2 Replies Latest reply on Feb 2, 2009 12:04 PM by Dan Bracuk
    if statement
    Level 1
      I have this code like this:
      <cfquery name=name datasource=datasource>
      Select *
      From table
      </cfquery>
      <script language="JavaScript">
      if (condition)
      </script>
      my question is how can I compare a column from the database from a text in if statement in javascript?
      thanks
        • 1. Re: if statement
          Level 7
          > thanks
          Most likely, by the simple phrasing of your question, you can *NOT* do
          what you think you want to do.
          An important beginning concept to to fully understand is the difference
          between CFML that runs on the *server* and JavaScript that runs on the
          *client* and never will the two meet. Before a user client ever sees an
          opening <html...> or doctype tag, the CFML has completed its work and
          moved on to an entirely new request for a completely different user.
          You can use CFML to dynamically build JavaScript to be delivered to the
          client. This is very powerful and is no different then using CFML to
          generate HTML or text or anything else you would like to deliver to a
          client.
          You can use JavaScript to make requests to a server. These requests can
          be for CFML templates that return new, dynamically generated information
          to the client. When done asynchronously and XML is used to return the
          information, this is popularly called AJAX. But that is not the only
          way to do this.
          Now if we had some hint of your goal, we could probably give you some
          hints. But without that, I can only say, "Sorry ColdFusion and
          JavaScript do not mix."
          Ian
          • 2. Re: if statement
            Dan Bracuk Level 5
            You can use the toscript tag to bring your query results into javascript. Details are in the cfml reference manual. If you don't have one, the internet does.
