1 Reply Latest reply on Jan 3, 2016 6:45 AM by Mylenium
    analysis solve failed!
    PROblomboy
      i am going to do 3d camera tracking on my video.
      but analysis solve failed problem in on anytime.
      what is the problem? my video is not fast-camera move ! T__T
      my video format is this. recorded by Geforce Experience - Share. please help me!
      Complete name                  :
      Format                        : MPEG-4
      Format profile                : Base Media / Version 2
      Codec ID                      : mp42 (mp41/isom)
      Overall bit rate              : 46.9 Mbps
      Format                        : AVC
      Format/Info                    : Advanced Video Codec
      Format profile                : High@L4.2
      Format settings, CABAC        : Yes
      Format settings, ReFrames      : 1 frame
      Format settings, GOP          : M=1, N=30
      Codec ID                      : avc1
      Codec ID/Info                  : Advanced Video Coding
      Bit rate                      : 46.7 Mbps
      Display aspect ratio          : 16:9
      Frame rate mode                : Variable
      Frame rate                    : 59.940 (59940/1000) fps
      Minimum frame rate            : 58.252 fps
      Maximum frame rate            : 62.959 fps
      Original frame rate            : 60.000 fps
      Standard                      : PAL
      Color space                    : YUV
      Chroma subsampling            : 4:2:0
      Bit depth                      : 8 bits
      Scan type                      : Progressive
      Bits/(Pixel*Frame)            : 0.376
      Color range                    : Limited
      Color primaries                : BT.601 NTSC
      Transfer characteristics      : BT.470 System M
      Matrix coefficients            : BT.601
      mdhd_Duration                  : 80203
        • 1. Re: analysis solve failed!
          Nobody can tell you anything without seeing the footage. The technical specs don't matter for the analysis, the content does. That said, your mere mention of "GeForce Experience" made me shiver - game footage is unsuitable for serious 3D tracking since in itself it is not temporally and spatially consistent as would be required.
          Mylenium
