3 Replies Latest reply on Jan 3, 2016 4:45 PM by rachelb92394081
    LR CC impossibly slow in Develop module
      I just got Lightroom CC and a new iMac with Retina display on Tuesday.  I have a fusion drive 1TB.  Everything was working great until today, when suddenly the adjustment brushes slowed down to such an extreme that I cannot edit my images. Every time I click on the brush or heal tool, the spinning wheel pops up for several seconds.  Then when I make an adjustment, it takes about 20 seconds for the brush stroke to show up in the history panel and an additional 15 seconds or so for the adjustment to appear on the image.  Zooming in and out also takes several seconds.  Here are the strategies I have already tried:
      Restarting my computer
      Turning off the GPU
      Turning on the GPU
      Taking LR offline
      Purging my cache
      Increasing my cache
      Making the screen smaller
      Decreasing the resolution
      Restarting LR
      Redistributing my files among folders, so the folders are smaller
      Making all my files DNG
      Changing my Raw compatibility - it was on the latest, and then I tried the version prior
      Everything is completely updated
      I do not use a Wacomb tablet ( I read in the forums that some people were having this issue and Adobe suggested the tablet could be the problem)
      Any help you can offer would be greatly appreciated! I am on a deadline with an extremely important client and I think I'm getting an ulcer
      Thank you in advance for taking the time!
        • 1. Re: LR CC impossibly slow in Develop module
          Mrinmay Majhi Adobe Employee
          Hi Rachel,
          Please disconnect the USB devices and check for the issue.
          If you still face any issue, please try creating a new catalog and then check.
          • 2. Re: LR CC impossibly slow in Develop module
            dj_paige Level 9
            It's not the USB devices, and it's not going to be solved by a new catalog. Use of a lot of adjustment brushes (and/or a lot of spot healing) on a photo will cause the develop module to slow to a crawl. Your symptoms are exactly what you would expect from using a lot of adjustment brushes (and/or a lot of spot healing).
            Some things you can try:
            1. Do the brushing (and spot healing) as the next to last step, with lens corrections turned off; and as the last step, turn on the lens corrections (and all the while, please be 100% sure you have turned off the GPU ... I know you said you did, but I would double-check and triple-check)
            2. Do the brushing (and spot healing) in Photoshop or Photoshop Elements
            3. Get a faster CPU
            • 3. Re: LR CC impossibly slow in Develop module
              rachelb92394081 Level 1
              Thank you, dj_paige! That makes sense -- when I move on to another image
              and start over, LR is back to it's normal speed, but as I make more
              adjustments, it eventually slows down considerably.  I don't normally do
              this much retouching, so I had no idea   Moving on to Photoshop for
              these.  Thanks again!
