1 Reply Latest reply on Feb 3, 2009 4:55 PM by Gregory Lafrance
    Help needed with XML
    G009 Level 1
      Hi guys,
      i was wondering if it is possible to copy data from xml file into array and use that data to make search in some other xml file. Since i coulnt get any help on my previous post am raising this question. I have lot more to ask but right now this much only. :).
      Thanks in advance.
        • 1. Re: Help needed with XML
          Gregory Lafrance Level 6
          Depending on the structure of the XML file, you should be able to use E4X syntax to put required data into an Array, or perhaps an ArrayCollection.
          Then I would think you should be able to once again use E4X syntax to search (filter???) the other XML file using the data in the ArrayCollection.
