rfl: 0x0000000000000206  cr2: 0x0000700000113798
      Logical CPU:     0
      Error Code:      0x02000148
      Trap Number:     133
      Binary Images:
             0x100000000 -        0x100005ff7 +com.adobe.AdobePremierePro (9.1.0 - 9.1.0) <C1A3181D-0098-3823-B9D4-E7DF8F9016A4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/MacOS/Adobe Premiere Pro CC 2015
             0x100010000 -        0x100013fff +com.adobe.AdobeCrashReporter (7.2 - 7.2.3) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x10001b000 -        0x10011dfff +com.adobe.amtlib (9.0.0.89 - 9.0.0.89) <EBF9B7FD-5C40-31E1-976E-D5B5608080B9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x100130000 -        0x100133ff7 +com.adobe.PRM.framework (9.1.0 - 9.1.0.174) <86C5FCBF-2A96-3439-9E09-8A4B3209E235> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x10013f000 -        0x100144ff7 +com.adobe.boost_system.framework (9.1.0 - 9.1.0.174) <23D4DB49-DC0B-3267-B415-5951B48CDA62> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x100150000 -        0x100158ff7 +com.adobe.boost_date_time.framework (9.1.0 - 9.1.0.174) <5C055CA3-62A8-38DC-9B11-5D5E13372275> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x10016f000 -        0x10017efff +com.adobe.boost_threads.framework (9.1.0 - 9.1.0.174) <F38B746E-97D7-3849-BBD3-9897133046B9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x100199000 -        0x1001a7fff +com.adobe.boost_filesystem.framework (9.1.0 - 9.1.0.174) <60C53697-69F6-3C20-B297-F39C519C9D25> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
             0x1001ba000 -        0x1004b2fff +com.adobe.dvacore.framework (9.1.0 - 9.1.0.174) <E3FBCA69-B076-3544-9AD1-7EC6DA1B1F2C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x100731000 -        0x10076ffff +com.adobe.dvamediatypes.framework (9.1.0 - 9.1.0.174) <BC39DCEE-29B1-3A69-97AD-B24930E49E0A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x1007a8000 -        0x1007fafff +com.adobe.ASLFoundation.framework (9.1.0 - 9.1.0.174) <DD2ABF0F-FC32-3554-963A-C4EF66EF48C0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x100865000 -        0x1009c0ff7 +com.adobe.Frontend.framework (9.1.0 - 9.1.0.174) <2280DD25-67E1-3827-9EFB-5D72010B9233> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
             0x100b2c000 -        0x100b7aff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
             0x100be3000 -        0x100d22ff7 +com.adobe.headlights.LogSessionFramework (7.3.1.70) <408F19FE-B672-3E82-89B6-B782E000D2B0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x100dd6000 -        0x100f4cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 111 - 79.158325) <0DF03DF6-1105-3715-846B-F110CD7ABF7F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x10102f000 -        0x10118dff7 +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 168 - 79.158325) <54620EAA-BE33-39D8-85E2-3B6233A81517> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x101259000 -        0x101269ff7 +com.adobe.ASLMessaging.framework (9.1.0 - 9.1.0.174) <B5D56726-854E-3D26-B9D0-53BCFE760649> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x101282000 -        0x101283ff7 +com.adobe.Memory.framework (9.1.0 - 9.1.0.174) <62818A45-2F55-3EBA-87C1-2E9D276A5F33> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x10128a000 -        0x101299ff7 +com.adobe.ASLUnitTesting.framework (9.1.0 - 9.1.0.174) <8C845CE0-6D66-318C-9077-9EA26C2275F7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x1012b3000 -        0x10131fff7 +com.adobe.dvatransport.framework (9.1.0 - 9.1.0.174) <2D869A9D-A174-30F8-85A8-59436AAB9879> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x1013b3000 -        0x1013e0fff +com.adobe.dvamarshal.framework (9.1.0 - 9.1.0.174) <3C27833E-8998-3B21-AA1B-39E221B42846> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x101426000 -        0x10169dfff +com.adobe.dynamiclink.framework (9.1.0 - 9.1.0.174) <0D30D8C6-7C69-3D5D-A099-DED5067AA6D5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x10190d000 -        0x1019b3ff7 +com.adobe.MediaFoundation.framework (9.1.0 - 9.1.0.174) <B3ABCEA7-2C13-34E1-9FA0-85062F2CF69F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x101a77000 -        0x101b1bff7 +com.adobe.AudioRenderer.framework (9.1.0 - 9.1.0.174) <C2F2AEF4-FECC-352E-82D6-406BF3975B9E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x101be9000 -        0x101ce8ff7 +com.adobe.dvacaptioning.framework (9.1.0 - 9.1.0.174) <D62AF5EE-7370-302C-B791-0B22D4273A96> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
             0x101dbf000 -        0x101e28ff7 +com.adobe.dvatemporalxmp.framework (9.1.0 - 9.1.0.174) <23E0D0F0-2917-35F1-BB07-23912E8730C5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x101e6a000 -        0x101e76fff +com.adobe.boost_signals.framework (9.1.0 - 9.1.0.174) <B71D157B-9999-3CD9-90E6-8B31C5FE73B5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x101e8e000 -        0x101f6efff +com.adobe.dvametadata.framework (9.1.0 - 9.1.0.174) <B5E42303-EA1A-3FAC-9099-FC636181CE4F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x10204c000 -        0x102f36ff7 +com.adobe.Backend.framework (9.1.0 - 9.1.0.174) <D49E2B1A-37A8-3510-A49B-24C95570351B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x103c44000 -        0x103c7cff7 +com.adobe.MLFoundation.framework (9.1.0 - 9.1.0.174) <100BE828-A1B5-3CFC-9A70-0EF3A38C52BA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x103ccc000 -        0x103e2cfef +com.adobe.ImageRenderer.framework (9.1.0 - 9.1.0.174) <110F3C12-28EC-3C91-A11B-B984A131BB26> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x103f3a000 -        0x103fb9fff +com.adobe.VideoFrame.framework (9.1.0 - 9.1.0.174) <9840B41F-F849-34BF-89D0-E95322414785> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x10402a000 -        0x10406bfff +com.adobe.PluginSupport.framework (9.1.0 - 9.1.0.174) <7ABD13A1-C13D-3041-9799-B8A6A3E6CFC6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x1040b7000 -        0x1040e3fff +com.adobe.SweetPeaSupport.framework (9.1.0 - 9.1.0.174) <6B313C56-0AFD-3280-A95F-E3D8B0C2C448> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x104125000 -        0x104177ff7 +com.adobe.TransmitHost.framework (9.1.0 - 9.1.0.174) <E5F7AA83-E0AF-3B96-A1F5-B90E5876CBF0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
             0x1041d1000 -        0x1042b4fef +com.adobe.atlaudio.framework (9.1.0 - 9.1.0.174) <BBD53B91-78A7-3396-B1A0-987A35846395> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
             0x1042e0000 -        0x104344ff7 +com.adobe.AudioSupport.framework (9.1.0 - 9.1.0.174) <C70AF499-9341-3250-8A81-0F8B57ABCFFE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x1043ae000 -        0x1043b1ff7 +com.adobe.MediaUtils.framework (9.1.0 - 9.1.0.174) <56048C6D-0E68-31A0-816F-346A96DEA97C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x1043b9000 -        0x1043fafff +com.adobe.AudioFilterHost.framework (9.1.0 - 9.1.0.174) <751BE399-9434-36D1-947D-65929AD1E8E2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x104459000 -        0x10449fff7 +com.adobe.AudioFilters.framework (9.1.0 - 9.1.0.174) <11FAC7AF-B47C-348D-A992-997D6E981F82> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x104515000 -        0x104b1cfff +com.adobe.dvaui.framework (9.1.0 - 9.1.0.174) <6AEC32DD-9B8F-3501-A08E-3B741359A027> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x1053c4000 -        0x10568fff7 +com.adobe.UIFramework.framework (9.1.0 - 9.1.0.174) <B5B1CCCF-4BE2-3DC7-9683-684D5163627B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
             0x105a32000 -        0x105b7dfff +com.adobe.VideoRenderer.framework (9.1.0 - 9.1.0.174) <911B2C69-5D8D-3100-A6C5-BEC348524820> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x105ccd000 -        0x105e85ff7 +com.adobe.ImporterHost.framework (9.1.0 - 9.1.0.174) <32A56C59-4106-38CE-9FAD-669C4F97D003> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x106034000 -        0x10613fff7 +com.adobe.ExporterHost.framework (9.1.0 - 9.1.0.174) <6F14E691-3806-3265-9BCF-0A78A883C362> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x106235000 -        0x1062a6fff +com.adobe.PlayerHost.framework (9.1.0 - 9.1.0.174) <1F9845AB-7154-382E-838E-F2F7E324E185> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x10633c000 -        0x1063abff7 +com.adobe.RecorderHost.framework (9.1.0 - 9.1.0.174) <2F368E71-68DE-3A23-BA5E-3743CF5A4ABB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
             0x106433000 -        0x106446fff +com.adobe.ProjectConverterHost.framework (9.1.0 - 9.1.0.174) <57CEB312-D101-3C47-AE87-DFCCE63124BB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
             0x10646a000 -        0x10657eff7 +com.adobe.VideoFilterHost.framework (9.1.0 - 9.1.0.174) <87BAB7C8-0E11-3591-AF56-37CE226077AD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x106681000 -        0x106698fff +com.adobe.ProjectSupport.framework (9.1.0 - 9.1.0.174) <C6BEA60F-0E07-331C-946E-261095272547> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x1066c3000 -        0x106878ff7 +com.adobe.EncoderHost.framework (9.1.0 - 9.1.0.174) <2E260C6E-0494-3590-971B-DDAE5FADA49F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x106a09000 -        0x107294fff +com.adobe.Mezzanine.framework (9.1.0 - 9.1.0.174) <7203FD16-A78B-320F-AFBD-36886C5DC9B3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
             0x107844000 -        0x1079c7ff7 +com.adobe.dvaworkspace.framework (9.1.0 - 9.1.0.174) <566F9D9F-196F-3FDA-BD29-F5E96DFE9300> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x107c3e000 -        0x107d39fff +com.adobe.ScriptLayerPPro.framework (9.1.0 - 9.1.0.174) <DC2370FE-5EF2-376E-817D-4048544E3881> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
             0x107e44000 -        0x107f06fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <BA3DD538-DDFC-3F17-BD0C-ED236538B40F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x107f57000 -        0x10800eff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <9274F8EE-BE07-3C74-9A2A-DC338B894443> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x108054000 -        0x10821cfff +com.adobe.ScriptLayerPProQE.framework (9.1.0 - 9.1.0.174) <63018F44-CAAE-39C6-9E68-3981A1144651> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
             0x1084df000 -        0x1085b0ff7 +com.adobe.PProDynamicLinkServer.framework (9.1.0 - 9.1.0.174) <7D1E9E18-275A-3A5B-9A09-FE1B57F7D390> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSe rver
             0x108715000 -        0x108751fff +com.adobe.PrRegistration.framework (9.1.0 - 9.1.0.174) <2E5A6F33-F8E8-3828-A5BB-4DDFA99B6D75> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrRegistration
             0x10878f000 -        0x108877ff7 +com.adobe.dvaeve.framework (9.1.0 - 9.1.0.174) <4796974C-435C-3028-89B2-AD35CFC33835> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x1089b8000 -        0x108de8ff7 +com.adobe.Dialogs.framework (9.1.0 - 9.1.0.174) <B83341D8-A112-377D-8EFB-E5F3E5CBA839> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
             0x1091c7000 -        0x109218fff +com.adobe.BravoInitializer.framework (9.1.0 - 9.1.0.174) <13A51FDE-C4DA-38CE-8380-E333EA3F528C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
             0x10928d000 -        0x1093dcff7 +com.adobe.ACE (AdobeACE 2.20.02.34962 - 2.20.02.34962) <A8A54AE7-8D74-32BD-A417-CA05B53358EB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x1093f2000 -        0x109737ff7 +com.adobe.AGM (AdobeAGM 4.30.58.34962 - 4.30.58.34962) <F1FE36DB-385E-3A81-AEED-E34915F5E65F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x1097a6000 -        0x1097c6ff7 +com.adobe.BIB (AdobeBIB 1.2.03.34962 - 1.2.03.34962) <31B2A685-932D-3381-940A-9F70972E53EA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x1097cf000 -        0x109af6ff7 +com.adobe.CoolType (AdobeCoolType 5.15.00.34962 - 5.15.00.34962) <02CEEA73-7375-3431-83C9-25879D530EA3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x109b3e000 -        0x109b92ff7 +com.adobe.MediaCoreUI.framework (9.1.0 - 9.1.0.174) <BA2FD0BD-4370-3207-AC3E-98A077D30DAD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x109bfd000 -        0x109e1aff7 +com.adobe.SettingsUI.framework (9.1.0 - 9.1.0.174) <B14483BF-62E2-3C2A-A5BB-E635303B3DC6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x10a101000 -        0x10a3a1fff +com.adobe.HSL.framework (9.1.0 - 9.1.0.174) <F51E712B-C577-3F5D-B54A-CB6CECEFDAC5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
             0x10a648000 -        0x10ab31fff +com.adobe.GPUFoundation.framework (9.1.0 - 9.1.0.174) <3C07EB7C-9F28-3595-8D64-337F786DE431> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
             0x10adeb000 -        0x10aec9fff +com.adobe.exo.framework (9.1.0 - 9.1.0.174) <0C37A4C3-633B-3729-BB72-322A14EB4835> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x10b050000 -        0x10b0b2fff +com.adobe.CSXSManager.framework (9.1.0 - 9.1.0.174) <41819C9D-1958-37A1-BDC9-59D384EDFCF5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
             0x10b130000 -        0x10b44bfdf +com.adobe.PlugPlug (6.1.0.158 - 6.1.0.158) <F26B79B6-22A4-38B4-8AB8-DFEEF9AE6824> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
             0x10b771000 -        0x10b7a9fff +com.adobe.HandlerAudioMiniMixer.framework (9.1.0 - 9.1.0.174) <0C513D41-7A47-3FFE-9CA0-9C859D8B83F7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniM ixer
             0x10b800000 -        0x10b8b5ff7 +com.adobe.HandlerAudioMixer.framework (9.1.0 - 9.1.0.174) <ED948452-B378-3F73-B553-148EB6BDC4EA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
             0x10b980000 -        0x10b9dcff7 +com.adobe.HandlerAudioClipMixer.framework (9.1.0 - 9.1.0.174) <7EBB1919-483E-3601-92C2-91AEC8D259E2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipM ixer
             0x10ba6a000 -        0x10bac9fff +com.adobe.HandlerCaptions.framework (9.1.0 - 9.1.0.174) <F9F33A45-2ED5-3C0D-98E9-95EFA9567779> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
             0x10bb67000 -        0x10bbeefff +com.adobe.HandlerCapture.framework (9.1.0 - 9.1.0.174) <633A19C1-D6D2-3FFE-8A2A-AA31376A9879> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
             0x10bc95000 -        0x10bd3bff7 +com.adobe.HandlerColor.framework (9.1.0 - 9.1.0.174) <A3419FB7-F74B-3F0C-9026-9AF77F1EA048> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
             0x10bdf6000 -        0x10be42ff7 +com.adobe.HandlerEditToTape.framework (9.1.0 - 9.1.0.174) <26AE2496-66D3-37CF-B139-A17766AF0E1A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
             0x10beb8000 -        0x10beedff7 +com.adobe.HandlerCSXS.framework (9.1.0 - 9.1.0.174) <04022B30-299F-3CC4-AE3E-82F34EA311F8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
             0x10bf60000 -        0x10c1bfff7 +com.adobe.HandlerEffectControls.framework (9.1.0 - 9.1.0.174) <BA1EB3DD-8D6A-3C8C-A0A4-F1112B827697> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCont rols
             0x10c3b7000 -        0x10c435fff +com.adobe.HandlerEffects.framework (9.1.0 - 9.1.0.174) <14E5EBD1-2055-361B-AB76-5AF4EA8BACEF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
             0x10c4d3000 -        0x10c4f7fff +com.adobe.HandlerEvents.framework (9.1.0 - 9.1.0.174) <DFB7CA51-FCBE-3BE1-89A5-AAB37B33F437> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
             0x10c545000 -        0x10c55efff +com.adobe.HandlerGetProperties.framework (9.1.0 - 9.1.0.174) <FF1550FD-7809-3619-B907-DE1A109A2DC0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperti es
             0x10c594000 -        0x10c5b0ff7 +com.adobe.HandlerHistory.framework (9.1.0 - 9.1.0.174) <AF2E0D36-459D-3128-B951-A2E4CF7C50E7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
             0x10c5eb000 -        0x10c5f4fff +com.adobe.HandlerStoryPanel.framework (9.1.0 - 9.1.0.174) <E859FA7A-F9B6-3DEE-8158-CAF9381A8A3A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
             0x10c60c000 -        0x10c63ffff +com.adobe.HandlerInfo.framework (9.1.0 - 9.1.0.174) <2E6B4CDB-3EA4-3840-84C9-9EFC2E0C4A2C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
             0x10c69e000 -        0x10c6d9ff7 +com.adobe.HandlerMarkerList.framework (9.1.0 - 9.1.0.174) <8DA43562-B754-360C-B4DC-31B30D9AF378> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
             0x10c755000 -        0x10c7b4fff +com.adobe.HandlerMetadataEditor.framework (9.1.0 - 9.1.0.174) <0016CF7E-DECE-310F-90B9-1CCDCC40BB68> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEd itor
             0x10c85d000 -        0x10c88cfff +com.adobe.HandlerMediaBrowser.framework (9.1.0 - 9.1.0.174) <FEE3A32E-D621-3819-B867-218FEB6BB1A5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
             0x10c8f5000 -        0x10c9efff7 +com.adobe.HandlerProgramMonitor.framework (9.1.0 - 9.1.0.174) <351E9EFA-0073-374B-910A-2D418B590679> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMon itor
             0x10caf2000 -        0x10cd21fff +com.adobe.HandlerProject.framework (9.1.0 - 9.1.0.174) <2FDE8317-3062-3FD6-9D29-51F9A254D7D6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
             0x10cf7e000 -        0x10cf95fff +com.adobe.HandlerScopes.framework (9.1.0 - 9.1.0.174) <671BF72C-0BEC-3530-AB55-4B21CC249B0E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
             0x10cfc2000 -        0x10d131fff +com.adobe.HandlerSourceMonitor.framework (9.1.0 - 9.1.0.174) <25554896-E1A4-3458-B947-789B17A501B0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonit or
             0x10d248000 -        0x10d261fff +com.adobe.HandlerTimecode.framework (9.1.0 - 9.1.0.174) <157F9C7B-10EC-30D6-9339-ECA50F76D9BE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
             0x10d296000 -        0x10d57cfff +com.adobe.HandlerTimeline.framework (9.1.0 - 9.1.0.174) <D5569979-0C5B-351C-817D-30BEA26E178D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
             0x10d80c000 -        0x10d86eff7 +com.adobe.FontEngine.framework (9.1.0 - 9.1.0.174) <D33101B5-2E66-3A38-B1BC-3593D8C49956> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
             0x10d8fa000 -        0x10d917fff +com.adobe.TitleLayer.framework (9.1.0 - 9.1.0.174) <76CC3650-E881-3B09-9551-4B1F1B840C7B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
             0x10dab1000 -        0x10dabfff7 +com.adobe.TitleImageManager.framework (9.1.0 - 9.1.0.174) <48A712C2-E7AD-3B57-81E4-A3BBF83F125D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
             0x10dadb000 -        0x10db67fff +com.adobe.TitleCharacterFactory.framework (9.1.0 - 9.1.0.174) <1897891C-8B53-3BBC-B9E9-CCE700C4D5CA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFac tory
             0x10dbbe000 -        0x10dd33fff +com.adobe.TitleCG.framework (9.1.0 - 9.1.0.174) <F61AB6A3-2D74-305B-8348-CB8CAEE565FC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
             0x10de4e000 -        0x10e0fdff7 +com.adobe.TitleLayout.framework (9.1.0 - 9.1.0.174) <BEB8CAC4-CC13-30B2-8F58-B7B92CD27EF5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
             0x10e5e8000 -        0x10e649ff7 +com.adobe.TitleRenderer.framework (9.1.0 - 9.1.0.174) <BEB88A53-7583-34CA-BA16-38B20D7DDE5F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
             0x10e6d8000 -        0x10ee7dfff +com.adobe.HandlerTitler.framework (9.1.0 - 9.1.0.174) <851FC01E-6FA7-31FA-ABD1-16254718A975> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
             0x10f6d9000 -        0x10f808fff +com.winsoft.wrservices (WRServices 8.0.0 - 8.0.0) <3DDC40D0-BC6F-3758-B00A-E102E80D4F5F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
             0x10f866000 -        0x10f88dfff +com.adobe.HandlerTools.framework (9.1.0 - 9.1.0.174) <76705DF7-2055-3630-BF5C-0310E7FE73F3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
             0x10f8e8000 -        0x10f8f1fff +com.adobe.HandlerProgress.framework (9.1.0 - 9.1.0.174) <C8F1A7BC-741E-3BBA-839E-8216E3A1DB42> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
             0x10f90a000 -        0x10f9e1ff7 +com.adobe.dvaaudiofilterhost.framework (9.1.0 - 9.1.0.174) <E813E6F3-AD64-3ED5-88AA-1FEBE71C0529> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
             0x10fac9000 -        0x10fb1fff7 +com.adobe.dvaaudiofilterhostui.framework (9.1.0 - 9.1.0.174) <570557E9-EA5D-36BB-B158-8A1869F13CC0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhost ui
             0x10fbc1000 -        0x10fbe9ff7 +com.adobe.dvaunittesting.framework (9.1.0 - 9.1.0.174) <822132B8-523D-349F-B004-539343C9CA9C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x10fc2b000 -        0x10fcd6ff7 +com.adobe.dvaaudiodevice.framework (9.1.0 - 9.1.0.174) <13210D61-9F1B-32FC-BB99-96624A2F4FD9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
             0x10fdb5000 -        0x10fdedfff +com.adobe.dvaaudiodeviceui.framework (9.1.0 - 9.1.0.174) <DFB2F28D-B7B3-3A34-A4DF-38352A1F8816> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
             0x10fe3e000 -        0x10fe87fff +com.adobe.dvanet.framework (9.1.0 - 9.1.0.174) <5D5C3CEF-07A4-345B-A3DD-1D37960F646C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
             0x10fef8000 -        0x11001aff7 +com.adobe.dvanetsync.framework (9.1.0 - 9.1.0.174) <FA665CC1-A904-3C33-82A9-B925FA95738C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
             0x11017d000 -        0x11067efff +com.adobe.EAClient.framework (9.1.0 - 9.1.0.174) <F414394B-30FD-3872-89A9-DE9C77FE82FF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
             0x110bc5000 -        0x110dbdfff +com.adobe.EACodec.framework (9.1.0 - 9.1.0.174) <36E8AE05-E957-3F43-AF89-1608D8CEF461> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
             0x110e8e000 -        0x111180ff7 +com.adobe.EAMedia.framework (9.1.0 - 9.1.0.174) <FD22D3CC-82B0-3B97-8DEB-F749BB0DFA7E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
             0x111459000 -        0x111925fff +com.adobe.EAProjectBridge.framework (9.1.0 - 9.1.0.174) <D179B775-B4CD-3FF6-AD5C-4E18647D4302> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
             0x111de7000 -        0x111f1afff +com.adobe.EAPrBridge.framework (9.1.0 - 9.1.0.174) <3F51B32C-9FF3-343A-A6A0-01895FE57F8B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
             0x11208a000 -        0x1120c9ff7 +com.adobe.dvacontrolsurfacehost.framework (9.1.0 - 9.1.0.174) <BD5C2369-900F-38FA-9702-89985A84CCF0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurface host
             0x11214b000 -        0x112196ff7 +com.adobe.ControlSurface.framework (9.1.0 - 9.1.0.174) <219B9231-C2CF-38B9-B81B-10F3AE90BB45> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
             0x112203000 -        0x11221cfff +com.adobe.postprocess.framework (9.1.0 - 9.1.0.174) <2D723BEC-A690-330F-928A-31D6257B2157> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
             0x112247000 -        0x11251ffe6 +libxerces-c-3.0.dylib (0) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x1126a0000 -        0x1126c5fff +com.mainconcept.mc.enc.dv (9.11 - 9.11.14.3173) <2525D6D6-09D2-4718-AFD8-49E0DAE682F0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
             0x1126dc000 -        0x11278cff7 +com.adobe.boost_regex.framework (9.1.0 - 9.1.0.174) <581EFE1D-BE7C-3BF0-92FE-C2ABA784B611> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
             0x11280b000 -        0x112862fff +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 1.0 -c 30 - 79.158325) <77ECCB53-F2C4-3C40-A36F-9FE9479704CA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
             0x1128db000 -        0x1128dfff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x1128e6000 -        0x112906fff +VulcanControl.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <7DED4C28-2DC8-397F-9BCF-FB4777D99386> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/VulcanControl.dylib
             0x11292d000 -        0x112965ff7 +VulcanMessage5.dylib (5.2.0.35 - 5.2.0.35 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <4B0B878A-02F8-3EB1-89D5-4071034EDD0D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
             0x1129a7000 -        0x1129b8ff7 +com.adobe.RuntimeInstaller.framework (9.1.0 - 9.1.0.174) <C008553A-17EB-325A-B835-EB7F14B52F5A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
             0x1129d7000 -        0x112ac8fe7 +com.mainconcept.mc.mfimport (9.11 - 9.11.14.3173) <6966DD9D-0146-88B2-0BA7-E6D453A7E25C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimport
             0x112add000 -        0x112d9bfcf +com.adobe.dvaaudiodsp.framework (9.1.0 - 9.1.0.174) <1865EF17-221A-3262-9C63-F3209D92BC27> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
             0x112e16000 -        0x112e5dfff  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <14F0B230-CA35-3D7D-A0B1-437BF4120290> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
             0x112e97000 -        0x112fd4fef  com.apple.mobiledevice (823.10.3 - 823.10.3) <1DD0B2D9-8E99-3411-BC29-993822BD4A4A> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/MobileDevice
             0x11305a000 -        0x113091fff  com.apple.audio.midi.CoreMIDI (1.10 - 88) <4A755EA1-3CF5-32A6-8939-8D2998577406> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
             0x1130ba000 -        0x1131c9fff  com.apple.AudioVideoBridging (403.4 - 403.4) <8AAB1A21-CA30-3B77-BD3B-8F3544BB098F> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
             0x11327a000 -        0x113293fff  libexpat.1.dylib (12.20.1) <AA76E4CF-52F5-3CF9-907B-FBB80BAFB125> /usr/lib/libexpat.1.dylib
             0x11329d000 -        0x1132a3fff  com.apple.TimeSync (1.0 - 403.4) <4E3FCB52-7F47-39A2-9C29-11CFE4823CC4> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
             0x1132ae000 -        0x113308fff +com.adobe.dynamiclinkui.framework (9.1.0 - 9.1.0.174) <F3AF991E-2084-338D-A22F-0F000F9E0AA0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x113398000 -        0x113490fff +com.adobe.OpticalFlow.framework (9.1.0 - 9.1.0.174) <7A7273B1-E0C2-32F0-9965-4CA3DF3E7246> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
             0x113569000 -        0x1135d0ff7 +com.adobe.QT32Client.framework (9.1.0 - 9.1.0.174) <081E747B-6AE6-3F27-9CC7-E0D60E12E743> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x113659000 -        0x1136bcfff +com.adobe.DynamicLinkMedia.framework (9.1.0 - 9.1.0.174) <A1E32D03-6B16-3AEC-820C-4C2F9DEC5B71> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x113772000 -        0x113797fff +com.adobe.TimeCarving.framework (9.1.0 - 9.1.0.174) <96A6D59C-53A0-3A11-8EC4-E541521EF372> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
             0x1137cd000 -        0x113976fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
             0x113a9c000 -        0x113ab8fff +com.adobe.ahclientframework (2.0.0.1 - 2.0.0.1) <075BD455-9D2E-3B8A-8C83-8B40D3059A55> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x113ac4000 -        0x113c2afff +com.adobe.dvametadataDB.framework (9.1.0 - 9.1.0.174) <0145A3AA-012D-372E-B591-75B04AE65E06> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
             0x113c7a000 -        0x113da3fff +com.adobe.dvametadataUI.framework (9.1.0 - 9.1.0.174) <D31B7537-B55D-3AEE-BAEC-DD745FFBCCD9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x113efb000 -        0x113f0dff7 +com.adobe.dvamarkerUI.framework (9.1.0 - 9.1.0.174) <FCD0FD99-ED6B-316A-A174-336AF90CB178> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
             0x113f37000 -        0x113f64ff7 +com.adobe.dvastoryparser.framework (9.1.0 - 9.1.0.174) <624F363C-FFEB-300D-9EB2-058A67FA9ACD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
             0x113f95000 -        0x114005fff +com.adobe.TimeWarpFilter.framework (9.1.0 - 9.1.0.174) <0C43D915-11E6-37D3-9844-E6AC6762A9BC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
             0x114065000 -        0x114157ff7 +com.adobe.MBCProvider.framework (9.1.0 - 9.1.0.174) <C55BC91D-2E93-328B-8E1A-C75B3AD12DC4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
             0x11422a000 -        0x114275ff7 +com.adobe.DisplaySurface.framework (9.1.0 - 9.1.0.174) <4ED15B14-53EB-3703-89BC-A54B69B965B7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
             0x1142cc000 -        0x1142f4fff +com.adobe.AMEAppFoundation.framework (9.1.0 - 9.1.0.174) <F4664854-E2D6-3672-9B1F-0B780E5A7CC5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x114339000 -        0x1143e4fff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
             0x11440e000 -        0x114436fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <C2069FBA-AE26-3284-AB00-8B9F4DB5A0DA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x114471000 -        0x114475fff  com.apple.agl (3.3.1 - AGL-3.3.1) <9FC80CE7-56CD-3034-9D03-EF126542657C> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x11447d000 -        0x114782fe7 +com.mainconcept.mc.enc.avc (9.11 - 9.11.14.3173) <46F1119D-4950-013D-5430-0BD6B59C8930> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_avc.framework/Versions/9/mc_enc_avc
             0x1147c2000 -        0x1149d1fd7 +com.mainconcept.mc.dec.avc (9.11 - 9.11.14.3173) <F485F523-A862-D4E7-5916-751A794712D4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_dec_avc.framework/Versions/9/mc_dec_avc
             0x1149db000 -        0x114de5fef +com.mainconcept.mc.mux.mp4 (9.11 - 9.11.14.3173) <9AA9F571-0888-99CA-6ECC-4A60E581C2A5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/9/mc_mux_mp4
             0x114e2d000 -        0x115020ff7 +com.adobe.CodecSupport.framework (9.1.0 - 9.1.0.174) <53F3A575-70FC-3C16-ADF0-6C83E04AC9F5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
             0x115159000 -        0x1152efff7 +com.mainconcept.mc.dec.mp2v (9.11 - 9.11.14.3173) <7BFF83AD-EAF4-C71A-960E-1612262E8617> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/9/mc_dec_mp2v
             0x1152f8000 -        0x11558afcf +com.mainconcept.mc.bc.dec.avc (9.11 - 9.11.14.3173) <BA8A5407-5E33-7EF3-EA5D-415559C215D1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/9/mc_bc_dec_avc
             0x11559b000 -        0x11576cfef +com.mainconcept.mc.dec.mp4v (9.11 - 9.11.14.3173) <508B143D-25B1-4407-CC3F-8A2B9245C3F1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/9/mc_dec_mp4v
             0x11577a000 -        0x115b89fef +libDNxHR.dylib (0) <40A98B9A-F35C-3B56-B009-E4A5856D7129> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libDNxHR.dylib
             0x115c5b000 -        0x115d37fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libmp4decMT.dylib
             0x115d93000 -        0x115e9dfff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libCFHDDecoder.dylib
             0x115f3c000 -        0x11603efff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libCFHDEncoder.dylib
             0x1160ea000 -        0x116144fff +com.adobe.boost_serialization.framework (9.1.0 - 9.1.0.174) <F912EFED-661F-3F2D-A8B9-E78683B1B927> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
             0x116232000 -        0x116243ff7 +com.adobe.dvacaptioningui.framework (9.1.0 - 9.1.0.174) <5E8D44B3-3B07-3D66-B3EC-2CB54DA833A0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
             0x116263000 -        0x1163adfff +com.adobe.RendererGPU.framework (9.1.0 - 9.1.0.174) <171B5F6A-9210-3C95-9128-E8BDC0B2C772> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
             0x1164a7000 -        0x1164c7fff +com.adobe.dvamediaui.framework (9.1.0 - 9.1.0.174) <AA377CB9-A58C-3B78-B81E-6BDF4D455247> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
             0x116515000 -        0x116620ff7 +com.adobe.dvamediabrowser.framework (9.1.0 - 9.1.0.174) <B474BD0D-A6AE-3055-9A25-9E207369355D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
             0x11679a000 -        0x1167c0ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/adbeapecore.framework/Versions/A/adbeapecore
             0x1167d3000 -        0x116829ff7 +com.adobe.dvastorypanel.framework (9.1.0 - 9.1.0.174) <4617FD8E-8F76-3E23-AD5D-8A5395592A9B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
             0x118e4d000 -        0x118e77ff7  GLRendererFloat (12.0.40.6) <805456A3-3352-340B-881A-E6E656A33645> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x11c111000 -        0x11c2bcffb  GLEngine (12.0.40.6) <CFA83347-B042-35C1-B92C-D636294EF831> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x11c2f9000 -        0x11c3adfff  com.apple.AMDRadeonX4000GLDriver (1.40.15 - 1.4.0) <FC5A23BC-DA6F-3336-AEC6-5B2543A6FE24> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLD river
             0x11e800000 -        0x11ec33ff7  ATIRadeonX4000SCLib.dylib (1.40.15) <7043C787-9E18-394A-84B0-012A60808010> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCL ib.dylib
             0x11ed51000 -        0x11ed53ff7  com.apple.textencoding.unicode (3.0 - 3.0) <78B2E03E-3AE3-34E0-AA72-22F1D696170B> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x11eda9000 -        0x11edbdfe3  libCGInterfaces.dylib (317.9) <5079DE4F-3717-32FF-B76A-77F53236D17D> /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/Versions/A/Li braries/libCGInterfaces.dylib
             0x11f6d6000 -        0x11f6dafff  com.apple.audio.AppleHDAHALPlugIn (272.51.3 - 272.51.3) <7E9DC6D6-CB61-3EA1-94AD-5C6F20D3EDBF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x120ac5000 -        0x120b05ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.15 - 9.0.0.15) <777D69DE-E701-3DAE-AF9C-7B7B48C0189C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
             0x123af1000 -        0x123af3fff +com.adobe.AEFilterAlphaAdjust.framework (9.1.0 - 9.1.0.174) <424949C8-5BB9-391C-A367-3D86F6C452D4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterAlphaAdjust.bundle/Contents/MacOS/AEFilterAlpha Adjust
             0x123ffb000 -        0x123ffbff7 +com.adobe.Mosaic.framework (9.1.0 - 9.1.0.174) <BB9A1E23-B58C-3EE6-8E61-0D149442FAC4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
             0x124800000 -        0x12488ffe7 +CubeTec.chorus2 (2.0.0.4) <21293E6D-3A47-6CD0-0953-DCED768F145D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Chorus1.vst/Contents/MacOS/Chorus1
             0x124b00000 -        0x124b8ffe7 +CubeTec.chorus2 (2.0.0.4) <153AB9B1-B08E-229F-D42F-0BCF3F53F951> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Chorus2.vst/Contents/MacOS/Chorus2
             0x124c23000 -        0x124cb2fe7 +CubeTec.chorus6 (2.0.0.4) <5AB2078C-8CD0-500C-4A55-9A838A040A40> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Chorus6.vst/Contents/MacOS/Chorus6
             0x124d46000 -        0x124dfbfe7 +CubeTec.DeClicker1 (2.0.0.4) <96D5F5A1-BD78-07BD-57DC-311DB3BA9A5E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeClicker1.vst/Contents/MacOS/DeClicker1
             0x124e94000 -        0x124f49fe7 +CubeTec.DeClicker2 (2.0.0.4) <9589D01B-D032-35D0-5E11-2921B33A80EC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeClicker2.vst/Contents/MacOS/DeClicker2
             0x124fe2000 -        0x125097fe7 +CubeTec.DeClicker6 (2.0.0.4) <96698B41-2D1C-7951-FC51-172559C29521> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeClicker6.vst/Contents/MacOS/DeClicker6
             0x125130000 -        0x1251e5fe7 +CubeTec.DeCrackler2 (2.0.0.4) <C6072151-3507-E8BC-E0D2-14CBBD05CBAE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeCrackler1.vst/Contents/MacOS/DeCrackler1
             0x125361000 -        0x125416fe7 +CubeTec.DeCrackler2 (2.0.0.4) <03788EA9-6CC1-0C19-365F-D707E82540D0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeCrackler2.vst/Contents/MacOS/DeCrackler2
             0x1254ae000 -        0x125563fe7 +CubeTec.DeCrackler2 (2.0.0.4) <E26B50A0-97B2-81A0-07BF-C4BC6140E551> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeCrackler6.vst/Contents/MacOS/DeCrackler6
             0x1255fb000 -        0x125695fe7 +CubeTec.DeEsser1 (2.0.0.4) <BDE7C70C-091A-AE5E-7FE1-0B5C45BB6066> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeEsser1.vst/Contents/MacOS/DeEsser1
             0x12572e000 -        0x1257c8fe7 +CubeTec.DeEsser2 (2.0.0.4) <24FFAC24-9F35-AEDB-D3D5-51B1D95DC4A3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeEsser2.vst/Contents/MacOS/DeEsser2
             0x125861000 -        0x1258fbfe7 +CubeTec.DeEsser6 (2.0.0.4) <88041615-1D86-E27E-90FB-09689EB4BA6F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeEsser6.vst/Contents/MacOS/DeEsser6
             0x1259eb000 -        0x1259f1fff +com.adobe.AEFilterClipName.framework (9.1.0 - 9.1.0.174) <429A2825-5CF0-3A81-9C19-B5005FAD67E3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterClipName.bundle/Contents/MacOS/AEFilterClipName
             0x125be4000 -        0x125c71fe7 +CubeTec.DeHummer1 (2.0.0.4) <539981DA-7D80-6DF0-2AC5-4D4AE5E6318F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeHummer1.vst/Contents/MacOS/DeHummer1
             0x125d06000 -        0x125d93fe7 +CubeTec.DeHummer2 (2.0.0.4) <15F7858B-15C6-A583-D5D0-E394B2936942> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeHummer2.vst/Contents/MacOS/DeHummer2
             0x125f0c000 -        0x125f99fe7 +CubeTec.DeHummer6 (2.0.0.4) <9B7CD154-EE8E-937B-7D0D-99A6D4A91A07> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeHummer6.vst/Contents/MacOS/DeHummer6
             0x12602e000 -        0x1260e4fe7 +CubeTec.Denoiser1 (2.0.0.4) <BC9EBDE2-4F5B-AE9F-9621-C02EC73997B2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeNoiser1.vst/Contents/MacOS/DeNoiser1
             0x126300000 -        0x1263b6fe7 +CubeTec.Denoiser2 (2.0.0.4) <C3B99059-A74E-13AD-9425-08C90BF97A2F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeNoiser2.vst/Contents/MacOS/DeNoiser2
             0x126616000 -        0x1266ccfe7 +CubeTec.Denoiser6 (2.0.0.4) <D9C2AE9B-3444-2556-4653-437A21D017C3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/DeNoiser6.vst/Contents/MacOS/DeNoiser6
             0x1267bb000 -        0x1267ccff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_BinaryLoader.dyl ib.4.5.7
             0x1267dc000 -        0x1267e3ff7 +com.adobe.AEFilterColorFast.framework (9.1.0 - 9.1.0.174) <E2D9741A-9158-3BB4-9B66-25E6E44996D3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterColorFast.bundle/Contents/MacOS/AEFilterColorFa st
             0x1267ed000 -        0x1267effff +com.adobe.AEFilterCrossDissolve.framework (9.1.0 - 9.1.0.174) <CBC4F859-7427-384E-9C51-E5AE5F8E10E2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterCrossDissolve.bundle/Contents/MacOS/AEFilterCro ssDissolve
             0x1267f7000 -        0x1267f9ff7 +com.adobe.AEFilterGaussianBlur.framework (9.1.0 - 9.1.0.174) <9EF48DDD-A340-39C6-BAB7-FC2BB5EA25BD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterGaussianBlur.bundle/Contents/MacOS/AEFilterGaus sianBlur
             0x126900000 -        0x12699dfef +CubeTec.dynamics1 (2.0.0.4) <06A7F1B3-C6D7-7E41-76DA-322CB500C102> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Dynamics1.vst/Contents/MacOS/Dynamics1
             0x126a39000 -        0x126ad6fef +CubeTec.dynamics2 (2.0.0.4) <751A2C3F-8178-1F9A-578F-BABEC75A7294> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Dynamics2.vst/Contents/MacOS/Dynamics2
             0x126b72000 -        0x126c0ffef +CubeTec.dynamics6 (2.0.0.4) <0F025606-63FE-5C67-AC48-B9BB6F5CAA07> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Dynamics6.vst/Contents/MacOS/Dynamics6
             0x126cab000 -        0x126d48fef +CubeTec.Eq1 (2.0.0.4) <443FF504-AC30-3EAE-CA8F-31EE1E676BAB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/EQ1.vst/Contents/MacOS/EQ1
             0x126ddf000 -        0x126de9ff7 +com.adobe.AEFilterCrop.framework (9.1.0 - 9.1.0.174) <FDE36A71-1DC1-3DC8-861B-EF8523E56A7E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterCrop.bundle/Contents/MacOS/AEFilterCrop
             0x126df7000 -        0x126dfaff7 +com.adobe.AEFilterNonRedKey.framework (9.1.0 - 9.1.0.174) <2B0C08C6-5429-313D-8E79-FBB737357785> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterNonRedKey.bundle/Contents/MacOS/AEFilterNonRedK ey
             0x126f57000 -        0x126ff4fef +CubeTec.Eq2 (2.0.0.4) <E60C5876-A622-B6B3-B3F1-3045F2D7BD4F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/EQ2.vst/Contents/MacOS/EQ2
             0x12716f000 -        0x12720cfef +CubeTec.Eq6 (2.0.0.4) <68CD4743-DA6F-0432-0283-3A11352144DB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/EQ6.vst/Contents/MacOS/EQ6
             0x1272a3000 -        0x127332fe7 +CubeTec.flanger1 (2.0.0.4) <C1C00ECD-88C8-5061-91E2-5AC4E21B74AA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Flanger1.vst/Contents/MacOS/Flanger1
             0x1273c7000 -        0x127456fe7 +CubeTec.flanger2 (2.0.0.4) <DC3704D0-96B6-500D-79B1-E793570C8A08> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Flanger2.vst/Contents/MacOS/Flanger2
             0x1274eb000 -        0x12757afe7 +CubeTec.flanger6 (2.0.0.4) <B1186C7E-92B0-1AD7-24BB-0432BD469BBD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Flanger6.vst/Contents/MacOS/Flanger6
             0x12760f000 -        0x1276c1fef +CubeTec.Multiband1 (2.0.0.4) <7F7B16C6-F7D3-352D-F770-F11F35997E86> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/MultiBand1.vst/Contents/MacOS/MultiBand1
             0x127763000 -        0x127815fef +CubeTec.Multiband2 (2.0.0.4) <A796560E-8F45-653B-B37C-6EF8FAD849CC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/MultiBand2.vst/Contents/MacOS/MultiBand2
             0x1278b7000 -        0x127969fef +CubeTec.Multiband6 (2.0.0.4) <BA4BE90B-28F8-4DF6-3F3D-C7700DE626E5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/MultiBand6.vst/Contents/MacOS/MultiBand6
             0x127d99000 -        0x127e28fe7 +CubeTec.Phaser1 (2.0.0.4) <B6534D15-C442-D8E5-06DA-1D50DB48A0EA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Phaser1.vst/Contents/MacOS/Phaser1
             0x127f0f000 -        0x127f9efe7 +CubeTec.Phaser2 (2.0.0.4) <34ACD43D-5401-DA90-B2AC-C973AAC16265> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Phaser2.vst/Contents/MacOS/Phaser2
             0x128033000 -        0x1280c2fe7 +CubeTec.Phaser6 (2.0.0.4) <1CF16E1D-F64F-D98B-DB39-3A6D1B10A8B0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Phaser6.vst/Contents/MacOS/Phaser6
             0x128157000 -        0x128206fff +CubeTec.PitchShifter1 (2.0.0.4) <10AE812B-E36C-8E8A-6430-FB85ADD7B81F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/PitchShifter1.vst/Contents/MacOS/PitchShifter 1
             0x12829f000 -        0x12834efff +CubeTec.PitchShifter2 (2.0.0.4) <6D4753D2-4492-3FE7-FE14-42400CDFBAB0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/PitchShifter2.vst/Contents/MacOS/PitchShifter 2
             0x1283e7000 -        0x128496fff +CubeTec.PitchShifter6 (2.0.0.4) <D9327BB8-885E-7E02-5A8F-B3B56EC8FD18> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/PitchShifter6.vst/Contents/MacOS/PitchShifter 6
             0x12852f000 -        0x1285c3fe7 +CubeTec.Reverb1 (2.0.0.4) <75481D64-BFC7-9A24-8C60-CA29C58940BE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Reverb1.vst/Contents/MacOS/Reverb1
             0x12865b000 -        0x1286effe7 +CubeTec.Reverb2 (2.0.0.4) <6FB7A3B0-4E86-2E28-D81B-3F00C0E89010> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Reverb2.vst/Contents/MacOS/Reverb2
             0x128787000 -        0x12881cfe7 +CubeTec.Reverb6 (2.0.0.4) <CA3116C2-7181-B143-A76D-F6D6EAEF6402> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/Reverb6.vst/Contents/MacOS/Reverb6
             0x1288b4000 -        0x128961fef +CubeTec.SpectralNoiseReduction1 (2.0.0.4) <C64E278F-CB09-0FB0-0E7E-66D651F321B6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/SpectralNoiseReduction1.vst/Contents/MacOS/Sp ectralNoiseReduction1
             0x128a03000 -        0x128ab0fef +CubeTec.SpectralNoiseReduction2 (2.0.0.4) <3AA861CE-EA05-D746-0EDC-568D759E7F6C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/SpectralNoiseReduction2.vst/Contents/MacOS/Sp ectralNoiseReduction2
             0x128b52000 -        0x128b8aff7 +libMOG_Framework.dylib.2.2.16 (2.2.16) <D812AA15-B0AE-331D-E39E-99AB1D2BE0A1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.dylib.2.2.16
             0x128ba9000 -        0x128bc1fff +com.adobe.AEAutoColor.framework (9.1.0 - 9.1.0.174) <959931EE-4023-3A6C-92F0-BF02B2334C29> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEAutoColor.bundle/Contents/MacOS/AEAutoColor
             0x128bd5000 -        0x128bdcfff +com.adobe.AEFilterGarbageMatte.framework (9.1.0 - 9.1.0.174) <F16E5F3F-1E45-3AC2-B501-51C849F1409C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte.bundle/Contents/MacOS/AEFilterGarb ageMatte
             0x128be9000 -        0x128bf1ff7 +com.adobe.AEFilterGarbageMatte16.framework (9.1.0 - 9.1.0.174) <1E6306AF-3697-393B-9243-1C6DEA46A6FF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte16.bundle/Contents/MacOS/AEFilterGa rbageMatte16
             0x128d00000 -        0x128dadfef +CubeTec.SpectralNoiseReduction6 (2.0.0.4) <39EF9174-3DD1-F5CF-D14B-A8EAFEE613A1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/en_US/VSTPlugins/SpectralNoiseReduction6.vst/Contents/MacOS/Sp ectralNoiseReduction6
             0x128e4f000 -        0x129199ff7 +com.adobe.AAF.framework (9.1.0 - 9.1.0.174) <BB17C0D6-37D7-396B-8775-6E93614D749E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AAF.bundle/Contents/MacOS/AAF
             0x1293d7000 -        0x1295e5fff +libMXF_SDK.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.dylib.4.5.7
             0x129783000 -        0x12979bff7 +com.adobe.AEAutoContrast.framework (9.1.0 - 9.1.0.174) <E3ADFD3D-9EB1-3377-B535-FE2D46690F02> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEAutoContrast.bundle/Contents/MacOS/AEAutoContrast
             0x1297af000 -        0x1297c7ff7 +com.adobe.AEAutoLevels.framework (9.1.0 - 9.1.0.174) <4F1B623F-AD4C-3D32-998D-5FBFAA01DB3C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEAutoLevels.bundle/Contents/MacOS/AEAutoLevels
             0x1297db000 -        0x1297fafff +com.adobe.AEFilterColorRGBCorrector.framework (9.1.0 - 9.1.0.174) <75ED62C8-AC2B-3CD9-878B-468FAD6FC132> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterColorRGBCorrector.bundle/Contents/MacOS/AEFilte rColorRGBCorrector
             0x129807000 -        0x12981ffe7 +com.adobe.AEFilterColorThreeWay.framework (9.1.0 - 9.1.0.174) <6D9754EE-21EE-3A52-AE49-D09215D5A4E7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterColorThreeWay.bundle/Contents/MacOS/AEFilterCol orThreeWay
             0x129836000 -        0x12983dff7 +com.adobe.AEFilterGarbageMatte8.framework (9.1.0 - 9.1.0.174) <C7BE05DF-0B5C-3698-924F-4D71392BCBAD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte8.bundle/Contents/MacOS/AEFilterGar bageMatte8
             0x12984a000 -        0x129852ff7 +com.adobe.AEFilterImageMatteKey.framework (9.1.0 - 9.1.0.174) <162564D3-5243-38F4-BF7E-271506197A66> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterImageMatteKey.bundle/Contents/MacOS/AEFilterIma geMatteKey
             0x129860000 -        0x129873ff7 +com.adobe.AEFilterLightingEffect.framework (9.1.0 - 9.1.0.174) <A6918045-80B2-3666-9887-926735102277> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterLightingEffect.bundle/Contents/MacOS/AEFilterLi ghtingEffect
             0x129885000 -        0x1298a0fff +com.adobe.AEFilterLumaCorrector.framework (9.1.0 - 9.1.0.174) <1353B432-6385-3963-A0B3-7990789FD2AF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterLumaCorrector.bundle/Contents/MacOS/AEFilterLum aCorrector
             0x1298ad000 -        0x1298c5ff7 +com.adobe.AEFilterLumaCurve.framework (9.1.0 - 9.1.0.174) <D3FFF747-FC08-3B5F-8DBF-3072295DDA7F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterLumaCurve.bundle/Contents/MacOS/AEFilterLumaCur ve
             0x1298d1000 -        0x1298d4fff +com.adobe.AEFilterLumaKey.framework (9.1.0 - 9.1.0.174) <1983EBA5-47D0-3092-877B-3DEF69B49E90> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterLumaKey.bundle/Contents/MacOS/AEFilterLumaKey
             0x1298db000 -        0x129c37ff7 +com.adobe.AEFilterLumetri.framework (9.1.0 - 9.1.0.174) <4F842A23-BD83-3738-9589-ED47B0F6F8D1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterLumetri.bundle/Contents/MacOS/AEFilterLumetri
             0x129dfe000 -        0x129e6bfff +com.adobe.ICUData (4.0 - 3.61) <1770B361-1521-3A4F-A2D5-FE17EC641669> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
             0x129e6f000 -        0x129eacff7 +com.adobe.ARE (AdobeARE 1.5.02.34962 - 1.5.02.34962) <3F9B60C4-217F-3A73-BCA5-F22BD393D5CF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x129eb4000 -        0x129ed8ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.34320 - 3.8.0.34320) <674F1792-D790-3E12-8C0F-85CAF9D848B1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
             0x129efc000 -        0x129fb5ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.34491) <574A97AF-0EA2-3FB9-BE6B-7E02C76EC6F2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x12a800000 -        0x12b00bf8f +com.adobe.AEFilterMask.framework (9.1.0 - 9.1.0.174) <4B22139A-AD79-3B7A-8E6E-D269C65D6D3B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterMask.bundle/Contents/MacOS/AEFilterMask
             0x12b11e000 -        0x12b1c7ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
             0x12b1f0000 -        0x12b2f3ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
             0x12b33e000 -        0x12b732ff7 +com.adobe.MPS (AdobeMPS 5.8.1.33340 - 5.8.1.33340) <4B02E5D5-79A8-3281-920A-BD3B74DFEDF7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x12b7ad000 -        0x12bf46fff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.34348) <4D649496-C10E-351F-B665-ABB0BD0C9FC3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
             0x12c003000 -        0x12c742ff7 +com.adobe.AEFilterMorphCut.framework (9.1.0 - 9.1.0.174) <1137ED07-F44E-3CE5-80EB-D1BC19EE6230> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterMorphCut.bundle/Contents/MacOS/AEFilterMorphCut
             0x12ca8b000 -        0x12ca8dfff +com.adobe.AEFilterProcAmp.framework (9.1.0 - 9.1.0.174) <E2989D05-873D-3938-BAC3-0BCA953E217A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterProcAmp.bundle/Contents/MacOS/AEFilterProcAmp
             0x12ca94000 -        0x12ca96fff +com.adobe.AEFilterRemoveMatte.framework (9.1.0 - 9.1.0.174) <8F8892B6-1EF7-38FB-B59C-19E73EC665D1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterRemoveMatte.bundle/Contents/MacOS/AEFilterRemov eMatte
             0x12ca9c000 -        0x12cab7fff +com.adobe.AEFilterRGBCurves.framework (9.1.0 - 9.1.0.174) <A36B67B6-71C6-322F-B536-D026DF631B77> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterRGBCurves.bundle/Contents/MacOS/AEFilterRGBCurv es
             0x12cac4000 -        0x12cacbfff +com.adobe.AEFilterSDRConform.framework (9.1.0 - 9.1.0.174) <E430E81A-9ACF-3C3B-85E1-4C26725C7B60> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterSDRConform.bundle/Contents/MacOS/AEFilterSDRCon form
             0x12cad8000 -        0x12cae2ff7 +com.adobe.AEFilterTimecode.framework (9.1.0 - 9.1.0.174) <9C2D9EFE-55BD-3FD9-BB3E-32B85661E72C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterTimecode.bundle/Contents/MacOS/AEFilterTimecode
             0x12caf0000 -        0x12caf4fff +com.adobe.AEFilterTrackMatteKey.framework (9.1.0 - 9.1.0.174) <748AE8C4-D5EB-32EB-9685-433BA5356994> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterTrackMatteKey.bundle/Contents/MacOS/AEFilterTra ckMatteKey
             0x12cafb000 -        0x12cb07ff7 +com.adobe.AEFilterUltraKey.framework (9.1.0 - 9.1.0.174) <B7D92F50-ADD1-3883-9292-60BA08BF94E1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterUltraKey.bundle/Contents/MacOS/AEFilterUltraKey
             0x12cb12000 -        0x12cb17ff7 +com.adobe.AEFilterVideoLimiter.framework (9.1.0 - 9.1.0.174) <829D3FEB-C2A6-308B-84C9-0EF56A39F029> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEFilterVideoLimiter.bundle/Contents/MacOS/AEFilterVide oLimiter
             0x12cb1f000 -        0x12cb3bff7 +com.adobe.AEShadowHighlight.framework (9.1.0 - 9.1.0.174) <D44BA211-6948-36BD-8AFF-C33AADA53E38> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/AEShadowHighlight.bundle/Contents/MacOS/AEShadowHighlig ht
             0x12cbb2000 -        0x12cbb3fff +com.adobe.Arithmetic.framework (9.1.0 - 9.1.0.174) <90C4E145-AE53-39BA-A03B-ACC0B7B27D0A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Arithmetic.bundle/Contents/MacOS/Arithmetic
             0x12cbb8000 -        0x12cbbbff7 +com.adobe.ARRIRAWSourceSettings.framework (9.1.0 - 9.1.0.174) <A0BAAB20-DD83-3695-98C3-1E2546DBD015> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ARRIRAWSourceSettings.bundle/Contents/MacOS/ARRIRAWSour ceSettings
             0x12cbc2000 -        0x12cbc8ff7 +com.adobe.B-C-2.framework (9.1.0 - 9.1.0.174) <B75BFC48-250A-38C2-9884-A82D8ECA86C8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/B-C-2.bundle/Contents/MacOS/B-C-2
             0x12cbd4000 -        0x12cbdbff7 +com.adobe.Basic_3D.framework (9.1.0 - 9.1.0.174) <F59D65A0-5656-372A-85D8-CE55B708264C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Basic_3D.bundle/Contents/MacOS/Basic_3D
             0x12cbe1000 -        0x12cbe7ff7 +com.adobe.Bevel_Alpha.framework (9.1.0 - 9.1.0.174) <7358F699-F5DB-369E-8989-4175BAAD4D59> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Bevel_Alpha.bundle/Contents/MacOS/Bevel_Alpha
             0x12cbf3000 -        0x12cbf4ff7 +com.adobe.Bevel_Edges.framework (9.1.0 - 9.1.0.174) <04D7135B-3D53-33DC-B5AF-81EB86AA7B0B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Bevel_Edges
             0x12cbf9000 -        0x12cbfefff +com.adobe.Blend.framework (9.1.0 - 9.1.0.174) <ADF5B3DC-4F23-3DAF-9763-35F264E3FD21> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Blend.bundle/Contents/MacOS/Blend
             0x12cc09000 -        0x12cc0fff7 +com.adobe.Block_Dissolve.framework (9.1.0 - 9.1.0.174) <06E8D65B-E15B-3AB3-9647-6567CE234497> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Block_Dissolve.bundle/Contents/MacOS/Block_Dissolve
             0x12cc1b000 -        0x12cc1cfff +com.adobe.Broadcast_Colors.framework (9.1.0 - 9.1.0.174) <12CA62FF-7616-3F6D-9093-C9A7FAC2A708> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Broadcast_Colors.bundle/Contents/MacOS/Broadcast_Colors
             0x12cc21000 -        0x12cc22ff7 +com.adobe.Brush_Strokes.framework (9.1.0 - 9.1.0.174) <EB20F0D3-6C3E-3AA9-B8B9-5F771B651A48> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Brush_Strokes.bundle/Contents/MacOS/Brush_Strokes
             0x12cc27000 -        0x12cc2cfff +com.adobe.Calculations.framework (9.1.0 - 9.1.0.174) <12A6B407-BCA8-3CF5-A590-AFB0CDD3F1A5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Calculations.bundle/Contents/MacOS/Calculations
             0x12cc36000 -        0x12cc3cff7 +com.adobe.CellPattern.framework (9.1.0 - 9.1.0.174) <8A1467C4-FE8D-3E07-89F8-8FD5BA838B7B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/CellPattern.bundle/Contents/MacOS/CellPattern
             0x12cc42000 -        0x12cc49ff7 +com.adobe.Change_Color.framework (9.1.0 - 9.1.0.174) <3292C4A7-04CE-3157-8F26-6109D104F034> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Change_Color.bundle/Contents/MacOS/Change_Color
             0x12cc56000 -        0x12cc5dfff +com.adobe.ChangeToColor.framework (9.1.0 - 9.1.0.174) <246B944C-0EF4-3F76-AC9E-3B61059ABAEB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ChangeToColor.bundle/Contents/MacOS/ChangeToColor
             0x12cc69000 -        0x12cc70fff +com.adobe.Channel_Blur.framework (9.1.0 - 9.1.0.174) <FEDC79EE-D5A3-351D-BA59-9F8534020041> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Channel_Blur.bundle/Contents/MacOS/Channel_Blur
             0x12cc7c000 -        0x12cc7dfff +com.adobe.Channel_Mixer.framework (9.1.0 - 9.1.0.174) <20D708FD-AEE9-3730-9EF0-5A760C61FCA2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Channel_Mixer.bundle/Contents/MacOS/Channel_Mixer
             0x12cc82000 -        0x12cc84ff7 +com.adobe.Checkerboard.framework (9.1.0 - 9.1.0.174) <5B4E662E-F05C-3F5C-B1EB-386F11A865B1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Checkerboard.bundle/Contents/MacOS/Checkerboard
             0x12cc89000 -        0x12cc8bff7 +com.adobe.CinemaDNGSourceSettings.framework (9.1.0 - 9.1.0.174) <90690501-9B74-3A46-A336-03B671E6C994> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/CinemaDNGSourceSettings.bundle/Contents/MacOS/CinemaDNG SourceSettings
             0x12cc91000 -        0x12cc9aff7 +com.adobe.CineonEffect.framework (9.1.0 - 9.1.0.174) <B033B1E3-9484-3C85-92A0-C76486864457> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/CineonEffect.bundle/Contents/MacOS/CineonEffect
             0x12ccb7000 -        0x12ccb9ff7 +com.adobe.Circle.framework (9.1.0 - 9.1.0.174) <6D7D6B7C-B21A-3592-8DA0-D4768A402B8F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Circle.bundle/Contents/MacOS/Circle
             0x12ccbe000 -        0x12ccc5fff +com.adobe.Color_Balance_2.framework (9.1.0 - 9.1.0.174) <92586642-36C1-388F-8F10-68823E5446EF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Color_Balance_2.bundle/Contents/MacOS/Color_Balance_2
             0x12ccd0000 -        0x12ccd6ff7 +com.adobe.Color_Emboss.framework (9.1.0 - 9.1.0.174) <5CEE4154-1121-3295-BF00-8D29FF51274B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Color_Emboss.bundle/Contents/MacOS/Color_Emboss
             0x12cce2000 -        0x12cce7ff7 +com.adobe.Color_HLS.framework (9.1.0 - 9.1.0.174) <9176EE8C-167F-3C74-B632-87D4AC21DA08> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Color_HLS.bundle/Contents/MacOS/Color_HLS
             0x12ccf1000 -        0x12ccf2fff +com.adobe.Compound_Arith.framework (9.1.0 - 9.1.0.174) <772ABDD8-B1C0-3638-9E55-BA5DC93163F0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Compound_Arith.bundle/Contents/MacOS/Compound_Arith
             0x12ccf7000 -        0x12ccf8ff7 +com.adobe.Equalize.framework (9.1.0 - 9.1.0.174) <64526ABB-4E37-3C73-BA82-8E336226FE94> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Equalize.bundle/Contents/MacOS/Equalize
             0x12ce00000 -        0x12ce06ff7 +com.adobe.Color_Key.framework (9.1.0 - 9.1.0.174) <4BD8AD1C-9847-30B9-951E-D02A3E292853> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Color_Key.bundle/Contents/MacOS/Color_Key
             0x12ce11000 -        0x12ce17fff +com.adobe.ColorsQuad.framework (9.1.0 - 9.1.0.174) <604D6DE8-E5C6-336C-8458-ED7992BB6E8C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ColorsQuad.bundle/Contents/MacOS/ColorsQuad
             0x12ce21000 -        0x12ce29fff +com.adobe.Compound_Blur.framework (9.1.0 - 9.1.0.174) <D2750ED7-642F-394B-B193-13BB7E398B30> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Compound_Blur.bundle/Contents/MacOS/Compound_Blur
             0x12ce36000 -        0x12ce46fff +com.adobe.Corner_Pin.framework (9.1.0 - 9.1.0.174) <119DB96F-10BF-336A-8AD5-DA1928389A5C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Corner_Pin.bundle/Contents/MacOS/Corner_Pin
             0x12ce54000 -        0x12ce6cff7 +com.adobe.DeviceControlFirewire.framework (9.1.0 - 9.1.0.174) <2B304286-BF22-3A8C-8B08-B7BD7A362D3D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/DeviceControlFireWire.bundle/Contents/MacOS/DeviceContr olFirewire
             0x12ce86000 -        0x12cebdff7  com.apple.AVCVideoServices (1.0 - 42) <32685D8F-4273-3CF7-828F-839EFBB5035F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
             0x12cf09000 -        0x12cf0efff +com.adobe.Difference.framework (9.1.0 - 9.1.0.174) <2728B31A-DD86-3C2B-AB38-F3A4D6221975> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Difference.bundle/Contents/MacOS/Difference
             0x12cf19000 -        0x12cf1fff7 +com.adobe.DirectionalBlur.framework (9.1.0 - 9.1.0.174) <3CD5A28C-BE1A-3120-9875-F8FD7FA1DF30> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/DirectionalBlur.bundle/Contents/MacOS/DirectionalBlur
             0x12cf2b000 -        0x12cf2ffff +com.adobe.DPXSourceSettings.framework (9.1.0 - 9.1.0.174) <4784392B-E1D8-3287-9F79-A1CDC202FB18> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/DPXSourceSettings.bundle/Contents/MacOS/DPXSourceSettin gs
             0x12cf35000 -        0x12cf3cfff +com.adobe.Drop_Shadow.framework (9.1.0 - 9.1.0.174) <769D5C15-59E6-3732-B2DA-B828C5FBC5AC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Drop_Shadow.bundle/Contents/MacOS/Drop_Shadow
             0x12cf47000 -        0x12cf5cfff +com.adobe.Dust.framework (9.1.0 - 9.1.0.174) <BC8DDA3B-EA35-344B-9932-04C084367A8B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Dust.bundle/Contents/MacOS/Dust
             0x12cf68000 -        0x12cf9bff7 +com.adobe.EASequenceRenderer.framework (9.1.0 - 9.1.0.174) <85CAAA85-FBB8-3AAA-96AD-DEFCCD9A6BCE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRend erer
             0x12cfe1000 -        0x12cfe7ff7 +com.adobe.Echo.framework (9.1.0 - 9.1.0.174) <0E498B6C-C48F-317C-B93C-90E6E1651552> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Echo.bundle/Contents/MacOS/Echo
             0x12cff3000 -        0x12d00fff7 +com.adobe.Ellipse.framework (9.1.0 - 9.1.0.174) <EF00D008-680D-3B52-B031-ED80E39955BA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Ellipse.bundle/Contents/MacOS/Ellipse
             0x12d01d000 -        0x12d023fff +com.adobe.Emboss.framework (9.1.0 - 9.1.0.174) <A329FDB9-7158-3E5E-B742-7C65A255E3EC> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Emboss.bundle/Contents/MacOS/Emboss
             0x12d02f000 -        0x12d034fff +com.adobe.ExporterAIFF.framework (9.1.0 - 9.1.0.174) <6AC9A6F4-1F0D-362E-A840-7A350FA58FD9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterAIFF.bundle/Contents/MacOS/ExporterAIFF
             0x12d03f000 -        0x12d04efff +com.adobe.ExporterDPX.framework (9.1.0 - 9.1.0.174) <39274F83-1FE5-39AC-8746-2C92909A82D9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterDPX.bundle/Contents/MacOS/ExporterDPX
             0x12d05e000 -        0x12d079ff7 +com.adobe.ExporterJPEG.framework (9.1.0 - 9.1.0.174) <8B7E3E0C-E045-3CB4-931A-DEA3BE666272> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterJPEG.bundle/Contents/MacOS/ExporterJPEG
             0x12d089000 -        0x12d0e0fe7 +com.adobe.ExporterMP3.framework (9.1.0 - 9.1.0.174) <912EEB11-F5DD-3E7F-A9F6-6122D389EFA7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterMP3.bundle/Contents/MacOS/ExporterMP3
             0x12d11e000 -        0x12d1a4ff7 +com.adobe.ExporterMPEG2.framework (9.1.0 - 9.1.0.174) <9400FC3D-398E-351C-908D-1DC39D83F6CF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
             0x12d206000 -        0x12d216fff +com.mainconcept.mc.enc.mpa (9.11 - 9.11.14.3173) <2BBD5347-691C-6A90-1DAA-E9F5868D2468> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/9/mc_enc_mpa
             0x12d235000 -        0x12d41ffff +com.mainconcept.mc.enc.mp2v (9.11 - 9.11.14.3173) <E235F75A-ECD4-49C3-415E-9CEBAFC369A3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/9/mc_enc_mp2v
             0x12d46e000 -        0x12d577fe7 +com.mainconcept.mc.mux.mp2 (9.11 - 9.11.14.3173) <E0867C8A-33B8-F6FF-E852-264D48816406> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/9/mc_mux_mp2
             0x12d5a6000 -        0x12d5e3fe7 +com.adobe.dolbyparamsupport.framework (9.1.0 - 9.1.0.174) <04352C0D-4CC9-387A-BB79-C638283877A9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dolbyparamsupport.framework/Versions/A/dolbyparamsupport
             0x12d6a9000 -        0x12d6cefff +com.adobe.ExporterMPEGPreview.framework (9.1.0 - 9.1.0.174) <C804D1C5-67B2-3737-8B90-2F894A7D7A0B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGP review
             0x12d6eb000 -        0x12d6f3fff +com.mainconcept.mc.enc.mp2sr (9.11 - 9.11.14.3173) <82CE2AEA-3BAF-AAE2-25C3-93EE146657B0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/9/mc_enc_mp2sr
             0x12d6f8000 -        0x12d6f9ff7 +com.adobe.EyedropperFill.framework (9.1.0 - 9.1.0.174) <B5DF61B3-CF97-3087-815C-1CFFEDE80E62> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/EyedropperFill.bundle/Contents/MacOS/EyedropperFill
             0x12d800000 -        0x12d93bfe7 +com.adobe.ExporterMPEG4.framework (9.1.0 - 9.1.0.174) <909D1477-7C8B-3C71-A34D-0087A47855B9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
             0x12d9bd000 -        0x12db74ff7 +com.mainconcept.mc.enc.mp4v (9.11 - 9.11.14.3173) <8F147EBB-50BE-FC08-7A29-E6FD294EDD9C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/9/mc_enc_mp4v
             0x12dbb2000 -        0x12dc65fe7 +com.adobe.IPPMPEGDecoder.framework (9.1.0 - 9.1.0.174) <6BE2FC62-7DB9-30F8-AD0F-252EDD214146> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
             0x12dcac000 -        0x12dce6fef +com.mainconcept.mc.enc.aac (9.11 - 9.11.14.3173) <2DACE4F6-E4B1-5CE1-FE8B-2B8F1A606856> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_enc_aac.framework/Versions/9/mc_enc_aac
             0x12dceb000 -        0x12de20fff +com.adobe.ExporterMXF.framework (9.1.0 - 9.1.0.174) <94914300-E42F-3D63-A7EF-3C3CFE0F2619> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
             0x12dea8000 -        0x12deb2fff +libMXF_SDK_GenericContainer_AES3.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3.dylib.4 .5.7
             0x12debb000 -        0x12dec6ff7 +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AES3_S302M.d ylib.4.5.7
             0x12decf000 -        0x12ded5fff +libMXF_SDK_GenericContainer_AVI.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AVI.dylib.4. 5.7
             0x12deda000 -        0x12dee7fff +libMXF_SDK_GenericContainer_D10.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_D10.dylib.4. 5.7
             0x12deef000 -        0x12df0afe7 +libMXF_SDK_GenericContainer_DV.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_DV.dylib.4.5 .7
             0x12df1c000 -        0x12df2bff7 +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_JPEG2000.dyl ib.4.5.7
             0x12df38000 -        0x12df43fef +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_ESAudio .dylib.4.5.7
             0x12df4c000 -        0x12df5dfef +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEG2Vi deo.dylib.4.5.7
             0x12df6a000 -        0x12df7efef +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEG4.d ylib.4.5.7
             0x12df89000 -        0x12df93fff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEGPS. dylib.4.5.7
             0x12df9a000 -        0x12dfa6fff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MPEGTS. dylib.4.5.7
             0x12dfae000 -        0x12dfb8fff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_SystemScheme 1.dylib.4.5.7
             0x12dfc1000 -        0x12dfd3fff +libMXF_SDK_GenericContainer_Wave.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Wave.dylib.4 .5.7
             0x12dfe3000 -        0x12dfeefff +libMXF_SDK_Metadata_RP224.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_RP224.dylib.4.5.7
             0x12dff5000 -        0x12e00dffb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader.dylib. 4.5.7
             0x12e01e000 -        0x12e040ffa +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetadata_XSDLoader2.dylib .4.5.7
             0x12e058000 -        0x12e6a4fef +libMXF_SDK_XMLUtils.dylib.4.5.7 (4.5.7) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLUtils.dylib.4.5.7
             0x12eaac000 -        0x12eabcfff +libMXF_SDK_GenericContainer_AIFF.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_AIFF.dylib.1 .4.13
             0x12eac8000 -        0x12eacfff7 +libMXF_SDK_GenericContainer_Binary.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Binary.dylib .1.4.13
             0x12ead5000 -        0x12eae2fff +libMXF_SDK_GenericContainer_Blind.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_Blind.dylib. 1.4.13
             0x12eaeb000 -        0x12eaf7fff +libMXF_SDK_GenericContainer_MPEG_AAC.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AAC.dyl ib.1.4.13
             0x12eb00000 -        0x12eb36ff0 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVC.dyl ib.1.4.13
             0x12eb53000 -        0x12eb5afff +libMXF_SDK_GenericContainer_MPEG_AVCProxy.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVCProx y.dylib.1.4.13
             0x12eb5f000 -        0x12eb6aff8 +libMXF_SDK_GenericContainer_MPEG_AVCUltra.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_AVCUltr a.dylib.1.4.13
             0x12eb75000 -        0x12eb85fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_MP4.dyl ib.1.4.13
             0x12eb8e000 -        0x12eba1ff2 +libMXF_SDK_GenericContainer_MPEG_XAVC.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_MPEG_XAVC.dy lib.1.4.13
             0x12ebb0000 -        0x12ebc3fff +libMXF_SDK_GenericContainer_VC3.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_GenericContainer_VC3.dylib.1. 4.13
             0x12ebd1000 -        0x12ebd7fff +libMXF_SDK_Metadata_AS11.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_AS11.dylib.1.4.13
             0x12ebdf000 -        0x12ebe5fff +libMXF_SDK_Modules_DataIO.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_Modules_DataIO.dylib.1.4.13
             0x12ebea000 -        0x12ec25ffb +libMXF_SDK_MXFIO_AS11.dylib.1.4.13 (1.4.13) /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_MXFIO_AS11.dylib.1.4.13
             0x12ec47000 -        0x12ec79ffb +libMXF_SDK_XMLBuilder.dylib.1.4.13 (1.4.13) <02E9A2A6-82F3-5113-13B9-8B27A2338D03> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK_XMLBuilder.dylib.1.4.13
             0x12ec9e000 -        0x12eca3ff7 +com.adobe.ExporterPNG.framework (9.1.0 - 9.1.0.174) <B61D5B6E-5CA9-3919-85F5-858DE249420A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterPNG.bundle/Contents/MacOS/ExporterPNG
             0x12ecae000 -        0x12ecb2ff7 +com.adobe.ExporterTarga.framework (9.1.0 - 9.1.0.174) <BC57FEA5-BE9E-39F1-87F0-B52EADACA2A6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterTarga.bundle/Contents/MacOS/ExporterTarga
             0x12ecbc000 -        0x12ecc0fff +com.adobe.ExporterTIFF.framework (9.1.0 - 9.1.0.174) <446818AA-75B7-344C-8896-D2D832B3E7A0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterTIFF.bundle/Contents/MacOS/ExporterTIFF
             0x12ecca000 -        0x12ecccfff +com.adobe.F65SourceSettings.framework (9.1.0 - 9.1.0.174) <64DBED05-B739-3B05-8B81-6E30882C78F5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/F65SourceSettings.bundle/Contents/MacOS/F65SourceSettin gs
             0x12ecd2000 -        0x12ecd8ff7 +com.adobe.Fast_Blur.framework (9.1.0 - 9.1.0.174) <9AF16BFA-29D0-36AF-9535-1E795B11D02F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Fast_Blur.bundle/Contents/MacOS/Fast_Blur
             0x12ece3000 -        0x12ece8ff7 +com.adobe.Find_Edges.framework (9.1.0 - 9.1.0.174) <14C78146-8736-3A14-8820-393C8BC13C0E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Find_Edges.bundle/Contents/MacOS/Find_Edges
             0x12ecf2000 -        0x12ecf4ff7 +com.adobe.Grid.framework (9.1.0 - 9.1.0.174) <24FB41B2-BCDE-3276-A280-75AD1CE71B25> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Grid.bundle/Contents/MacOS/Grid
             0x12ecf9000 -        0x12ecfafff +libtlshook.dylib (5) <976ED4F8-3F0D-2EFE-F97A-71AD6357D5E7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libtlshook.dylib
             0x12ee00000 -        0x12eef7ff7 +com.adobe.ExporterP2.framework (9.1.0 - 9.1.0.174) <8927DCB9-FC56-37A5-AEA3-3CC8521B652E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/ExporterP2
             0x12ef4a000 -        0x12ef51ff7 +com.adobe.Gradient_Wipe.framework (9.1.0 - 9.1.0.174) <21EAC9E5-7221-378F-A1A9-C27F23AEE9EB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Gradient_Wipe.bundle/Contents/MacOS/Gradient_Wipe
             0x12ef5e000 -        0x12ef62ff7 +com.adobe.ImporterAiff.framework (9.1.0 - 9.1.0.174) <DEA255CD-1B59-30DA-BF10-79A0CAB7029C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterAiff.bundle/Contents/MacOS/ImporterAiff
             0x12ef6b000 -        0x12ef9aff7 +com.adobe.ImporterARRIRAW.framework (9.1.0 - 9.1.0.174) <D24155B0-53F1-3E52-8C25-321263826232> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterARRIRAW.bundle/Contents/MacOS/ImporterARRIRAW
             0x12efdb000 -        0x12efdcff7 +com.adobe.ImporterBlackMatte.framework (9.1.0 - 9.1.0.174) <84F15B3E-CE26-327E-A88E-36E9512F7FE1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterBlackMatte.bundle/Contents/MacOS/ImporterBlackM atte
             0x12efe1000 -        0x12efe2ff7 +com.adobe.ImporterColorMatte.framework (9.1.0 - 9.1.0.174) <863A259D-1598-3FEF-8AB0-75FFAB2F0482> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterColorMatte.bundle/Contents/MacOS/ImporterColorM atte
             0x12efe9000 -        0x12eff1fff +com.adobe.ImporterPhotoshopProxy.framework (9.1.0 - 9.1.0.174) <1DCDC03E-0BC7-38A2-A6FD-A27C4E0CC8B3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterPhotoshopProxy.bundle/Contents/MacOS/ImporterPh otoshopProxy
             0x12f500000 -        0x12f5a1fff +com.adobe.ExporterXDCAMHD.framework (9.1.0 - 9.1.0.174) <8ED836B0-2E7E-34FB-A4B5-F04EAECC1194> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
             0x12f628000 -        0x12f92dfe7 +com.mainconcept.mc.bc.enc.avc (9.11 - 9.11.14.3173) <EBE12E6E-B2FF-28E3-FFBA-B552A247CF51> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/9/mc_bc_enc_avc
             0x12f96d000 -        0x12f9dbfff +libcudart.dylib (5) <3606C4C7-BA5A-5780-3DD6-0D01A11BD515> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/libcudart.dylib
             0x12f9f7000 -        0x12f9f8ff7 +com.adobe.ImporterTransparentMatte.framework (9.1.0 - 9.1.0.174) <92AB8E5D-5F70-3C59-ACCD-1F522F74114F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterTransparentMatte.bundle/Contents/MacOS/Importer TransparentMatte
             0x12f9fe000 -        0x12f9fefe7 +cl_kernels (???) <BAFBD271-F786-4045-9CFC-217799796AA0> cl_kernels
             0x12fb00000 -        0x130085fe7 +com.adobe.FCPXProjectConverter.framework (9.1.0 - 9.1.0.174) <A1946CFD-F000-3EB8-8C98-FEEFF3A782A1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/FCPXProjectConverter.bundle/Contents/MacOS/FCPXProjectC onverter
             0x13030f000 -        0x130367ff7 +com.adobe.ImporterAIEPS.framework (9.1.0 - 9.1.0.174) <FE47A248-349E-359E-A4FD-C36EF2958C8C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterAIEPS.bundle/Contents/MacOS/ImporterAIEPS
             0x1303e2000 -        0x130f0cfe7 +com.arri.ArriRawSDK.framework (4.5 - 4.5.0.0) <997DCF91-ECB0-3989-AADA-7B60F27D805F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/ArriRawSDK.framework/Versions/A/ArriRawSDK
             0x1310d0000 -        0x1310eafff +com.adobe.ImporterJPEG.framework (9.1.0 - 9.1.0.174) <4005ECE9-CEA9-36BC-87F6-585A16835E74> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterJPEG.bundle/Contents/MacOS/ImporterJPEG
             0x1310f9000 -        0x1310faff7 +com.adobe.Leave_Color.framework (9.1.0 - 9.1.0.174) <54EF4176-747C-3D65-94D9-CD770CB7ED74> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Leave_Color.bundle/Contents/MacOS/Leave_Color
             0x131200000 -        0x131231fff +com.adobe.ImporterASND.framework (9.1.0 - 9.1.0.174) <87C36C3C-6B3F-3D5A-A2EA-AAD70AABD64F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterASND.bundle/Contents/MacOS/ImporterASND
             0x13127d000 -        0x131296fff +com.adobe.ImporterBarsAndTone.framework (9.1.0 - 9.1.0.174) <0CF97032-0B58-3AD2-8538-030865398A4F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterBarsAndTone.bundle/Contents/MacOS/ImporterBarsA ndTone
             0x1312b3000 -        0x1312d1fff +com.adobe.ImporterCaptioning.framework (9.1.0 - 9.1.0.174) <693644F7-9F2F-3752-8AE9-DBB96DD00921> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterCaptioning.bundle/Contents/MacOS/ImporterCaptio ning
             0x131400000 -        0x13141cff7 +com.adobe.ImporterDPX.framework (9.1.0 - 9.1.0.174) <7FD516AC-1176-3FB0-AD56-2F43E60C801D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterDPX.bundle/Contents/MacOS/ImporterDPX
             0x13143f000 -        0x13177cfff +com.adobe.ImporterF65.framework (9.1.0 - 9.1.0.174) <0083BD90-4692-3EAE-9069-9692BC2F0716> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterF65.bundle/Contents/MacOS/ImporterF65
             0x131948000 -        0x131a2ffff +libSonyRawDev.dylib (2.2) <66D03A98-EF92-3B07-A078-1EE7BFBA0C63> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterF65.bundle/Contents/Frameworks/libSonyRawDev.dy lib
             0x131a93000 -        0x131c8ffff +libSMDK-Mac-x64.4.2.0.dylib (4.2) <CFB2ECFB-9DFD-32C7-B154-3EFE10019DD1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterF65.bundle/Contents/Frameworks/libSMDK-Mac-x64. 4.2.0.dylib
             0x131ce4000 -        0x131cfcfff +com.adobe.ImporterFastMPEG.framework (9.1.0 - 9.1.0.174) <3F6D3629-AB19-3039-9572-56643959FE73> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterFastMPEG.bundle/Contents/MacOS/ImporterFastMPEG
             0x131d1a000 -        0x131d33fff +com.adobe.ImporterHDBarsAndTone.framework (9.1.0 - 9.1.0.174) <B30A42C1-AEE0-33D9-9BA9-BEA402A0C408> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterHDBarsAndTone.bundle/Contents/MacOS/ImporterHDB arsAndTone
             0x131d50000 -        0x131d6aff7 +com.adobe.ImporterLeader.framework (9.1.0 - 9.1.0.174) <75A7E034-9725-3736-A344-A672413C47EF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterLeader.bundle/Contents/MacOS/ImporterLeader
             0x131d94000 -        0x13217dfff +com.adobe.ImporterLumetri.framework (9.1.0 - 9.1.0.174) <BA056680-9617-3EDE-9EB8-C142A21D096C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterLumetri.bundle/Contents/MacOS/ImporterLumetri
             0x132432000 -        0x13245fff7 +com.adobe.ImporterMP3.framework (9.1.0 - 9.1.0.174) <DDB73EA8-A25C-3915-A2F7-590118D0B5C8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterMP3.bundle/Contents/MacOS/ImporterMP3
             0x13247a000 -        0x1324acfff +com.adobe.ImporterMPEG.framework (9.1.0 - 9.1.0.174) <78A91EDD-2523-3D10-A92D-E586C77180BA> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
             0x1324d9000 -        0x1327a1ff7 +com.mainconcept.mc.demux.mp4 (9.11 - 9.11.14.3173) <C3A22E66-8BDF-A21C-2543-E279739B915A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_demux_mp4.framework/Versions/9/mc_demux_mp4
             0x1327d9000 -        0x13280efff +com.adobe.QTParser.framework (9.1.0 - 9.1.0.174) <8D26EC9C-918E-3A1C-8AE9-2E379A13BC66> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x13282e000 -        0x132929fff +com.adobe.ImporterMXF.framework (9.1.0 - 9.1.0.174) <E5B97DA7-8342-307E-A4CD-D420FCD0EB47> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterMXF.bundle/Contents/MacOS/ImporterMXF
             0x1329f7000 -        0x1329fbfff +com.adobe.ImporterPNG.framework (9.1.0 - 9.1.0.174) <57B99337-DED5-3957-8D40-72C9D2E2EE30> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterPNG.bundle/Contents/MacOS/ImporterPNG
             0x132a05000 -        0x132a08ff7 +com.adobe.ImporterTarga.framework (9.1.0 - 9.1.0.174) <82EABAF6-8265-3DBE-9E75-3CB72D96BD26> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterTarga.bundle/Contents/MacOS/ImporterTarga
             0x132a0f000 -        0x132a16ff7 +com.adobe.ImporterTiff.framework (9.1.0 - 9.1.0.174) <4A753304-051E-37FD-8286-1E4743403142> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterTiff.bundle/Contents/MacOS/ImporterTiff
             0x132a1e000 -        0x132a25fff +com.adobe.ImporterWave.framework (9.1.0 - 9.1.0.174) <722CCDEB-88BE-3477-850A-C058382C13B5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterWave.bundle/Contents/MacOS/ImporterWave
             0x132a30000 -        0x132a66ff7 +com.adobe.ImporterXDCAMEX.framework (9.1.0 - 9.1.0.174) <0A65599A-FFF9-3075-AF81-F442350E3BB8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterXDCAMEX.bundle/Contents/MacOS/ImporterXDCAMEX
             0x132aa0000 -        0x132aa7fff +com.adobe.Invert.framework (9.1.0 - 9.1.0.174) <32048571-D76D-33B9-9655-172D9B664774> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Invert.bundle/Contents/MacOS/Invert
             0x132ab3000 -        0x132abdfff +com.adobe.Lens_Flare.framework (9.1.0 - 9.1.0.174) <1D9E9D65-A4EF-349E-92E1-626C6CA91D2A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Lens_Flare.bundle/Contents/MacOS/Lens_Flare
             0x132ac3000 -        0x132ac9ff7 +com.adobe.Lightning.framework (9.1.0 - 9.1.0.174) <A282988C-8B0A-3024-A084-77C2A89477E9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Lightning.bundle/Contents/MacOS/Lightning
             0x132acf000 -        0x132ad5ff7 +com.adobe.Linear_Wipe.framework (9.1.0 - 9.1.0.174) <2CEA513C-70AE-3009-BA22-F093ED6A1426> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Linear_Wipe.bundle/Contents/MacOS/Linear_Wipe
             0x132ae1000 -        0x132ae4ff7 +com.adobe.Magnify.framework (9.1.0 - 9.1.0.174) <1DF3B9BE-990D-3D48-8564-BAE25CF69EF3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Magnify.bundle/Contents/MacOS/Magnify
             0x132aea000 -        0x132af2ff7 +com.adobe.Median.framework (9.1.0 - 9.1.0.174) <AC16FB6A-4F7C-30D1-B9BF-9D61B9F4904F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Median.bundle/Contents/MacOS/Median
             0x132af8000 -        0x132af9ff7 +com.adobe.Mirror.framework (9.1.0 - 9.1.0.174) <8E56571F-51E2-3191-96AE-4806EB558E82> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Mirror.bundle/Contents/MacOS/Mirror
             0x132d00000 -        0x132f3dfef +com.adobe.ImporterRED.framework (9.1.0 - 9.1.0.174) <6D872053-B174-324B-8D8C-42E6A0953CF0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
             0x13301f000 -        0x133021fff +com.adobe.Motion.framework (9.1.0 - 9.1.0.174) <79BBAB7F-5B8B-33BA-BB1F-97F5D4DAA0E7> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
             0x133027000 -        0x13302dff7 +com.adobe.Noise.framework (9.1.0 - 9.1.0.174) <88D6817D-6E14-395B-8A0E-259378C7D6AB> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Noise.bundle/Contents/MacOS/Noise
             0x133039000 -        0x13303cfff +com.adobe.NoiseAlpha.framework (9.1.0 - 9.1.0.174) <9104DF82-918F-3801-8F95-EA03E74A9887> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/NoiseAlpha.bundle/Contents/MacOS/NoiseAlpha
             0x133041000 -        0x133046fff +com.adobe.NoiseHLS.framework (9.1.0 - 9.1.0.174) <195F13A9-0269-3C51-8303-C63DFED4B9A8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/NoiseHLS.bundle/Contents/MacOS/NoiseHLS
             0x13304c000 -        0x133051ff7 +com.adobe.NoiseHLSAuto.framework (9.1.0 - 9.1.0.174) <5F090D1C-78B6-3EAA-A5EA-BABEF650EA72> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/NoiseHLSAuto.bundle/Contents/MacOS/NoiseHLSAuto
             0x133057000 -        0x13305cfff +com.adobe.Offset.framework (9.1.0 - 9.1.0.174) <45624253-1B94-361D-A43E-82F41AAB5DC9> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Offset.bundle/Contents/MacOS/Offset
             0x133066000 -        0x133068fff +com.adobe.Opacity.framework (9.1.0 - 9.1.0.174) <FA01FCA6-8256-3117-828C-6595C89A5AA8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacity
             0x13306f000 -        0x133074fff +com.adobe.PaintBucket.framework (9.1.0 - 9.1.0.174) <90E57B52-69AA-3648-93EB-599EA3CFA3C2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/PaintBucket.bundle/Contents/MacOS/PaintBucket
             0x13307a000 -        0x133080ff7 +com.adobe.Posterize.framework (9.1.0 - 9.1.0.174) <F2C68972-5ADF-31C4-8FBB-7B58723A0F36> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Posterize.bundle/Contents/MacOS/Posterize
             0x13308d000 -        0x13308eff7 +com.adobe.Posterize_Time.framework (9.1.0 - 9.1.0.174) <32EA833E-D7DF-311E-B4C3-40D4DD890D99> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Posterize_Time.bundle/Contents/MacOS/Posterize_Time
             0x133094000 -        0x1330a4ff7 +com.adobe.PremiereFiltersMetaPlugin.framework (9.1.0 - 9.1.0.174) <D58BD5B2-1836-3765-B69F-304A52408C40> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereF iltersMetaPlugin
             0x1330b7000 -        0x1330bdfff +com.adobe.Radial_Wipe.framework (9.1.0 - 9.1.0.174) <CF7A3D17-C316-3B2F-8A04-C6C2AD64006C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Radial_Wipe.bundle/Contents/MacOS/Radial_Wipe
             0x1330c9000 -        0x1330cbfff +com.adobe.RadialShadow.framework (9.1.0 - 9.1.0.174) <22C78FF3-6B37-3774-9358-1EFD03CFAA50> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/RadialShadow.bundle/Contents/MacOS/RadialShadow
             0x1330d1000 -        0x1330d9fff +com.adobe.Ramp.framework (9.1.0 - 9.1.0.174) <27EB3389-786F-32FA-90A1-79EAB1771AFD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Ramp.bundle/Contents/MacOS/Ramp
             0x1330e5000 -        0x1330e9ff7 +com.adobe.RoughenEdges.framework (9.1.0 - 9.1.0.174) <1C5A34DA-E440-3333-9253-3C093F728809> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/RoughenEdges.bundle/Contents/MacOS/RoughenEdges
             0x1330ef000 -        0x1330f3ff7 +com.adobe.Sharpen.framework (9.1.0 - 9.1.0.174) <C329BE42-EFDC-3686-AFD1-B0F864B0FAC4> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Sharpen.bundle/Contents/MacOS/Sharpen
             0x133200000 -        0x1333d0fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
             0x133599000 -        0x1335b8fff +com.adobe.RecorderHDVMac.framework (9.1.0 - 9.1.0.174) <7F64785B-8C9D-3A2D-80C8-FF841ED1CD0A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
             0x1335df000 -        0x13361ffff  com.apple.glut (3.6.3 - GLUT-3.6.3) <03D23A85-359F-3162-B600-440F357E3392> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
             0x133694000 -        0x1336c3ff7 +com.mainconcept.mc.dec.mpa (9.11 - 9.11.14.3173) <2E8068BF-68E4-F492-56D7-2F2471BA9342> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/mc_dec_mpa.framework/Versions/9/mc_dec_mpa
             0x1336c8000 -        0x1336ecfff +com.adobe.RecorderQTKit.framework (9.1.0 - 9.1.0.174) <9D4F1A17-CC33-3048-8403-EB8EA367C8D0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
             0x133718000 -        0x1338f3fff +com.adobe.REDSourceSettings.framework (9.1.0 - 9.1.0.174) <EBFF991D-B54F-3C3F-818D-7BB771EEC18E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/REDSourceSettings.bundle/Contents/MacOS/REDSourceSettin gs
             0x133978000 -        0x134029f5f +com.adobe.RollingShutter.framework (9.1.0 - 9.1.0.174) <3DEB1798-2315-3F41-BF15-056F676D9EE0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/RollingShutter.bundle/Contents/MacOS/RollingShutter
             0x1340e8000 -        0x1340eeff7 +com.adobe.Set_Matte.framework (9.1.0 - 9.1.0.174) <F60F5461-58CB-3365-A9D9-6CA2E63E5F99> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Set_Matte.bundle/Contents/MacOS/Set_Matte
             0x1340fa000 -        0x1340ffff7 +com.adobe.SolidComposite.framework (9.1.0 - 9.1.0.174) <46B35263-1292-37CA-9BF4-06FB40298365> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/SolidComposite.bundle/Contents/MacOS/SolidComposite
             0x13410a000 -        0x13410fff7 +com.adobe.Spherize.framework (9.1.0 - 9.1.0.174) <CDB921CC-598E-336B-B730-0CF002D103F0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Spherize.bundle/Contents/MacOS/Spherize
             0x13411a000 -        0x1356a9f37 +com.adobe.Stabilizer.framework (9.1.0 - 9.1.0.174) <AC2E5CF6-EFC0-38D8-BF4A-E276AF263070> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Stabilizer.bundle/Contents/MacOS/Stabilizer
             0x135869000 -        0x13586afff +com.adobe.Strobe_Light.framework (9.1.0 - 9.1.0.174) <7602DB2A-5E63-39D4-8258-C3F291A673B6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Strobe_Light.bundle/Contents/MacOS/Strobe_Light
             0x13586f000 -        0x135870fff +com.adobe.Texturize.framework (9.1.0 - 9.1.0.174) <F12FB1FD-66F6-37DA-A7B4-99ADE742580C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Texturize.bundle/Contents/MacOS/Texturize
             0x135875000 -        0x13587bff7 +com.adobe.Threshold.framework (9.1.0 - 9.1.0.174) <808DB63F-8042-342F-A5E1-E655AC4FEA3E> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Threshold.bundle/Contents/MacOS/Threshold
             0x135888000 -        0x13588efff +com.adobe.Tint.framework (9.1.0 - 9.1.0.174) <E621ED01-8E96-35FE-9280-462E01CE2066> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Tint.bundle/Contents/MacOS/Tint
             0x13589a000 -        0x13589fff7 +com.adobe.Transform.framework (9.1.0 - 9.1.0.174) <0C72F0F1-DC9E-3B3E-8569-EA49DAD31908> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Transform.bundle/Contents/MacOS/Transform
             0x1358a6000 -        0x1358b6ff7 +com.adobe.TransitionsMetaPlugin.framework (9.1.0 - 9.1.0.174) <81AB052E-57D4-34DC-A2F0-EBAA60B47496> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMe taPlugin
             0x1358c9000 -        0x1358cbff7 +com.adobe.TransmitDesktopAudio.framework (9.1.0 - 9.1.0.174) <1E4639A0-73FB-3CE9-AF7E-67CC68FE86CE> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesk topAudio
             0x1358d4000 -        0x1358eaff7 +com.adobe.TransmitDV.framework (9.1.0 - 9.1.0.174) <2D0C523B-6B5D-384E-9F75-6337BB8E9CE8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
             0x135908000 -        0x13590dff7 +com.adobe.TransmitFullScreen.framework (9.1.0 - 9.1.0.174) <737ABAE6-16DA-3694-8BCE-8949AD33B0F8> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullSc reen
             0x135919000 -        0x135b06fe7 +com.adobe.TransmitScopes.framework (9.1.0 - 9.1.0.174) <B8E026FE-8F79-3835-A96C-0241B93135E0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
             0x13730f000 -        0x13732dfff +com.adobe.TurbulentDisplace.framework (9.1.0 - 9.1.0.174) <1B519823-97FF-3F42-95E8-83E77BA5B48A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/TurbulentDisplace.bundle/Contents/MacOS/TurbulentDispla ce
             0x13733b000 -        0x137343fff +com.adobe.Twirl.framework (9.1.0 - 9.1.0.174) <8E60669D-1265-3C7F-B62B-AB4AEB14D701> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
             0x137350000 -        0x137358fff +com.adobe.Unsharp_Mask.framework (9.1.0 - 9.1.0.174) <4929A1B8-8435-3F88-8474-797D4EFF4611> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Unsharp_Mask.bundle/Contents/MacOS/Unsharp_Mask
             0x137365000 -        0x13736bfff +com.adobe.Venetian_Blinds.framework (9.1.0 - 9.1.0.174) <8D8B6629-F8D5-3300-927A-F422FE8DC018> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Venetian_Blinds.bundle/Contents/MacOS/Venetian_Blinds
             0x137377000 -        0x13777bfff +AnalogDelayCore (???) <F3997977-F409-3385-AD3F-612249910306> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/AnalogDelay.vst3/Contents/Resources/AnalogDelayCor e.bundle/Contents/MacOS/AnalogDelayCore
             0x1377ca000 -        0x137bd7fff +ChorusFlangerCore (???) <AF8AB4FF-C573-3AA3-A589-8381E683368C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/ChorusFlanger.vst3/Contents/Resources/ChorusFlange rCore.bundle/Contents/MacOS/ChorusFlangerCore
             0x137c26000 -        0x13805cfff +ConvolutionReverbCore (???) <C87E0B86-288B-3CA2-A157-3CB8D5770DDD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/ConvolutionReverb.vst3/Contents/Resources/Convolut ionReverbCore.bundle/Contents/MacOS/ConvolutionReverbCore
             0x1380aa000 -        0x1384cbfff +DeEsserCore (???) <04E383F0-8FB9-31F4-A84E-9B8E9442B98D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/DeEsser.vst3/Contents/Resources/DeEsserCore.bundle /Contents/MacOS/DeEsserCore
             0x13851a000 -        0x138937fff +DeHummerCore (???) <84151AF2-68F7-32FF-A628-427687D90F96> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/DeHummer.vst3/Contents/Resources/DeHummerCore.bund le/Contents/MacOS/DeHummerCore
             0x138985000 -        0x138da7fff +DistortionCore (???) <C660EA06-768B-3044-8135-642C51907609> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/Distortion.vst3/Contents/Resources/DistortionCore. bundle/Contents/MacOS/DistortionCore
             0x138df6000 -        0x13923efff +GuitarSuiteCore (???) <FCE989F5-563A-3240-A61E-33537BEFDBA3> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/GuitarSuite.vst3/Contents/Resources/GuitarSuiteCor e.bundle/Contents/MacOS/GuitarSuiteCore
             0x139290000 -        0x1396b3fff +MultiBandCompressorCore (???) <B877EB71-CEAC-3906-8A85-2EEA5B5EFD36> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/MultiBandCompressor.vst3/Contents/Resources/MultiB andCompressorCore.bundle/Contents/MacOS/MultiBandCompressorCore
             0x139703000 -        0x139b0eff7 +PhaserCore (???) <42CB945B-B4EA-3D51-B39B-DEE056335789> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/Phaser.vst3/Contents/Resources/PhaserCore.bundle/C ontents/MacOS/PhaserCore
             0x139b5d000 -        0x139fd5fff +SimpleMasteringCore (???) <2847B4DC-3016-3728-B755-FE533DADC031> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/SimpleMastering.vst3/Contents/Resources/SimpleMast eringCore.bundle/Contents/MacOS/SimpleMasteringCore
             0x13a029000 -        0x13a421ff7 +SingleBandCompressorCore (???) <8094AFE1-2B6A-3A48-9735-43AD05D9A20F> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/SingleBandCompressor.vst3/Contents/Resources/Singl eBandCompressorCore.bundle/Contents/MacOS/SingleBandCompressorCore
             0x13a46f000 -        0x13a8b5fff +SurroundReverbCore (???) <B7FACE86-7421-3827-AF7B-2DE36097F0C6> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/SurroundReverb.vst3/Contents/Resources/SurroundRev erbCore.bundle/Contents/MacOS/SurroundReverbCore
             0x13a904000 -        0x13acb0ff7 +TubeModeledCompressorCore (???) <8777C403-CC8A-3B21-9F5A-FE48529E9F38> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/TubeModeledCompressor.vst3/Contents/Resources/Tube ModeledCompressorCore.bundle/Contents/MacOS/TubeModeledCompressorCore
             0x13acfa000 -        0x13b10dfff +VocalEnhancerCore (???) <B2E9B8F6-C824-3E3A-A3F7-A81B0587FD9A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/VST3/VocalEnhancer.vst3/Contents/Resources/VocalEnhance rCore.bundle/Contents/MacOS/VocalEnhancerCore
             0x13b15b000 -        0x13b15ffff +com.adobe.Wave_Warp.framework (9.1.0 - 9.1.0.174) <FE4191D9-99B9-330A-B89E-3D8654FEAD78> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Wave_Warp.bundle/Contents/MacOS/Wave_Warp
             0x13b164000 -        0x13b5b9fff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
             0x13ba6a000 -        0x13ba6dff7 +com.adobe.Write_on.framework (9.1.0 - 9.1.0.174) <8F75F881-25B0-3492-8FF8-E6683DCC14F5> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/Write_on.bundle/Contents/MacOS/Write_on
             0x13ba73000 -        0x13bad0fff +com.adobe.PlayerMediaCore.framework (9.1.0 - 9.1.0.174) <83CB39ED-EA49-3162-A08F-590F20B56D8A> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
             0x13bb29000 -        0x13bb59fff +com.adobe.RendererCPU.framework (9.1.0 - 9.1.0.174) <D5B71216-D1B1-33E2-9B87-D0DA91DE1577> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
             0x13bb8f000 -        0x13bb97fff +com.adobe.ExporterCoreAudio.framework (9.1.0 - 9.1.0.174) <8742F88D-6763-3682-8F5C-526645BC39DF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCoreAud io
             0x13bba3000 -        0x13bbb1fff +com.adobe.AudioConverter.framework (9.1.0 - 9.1.0.174) <A3E9DDA4-C48B-3B1C-9262-A2A8F3440ED2> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x13bbc2000 -        0x13bcf2ffb  com.apple.audio.units.Components (1.13 - 1.13) <31056DB7-E93B-342A-8717-3313B2CE86A1> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
             0x13bdab000 -        0x13c09bfe7  com.apple.audio.codecs.Components (6.0 - 6.0) <709ADB37-A773-3543-8D86-7A01E83B19FA> /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x13c150000 -        0x13c1a0fff +com.adobe.ExporterQuickTimeHost.framework (9.1.0 - 9.1.0.174) <8CC26B63-FF47-38B7-9898-D6C138E79A8B> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQui ckTimeHost
             0x13c1db000 -        0x13c1f6ff7 +com.adobe.QTWriter.framework (9.1.0 - 9.1.0.174) <D3337DE5-89EA-30F1-AE04-AE4172498CFF> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
             0x13c303000 -        0x13c676fef +com.adobe.ImporterQuickTime.framework (9.1.0 - 9.1.0.174) <4D853D55-C061-3A24-A5AB-4F88F4247DFD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQuickTi me
             0x13c9cd000 -        0x13cabefff +com.adobe.adobe_caps (adobe_caps 9.0.0.28 - 9.0.0.28) <5FA2F01A-0E75-3655-8CC0-C09088813A57> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
             0x13cace000 -        0x13cc0afff +IMSLib.dylib (9.0.1.27 - 9.0.1.27) <34A6D87D-661D-39E2-BD7D-80FB16812C1E> /Library/Application Support/Adobe/*/IMSLib.dylib
             0x13cc2a000 -        0x13cca4ff7  com.apple.xquery (1.3.1 - 30) <AAEFB337-E58A-39F5-8C19-6E990401B72F> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
             0x13cf9e000 -        0x13cfd8fff +com.adobe.pip (7.3.1.70) <62832BC3-E82F-3648-B0D2-67EFD1263C89> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
             0x13dbc3000 -        0x13dbecfff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
             0x13df5a000 -        0x13df62fff +com.adobe.PostProcessCC.framework (9.1.0 - 9.1.0.174) <9B3E100F-42C6-39C5-8675-9BCDAFBC50AD> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PostProcessCC.bundle/Contents/MacOS/PostProcessCC
             0x1437df000 -        0x1437dfff7 +com.adobe.dvahapticcore.framework (9.1.0 - 9.1.0.0) <0A26F94F-8D32-32CE-B5C0-970C6FD8D32D> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/dvahapticcore.framework/dvahapticcore
             0x147b9c000 -        0x147baeff7 +com.adobe.PostProcessFTP.framework (9.1.0 - 9.1.0.174) <E4DEE37D-43D5-3C28-81E9-E5554250B423> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PostProcessFTP.bundle/Contents/MacOS/PostProcessFTP
             0x147cd9000 -        0x147cddfff  libFontRegistryUI.dylib (155.1) <79B125DD-4565-391D-A084-DB4F2A7CF322> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
             0x17cdab000 -        0x17cdf4fff +com.adobe.PostProcessFacebook.framework (9.1.0 - 9.1.0.174) <E0178923-9BA3-3FC4-A5FA-CC9C7E0D570C> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PostProcessFacebook.bundle/Contents/MacOS/PostProcessFaceboo k
             0x1e6fef000 -        0x1e70ecfff  com.apple.AMDMTLBronzeDriver (1.40.15 - 1.4.0) <72BCEF76-AE00-3BAB-83ED-85BB450D878A> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
             0x1f3abd000 -        0x1f3b0ffff +com.adobe.CCSyncPlugin.framework (8.2.0 - 8.2.0.16) <1D144922-BE78-38B2-BE25-75DD65CE3CA1> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/CCSyncPlugin.framework/Versions/A/CCSyncPlugin
             0x1f7947000 -        0x1f7992ff7 +com.adobe.PostProcessVimeo.framework (9.1.0 - 9.1.0.174) <0B3540ED-69D8-3E8C-B977-1B91A3425D24> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PostProcessVimeo.bundle/Contents/MacOS/PostProcessVimeo
             0x1f9001000 -        0x1f9047ff7 +com.adobe.PostProcessYouTube.framework (9.1.0 - 9.1.0.174) <0D53016E-57F8-35A0-BF57-2320BA2B00B0> /Applications/Adobe Premiere Pro CC 2015/Adobe Premiere Pro CC 2015.app/Contents/Frameworks/PostProcessYouTube.bundle/Contents/MacOS/PostProcessYouTube
             0x237533000 -        0x23754effb  com.apple.security.csparser (3.0 - 57337.20.44) <2E927C7E-BC87-3EDB-8E60-84D95D6E3B08> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
          0x7fff61c98000 -     0x7fff61ccefa7  dyld (360.18) <1A7F8274-FC32-3B86-9979-66B8F2B7B5E2> /usr/lib/dyld
          0x7fff81e3a000 -     0x7fff82045fff  libFosl_dynamic.dylib (16.24) <363B7CEE-B662-32F3-9D7B-245E64927C35> /usr/lib/libFosl_dynamic.dylib
          0x7fff820a8000 -     0x7fff820b1ff7  com.apple.CommonAuth (4.0 - 2.0) <B2CEE6B5-9464-35F2-9339-9F52001C8A27> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff820b2000 -     0x7fff820bbff7  libsystem_pthread.dylib (138.10.4) <327CECD0-B881-3153-8FCC-4FD4818B7F16> /usr/lib/system/libsystem_pthread.dylib
          0x7fff82157000 -     0x7fff8222dff7  com.apple.DiskImagesFramework (10.11.2 - 417.1) <4A510EE1-893E-38A8-AD09-5ACC9F2BE86F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
          0x7fff82231000 -     0x7fff8224cfff  com.apple.aps.framework (4.0 - 4.0) <894B1FD6-6EBE-302B-947B-D5813DABEDF0> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
          0x7fff822fc000 -     0x7fff824a2ff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <F912765D-88ED-3324-B512-3778A8CE878B> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff824e7000 -     0x7fff82504fff  com.apple.pluginkit.framework (1.0 - 1) <AE3DFBE5-A012-345F-8A77-520686B6FBFF> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
          0x7fff82505000 -     0x7fff83128ff7  com.apple.AppKit (6.9 - 1404.34) <FB9C0E8D-8E07-35CD-91D8-7A3869B8EB03> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff83129000 -     0x7fff8312afff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fff8312b000 -     0x7fff8318efff  libAVFAudio.dylib (161.2) <C42EF0ED-56B2-387F-B188-C42FB8A1B7AB> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
          0x7fff83201000 -     0x7fff83203fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <B461272B-2DFF-3CA9-8DCA-689B2AAC0379> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
          0x7fff83204000 -     0x7fff8321bfff  com.apple.ScriptingBridge (1.3.3 - 68) <4C81A32D-9B9F-354F-9857-E5BD0852290A> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
          0x7fff83222000 -     0x7fff83240fff  libsystem_kernel.dylib (3248.20.55) <0E688457-4915-36DD-8798-5C2EDEE3F1A3> /usr/lib/system/libsystem_kernel.dylib
          0x7fff83241000 -     0x7fff83256fff  com.apple.ToneKit (1.0 - 1) <298E6855-B818-3949-85ED-08CF12ACEE59> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
          0x7fff833bf000 -     0x7fff833c2ffb  libScreenReader.dylib (425.102) <BDC46586-4925-38F2-85D3-BD23DB6E6D43> /usr/lib/libScreenReader.dylib
          0x7fff8366d000 -     0x7fff8366ffff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
          0x7fff83670000 -     0x7fff83916ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff83917000 -     0x7fff83933fff  com.apple.GenerationalStorage (2.0 - 239) <EE667C63-3ADF-34D3-A8A7-316B66C7E290> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff83934000 -     0x7fff83961fff  libdispatch.dylib (501.20.1) <324C9189-2AF3-3356-847F-6F4CE1C6E901> /usr/lib/system/libdispatch.dylib
          0x7fff83988000 -     0x7fff83b2fffb  com.apple.avfoundation (2.0 - 1046.9.2) <FE83988E-9A6D-3386-ACD7-A0A4D7A006DF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff83c0b000 -     0x7fff83c22fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
          0x7fff83c49000 -     0x7fff83c4afff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fff83e71000 -     0x7fff850c2fff  com.apple.CoreGraphics (1.600.0 - 948) <5C9D3150-55FF-3C12-806C-D74837E12B1A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fff852b1000 -     0x7fff85613f3f  libobjc.A.dylib (680) <9F45830D-F1D5-3CDF-9461-1A5477ED7D1E> /usr/lib/libobjc.A.dylib
          0x7fff85699000 -     0x7fff856c8ff7  com.apple.securityinterface (10.0 - 55065.20.1) <EDBD990A-0960-3DBB-BB42-43A36F49477F> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fff856c9000 -     0x7fff8575efff  com.apple.ink.framework (10.9 - 214) <6B573126-A6E9-357F-B36A-AA5BDC0BEAF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff85825000 -     0x7fff8582dfff  com.apple.NetFS (6.0 - 4.0) <BDD59EC5-D399-31EA-9B2A-60E3A859FC42> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff85839000 -     0x7fff85852ffb  com.apple.openscripting (1.7 - 169) <DB62452B-3C83-3B7A-8349-7536F4E1532B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff85885000 -     0x7fff85888ff7  libsystem_sandbox.dylib (460.20.9) <1C891336-1B25-365D-B43E-96D5B3BE66B0> /usr/lib/system/libsystem_sandbox.dylib
          0x7fff85889000 -     0x7fff858a2fff  com.apple.CFOpenDirectory (10.11 - 194) <C21F33AA-CD06-3163-A1F3-1D116F788A11> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff858a3000 -     0x7fff858adfff  com.apple.NetAuth (6.0 - 6.0) <19E44307-6F9F-3DEC-8C1A-4685BC252A35> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fff858af000 -     0x7fff85961fff  com.apple.cloudkit.CloudKit (481.8 - 481.8) <E927AE82-8E55-38A4-BE6E-4D0829272653> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
          0x7fff85962000 -     0x7fff85971ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <0D1BCC13-76B9-3C19-85AA-D8DD8299F007> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff85ad7000 -     0x7fff85b00fff  libxpc.dylib (756.20.4) <61AB4610-9304-354C-9E9B-D57198AE9866> /usr/lib/system/libxpc.dylib
          0x7fff85b01000 -     0x7fff85b0cfff  libGL.dylib (12.0.40.6) <3F719CC4-8024-33B5-A49D-15FAE1955A12> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff85b0d000 -     0x7fff85c1bff3  com.apple.desktopservices (1.10 - 1.10) <0BAED9FA-EFA5-3DA0-8715-043FD2400B77> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff85c1e000 -     0x7fff85c32fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <8D8A190B-3C08-3624-8DC6-E9EBE22BC3BB> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
          0x7fff85c33000 -     0x7fff85c85fff  com.apple.AppleVAFramework (5.0.32 - 5.0.32) <082B5F3A-6FB2-3444-9B84-F8675BFCE517> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff85c89000 -     0x7fff86085fff  libLAPACK.dylib (1159) <7618C270-D895-345C-B08B-102286A05A55> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff86086000 -     0x7fff86086fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F450DC3F-837D-35CB-97F3-5835E789EF02> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff860bd000 -     0x7fff8614afff  libsystem_c.dylib (1082.20.4) <EAB38A6C-8671-3B13-B500-90EC1B912063> /usr/lib/system/libsystem_c.dylib
          0x7fff8614b000 -     0x7fff86185ff7  com.apple.DebugSymbols (132 - 132) <BDF57386-2881-35BD-9310-36904C764E93> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff86366000 -     0x7fff86376ff3  com.apple.ProtocolBuffer (1 - 242) <127AF54F-615B-362A-A221-3E758C46A235> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
          0x7fff8651e000 -     0x7fff86554fff  libssl.0.9.8.dylib (59) <DC4B66A8-AFED-33A9-A5B8-D2088C6EF5B2> /usr/lib/libssl.0.9.8.dylib
          0x7fff86967000 -     0x7fff86973ff7  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <8B6C0DB6-8744-3AEB-BD00-9FA6967E7125> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
          0x7fff86974000 -     0x7fff8697cfff  libsystem_networkextension.dylib (385.20.6) <DC8A102A-BF02-31A4-8914-65C34DF6B592> /usr/lib/system/libsystem_networkextension.dylib
          0x7fff86be9000 -     0x7fff86c7ffff  com.apple.ColorSync (4.9.0 - 4.9.0) <8BB8DF19-C24F-39F8-8B90-AD186D74587C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff870aa000 -     0x7fff870daff7  libsandbox.1.dylib (460.20.9) <F0002EB6-27DF-38D5-AA6F-DE2A27C9C0A3> /usr/lib/libsandbox.1.dylib
          0x7fff870db000 -     0x7fff870ddfff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
          0x7fff87465000 -     0x7fff8747bff7  libsystem_coretls.dylib (83.20.8) <30AF7134-6CA7-3582-B9D3-507D6ED19A88> /usr/lib/system/libsystem_coretls.dylib
          0x7fff8749f000 -     0x7fff874c6fff  com.apple.ChunkingLibrary (167 - 167) <508861C9-F5E6-343B-8DD0-D71DFE49ECFD> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fff876e3000 -     0x7fff876f4fff  libSparseBLAS.dylib (1159) <3C520738-8F54-36E4-B966-97D1F886F59E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
          0x7fff876f5000 -     0x7fff877a5fff  com.apple.backup.framework (1.7.2 - 1.7.2) <890AF1EE-CFC9-3DAB-B236-88E203B4ADBC> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fff877b3000 -     0x7fff877d4fff  com.apple.Sharing (442.9.1 - 442.9.1) <672DE6DF-98E0-30A4-BA25-44BDE188D0BE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fff87826000 -     0x7fff87d7dfff  com.apple.MediaToolbox (1.0 - 1731.15.33) <16374746-DF5E-3103-994B-74CF151BD06A> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff880a6000 -     0x7fff880daff7  com.apple.CoreVideo (1.8 - 191.2) <88D903C8-E608-320E-8ACD-11E5B3003C18> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff880db000 -     0x7fff88118ff3  com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
          0x7fff88119000 -     0x7fff882dffff  com.apple.ImageIO.framework (3.3.0 - 1442) <1AE1EF1A-EA91-3453-A6F4-C11BD91B8D66> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fff882e0000 -     0x7fff8845efff  com.apple.UIFoundation (1.0 - 436.1) <8C254BB0-1DED-36A2-AAAF-786EB19CCE39> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
          0x7fff8845f000 -     0x7fff8866cffb  libicucore.A.dylib (551.41) <CFFD7342-A7D6-323A-AC14-B9EECF6EFFED> /usr/lib/libicucore.A.dylib
          0x7fff8866d000 -     0x7fff88698ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
          0x7fff8894c000 -     0x7fff88997ff7  com.apple.CoreMediaIO (703.0 - 4791) <7D342CFF-D074-3CAB-B76C-E1F878740AA6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff889a7000 -     0x7fff889c6ff7  com.apple.framework.Apple80211 (11.0 - 1110.33) <EC583C00-9073-39C3-B613-96D5BA0FDD32> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fff88a2b000 -     0x7fff88a50ff7  libPng.dylib (1442) <C13F5341-C342-3733-AF4C-434F2D8FF0A8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fff88a5d000 -     0x7fff88ae6ff7  com.apple.PerformanceAnalysis (1.0 - 1) <67DE6CD9-AA72-3664-9594-0161D03D4919> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fff88ae7000 -     0x7fff8918dffb  com.apple.JavaScriptCore (11601 - 11601.3.7) <F9351983-16A7-312D-9202-02873CBC1D9D> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff89191000 -     0x7fff891edfff  libTIFF.dylib (1442) <28DF1565-3705-3ED3-B570-C9CB12376D2E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fff89900000 -     0x7fff899bafff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <C4EC1EA7-E2AA-30F7-83CC-79171CDD50AA> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
          0x7fff899d5000 -     0x7fff899ddfff  libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
          0x7fff8a23d000 -     0x7fff8a615fef  com.apple.CoreAUC (214.0.0 - 214.0.0) <B43C7811-38A4-3F9A-9417-FD8F4B55EA82> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff8a616000 -     0x7fff8a69efff  com.apple.CoreSymbolication (3.1 - 58048.1) <2DFAF855-0528-370D-B4B0-EE0236766D9D> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff8a69f000 -     0x7fff8a6a1ff7  libquarantine.dylib (80) <163CF63A-7455-3D1F-AE57-8C4475A9204C> /usr/lib/system/libquarantine.dylib
          0x7fff8a6d0000 -     0x7fff8a81afc7  com.apple.coreui (2.1 - 365.2) <727C55D3-503A-3EC4-8A23-C984E320F65F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff8a8dc000 -     0x7fff8a8ddfff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
          0x7fff8a96e000 -     0x7fff8a9baff3  com.apple.HIServices (1.22 - 549) <14FB5BB6-8456-39F9-A694-8A1C12426880> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff8a9bb000 -     0x7fff8aaa6ff7  com.apple.QuickLookUIFramework (5.0 - 696.3) <8416C721-85D3-3F4A-9916-2CB4640BB0CB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff8aaa7000 -     0x7fff8aab2fff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fff8ac4f000 -     0x7fff8ac90ff7  libGLU.dylib (12.0.40.6) <D51C3497-7EC6-37F4-9E8D-B9BFED23974D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff8adf8000 -     0x7fff8ae00ff7  libcldcpuengine.dylib (2.6.4.1) <A065D1E1-ECCE-3AD0-9B90-7515318FA4CF> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fff8ae01000 -     0x7fff8b0e6ff3  com.apple.CoreServices.CarbonCore (1136 - 1136) <FFBDE3BF-0BB3-37A2-8A44-6E25284CC348> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff8b0ed000 -     0x7fff8b149fff  com.apple.Suggestions (5.0 - 180) <BCC095D1-3BF6-3AC6-9074-948ECE9885DF> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
          0x7fff8b14a000 -     0x7fff8b16cfff  com.apple.IconServices (68.1 - 68.1) <3ECAA762-1193-3D76-A25F-7680DB3A957E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fff8ba7f000 -     0x7fff8ba8afff  com.apple.DirectoryService.Framework (10.11 - 194) <159606E0-F3AF-36B0-9744-4BFE1DA3EC74> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fff8bb60000 -     0x7fff8bb77fff  libsystem_asl.dylib (322) <3C2D3ACD-0DD1-337A-8247-44A910D67A65> /usr/lib/system/libsystem_asl.dylib
          0x7fff8bbf4000 -     0x7fff8bc94ff7  com.apple.Metadata (10.7.0 - 972.16) <98CA1355-3E2C-364C-9C4F-3CA286DB08A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff8bc95000 -     0x7fff8bc95fff  libenergytrace.dylib (10) <A4AE7CBD-CF0A-3A74-8098-B642CE496611> /usr/lib/libenergytrace.dylib
          0x7fff8bc96000 -     0x7fff8bc96fff  com.apple.CoreServices (728.6 - 728.6) <1FC9300C-6D3D-330C-829C-C8F094BC38C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff8c5cc000 -     0x7fff8c636ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <6A535459-6A8A-3D60-986B-EE7ED833A9C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fff8c637000 -     0x7fff8c63cfff  com.apple.MediaAccessibility (1.0 - 79) <CCF71DC1-BB6A-3227-BD1B-AFD172592A63> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fff8c63d000 -     0x7fff8c63effb  libremovefile.dylib (41) <B8D1A5FC-CFD5-3AAB-8A10-14DDC129710A> /usr/lib/system/libremovefile.dylib
          0x7fff8c63f000 -     0x7fff8c642fff  com.apple.Mangrove (1.0 - 1) <7919AD18-0EDE-3408-A6AC-A9121B8D857F> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fff8c643000 -     0x7fff8c643fff  libOpenScriptingUtil.dylib (169) <5CE2080C-398C-34C2-8D65-B9C627AACA19> /usr/lib/libOpenScriptingUtil.dylib
          0x7fff8c644000 -     0x7fff8c8d4ff7  com.apple.RawCamera.bundle (6.18 - 828) <CB7F6CCD-3753-3147-816A-B613F500AE33> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff8c968000 -     0x7fff8c97dfff  com.apple.AppContainer (4.0 - 261.20.7) <30414623-E68F-31A1-9794-1C052391E900> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fff8c97e000 -     0x7fff8c9d3ff7  com.apple.AE (701 - 701) <FB22BE84-9CB8-36BF-8061-F93D716C0A84> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff8c9d4000 -     0x7fff8cb60ff7  libGLProgrammability.dylib (12.0.40.6) <FEFAFD3E-D2A1-3ECA-BD45-61546C294F0B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff8cb61000 -     0x7fff8cb80ff7  com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
          0x7fff8dad6000 -     0x7fff8dad9ff7  libCoreFSCache.dylib (119.5) <C7008E64-0AFB-3446-929E-BC3F76DEF049> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
          0x7fff8e131000 -     0x7fff8e163fff  libTrueTypeScaler.dylib (158.4) <4AEF2CB9-407D-3FEB-B0BD-4DB162EB9519> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff8e18a000 -     0x7fff8e1dcfff  com.apple.CloudDocs (1.0 - 383.5) <BBE4C32D-75E6-3EDD-A787-625BDD66DA20> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
          0x7fff8e1dd000 -     0x7fff8e2cdfff  libJP2.dylib (1442) <50DD1F07-6517-372B-8244-2AD19702385C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fff8e2ce000 -     0x7fff8e2dffff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
          0x7fff8e2e0000 -     0x7fff8e2e0fff  libmetal_timestamp.dylib (600.0.43.5) <A2B1C6F9-50D0-336B-A057-A7FBE2D7BDE2> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
          0x7fff8e2e1000 -     0x7fff8e358fe7  libcorecrypto.dylib (335.20.1) <C6BD205F-4ECE-37EE-BCAB-A76F39CDCFFA> /usr/lib/system/libcorecrypto.dylib
          0x7fff8e364000 -     0x7fff8e376fff  libsasl2.2.dylib (209) <02BF4226-23E9-34EC-A727-CF0E205395F8> /usr/lib/libsasl2.2.dylib
          0x7fff8e3e8000 -     0x7fff8e45eff7  com.apple.MMCS (1.3 - 351) <13D01D37-66F0-30BB-AA7E-D1D348F738E3> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
          0x7fff8e45f000 -     0x7fff8e754fff  com.apple.HIToolbox (2.1.1 - 807.2) <D9338BEF-CA84-3085-B6CB-4E93B3B9A2E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff8e7ec000 -     0x7fff8e810fff  libJPEG.dylib (1442) <9616E8A5-60BA-3C70-8F37-A33055D227C8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fff8e811000 -     0x7fff8e872ff7  libsystem_network.dylib (583.20.10) <1C0410F3-F66E-3B0D-B8AD-0D49AB15A529> /usr/lib/system/libsystem_network.dylib
          0x7fff8e873000 -     0x7fff8e877fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
          0x7fff8e878000 -     0x7fff8e8a4fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <FDCA9F2D-E06A-3DEC-8E1A-7535BAE68B62> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
          0x7fff8e91c000 -     0x7fff8ed4afff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <B8482831-77BD-3FBC-A0B1-12502353AA57> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fff8ed4b000 -     0x7fff8ed90ff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <72156BE7-0804-3F90-9AF9-14C4739430C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
          0x7fff8ed91000 -     0x7fff8ed9ffff  com.apple.ToneLibrary (1.0 - 1) <E92CE7C6-43CB-3312-9B1F-77353FE2C5DD> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
          0x7fff8ee18000 -     0x7fff8ee1bfff  libCoreVMClient.dylib (119.5) <CD7DE25C-D7AD-3ECD-BEEC-F57992A4A08E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff8ee1c000 -     0x7fff8ee1cfff  com.apple.Cocoa (6.11 - 22) <0A634D46-B468-3CBC-B2A0-16C381C11BF2> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff8ee92000 -     0x7fff8eea0ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
          0x7fff8eee4000 -     0x7fff8eefeff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
          0x7fff8eeff000 -     0x7fff8ef04fff  com.apple.DiskArbitration (2.7 - 2.7) <B7FAE647-156A-30C8-BA8B-69D188D02602> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff8ef05000 -     0x7fff8ef73ff7  com.apple.ApplicationServices.ATS (377 - 394.3) <66E581EE-67E2-39E9-97A7-0614F334B9B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff8ef74000 -     0x7fff8f083fe7  libvDSP.dylib (563.4) <A95572FF-D40C-32A8-9F36-5B1FD297A0EC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff8f23f000 -     0x7fff8f250ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
          0x7fff8f251000 -     0x7fff8f2b1fff  com.apple.QuickLookFramework (5.0 - 696.3) <D20C8962-7BB8-3A2C-BB80-5B61259B50F2> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff8f2b2000 -     0x7fff8f62dffb  com.apple.VideoToolbox (1.0 - 1731.15.33) <33AED54A-87AE-330F-BAAD-FB8389C3E686> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff8f62e000 -     0x7fff8f715ff7  libcrypto.0.9.8.dylib (59) <ED1C2A26-8FFC-30FF-8726-FF952EF94ADF> /usr/lib/libcrypto.0.9.8.dylib
          0x7fff8f73e000 -     0x7fff8fbafff3  com.apple.GeoServices (1.0 - 1151.2.13.9) <52A8FBB6-267C-3371-A516-264572B5800F> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
          0x7fff8fbb0000 -     0x7fff8fc24fff  com.apple.Heimdal (4.0 - 2.0) <009F223D-B89B-376B-94F5-6D982CBEF771> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff8fc25000 -     0x7fff8fc2eff3  libsystem_notify.dylib (150.20.3) <243FADE1-255A-3B78-8033-F336CD64B817> /usr/lib/system/libsystem_notify.dylib
          0x7fff8fc2f000 -     0x7fff8fc45fff  com.apple.CoreMediaAuthoring (2.2 - 953) <D74307B6-EC7E-3E5F-B2CF-7CE7A183F0F0> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff8fc46000 -     0x7fff8fc48ff7  libsystem_configuration.dylib (802.20.7) <5FD79070-36CC-3D02-BEA7-BB5D2AE97D5D> /usr/lib/system/libsystem_configuration.dylib
          0x7fff8fe5e000 -     0x7fff8fe5efff  com.apple.ApplicationServices (48 - 48) <DD9C4070-C0FC-3984-BCED-72E6E99838FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff8fe62000 -     0x7fff8fe67ff7  libmacho.dylib (875.1) <CB745E1F-4885-3F96-B38B-2093DF488FD5> /usr/lib/system/libmacho.dylib
          0x7fff8fedd000 -     0x7fff8ff2dff7  com.apple.Symbolication (1.4 - 58044) <2EC9F04A-4370-39C8-8549-FC6411D87463> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fff8ff2e000 -     0x7fff8ffbdff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
          0x7fff90028000 -     0x7fff90030fe7  libsystem_platform.dylib (74.10.3) <D3A27E10-7F08-3603-ACC8-7A92B2C04BAB> /usr/lib/system/libsystem_platform.dylib
          0x7fff90031000 -     0x7fff90032fff  libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
          0x7fff90033000 -     0x7fff90034ff7  libodfde.dylib (23) <5475AB3E-8C9A-3279-8294-E565293F7EF1> /usr/lib/libodfde.dylib
          0x7fff9032e000 -     0x7fff90330fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
          0x7fff90331000 -     0x7fff90341fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
          0x7fff90394000 -     0x7fff90396ff7  com.apple.xpc.ServiceManagement (1.0 - 1) <3777FD15-B6F3-32A2-A8E3-3E8CE3B8D5E7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fff90397000 -     0x7fff903d5ff7  libGLImage.dylib (12.0.40.6) <7A41B04A-8282-3530-809F-FAC4AC953CD2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff903e0000 -     0x7fff903e3ffb  libdyld.dylib (360.18) <5F3777A7-F07E-3D5F-BFA3-A920FF4170ED> /usr/lib/system/libdyld.dylib
          0x7fff903e4000 -     0x7fff903eaff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <FA5CB89A-2BFE-38CC-B1A3-E48792CD898C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff903eb000 -     0x7fff903f3fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <D44F75E7-C679-3C21-AD76-8FA8A2B898F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
          0x7fff9049f000 -     0x7fff90506fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <BEC7B27E-8CE8-3DAB-BFDF-6C240C6A4B12> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fff90507000 -     0x7fff90538fff  com.apple.GSS (4.0 - 2.0) <25DECD44-0905-3E53-9480-DE7BEB84DB83> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff9059b000 -     0x7fff9059bff7  libkeymgr.dylib (28) <09397E01-6066-3179-A50C-2CE666FDA929> /usr/lib/system/libkeymgr.dylib
          0x7fff905f9000 -     0x7fff90605fff  com.apple.CacheDelete (1.0 - 1) <22460C98-F7E0-350D-8C08-5406B9CF79B9> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
          0x7fff9060d000 -     0x7fff90659fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <449D8AB5-7891-32D0-9DC5-C90FE10DC0BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff9065a000 -     0x7fff9065afff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <D2E8EA94-3828-3D7C-87E2-97E4CD00269D> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff9065b000 -     0x7fff9065dfff  libCVMSPluginSupport.dylib (12.0.40.6) <8E97A929-0E60-3F6D-ACF7-67F700BE2530> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff90d87000 -     0x7fff90df6fff  com.apple.SearchKit (1.4.0 - 1.4.0) <CA50106F-F45A-36AC-AD2B-C3B19F5DD52F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff90e01000 -     0x7fff90e28fff  com.apple.ProtectedCloudStorage (1.0 - 1) <F9E1BDE2-16AF-34B5-B7FE-127D511BDC9E> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
          0x7fff90e29000 -     0x7fff91075ff7  com.apple.AddressBook.framework (9.0 - 1679.4) <B5C3056C-F9FD-3B28-A867-9548A9AC3ACA> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
          0x7fff91076000 -     0x7fff91078ff7  com.apple.SafariServices.framework (11601 - 11601.3.9) <86B9C242-287E-3A40-9F3A-AABAE3538C17> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
          0x7fff910b0000 -     0x7fff910dfffb  libsystem_m.dylib (3105) <26655445-CA97-321E-B221-801CB378D1AA> /usr/lib/system/libsystem_m.dylib
          0x7fff910e0000 -     0x7fff91126ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
          0x7fff91149000 -     0x7fff91150ff7  libcompiler_rt.dylib (62) <D3C4AB40-23B4-3BC6-8C38-5B8758D14E80> /usr/lib/system/libcompiler_rt.dylib
          0x7fff91151000 -     0x7fff91243ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
          0x7fff9128f000 -     0x7fff912ddfff  libcurl.4.dylib (90) <FF42FAA6-E71B-3D0D-B5C9-B05BD2460C9A> /usr/lib/libcurl.4.dylib
          0x7fff91311000 -     0x7fff91338fff  com.apple.shortcut (2.16 - 93) <D9DD2F6A-4AC7-38BD-A3B6-A9682EFCCE2E> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff91339000 -     0x7fff9145eff7  com.apple.LaunchServices (728.6 - 728.6) <8658230B-5894-3244-BDBA-A6C9DD347219> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff9145f000 -     0x7fff914bcfff  com.apple.CoreServices.OSServices (728.6 - 728.6) <E86385ED-70AA-3371-8E58-8FFDEF81C854> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff9153b000 -     0x7fff91540fff  com.apple.ImageCapture (9.0 - 9.0) <33F7822F-1124-3D73-AF66-515EA32A4A47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff91541000 -     0x7fff9157bfff  com.apple.QD (3.12 - 302) <3F36A108-C557-353A-A3F7-80DDCB82BB37> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff9157c000 -     0x7fff91633ff7  com.apple.CoreDuet (1.0 - 1) <20BDA287-415A-385E-BCB5-934D165BDAA4> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
          0x7fff91634000 -     0x7fff916a8fff  com.apple.framework.IOKit (2.0.2 - 1179.20.6) <BA27E459-85E8-3393-BEAA-BF67FE74F5F4> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff916c8000 -     0x7fff916cefff  com.apple.IOAccelerator (203.14 - 203.14) <D632883D-7A42-38C4-BF31-BD597BD31FAA> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fff91703000 -     0x7fff91970fff  com.apple.imageKit (2.6 - 932) <6738F065-3D55-3165-8D3E-33AA18D6E3EA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff91a75000 -     0x7fff91db2ff3  com.apple.WebKit (11601 - 11601.3.9) <5B562B26-2D3A-3F0F-B374-0FE43BFB0872> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x7fff91df2000 -     0x7fff91df4ff7  com.apple.securityhi (9.0 - 55006) <516B018C-177A-3FAD-8487-97B50FB67DD1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff91e56000 -     0x7fff91e56fff  com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff91e57000 -     0x7fff91e87ff3  com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <C34F0ECF-AABA-3FBC-980F-B4809C9B2DD1> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fff91ea0000 -     0x7fff91eaefff  com.apple.opengl (12.0.40 - 12.0.40) <4D469B19-F5B3-3A2F-93D5-31E3AA3B14BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff91eaf000 -     0x7fff91eafff7  libunc.dylib (29) <1D0F8265-F026-3CBD-93D3-F8DF14FFCE68> /usr/lib/system/libunc.dylib
          0x7fff91eb0000 -     0x7fff91eb2ff7  libRadiance.dylib (1442) <1E42E394-4CD2-3E10-8591-9BB234829AC6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fff9206c000 -     0x7fff92077ff7  libChineseTokenizer.dylib (16) <998637AB-DC37-3A7C-A85C-F10FD98CAAD7> /usr/lib/libChineseTokenizer.dylib
          0x7fff92078000 -     0x7fff920a1ff7  libxslt.1.dylib (14) <CF5C6F5F-75D6-3C00-B6B2-1032D2799FBC> /usr/lib/libxslt.1.dylib
          0x7fff920a2000 -     0x7fff920adfff  libGPUSupportMercury.dylib (12.0.40.6) <1BE26EAA-370D-3DFF-A4DF-E4A6427B8962> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fff920ae000 -     0x7fff92122ff3  com.apple.securityfoundation (6.0 - 55126) <943934A2-EC53-330F-BEB9-8A718A18F9FC> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff92132000 -     0x7fff9213afff  com.apple.AppleSRP (5.0 - 1) <25775E90-1DBB-3BFA-B4B4-F8F262B9EC1F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
          0x7fff9213b000 -     0x7fff9213dffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
          0x7fff9213e000 -     0x7fff9216cff7  com.apple.CoreServicesInternal (248.2 - 248.2) <7D0D2C65-C4C4-3FBD-89A7-12302EA444AA> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff92198000 -     0x7fff9219bfff  libspindump.dylib (197.1) <78CD77B4-3653-35B7-B8E6-3F76BDD7F8B6> /usr/lib/libspindump.dylib
          0x7fff9219c000 -     0x7fff9219dfff  libsystem_blocks.dylib (65) <49D42329-7DE9-3413-92C3-A473A7E9CF35> /usr/lib/system/libsystem_blocks.dylib
          0x7fff921ab000 -     0x7fff921aefff  com.apple.IOSurface (108.0.1 - 108.0.1) <7B05B27A-5CC4-30D4-8A10-ED444A2807A2> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff921af000 -     0x7fff921bbff7  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <E507D438-517D-32AE-8609-02ACD2F0D692> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff921bf000 -     0x7fff921c8fff  com.apple.IOAccelMemoryInfo (1.0 - 1) <65ABBEAD-FEAF-3364-ABA9-FCA6BB3B6779> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInf o
          0x7fff92225000 -     0x7fff92247ff7  com.apple.framework.familycontrols (4.1 - 410) <50F14127-3FCC-39A2-9158-5C2581B0FAE3> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
          0x7fff92248000 -     0x7fff92251ff7  com.apple.DisplayServicesFW (3.0 - 378) <E459962E-90C6-36CE-BA30-BC9E29E6C14A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff92252000 -     0x7fff92252fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <DA5F3EA8-A06B-328A-B22C-9EE29916FD74> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff92280000 -     0x7fff922afffb  com.apple.datadetectors (5.0 - 308) <F6564D99-03ED-3F4F-8922-E6D9508DA6F4> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
          0x7fff922b0000 -     0x7fff9247effb  com.apple.QuartzCore (1.11 - 410.14) <DB552FA2-D2D1-37F9-A1D4-C77D7EA82ECD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff9247f000 -     0x7fff9248afff  com.apple.AppSandbox (4.0 - 261.20.7) <0CA08EB7-D574-3E2F-A3AE-FEA80FF3F304> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fff9248b000 -     0x7fff9248ffff  com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
          0x7fff92490000 -     0x7fff924b9fff  libsystem_info.dylib (477.20.1) <6513635B-4ADE-3B45-BF63-ED7AC565B0C9> /usr/lib/system/libsystem_info.dylib
          0x7fff924ba000 -     0x7fff924e3ffb  libRIP.A.dylib (948) <96E8F983-A8BA-3B0F-9035-E09642A63F6E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff924e4000 -     0x7fff924e4fff  com.apple.Carbon (154 - 157) <34263101-328D-3FE4-B212-14BD3CFF6965> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff924f4000 -     0x7fff92581dd7  com.apple.AppleJPEG (1.0 - 1) <9F0E8564-FCC4-33BE-9C6A-2BA926A33F6F> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
          0x7fff9261a000 -     0x7fff9261bffb  libSystem.B.dylib (1226.10.1) <54388DF0-3813-33E4-BE8D-7743A81ACF4D> /usr/lib/libSystem.B.dylib
          0x7fff9261c000 -     0x7fff9262bfe7  com.apple.AppleFSCompression (81.20.2 - 1.0) <735A903C-EB3A-32EB-BA6B-C55644C59C5C> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
          0x7fff9262c000 -     0x7fff92771fff  com.apple.QTKit (7.7.3 - 2943) <1477C5F3-63B2-386D-A911-481BEFAFEB58> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff92779000 -     0x7fff928e0fff  libBLAS.dylib (1159) <8C24B8BC-E7D9-386D-97C8-929728AFE10B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff929a4000 -     0x7fff929affff  libcsfde.dylib (517.20.1) <42376761-F1B3-3086-AFBC-231507582BBE> /usr/lib/libcsfde.dylib
          0x7fff929cb000 -     0x7fff929d7fff  com.apple.HelpData (2.1.4 - 90) <3A533F58-9C3B-3341-A8F8-084C96BDB70D> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff929d8000 -     0x7fff92b33ffb  com.apple.WebKitLegacy (11601 - 11601.3.9) <C961A4F8-4947-31DA-9E91-FFB006BF1734> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
          0x7fff92b96000 -     0x7fff92b99ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <2B3F04CE-3C7D-3F51-99F3-C7847D1E4277> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff92bbe000 -     0x7fff92c69fff  com.apple.PDFKit (3.1 - 3.1) <4F470085-BBE3-3A75-AB79-430426F72CE4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff92c7a000 -     0x7fff92c85fff  com.apple.CommerceCore (1.0 - 459) <82EB2F45-0C56-3FA7-B8B2-2B4C7DB127C4> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
          0x7fff92c9c000 -     0x7fff92d43fff  com.apple.LanguageModeling (1.0 - 1) <E1E4091D-6CAB-36E0-A206-AAADE69791DC> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
          0x7fff92d44000 -     0x7fff92d4bff7  com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
          0x7fff92d4c000 -     0x7fff92d5dff7  libsystem_trace.dylib (201.10.3) <F0B7622B-FB6B-31E1-8703-38F57BE84553> /usr/lib/system/libsystem_trace.dylib
          0x7fff92d66000 -     0x7fff92d71ff7  libcommonCrypto.dylib (60075.20.1) <766BC3F5-41F3-3315-BABC-72718A98EA92> /usr/lib/system/libcommonCrypto.dylib
          0x7fff92daf000 -     0x7fff92dbbff7  com.apple.OpenDirectory (10.11 - 194) <5409AC27-3B83-3F35-8EB5-51228B4604AE> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff92dbc000 -     0x7fff92dc4fff  libGFXShared.dylib (12.0.40.6) <05770D51-DB02-3ACD-86EF-D3A475A83D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff92e93000 -     0x7fff92ee3fff  libcups.2.dylib (435) <28A05475-9DBF-35EA-B218-3432B69EA18B> /usr/lib/libcups.2.dylib
          0x7fff92ee6000 -     0x7fff92f1efff  com.apple.RemoteViewServices (2.0 - 99) <596153FD-3CB9-3FED-9D63-1B73B01AC6DB> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fff92f1f000 -     0x7fff92f8efff  com.apple.datadetectorscore (7.0 - 460) <CDBB7D7D-B189-37B0-AA4B-DC79090D0D71> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff92f95000 -     0x7fff92f98ff7  com.apple.help (1.3.3 - 46) <62056D9B-A87C-3E4D-B4E2-7E1CDB74CE68> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff92f99000 -     0x7fff92fa1ffb  libsystem_dnssd.dylib (625.20.4) <945B5FB1-DA91-3D45-A961-A8FAD53C1E7E> /usr/lib/system/libsystem_dnssd.dylib
          0x7fff92fa2000 -     0x7fff94061fff  com.apple.WebCore (11601 - 11601.3.8) <39580B20-B884-3D6C-8DE0-3FF7AD12A6CA> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x7fff9414a000 -     0x7fff94160ff7  libLinearAlgebra.dylib (1159) <FA316609-9851-3C5C-AF46-685A25768D45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
          0x7fff94162000 -     0x7fff94164fff  libCGXType.A.dylib (948) <C3D473CF-7261-3E0D-A161-E9B642B75D6A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
          0x7fff94166000 -     0x7fff9416afff  libGIF.dylib (1442) <39FA0286-1616-3474-8215-7CD07109C9E5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fff9416b000 -     0x7fff94297ff7  com.apple.CoreText (352.0 - 494.10) <9FD834B1-FF8E-3EB0-BB11-6E9120969086> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fff9429b000 -     0x7fff942aefff  com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
          0x7fff9431d000 -     0x7fff94671ff7  com.apple.Foundation (6.9 - 1256.1) <66106CC9-9D97-3846-88D8-4BF6BB508296> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff94672000 -     0x7fff94696fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <58FAFE0C-A2D8-3746-AC8F-BF553A7CDED7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff9469f000 -     0x7fff946fdfff  com.apple.SystemConfiguration (1.14 - 1.14) <A6ABDEA0-88BB-3EA2-8C97-FC1A33ABB1D7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff94830000 -     0x7fff94ca6fff  com.apple.CoreFoundation (6.9 - 1256.14) <068D1BA9-3859-34C7-986A-97EDF739C5C8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff94ca7000 -     0x7fff94cc3ff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
          0x7fff94cf8000 -     0x7fff94cfafff  com.apple.SecCodeWrapper (4.0 - 261.20.7) <E3E10533-B295-39EB-B0A3-42BD238E8C85> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fff94d25000 -     0x7fff94fbbfff  libmecabra.dylib (696.4) <0A1574F0-3222-3856-A1C6-D8BE20DC4C48> /usr/lib/libmecabra.dylib
          0x7fff9500d000 -     0x7fff950adfff  com.apple.ViewBridge (159 - 159) <A42BD1E4-C838-3135-B00E-8B051E42D5D3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fff9513b000 -     0x7fff95348ff7  com.apple.CoreImage (11.2.0 - 366.2.7) <344F1067-5F52-3626-8F6C-2B678DEB80A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
          0x7fff95349000 -     0x7fff9537cff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
          0x7fff9537d000 -     0x7fff954a1fff  libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
          0x7fff954a2000 -     0x7fff954a3ff3  com.apple.print.framework.Print (10.0 - 266) <BF573614-5666-3D16-9D45-4690911F030A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff954a4000 -     0x7fff954bfff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
          0x7fff954d0000 -     0x7fff955bffff  libxml2.2.dylib (29.2) <F70308DF-313F-334F-8F0E-82E79821583D> /usr/lib/libxml2.2.dylib
          0x7fff955c0000 -     0x7fff955cbfff  libkxld.dylib (3248.20.55) <3B8A19A8-7B41-3322-BDEC-9A2461E76423> /usr/lib/system/libkxld.dylib
          0x7fff955cf000 -     0x7fff955d4fff  com.apple.TCC (1.0 - 1) <C53628CA-0C75-34B6-AE6E-8BCF8A3ED099> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fff9560e000 -     0x7fff95612fff  libcache.dylib (75) <6B245C0A-F3EA-383B-A542-5B0D0456A41B> /usr/lib/system/libcache.dylib
          0x7fff95700000 -     0x7fff95a95fdb  com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff95c20000 -     0x7fff95c21fff  libsystem_secinit.dylib (20) <FD6ECF2C-1489-32CA-981B-9045B5EB1FAA> /usr/lib/system/libsystem_secinit.dylib
          0x7fff95c22000 -     0x7fff95d1eff7  libFontParser.dylib (158.4) <BF7F82EB-7820-364A-865E-442F42BFDFA4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff95d1f000 -     0x7fff95d27fff  libcopyfile.dylib (127) <F5133269-0B22-388C-A57C-079667B6291E> /usr/lib/system/libcopyfile.dylib
          0x7fff95d28000 -     0x7fff95d51fff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
          0x7fff95d52000 -     0x7fff95d60fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
          0x7fff95d61000 -     0x7fff95d69fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
          0x7fff95e17000 -     0x7fff95e17ff7  liblaunch.dylib (756.20.4) <EDF719D6-D2BB-38DD-8C94-4272BEFDA2CD> /usr/lib/system/liblaunch.dylib
          0x7fff95e18000 -     0x7fff95e64ff7  com.apple.corelocation (1486.17 - 1615.38) <5AE891F7-ED25-3C6C-A8DD-5D702FB87DC7> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
          0x7fff95e65000 -     0x7fff961d8ff7  com.apple.FinderKit (1.4.2 - 1.4.2) <B5F49EFF-B3FC-3381-AB32-4C19A1092552> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
          0x7fff96207000 -     0x7fff96223ff7  libextension.dylib (78) <589FA312-F17C-3A8D-986F-FD995D0065D5> /usr/lib/libextension.dylib
          0x7fff96229000 -     0x7fff96243fff  com.apple.Kerberos (3.0 - 1) <836358DE-2731-3ACD-98E3-E5FA48917728> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff96244000 -     0x7fff9631dfff  com.apple.CoreMedia (1.0 - 1731.15.33) <6109D83B-4E0B-3DE2-9856-9FD80EA51CE0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff9631e000 -     0x7fff963c2fff  com.apple.Bluetooth (4.4.3 - 4.4.3f4) <FF130A90-AB16-33C8-B0D6-1FFE38BFFD30> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
          0x7fff963c8000 -     0x7fff963dbfff  com.apple.CoreBluetooth (1.0 - 1) <BF5F87E3-6AAA-3B1F-9979-7A03D77937C8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
          0x7fff963dc000 -     0x7fff963f8ff7  libsystem_malloc.dylib (67) <9EECAB18-F025-34C4-8E32-7EFFA6720EFC> /usr/lib/system/libsystem_malloc.dylib
          0x7fff963f9000 -     0x7fff9644cff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
          0x7fff96489000 -     0x7fff96569ff7  unorm8_rgba.dylib (2.6.4.1) <6970FC46-0D13-3614-929D-9504AB54C740> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba .dylib
          0x7fff9656a000 -     0x7fff96578fff  com.apple.IntlPreferences (2.0 - 192) <CACF49DE-A307-3066-B168-B47DFC531B97> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
          0x7fff96da1000 -     0x7fff96da6ff7  libheimdal-asn1.dylib (453.20.2) <EE3DD8E9-E543-3849-ADC9-EDBF2379C97C> /usr/lib/libheimdal-asn1.dylib
          0x7fff96da7000 -     0x7fff96db0fff  com.apple.icloud.FindMyDevice (1.0 - 1) <BB049D2D-9789-39E8-A09D-D300E7AA94D2> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
          0x7fff96e11000 -     0x7fff96ef7fef  unorm8_bgra.dylib (2.6.4.1) <F2A325FF-D55F-3091-88E2-5EBF3648274A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
          0x7fff96f1f000 -     0x7fff96f4aff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <D4463131-B469-30B1-84C4-50DB1BAADC32> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
          0x7fff96f4b000 -     0x7fff96f9cff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <BB7C0F61-E39B-382C-AF03-1650C054BFE1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff96f9d000 -     0x7fff96fa2ff3  libunwind.dylib (35.3) <124E0F05-2350-3774-A32C-7F5BF38EDE73> /usr/lib/system/libunwind.dylib
          0x7fff96fb4000 -     0x7fff96febff7  com.apple.LDAPFramework (2.4.28 - 194.5) <79D981F2-F70C-3E47-B124-DC0C90D45563> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fff96fec000 -     0x7fff97031ff3  libFontRegistry.dylib (155.1) <593CC743-3785-3CC5-A229-D3846C51E054> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff97036000 -     0x7fff970e6fe7  libvMisc.dylib (563.4) <621D84AA-C752-34EE-8B16-CF0C2DE722FA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff970e9000 -     0x7fff97138ff7  com.apple.opencl (2.6.9 - 2.6.9) <DFB196DD-1863-3E1F-A2CB-41559E898F50> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff97145000 -     0x7fff97197fff  com.apple.ImageCaptureCore (7.0 - 7.0) <68537DDB-383F-3D4D-8125-789053333B13> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff97198000 -     0x7fff9719dfff  com.apple.AssetCacheServices (14 - 14) <33685005-A92A-3006-97F5-FBF8530925B2> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
          0x7fff9719e000 -     0x7fff971a2fff  com.apple.CommonPanels (1.2.6 - 96) <61E9D84F-435A-3C7B-A065-047B80775777> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff97472000 -     0x7fff9748fff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <25691042-E51E-3A47-A908-E2F6D35451FC> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
          0x7fff97495000 -     0x7fff974b9fff  com.apple.MultitouchSupport.framework (304.10 - 304.10) <CE5E8A54-180B-39FD-B57A-97E02B599B69> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fff974c7000 -     0x7fff974f5ff7  com.apple.DictionaryServices (1.2 - 250) <D9AB6B92-CAF5-3EC2-8D07-639B42DA1CB9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff974f6000 -     0x7fff974fcfff  com.apple.XPCService (2.0 - 1) <9A305622-14E1-3D9A-BE47-6524419BA58D> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fff97702000 -     0x7fff97c24fff  com.apple.QuartzComposer (5.1 - 334) <0A407B05-5CF5-3084-93EF-F4619BDEEF8B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff97c25000 -     0x7fff97ea5ff3  com.apple.security (7.0 - 57337.20.44) <6D1EFB27-3B0F-39EE-B491-6A697A12E98A> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff97ea6000 -     0x7fff97f35fff  com.apple.CorePDF (4.0 - 4) <6147B89F-46D8-38B2-A7D0-C5AABCE35BC6> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff981e8000 -     0x7fff98219ff7  libtidy.A.dylib (15.17) <03EF1071-8B43-3B41-9879-118FA27F89C5> /usr/lib/libtidy.A.dylib
          0x7fff9821a000 -     0x7fff984a0ff7  com.apple.CFNetwork (760.2.6 - 760.2.6) <DDE325B9-7F6F-3933-8F86-8D031E400DD5> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fff984a4000 -     0x7fff984bcfd7  libcompression.dylib (25) <202CE8A7-3D5B-347A-BD22-F0CB589B29AF> /usr/lib/libcompression.dylib
          0x7fff984d0000 -     0x7fff98512ff7  com.apple.Metal (55.2.8 - 55.2.8) <4EC5571C-8A19-3774-BDA0-CB15DB04D06A> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 9
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 941797
          thread_create: 0
          thread_set_state: 345
      VM Region Summary:
      ReadOnly portion of Libraries: Total=952.2M resident=0K(0%) swapped_out_or_unallocated=952.2M(100%)
      Writable regions: Total=4.0G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=4.0G(100%)
                                      VIRTUAL   REGION
      REGION TYPE                        SIZE    COUNT (non-coalesced)
      ATS (font support)                32.2M        6
      ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
      Accelerate.framework               256K        3
      Activity Tracing                  2048K        2
      CG backing stores                 43.3M        5
      CG image                          1100K       66
      CG shared images                   304K       10
      CoreAnimation                      200K       38
      CoreUI image data                 5440K       32
      CoreUI image file                  192K        4
      Dispatch continuations            16.0M        2
      Foundation                          28K        3
      IOKit                             7940K        2
      Image IO                          1252K       58
      Kernel Alloc Once                    8K        3
      MALLOC                           335.8M      290
      MALLOC guard page                   48K       10
      MALLOC_LARGE (reserved)           2048K        2         reserved VM address space (unallocated)
      Memory Tag 242                      12K        2
      Memory Tag 249                     156K        2
      Memory Tag 251                      12K        2
      OpenCL                           474.4M       19
      OpenGL GLSL                        256K        4
      Process Corpse Info               2048K        2
      STACK GUARD                       56.2M       49
      Stack                             31.5M       52
      VM_ALLOCATE                        3.1G      404
      VM_ALLOCATE (reserved)              36K        2         reserved VM address space (unallocated)
      __DATA                            88.7M      983
      __GLSLBUILTINS                    2588K        2
      __IMAGE                            528K        2
      __LINKEDIT                       308.3M      497
      __NV_CUDA                         1584K        3
      __TEXT                           643.9M      782
      __UNICODE                          552K        2
      mapped file                      106.9M      142
      shared memory                     16.4M       11
      TOTAL                              5.2G     3464
      TOTAL, minus reserved VM space     5.2G     3464
      System Profile:
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x142), Broadcom BCM43xx 1.0 (7.21.94.136.1a1)
      Bluetooth: Version 4.4.3f4 16616, 3 services, 27 devices, 1 incoming serial ports
      Thunderbolt Bus: iMac, Apple Inc., 26.1
      Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453220
      Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453220
      Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453220
      Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453220
      USB Device: USB 3.0 Bus
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: FaceTime HD Camera (Built-in)
      USB Device: Apple USB SuperDrive
      USB Device: USB Gaming Mouse
      Serial ATA Device: APPLE SSD SM1024F, 1 TB
      Model: iMac15,1, BootROM IM151.0207.B05, 4 processors, Intel Core i7, 4 GHz, 32 GB, SMC 2.23f11
      Network Service: Wi-Fi, AirPort, en1
      Graphics: AMD Radeon R9 M295X, AMD Radeon R9 M295X, PCIe, 4096 MB
