8 Replies Latest reply on Jan 14, 2016 5:57 PM by logancase8
    Change opacity with mouseover.
    logancase8 Level 1
      Hello. I am creating an application for my website and do not have a ton of experience with coding other than HTML5 and CSS3.
      It Adobe Edge Animate I have created my application and have an image I am using as a button. The opacity of the image is 50% by default. I would like the opacity to change to 100% on mouse over and go back to 50% on mouse off. I would also like it to stay 100% if the user clicks on it. Right now I have the mouse over and mouse off working but the problem is that it still goes back to 50% even after I click and hover off. How do I override the mouse off function? The image is called shirtsICO and the current code is as follows:
      click:
           sym.$("shirtsICO").css("opacity","1");
      mouseenter:
      mouseleave:
           sym.$("shirtsICO").css("opacity",".5");
      I have been playing around with If statements and couldn't get anything to work. As I mentioned I am not too experienced with javascript.
      Regards,
      Logan Case
        • 1. Re: Change opacity with mouseover.
          joel_pau Level 5
          Hi Logan,
          So, you want a clicked state. 2 ideas:
          1) You can disable mouseleave after a click as shown below:
          click:
              sym.$("shirtsICO").css("opacity","1").unbind("mouseleave");
          mouseenter:
          mouseleave:
          2) You can create a clicked state using a class as shown below:
          click:
              sym.$("shirtsICO").css("opacity","1").addClass(" clicked ");
              sym.$(" .clicked ").css( a property or some properties here); //you set the class here.
          mouseenter:
          mouseleave:
          • 2. Re: Change opacity with mouseover.
            logancase8 Level 1
            Thank you for your help. I was wondering if there is a way to reactivate the mouseleave when I click on another button. What I have is two buttons and when one is selected it goes to 100% opacity and sets the other button to 50%. Is there any way I can make it so that when I click the other button after clicking the first one it will be able to allow the mouseover of the other button to work again. What I mean is if the user selects Button A then it stops the mouseleave from working using the .unbind function. If they change their mind and select Button B after that is it possible to reset Button A so that mouseleave will be active again until Button A is selected again?
            Here is my code:
            //BUTTON A (shirtsICO)
            click:
            sym.$("hoodieICO").css("opacity",".5");
            mouseenter:
            mouseleave:
            //BUTTON B (hoodieICO)
            click:
            sym.$("hoodieICO").css("opacity","1").unbind("mouseleave");
            sym.$("shirtICO").css("opacity",".5");
            mouseenter:
            sym.$("hoodieICO").css("opacity","1");
            mouseleave:
            • 3. Re: Change opacity with mouseover.
              joel_pau Level 5
              So, if you have only 2 buttons:
              click:
              sym.$("hoodieICO").css("opacity",".5").bind("mouseleave");
              mouseenter:
              mouseleave:
              click:
              sym.$("shirtICO").css("opacity",".5").bind("mouseleave");
              mouseenter:
              mouseleave:
              If you have several buttons, it will better to use a class.
              1) With the properties panel (left side of the user interface), i click the c button (at the top of the properties panel) and i type: buttons.
              2) Inside code, i call the class using: .buttons
              click:
              sym.$(".buttons").css("opacity",".5").bind("mouseleave");
              mouseenter:
              mouseleave:
              click:
              mouseenter:
              mouseleave:
              • 4. Re: Change opacity with mouseover.
                logancase8 Level 1
                I chose to do it using the class but after doing what you instructed,whenever I select button A it makes the opacity of button B stay at 100%. I'm going to play around with it and see if I can figure out what happened. Thank you for your help.
                • 5. Re: Change opacity with mouseover.
                  joel_pau Level 5
                  well, i will build a demo file as fast as possible.
                  • 6. Re: Change opacity with mouseover.
                    logancase8 Level 1
                    ok. Thank you.
                    • 7. Re: Change opacity with mouseover.
                      joel_pau Level 5
                      Here your case ==> button States.zip - Box I use colors instead of opacity. It returns better.
                      • 8. Re: Change opacity with mouseover.
                        logancase8 Level 1
                        Thank you so much sir.
