1 Reply Latest reply on Jan 3, 2016 11:00 AM by BKBK
    DateConvert() vs DateAdd() inconsistency question
    SemperVI Level 1
      I am working on some Date Helper functions where I need to convert UTC dates to unixtimestamps and vice versa. Interestingly I came across an inconsistency using the DateConvert function in cooperation with DateDiff in that the timestamps are different. DateConvert makes the timestamp using local time while DateAdd uses the appropriate UTC Date. I was wondering if this is a bug / anomaly or my misunderstanding how DateConvert works in ColdFusion.
      The following is syntax to reproduce scenario
      <cfset unixEpoch = CreateDate(1970,1,1) />
      <cfoutput>
          <pre>
          Local Date:        #Now()# [CORRECT]
          UTC Date:          #DateConvert("local2Utc", now())# [CORRECT]
          UTC to Unix Timestamp Conversion
          UTX (DateConvert): #DateDiff("s", unixEpoch, DateConvert("local2Utc", now()))# [WRONG]
          UTX (DateAdd):     #DateDiff("s", unixEpoch, DateAdd( "s", GetTimeZoneInfo().UTCTotalOffset, now() ) )# [CORRECT]
          </pre>
      </cfoutput>
      The following is what the above unit of code output last time I ran it
      Local Date: {ts '2015-12-30 10:44:25'} [CORRECT]
      UTC Date: {ts '2015-12-30 18:44:25'} [CORRECT]
      UTX (DateConvert): 1451472265 [WRONG]
      UTX (DateAdd): 1451501065 [CORRECT]
      *** Use http://www.unixtimestamp.com/index.php to confirm unix timestamp discrepancies
      Any thoughts would certainly be helpful -- Thank you
        • 1. Re: DateConvert() vs DateAdd() inconsistency question
          BKBK Adobe Community Professional & MVP
          I think you have stumbled on a bug. I have isolated it as follows:
          <cfset utcDate1 = dateConvert("local2Utc", now()) />
          <cfset utcDate2 = dateAdd( "s", getTimeZoneInfo().UTCTotalOffset, now()) />
              <cfoutput>
                  <pre>
                  UTC Date:                #utcDate1#
                  Alternative UTC Date:      #utcDate2#
                  Difference in UTC dates: #dateDiff("s", utcDate1, utcDate2)# seconds
                  </pre>
              </cfoutput>
