0 Replies Latest reply on May 16, 2006 7:36 AM by andyfoltz
    Addressing a variable nested in an MC when the MC is attached via Actionscript
      Hello all,
      I've got a movieclip named "buttonmovie" which contains a string variable named "buttonvalue"
      I attach several instances of "buttonmovie" to the _root using attachmovie, naming the instances "buttons" + i.
      As each instance is created, I want to add the "buttonvalue" to a longer string called "seqstring."
      To address the "buttons" + i movieclips, I've tried addressing them literally, "buttons1.buttonvalue" I've tried using the array bracket things, "_root["buttons" + i].buttonvalue" but every time, I try to trace those, flash says it is undefined, even though if I debug it, the instance "buttons1" definitely has a variable "buttonvalue" that is populated with a string.
      Is there a better way to get the desired result? How can I address a variable that is a child of an actionscript spawned MC?
