0 Replies Latest reply on Dec 29, 2015 5:26 AM by iggy41144
    Print to file issue
    iggy41144 Level 1
      I am using a calendar templates. I use them each year for gifts to my friends.
      This year I thought I would be smart and set up each calendar,then in the print module use print to file..
      Then I could go in and print what I needed using a standard 8.5x11 template.This way I could quickly mix and match the months
      Worked as I thought, until I cut and put in the cd case.
      Lo and behold they were a lot smaller (4 1/4 x 5) then if I had printed the template as designed. they would be 4 1/2 x 5 1/4
      all I did was click print to file and it changed.. everything else on that page in the print module was the same..
      Any thoughts why it reduced the output size ?
