• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
how do I clean install flash player windows 10 64 bit
New Here ,
Dec 29, 2015 Dec 29, 2015
I keep getting this error when I try to run xsplit on my computer, and I have come to the conclusion that the version of flash that was pre-installed on this computer has become corrupt.  I had two blue-screens earlier today while working on a large photoshop CC project, I believe that's when it started.
I tried this How do I do a clean install of Flash Player? but no gravy.
Is it wrong of me to want to be able to uninstall a program on a computer that I own without having to get permission?
Views
713
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
Dec 30, 2015 Dec 30, 2015
On windows 10 you cannot do a true clean install, you can come close, but no cigar, uninstalling the integrated version that is native to Windows 10 could prove fatal to your system.
If you click on my name on these forums, then go to my sourceforge link in my profile then click under the green button browse all files. Go to the BAT version folder and grab either of the two files there, that should preform the closest think to a clean install of flash player(s) without deleting the OS files.
Hopefully that assists you
Best Regards
P.S. I hope you did not mess with the permissions of those file also try running windows updates
Votes
Translate
Translate
Report
Report
New Here ,
I tried both, but it didn't get anywhere.
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
1) did you fool, try to fool with, or try to modify the contents of C:\Windows\SysWOW64\Macromed , any of the sub folders or files in any way? IF you did it is beyond the scope of this forum. You can also try opening an elevated command prompt an use the following command:
sfc /scannow
If that does not work, you try two more times, re-booting between, You can also try running
Dism /Online /Cleanup-Image /RestoreHealth
all that is outlined here in option 3:
Windows 10 Forums
2) Is this a browser or some kind of home brew application?
3) Windows update is the only way to uninstall or update flash player that is integrated into the operating system.
Best regards
Votes
Translate
Translate
Report
Report
