4 Replies Latest reply on Dec 28, 2015 4:20 AM by ashleye81453589
    Video Effects - Skipping Frames
    ashleye81453589
      There is a certain effect i'm trying to learn with Premiere Elements from this video.
      1:28 - 1:33
      How would i go about doing this? Have very small parts of the clip been broken down to make the effect or has/can it be done using some feature that allows me to jump from one frame to another.
        • 1. Re: Video Effects - Skipping Frames
          A.T. Romano Level 7
          ashleye
          What version of Premiere Elements, what computer operating system?
          Also, after viewing the 1:28 - 1:33 segment of the YouTube video, I would ask you to confirm - are you after a sudden fast motion effect with a sort of turbulence effect mixed in?
          Please consider and supply more details.
          Thank you.
          ATR
          • 2. Re: Video Effects - Skipping Frames
            ashleye81453589 Level 1
            Its Version 13 and Windows 7 64-bit.
            I already know how to do the fast motion part its the part before i need help with. The sudden frame jumps of the boat.
            • 3. Re: Video Effects - Skipping Frames
              A.T. Romano Level 7
              ashleye
              Thanks for the clarification on the effect that you are seeking.
              I have two things that you may want to explore...
              1. fx Effects/NewBlue Art Effects Elements/Earthquake
              2. A bit different, but effective (could be too effective, but)
              Transitions/NewBlue Motion Blends Elements/Shake
              In this approach the transition is placed to cover the whole area where you want the "Shake" rather the the usual transition alignment of Left Clip, Between Clips, Right Clip. That is, this is a video transition used as a video effect.
              I will go into deeper details if necessary. I will also think about this some more.
              ATR
              • 4. Re: Video Effects - Skipping Frames
                I messed around with the two effects you suggested but neither of them give me the effect i wanted. The effect i'm looking for to make sure is the boat jumping from one position to the next. Is there a way to jump from one frame to the next in this program. I'm assuming there is but not sure where the option would be.
