1 Reply Latest reply on Dec 29, 2015 11:46 PM by Nanaky
    Can no longer return borrowed Library book.
    debbieoc58
      I'm trying to return some library books and at first I got this error message: E_AUTH_BAD_DEVICE_KEY_OR_PKCS12.  I de-authorized and re-authorized my computer and now when I try to return a book I get: Error returning item. Please authorize your computer.  Now what do I try?
        • 1. Re: Can no longer return borrowed Library book.
          Nanaky Level 5
          Macintosh:
          1. Open Adobe Digital Wditions.
          2. Press Command+Shift+D to deauthorize Adobe Digital Editions.
          3. Select Erase Authorization.
          4. Click OK and quit Adobe Digital Editions.
          5. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
            If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
          6. Open Adobe Digital Editions and reauthorize.
          Windows:
          1. Close all applications.
          2. Choose Start > Run.
          3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
          4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
          5. Select the Adept key.
          6. Choose File > Export.
          7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
          8. Right-click the Adept key and choose Delete.
          9. In the Confirm Key Delete dialog, click OK.
          10. Close the Registry Editor.
          11. Open Adobe Digital Editions and reauthorize.
