2 Replies Latest reply on Dec 29, 2015 9:48 AM by ojodegato
    IPP in PSCC 2015.1.1 release
    ojodegato Level 1
      Does IPP 3.2b4 support actions from Action Sets in PSCC 2015.1.1?
      I am unable to run an action from an action set using IPP 3.2b4 with PSCC 2015.1.1.
      I don't have this problem when using IPP 3.2b4 with PSCC 2014.2.2.
      The second Action drop down menu (in orange) is missing in IPP 3.2b4 in PSCC 2015.1.1.
        • 1. Re: IPP in PSCC 2015.1.1 release
          xbytor2 Level 4
          This appears to work on Win7 and not on OS X in PSCC 2015.1.1 and is simply a UI problem, not a functionality problem.
          I haven't been able to fix this as I cannot get PSCC 2015.1.1 running on my Mac.
          The only work-around is to set IPP up in the configuration you want.
          "Save..." the settings xml file to your desktop.
          Edit the XML file to add the Action you want.
          For example, I added this line
             <action enabled="true" when="Before Image Resize" set="Default Actions" name="Sepia Toning (layer)"/>
          to a settings file to get this.
          <ImageProcessorProSettings>
            <input source="folder" includeSubFolders="false" path="C:\Users\xbytor\Desktop\Adobe\Processor Pro Test Images"/>
            <output path="C:\Users\xbytor\Desktop\Output Folder" subfolder="false" keepStructure="false" retainOriginal="true"/>
            <taskList>
              <task enabled="true" subfolderName="Set 1" colorProfile="sRGB IEC61966-2.1">
                <saveOptions fileSaveType="jpg" jpgQuality="10" jpgEmbedColorProfile="true" jpgFormat="Standard" jpgConvertToSRGB="false" saveForWeb="false"/>
                <resizeOptions enabled="false"/>
                <namingOptions startingSerial="1">Name,-,yyyymmdd,upperCaseExtension</namingOptions>
              </task>
            </taskList>
            <preferences>
              <preserveFileName>false</preserveFileName>
            </preferences>
            <date>2015-12-29T10:43:08</date>
            <version>3.2b4</version>
            <uiPrefs>
              <lastSettingsFile>C:\Users\xbytor\Desktop\Test.xml</lastSettingsFile>
            </uiPrefs>
          </ImageProcessorProSettings>
          A simpler alternative is to get things setup in PSCC 2014.2.2,  Save... the settings file to your desktop (or wherever), run PSCC 2015.1.1, Load... the settings file there and you should be good to go.
          • 2. Re: IPP in PSCC 2015.1.1 release
            ojodegato Level 1
            Got it , thank you!
