4 Replies Latest reply on Jan 16, 2016 3:03 AM by GRVFX
    After Effect CC 2015 - KERNEL_SECURITY_CHECK_FAILURE ( Memory Dump )
    NetMan60
      Hi There
      As it's obvious, i got a problem after installing AE and it gives me a Blue Screen with a message above ( KERNEL_SECURITY_CHECK_FAILURE ). It seems there is a memory crash between AE and another software or driver. So i Analysed Memory.DMP file with WinDbg and gave me a result below.
      As you can see, i found out, file dxgkrnl.sys with AEGPUSniffer.e process make a memory crash. I need to say that befor installing AE i uninstalled my graphic card drivers ( Geforce and Intell ) and installed a vendor drivers directly but AE has a problem with DirecX! ( my DirectX Edition is 12 )
      Here is my System Configuration:
      Laptop: HP with UEFI Firmware ( secure boot off )
      Windows 10 edition 10586
      Ram: 16 GB
      Graphic cards: internal Intel (1 GB) and Dedicated Geforce GTX ( 4GB )
      CPU: 2.3 GH core i7 ( quad core  & 8 logical processors )
      HDD: 1 TB
      All drivers up to date
      Well, Any help will be appreciated. If there is no any way to make it correct, can i make it right with another edition of AE or wil be the same?
      Microsoft (R) Windows Debugger Version 10.0.10586.567 X86
      Copyright (c) Microsoft Corporation. All rights reserved.
      Loading Dump File [C:\Users\Babak\Desktop\MEMORY.DMP]
      Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
      Symbol search path is: srv*
      Executable search path is:
      Windows 10 Kernel Version 10586 MP (8 procs) Free x64
      Product: WinNt, suite: TerminalServer SingleUserTS
      Built by: 10586.17.amd64fre.th2_release.151121-2308
      Machine Name:
      Kernel base = 0xfffff802`6fa00000 PsLoadedModuleList = 0xfffff802`6fcdec70
      Debug session time: Tue Dec 29 01:11:09.512 2015 (UTC + 8:00)
      System Uptime: 0 days 0:00:54.331
      Loading Kernel Symbols
      ...........................................................Page 105d4a not present in the dump file. Type ".hh dbgerr004" for details
      Loading User Symbols
      PEB is paged out (Peb.Ldr = 00000000`002e2018).  Type ".hh dbgerr001" for details
      Loading unloaded module list
      *                        Bugcheck Analysis                                    *
      Use !analyze -v to get detailed debugging information.
      BugCheck 139, {3, ffffd00024267490, ffffd000242673e8, 0}
      Page 11b860 not present in the dump file. Type ".hh dbgerr004" for details
      Page 110e88 not present in the dump file. Type ".hh dbgerr004" for details
      Page 110515 not present in the dump file. Type ".hh dbgerr004" for details
      Page 1280 not present in the dump file. Type ".hh dbgerr004" for details
      Probably caused by : dxgkrnl.sys ( dxgkrnl!DXGDEVICE::DestroyAllDeviceState+1cb )
      Followup:    MachineOwner
      7: kd> !analyze -v
      KERNEL_SECURITY_CHECK_FAILURE (139)
      A kernel component has corrupted a critical data structure.  The corruption
      could potentially allow a malicious user to gain control of this machine.
      Arguments:
      Arg1: 0000000000000003, A LIST_ENTRY has been corrupted (i.e. double remove).
      Arg2: ffffd00024267490, Address of the trap frame for the exception that caused the bugcheck
      Arg3: ffffd000242673e8, Address of the exception record for the exception that caused the bugcheck
      Arg4: 0000000000000000, Reserved
      Debugging Details:
      DUMP_CLASS: 1
      DUMP_QUALIFIER: 401
      BUILD_VERSION_STRING:  10586.17.amd64fre.th2_release.151121-2308
      SYSTEM_MANUFACTURER:  Hewlett-Packard
      SYSTEM_PRODUCT_NAME:  HP ENVY 15 Notebook PC
      SYSTEM_SKU:  K8U61PA#UUF
      SYSTEM_VERSION:  097F120000405F10000310100
      BIOS_VENDOR:  Insyde
      BIOS_VERSION:  F.22
      BIOS_DATE:  11/25/2014
      BASEBOARD_MANUFACTURER:  Hewlett-Packard
      BASEBOARD_PRODUCT:  22A0
      BASEBOARD_VERSION:  KBC Version 83.12
      DUMP_TYPE:  1
      BUGCHECK_P1: 3
      BUGCHECK_P2: ffffd00024267490
      BUGCHECK_P3: ffffd000242673e8
      BUGCHECK_P4: 0
      TRAP_FRAME:  ffffd00024267490 -- (.trap 0xffffd00024267490)
      NOTE: The trap frame does not contain all registers.
      Some register values may be zeroed or incorrect.
      rax=ffffe0017d079730 rbx=0000000000000000 rcx=0000000000000003
      rdx=ffffe0017d045890 rsi=0000000000000000 rdi=0000000000000000
      rip=fffff8026fb59d82 rsp=ffffd00024267620 rbp=ffffd00024267729
      r8=ffffc001f8dfe3f0  r9=0000000000000003 r10=7fffc001f8dfe3f0
      r11=7ffffffffffffffc r12=0000000000000000 r13=0000000000000000
      r14=0000000000000000 r15=0000000000000000
      iopl=0        nv up ei pl nz na po cy
      nt! ?? ::FNODOBFM::`string'+0x8c82:
      fffff802`6fb59d82 cd29            int    29h
      Resetting default scope
      EXCEPTION_RECORD:  ffffd000242673e8 -- (.exr 0xffffd000242673e8)
      ExceptionAddress: fffff8026fb59d82 (nt! ?? ::FNODOBFM::`string'+0x0000000000008c82)
        ExceptionCode: c0000409 (Security check failure or stack buffer overrun)
        ExceptionFlags: 00000001
      NumberParameters: 1
        Parameter[0]: 0000000000000003
      Subcode: 0x3 FAST_FAIL_CORRUPT_LIST_ENTRY
      CPU_COUNT: 8
      CPU_MHZ: 8f7
      CPU_VENDOR:  GenuineIntel
      CPU_FAMILY: 6
      CPU_MODEL: 3c
      CPU_STEPPING: 3
      CPU_MICROCODE: 6,3c,3,0 (F,M,S,R)  SIG: 1E'00000000 (cache) 1E'00000000 (init)
      DEFAULT_BUCKET_ID:  LIST_ENTRY_CORRUPT
      BUGCHECK_STR:  0x139
      PROCESS_NAME:  AEGPUSniffer.e
      CURRENT_IRQL:  2
      ERROR_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
      EXCEPTION_CODE: (NTSTATUS) 0xc0000409 - The system detected an overrun of a stack-based buffer in this application. This overrun could potentially allow a malicious user to gain control of this application.
      EXCEPTION_CODE_STR:  c0000409
      EXCEPTION_PARAMETER1:  0000000000000003
      ANALYSIS_SESSION_HOST:  HP-ENVY15
      ANALYSIS_SESSION_TIME:  12-29-2015 17:10:58.0743
      ANALYSIS_VERSION: 10.0.10586.567 x86fre
      LAST_CONTROL_TRANSFER:  from fffff8026fb4d2e9 to fffff8026fb42760
      STACK_TEXT:
      ffffd000`24267168 fffff802`6fb4d2e9 : 00000000`00000139 00000000`00000003 ffffd000`24267490 ffffd000`242673e8 : nt!KeBugCheckEx
      ffffd000`24267170 fffff802`6fb4d610 : 00000000`00000000 fffff802`6fa3272f 00000000`00000000 00000000`00000000 : nt!KiBugCheckDispatch+0x69
      ffffd000`242672b0 fffff802`6fb4c7f3 : ffffe001`7b2bf010 ffffe001`7b2bf010 00000000`00000000 ffffe001`7d168270 : nt!KiFastFailDispatch+0xd0
      ffffd000`24267490 fffff802`6fb59d82 : ffffc001`f8dfe330 ffffc001`f8dfe3f0 00000000`00000000 00000000`00000000 : nt!KiRaiseSecurityCheckFailure+0xf3
      ffffd000`24267620 fffff801`4871147b : ffffc001`00000000 ffffc001`f7a6e010 ffffc001`f7a6e100 ffffc001`f7a6e100 : nt! ?? ::FNODOBFM::`string'+0x8c82
      ffffd000`24267650 fffff801`48710653 : ffffc001`f7a6e010 00000000`00000000 00000000`0000000b 00000000`00000000 : dxgkrnl!DXGDEVICE::DestroyAllDeviceState+0x1cb
      ffffd000`24267690 fffff801`486f3717 : ffffc001`f7a6e010 ffffc001`f8dfe330 ffffc001`f8dfe330 ffffe001`7cf74080 : dxgkrnl!ADAPTER_RENDER::DestroyDevice+0xa7
      ffffd000`242676c0 fffff801`486f00b4 : 00000000`00000100 ffffc001`f8dfe330 ffffc001`f8dfe330 fffff960`c5492d90 : dxgkrnl!DXGPROCESS::Destroy+0x2bf
      ffffd000`24267790 fffff960`c53b6c9c : 00000000`00001cb0 fffff901`407a3730 00000000`00000007 00000000`00000000 : dxgkrnl!DxgkProcessCallout+0x64
      ffffd000`242677f0 fffff960`c5035cb9 : fffff901`407a3730 fffff901`407a3730 ffffe001`7b72c080 00000000`00000001 : win32kbase!GdiProcessCallout+0x8c
      ffffd000`24267870 fffff960`c53d08cb : ffffd000`24267a48 ffffd000`242679c0 00000000`00000000 00000000`00000007 : win32kfull!W32pProcessCallout+0xd9
      ffffd000`242678a0 fffff802`6fdfc262 : ffffd000`242679c0 ffffe001`7b3e42b0 00000000`00000000 00000000`00000000 : win32kbase!W32CalloutDispatch+0x6b
      ffffd000`24267910 fffff802`6fe06ddf : ffffe001`7b3e42b0 00000000`00000000 00000000`00000000 ffffe001`7b72c080 : nt!PsInvokeWin32Callout+0x42
      ffffd000`24267950 fffff802`6fe812f2 : ffffe001`00000007 ffffe001`7cf74080 ffffe001`7cf74080 ffffe001`7b72c080 : nt!PspExitThread+0x49b
      ffffd000`24267a90 fffff802`6fb4cfa3 : ffffe001`7cf74080 ffffe001`7b72c080 ffffd000`24267b80 ffffd000`24267b80 : nt!NtTerminateProcess+0xde
      ffffd000`24267b00 00007ff8`14085364 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
      00000000`0014fd98 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`14085364
      STACK_COMMAND:  kb
      THREAD_SHA1_HASH_MOD_FUNC:  a0a5514a4d87706527c6f92c37842ea8c43b81ac
      THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  11718e5c925d2d833f63315284a04f89616e7880
      THREAD_SHA1_HASH_MOD:  c9f3f8c71ac99eb021b386cc891dde1c61018273
      FOLLOWUP_IP:
      fffff801`4871147b 488b4b50        mov    rcx,qword ptr [rbx+50h]
      FAULT_INSTR_CODE:  504b8b48
      SYMBOL_STACK_INDEX:  5
      SYMBOL_NAME:  dxgkrnl!DXGDEVICE::DestroyAllDeviceState+1cb
      FOLLOWUP_NAME:  MachineOwner
      MODULE_NAME: dxgkrnl
      IMAGE_NAME:  dxgkrnl.sys
      DEBUG_FLR_IMAGE_TIMESTAMP:  5632d261
      BUCKET_ID_FUNC_OFFSET:  1cb
      FAILURE_BUCKET_ID:  0x139_3_dxgkrnl!DXGDEVICE::DestroyAllDeviceState
      PRIMARY_PROBLEM_CLASS:  0x139_3_dxgkrnl!DXGDEVICE::DestroyAllDeviceState
      TARGET_TIME:  2015-12-28T17:11:09.000Z
      OSBUILD:  10586
      OSSERVICEPACK:  0
      SERVICEPACK_NUMBER: 0
      OS_REVISION: 0
      SUITE_MASK:  272
      PRODUCT_TYPE:  1
      OSPLATFORM_TYPE:  x64
      OSNAME:  Windows 10
      OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS
      OS_LOCALE:
      USER_LCID:  0
      OSBUILD_TIMESTAMP:  2015-11-22 17:24:24
      BUILDDATESTAMP_STR:  151121-2308
      BUILDLAB_STR:  th2_release
      BUILDOSVER_STR:  10.0.10586.17.amd64fre.th2_release.151121-2308
      ANALYSIS_SESSION_ELAPSED_TIME: 25c0
      ANALYSIS_SOURCE:  KM
      FAILURE_ID_HASH_STRING:  km:0x139_3_dxgkrnl!dxgdevice::destroyalldevicestate
      FAILURE_ID_HASH:  {070f1ec5-2412-7644-8cb9-60ac33a7233f}
