1 Reply Latest reply on Dec 30, 2015 11:54 PM by Nanaky
    update the default info in ADE.
    carols96668960
      How can I update the default email assosiated with ADE. The account is inactive and the information Adobe has on file is now corrected.
        • 1. Re: update the default info in ADE.
          Nanaky Level 5
          Mac:
          1. Open Adobe Digital Wditions.
          2. Press Command+Shift+D to deauthorize Adobe Digital Editions.
          3. Select Erase Authorization.
          4. Click OK and quit Adobe Digital Editions.
          5. Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
            If you are using 10.7, see Access hidden library files | Mac OS 10.7 and later.
          6. Open Adobe Digital Editions and reauthorize.
          Windows:
          1. Close all applications.
          2. Choose Start > Run.
          3. In the Open text box, type regedit and then press Enter. The Registry Editor opens.
          4. In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
          5. Select the Adept key.
          6. Choose File > Export.
          7. In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
          8. Right-click the Adept key and choose Delete.
          9. In the Confirm Key Delete dialog, click OK.
          10. Close the Registry Editor.
          11. Open Adobe Digital Editions and reauthorize.
