0 Replies Latest reply on Jan 1, 2016 12:17 PM by briana93128240
    TypeError: Error #1009: Cannot access a property or method of a null object reference.      at index_fla::MainTimeline/publishP2PVideo()
    briana93128240
      whats the cause of the above error? and why does the video freezes when i place a play video? my code is below
      import flash.net.NetConnection;
      import flash.events.NetStatusEvent;
      import flash.media.Camera;
      import flash.events.MouseEvent;
      import flash.net.NetStream;
      import flash.net.GroupSpecifier;
      import flash.net.NetStreamMulticastInfo;
      import flash.net.NetGroupSendResult;
      import fl.motion.MotionEvent;
      import flash.net.NetGroup;
      //step 1
      var CirrusAddress:String = "rtmfp://p2p.rtmfp.net";
      var DeveloperKey:String = "3d142a01affff31a508f31fc-f412604cf122";
      // step two
      var netConnection:NetConnection;
      // connect to cirrus
      netConnection = new NetConnection();
      netConnection.connect(CirrusAddress, DeveloperKey);
      netConnection.addEventListener(NetStatusEvent.NET_STATUS, netConnectionHandler);
      /////////////////////////////////////////////// handler function/////////////////////////////////////
      function netConnectionHandler(event:NetStatusEvent):void
        trace ("NetConnection event: " + event.info.code + "\n");
        switch (event.info.code)
        // the connection attempt succeded
        case "NetConnection.Connect.Success":
        trace("NetConnection.connect successful");
        connectSuccess();
        break;
        // the connection was closed succefully
        case "NetConnection.Connect.Closed":
        trace("NetConnection.connect successfully closed");
        break;
        case "NetConnection.Connect.Failed":
        trace("Unable to connect");
        break;
      // step three
      function connectSuccess():void{
        trace("connected, my ID:" + netConnection.nearID + "\n");
        nearId.text = netConnection.nearID;
      //step four
      var outgoingStream:NetStream;
      var incomingStream:NetStream;
      var camera:Camera;
      camera = Camera.getCamera();
      if (camera)
        camera.setMode(1280,720,24, false);
        camera.setQuality(0,90);
        camera.setKeyFrameInterval(30);
        else
        txtMsg.text = "no camera detected";
        videoPlayback.attachCamera (camera);
        // video publish function
      function publishP2PVideo(event:MouseEvent)
        if (!camera)
        Security.showSettings(SecurityPanel.PRIVACY);
        // create a new netstream object for video publishing
        outgoingStream new NetStream (netConnection, NetStream.DIRECT_CONNECTIONS);
        outgoingStream.addEventListener(NetStatusEvent.NET_STATUS, nsPublishVideoOnStatus );
        outgoingStream.publish("testVideoName");
        // attach the camera nd microphone to the server
        outgoingStream.attachCamera(camera);
      // publish a video handler function
      function nsPublishVideoOnStatus(infoObject:NetStatusEvent)
        if (infoObject.info.code == "NetStream.Publish.Start")
        trace ("nspublish: "+infoObject.info.code+"("+infoObject.info.description+")");
        txtMsg.text == "publish successful";
        if (infoObject.info.code == "NetStream.publish.StreamNotFound" || infoObject.info.code == "NetStream error"){
        trace (infoObject.info.description);
      // publish video function:
      function playP2PVideo(event:MouseEvent)
        //create a new Netstream Object for video playback
        incomingStream = new NetStream (netConnection, farId.text);
        //trace the NetStream status information
        incomingStream.addEventListener(NetStatusEvent.NET_STATUS, nsPublishVideoOnStatus);
        //subscribe to the named stream
        incomingStream.play("testVideoName");
        //attach the stream
        videoPlayback.attachNetStream(incomingStream);
        //play the hndler function
      function nsPlayVideoOnStatus(infoObject:NetStatusEvent)
        trace("nsplay: "+infoObject.info.code+" ("+infoObject.info.description+")");
        if (infoObject.info.code == "NetStream.Play.Start"){
        trace("nsplay: "+ infoObject.info.code+" ("+infoObject.info.description+")");
        txtMsg.text = "play successful";
        else if (infoObject.info.code == "NetStream.play.StreamNotFound " || infoObject.info.code == "NetStream Error" )
        trace(infoObject.info.description);
        else if (infoObject.info.code == "NetStream.publish.StreamNotFound " || infoObject.info.code == "NetStream Error"){
      publishVideo.addEventListener(MouseEvent.CLICK,publishP2PVideo);
      playVideo.addEventListener(MouseEvent.CLICK, playP2PVideo);
