Hello. When I generate CHM output from RH 2015, the TOC is missing, but the Search and Glossary tabs are present. I'm not opening the file from a server, but from my desktop. I copied it from the server to my desktop and renamed it. The file was originally created in, I think, RH 9, but I've successfully generated CHM output with this file in RH 10. Any ideas? Thanks!
Dawn
If I were in your shoes, the next thing I would try is to open the Output Setup pod. Define a new CHM window there. Then be sure to choose that new window in your Single Source Layout recipe.
Cheers... Rick
Hi there
When you look at the output settings, do you see the correct TOC listed?
Cheers... Rick
Thanks for your reply, Rick! Yes, I’ve tried it with both the default TOC selected as shown in your screen shot and with the name of the default TOC selected. Neither one works.
Cheers... Rick
Yes! Yes! Yes! It worked. Thank you! ☺
Dawn
