0 Replies Latest reply on Dec 29, 2015 11:55 AM by daveyj
    AE CC2014 - Crash on Saving File or Save As
    daveyj Level 1
      Hoping someone can read a crash log and help identify something. I am crashing on a stable project Every time i save or save as (or export to xml, etc.) I feel there is something corrupt in the file but have no idea how to troubleshoot.
      2013 Mac Pro Cylinder - 64 GB Ram - 12 Core dual 700 running Yosemite.
      The file saved fine on last version worked on, nothing new or offending added that i can recall.
      here is the log
      Process:               After Effects [1969]
      Path:                  /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/MacOS/After Effects
      Identifier:            com.adobe.AfterEffects
      Version:               13.2 (13.2)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           After Effects [1969]
      User ID:               501
      Date/Time:             2015-12-29 10:42:18.346 -0800
      OS Version:            Mac OS X 10.10.5 (14F1021)
      Report Version:        11
      Anonymous UUID:        067D218E-7C5F-AE7A-8FB5-75B4356C0EDF
      Sleep/Wake UUID:       F57F9889-4787-42D6-85FE-FF9478016411
      Time Awake Since Boot: 21000 seconds
      Time Since Wake:       6800 seconds
      Crashed Thread:        0  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       KERN_INVALID_ADDRESS at 0x00000000000024fc
      VM Regions Near 0x24fc:
          __TEXT                 0000000100000000-0000000100005000 [   20K] r-x/rwx SM=COW  /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/MacOS/After Effects
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   BEE.dylib                     0x00000001012f0922 BEEp_ResolveLayerParamFunc + 98
      1   BEE.dylib                     0x0000000101331f31 BEEp_FlattenLayerParamFunc(TDB_ParamLayerStream const*, bool) + 97
      2   TDB.dylib                     0x00000001025a9e25 TDB_ParamLayerStream::GetFlattenedReserved0() const + 69
      3   TDB.dylib                     0x0000000102588403 TDB_Stream::Write(SLU_File*) const + 1523
      4   TDB.dylib                     0x00000001025a1fe0 TDB_StreamGroup::Write(SLU_File*) const + 960
      5   FLT.dylib                     0x0000000101abab88 FLT_FCSeqSpec::Write(SLU_File*) const + 1656
      6   TDB.dylib                     0x00000001025a1fe0 TDB_StreamGroup::Write(SLU_File*) const + 960
      7   TDB.dylib                     0x00000001025a1fe0 TDB_StreamGroup::Write(SLU_File*) const + 960
      8   BEE.dylib                     0x00000001012f1998 BEE_Layer::WritePlus(SLU_File*, BEEp_FileInfo*) + 168
      9   BEE.dylib                     0x00000001013031a5 BEE_SetProjectSettingsFromString(std::basic_string<unsigned char, std::char_traits<unsigned char>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned char> > const&, BEE_Project*) + 7141
      10  BEE.dylib                     0x00000001011c6a3c int LIST_ForEachT<std::vector<BEE_Layer*, U_Allocator<BEE_Layer*> > >(std::vector<BEE_Layer*, U_Allocator<BEE_Layer*> >*, long, int (*)(std::vector<BEE_Layer*, U_Allocator<BEE_Layer*> >*, long, int, std::vector<BEE_Layer*, U_Allocator<BEE_Layer*> >::value_type), int*) + 76
      11  BEE.dylib                     0x00000001012f29f2 BEEp_WriteItemFunc(void*, BEE_Item*, BEE_FolderItem*, int) + 2658
      12  BEE.dylib                     0x0000000101237b76 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 278
      13  BEE.dylib                     0x00000001012f23c2 BEEp_WriteItemFunc(void*, BEE_Item*, BEE_FolderItem*, int) + 1074
      14  BEE.dylib                     0x000000010123f899 BEE_GetDefaultFolder(BEE_Project*, int, unsigned char) + 2009
      15  BEE.dylib                     0x0000000101237b76 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 278
      16  BEE.dylib                     0x00000001012fc604 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set<BEE_Item*, std::less<BEE_Item*>, std::allocator<BEE_Item*> > const*, FILE_Spec*) + 4052
      17  com.adobe.AfterEffectsLib.framework 0x00000001006feb35 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 309
      18  com.adobe.AfterEffectsLib.framework 0x0000000100700537 CPDir::DoSave(int) + 71
      19  com.adobe.AfterEffectsLib.framework 0x00000001007006d7 CPDir::DoSaveAs(FILE_Spec*) + 183
      20  com.adobe.AfterEffectsLib.framework 0x000000010031c630 CDocument::DoSaveFileAs() + 64
      21  com.adobe.AfterEffectsLib.framework 0x000000010035ad6c CDirTabPanel::DoCommand(int) + 220
      22  com.adobe.AfterEffectsLib.framework 0x00000001007b723d CTLOutlinePano::DoCommand(int) + 2077
      23  com.adobe.AfterEffectsLib.framework 0x0000000100325267 CSwitchboard::DoCommandHilite(int) + 103
      24  com.adobe.AfterEffectsLib.framework 0x0000000100234be6 CEggApp::DoKeyboardEvent(dvaui::ui::KeyboardEvent const&) + 486
      25  com.adobe.AfterEffectsLib.framework 0x000000010035c4e7 CDirTabPanel::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 711
      26  com.adobe.AfterEffectsLib.framework 0x000000010035c7cd non-virtual thunk to CDirTabPanel::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 13
      27  com.adobe.dvaui.framework     0x0000000103c0c6fb dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 539
      28  com.adobe.dvaui.framework     0x0000000103c7ca77 dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 151
      29  com.adobe.dvaui.framework     0x0000000103c80c09 dvaui::ui::OS_Window::UI_DispatchEvent(dvaui::ui::OS_Event*) + 89
      30  com.adobe.dvaui.framework     0x0000000103c970b4 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<bool, boost::_mfi::mf1<bool, dvaui::ui::OS_Window, dvaui::ui::OS_Event*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_Window*>, boost::_bi::value<dvaui::ui::OS_Event*> > >, bool>::invoke(boost::detail::function::function_buffer&) + 36
      31  FLT.dylib                     0x0000000101af137c boost::function0<bool>::operator()() const + 28
      32  FLT.dylib                     0x0000000101af144e int dvacore::config::ErrorManager::ExecuteFunction<bool>(boost::function0<bool>*, bool*) + 14
      33  com.adobe.AfterEffectsLib.framework 0x000000010027e264 Get_NAB_BUILD_SYNC_SETTINGS_HIDDEN() + 1780
      34  FLT.dylib                     0x0000000101af1268 bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<bool>(boost::f unction0<bool>, bool*) + 136
      35  FLT.dylib                     0x0000000101af115a bool dvacore::config::ExecuteTopLevelFunction<bool>(boost::function0<bool>, bool*) + 170
      36  com.adobe.dvaui.framework     0x0000000103c8a3ef -[DVAMacPanelWindow performKeyEquivalent:] + 207
      37  com.apple.AppKit               0x00007fff858a48e0 -[NSApplication _handleKeyEquivalent:] + 521
      38  com.apple.AppKit               0x00007fff857af83a -[NSApplication sendEvent:] + 4080
      39  com.adobe.dvaui.framework     0x0000000103c884db -[DVAMacApplication sendEvent:] + 603
      40  com.adobe.AfterEffectsLib.framework 0x00000001000ada0c GetAECocoaApplication() + 1404
      41  com.apple.AppKit               0x00007fff856d8b68 -[NSApplication run] + 711
      42  com.adobe.AfterEffectsLib.framework 0x000000010030f5d1 CApplication::Run() + 65
      43  com.adobe.AfterEffectsLib.framework 0x000000010027d25b MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int) + 875
      44  com.adobe.AfterEffectsLib.framework 0x000000010027cebb EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 59
      45  com.adobe.AfterEffects         0x000000010000310e main + 1838
      46  com.adobe.AfterEffects         0x00000001000029d4 start + 52
      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
      0   libsystem_kernel.dylib         0x00007fff9522a232 kevent64 + 10
      1   libdispatch.dylib             0x00007fff861da26e _dispatch_mgr_thread + 52
      Thread 2:
      0   libsystem_kernel.dylib         0x00007fff95229136 __psynch_cvwait + 10
      1   com.apple.CoreServices.CarbonCore 0x00007fff8f3bea77 TSWaitOnCondition + 108
      2   com.apple.CoreServices.CarbonCore 0x00007fff8f3bec76 TSWaitOnConditionTimedRelative + 171
      3   com.apple.CoreServices.CarbonCore 0x00007fff8f394d6b MPWaitOnQueue + 192
      4   com.adobe.dvacore.framework   0x000000010350429d dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr<dvacore::threads::Al locatedFunctionT<boost::function<void ()> > >&, int) + 141
      5   com.adobe.dvacore.framework   0x0000000103502200 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 160
      6   com.adobe.dvacore.framework   0x00000001034f269c boost::function0<void>::operator()() const + 28
      7   com.adobe.dvacore.framework   0x00000001034ff173 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 115
      8   com.adobe.boost_threads.framework 0x0000000108a3fdba thread_proxy + 186
      9   libsystem_pthread.dylib       0x00007fff9308205a _pthread_body + 131
      10  libsystem_pthread.dylib       0x00007fff93081fd7 _pthread_start + 176
      11  libsystem_pthread.dylib       0x00007fff9307f3ed thread_start + 13
      Thread 3:
      0   libsystem_kernel.dylib         0x00007fff9522a21a kevent + 10
      1   com.adobe.dvatransport.framework 0x00000001086c61a7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 375
      2   com.adobe.dvatransport.framework 0x00000001086c5d18 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 552
      3   com.adobe.dvatransport.framework 0x00000001086b5157 SkyConnectionEnv::MainLoop() + 167
      4   com.adobe.dvatransport.framework 0x00000001086b4c09 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      5   com.adobe.boost_threads.framework 0x0000000108a3fdba thread_proxy + 186
      6   libsystem_pthread.dylib       0x00007fff9308205a _pthread_body + 131
      7   libsystem_pthread.dylib       0x00007fff93081fd7 _pthread_start + 176
      8   libsystem_pthread.dylib       0x00007fff9307f3ed thread_start + 13
      Thread 4:
      1   com.adobe.dvacore.framework   0x00000001034cc0cb boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 139
      2   com.adobe.dvacore.framework   0x00000001034cbe38 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 552
      3   com.adobe.dvacore.framework   0x00000001034cbbfa boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
      4   com.adobe.dvatransport.framework 0x00000001086c6bb3 boost_asio_detail_posix_thread_function + 19
      5   libsystem_pthread.dylib       0x00007fff9308205a _pthread_body + 131
      6   libsystem_pthread.dylib       0x00007fff93081fd7 _pthread_start + 176
      7   libsystem_pthread.dylib       0x00007fff9307f3ed thread_start + 13
      Thread 5:
      Thread 6:
      0   libsystem_kernel.dylib         0x00007fff952244de mach_msg_trap + 10
      1   libsystem_kernel.dylib         0x00007fff9522364f mach_msg + 55
      2   com.apple.CoreFoundation       0x00007fff93ba7eb4 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation       0x00007fff93ba737b __CFRunLoopRun + 1371
      4   com.apple.CoreFoundation       0x00007fff93ba6bd8 CFRunLoopRunSpecific + 296
      5   com.apple.AVCVideoServices     0x0000000136aedc32 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 194
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 3
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 8292
          thread_create: 0
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=788.6M resident=256.7M(33%) swapped_out_or_unallocated=531.9M(67%)
      Writable regions: Total=5.1G written=2.2G(43%) resident=2.4G(48%) swapped_out=0K(0%) unallocated=2.6G(52%)
      REGION TYPE                        VIRTUAL
      ATS (font support)                   32.1M
      ATS (font support) (reserved)           4K        reserved VM address space (unallocated)
      Activity Tracing                     2048K
      CG backing stores                    33.3M
      CG image                              616K
      CG raster data                         40K
      CG shared images                      336K
      CoreAnimation                        8644K
      CoreImage                              72K
      CoreUI image data                     248K
      Foundation                           1476K
      IOKit                               414.4M
      Image IO                             3512K
      JS JIT generated code               128.0M
      JS JIT generated code (reserved)    896.0M        reserved VM address space (unallocated)
      JS garbage collector                 1344K
      Kernel Alloc Once                       8K
      MALLOC                                1.7G
      MALLOC (admin)                         32K
      Memory Tag 242                         12K
      Memory Tag 249                        192K
      Memory Tag 251                         96K
      OpenCL                               5800K
      OpenCL (reserved)                      12K        reserved VM address space (unallocated)
      OpenGL GLSL                           512K
      STACK GUARD                          56.4M
      Stack                               139.9M
      VM_ALLOCATE                           1.7G
      VM_ALLOCATE (reserved)                 36K        reserved VM address space (unallocated)
      WebKit Malloc                         768K
      __DATA                               66.9M
      __GLSLBUILTINS                       2588K
      __IMAGE                               528K
      __LINKEDIT                          215.7M
      __NV_CUDA                            5228K
      __TEXT                              572.9M
      __UNICODE                             552K
      mapped file                         191.3M
      shared memory                          68K
      TOTAL                                 6.1G
      TOTAL, minus reserved VM space        5.2G
      Model: MacPro6,1, BootROM MP61.0116.B16, 12 processors, 12-Core Intel Xeon E5, 2.7 GHz, 64 GB, SMC 2.20f18
      Graphics: AMD FirePro D700, AMD FirePro D700, PCIe, 6144 MB
      Memory Module: DIMM1, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D314739453120
      Memory Module: DIMM2, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D314739453120
      Memory Module: DIMM3, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D314739453120
      Memory Module: DIMM4, 16 GB, DDR3 ECC, 1866 MHz, 0x802C, 0x33364A534632473732505A2D314739453120
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.15.166.24.3)
      Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Ethernet 2, Ethernet, en1
      Network Service: Wi-Fi, AirPort, en2
      PCI Card: AMD FirePro D700, Display Controller, Slot-2
      PCI Card: AMD FirePro D700, Display Controller, Slot-1
      PCI Card: pci1b4b,9235, AHCI Controller, Thunderbolt@160,0,0
      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@107,0,0
      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@106,0,0
      PCI Card: pci1b4b,9235, AHCI Controller, Thunderbolt@163,0,0
      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@105,0,0
      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@104,0,0
      PCI Card: ethernet, Ethernet Controller, Thunderbolt@112,0,0
      PCI Card: pci1b73,1100, USB eXtensible Host Controller, Thunderbolt@111,0,0
      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@110,0,0
      Serial ATA Device: APPLE SSD SM1024F, 1 TB
      Serial ATA Device: Samsung SSD 850 EVO 1TB, 1 TB
      Serial ATA Device: OWC Mercury EXTREME Pro 6G SSD, 240.06 GB
      Serial ATA Device: Hitachi HDS723020BLA642, 2 TB
      Serial ATA Device: Samsung SSD 840 EVO 1TB, 1 TB
      USB Device: Hub
      USB Device: BRCM20702 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: Keyboard Hub
      USB Device: USB Receiver
      USB Device: Apple Keyboard
      USB Device: Backup+  Desk
      USB Device: USB audio CODEC
      Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
      Thunderbolt Device: ThunderBay 4 mini, Other World Computing, 1, 25.1
      Thunderbolt Device: RocketStor 6328L, HighPoint Technologies, Inc., 3, 24.2
