2 Replies Latest reply on Feb 2, 2009 8:32 AM by mordsm
    run .air file
    mordsm Level 1
      Hi all
      how can I run air file from command line
      (specifically i need to run it from setup file and i need the command that runs it)
      moshe
        • 1. Re: run .air file
          Cesare Rocchi
          The application which "interprets" .air files is named
          "Adobe AIR Application Installer"
          depending on the os (and the os language) it can be located in many places:
          - MacOsx /Applications/Utilities
          - WinXp c:/Program Files/ ... Adobe Air/Versions/1.5/
          - Linux /opt/... Adobe Air/Versions/1.5/
          You can pass the .air file as a parameter as in this video: http://www.vimeo.com/1302408
          HTH,
          • 2. Re: run .air file
            mordsm Level 1
            Hi
            thanks for the answer but when I run "Adobe AIR Application Installer.exe OffLineMD.air" I got error
            " the AIR file is damaged. Try obtaining a new AIR file from the application author." but if I click on the air file it works fine
            moshe
            p.s. I can't see th letters in the video file
