7 Replies Latest reply on Dec 29, 2015 1:16 PM by kglad
    Using AS 2.0 How do i fade the color of a object from blue to red while using a button
    lcdarnell Level 1
      I want to create a template, in this template i want the user to be able to view certain object in whatever color they choose, in addition to them choosing a color i want the color to fade into the next color smoothly.
        • 1. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
          lcdarnell Level 1
          here is the code im trying to use
          on (release) {
            colorme.colorTo(0x00FF00,2.5);
          • 2. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
            don't attach code to objects and you can use colorF to color tween the first argument using the colors in the 2nd and 3rd arguments over the 4th arguments duration (in seconds):
            import mx.transitions.Tween;
            import mx.transitions.easing.*;
            import flash.geom.ColorTransform;
            var rTween:Tween;
            var gTween:Tween;
            var bTween:Tween;
            var colorObj:Object = {};
            var mc_color:MovieClip;
            var ct:ColorTransform;
            colorF(mc,0xff0000,0xaaffff,1);
            function colorF(mc:MovieClip,startColor:Number,endColor:Number,duration:Number):Void{
                rTween = new Tween(colorObj,'red',None.easeNone,(startColor&0xff0000)>>16,(endColor&0xff0000)>>16,dura tion,true);
                gTween = new Tween(colorObj,'green',None.easeNone,(startColor&0x00ff00)>>8,(endColor&0x00ff00)>>8,dura tion,true);
                bTween = new Tween(colorObj,'blue',None.easeNone,startColor&0x0000ff,endColor&0x0000ff,duration,true);
                mc_color = mc;
                ct = mc.transform.colorTransform;
                rTween.onMotionChanged = colorChangeF;
            function colorChangeF():Void{
                ct.rgb = Math.round(colorObj.red)<<16 | Math.round(colorObj.green)<<8 | Math.round(colorObj.blue);
                mc_color.transform.colorTransform = ct;
            • 3. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
              lcdarnell Level 1
              ok im still pretty new at this so i have my three test buttons set up and the area i want to be colored.. if i understand you correctly
              var rTween:Tween;
              var gTween:Tween;
              var bTween:Tween;
              this part all goes into by button area and the rest goes onto the stage area//// or does it go inside the object i want to be colored
              • 4. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
                lcdarnell Level 1
                Actually I figured it out my only question is..
                on the startColor:Number is there a way that I can make it start from any previous color I used for example.... if I clicked on blue than clicked on green is there a way I can make the
                code start from the previous color without always making a startColor:Number
                the reason I want to know is because if I want to have a lot of colors to choose from I don't want to have to keep creating a startColor:Number for each and every keyframe.
                Your code works amazing but I tweaked it a little.
                function colorF(mc:MovieClip,endColor:Number,duration:Number):Void{
                I took out the startColor:Number and it works excellent but whenever I click a different color it default back to black before getting to its color.
                • 5. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
                  yes, save the previous endColor so you can use that as the next startColor.  eg,
                  mc.endColor=endColor;
                      mc_color = mc;
                  then whenever you want to color-tween something:
                  if(mc.endColor){
                  colorF(mc,mc.endColor,endColor,1);
                  (p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
                  • 6. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
                    lcdarnell Level 1
                    I hit the correct button in the forum.. But what i want to do is a little more complex and its hard to explain in text, I know you would not want random people calling you all day so if you don't mind here is my cell phone number if you can call me so that i can better explain what Im trying to do that will be much appreciated.
                    you can call me from a blocked number
                    My name is Charles661.618.6436
                    • 7. Re: Using AS 2.0 How do i fade the color of a object from blue to red while using a button
                      if you want to hire me to help, please send me an email via my website:  http://www.kglad.com
                      in addition, to my flash-for-pay work i donate considerable time and effort to the flash community by trying to help people that post on the 3 main (as1/as2, as3, flash) adobe flash forums.  if you want free help, post your issue to the appropriate forum.  if i am able and interested in your issue, i will probably respond.  and, if i don't, someone else probably will.
                      if you state your issue clearly, and especially if you pinpoint the problem, you almost certainly will be helped free of charge.  if you have a complex problem and especially if you require source (fla and/or as) files to be corrected, you almost certainly should consider hiring someone to help.  again, you can hire me via my website.
                      thank you for understanding,
                      kglad
                      Flash Consulting Services
                      www.kglad.com
