1 Reply Latest reply on Aug 31, 2009 1:52 PM by jimmont.com
    day 5 last exercise bundle error
    Wrensthav
      found this after fixing some errors in my code.
      Unable to resolve resource bundle "localization".
      Resource= ReservationSystem
      Location= Unknown
      so how do I fix this problem?
        • 1. Re: day 5 last exercise bundle error
          jimmont.com
          was able to figure this out from the docs under topic:
          Advanced Flex Programming
               > Localizing Flex Applications
                    > Creating resources ( http://livedocs.adobe.com/flex/3/html/l10n_3.html#158343 )
          step 19 needs an additional command-line argument to add your locale resources to the source-path, so all of the command-line options I am using look like this (the ../locale is relative to the src directory):
          -locale=en_US,es_ES -source-path=../locale/{locale} -allow-source-path-overlap=true
          making this change allows the solution to compile (I'm using sdk version 3.4).
          Another detail I had to correct on my workstation was to reset the command-line flex_sdk_home and path environment variables when using the copylocale command from my shell (it was pointing to another version of the flex sdk, putting the locale/es_ES assets in the wrong place).
          edit: this relates to exercise 26 (Localization using resource bundles) on the 5th day of the Flex in a week series.
