Rats! I tried republishing my own Captivate 3 training/simulation using Flash 9, and then reinserted into my PPT using Presenter 6 but the text entry box in the Captivate SWF still can not be typed in when published using Presenter 6.
Any more ideas? I actually logged a ticket about this with Adobe.
JLTX,
If not mistaken, Pres 6 won't output to flash player 9. What you may have to do is try publishing your Captivate content to FP8. Give that a shot.
Rob
Hi Rob,
By FP8 do you mean Flash 8? Since I already tried publishing my Captivate 3 file in Flash 9, why would going back to Flash 8 help if Pres 6 can't publish using the newer Flash versions (not sure what version it does publish in)?
So are you saying that by using say Presenter 7, the text entry boxes work becasue it publishes using a newer Flash product?
Thanks for the insights - Jeff
That's exactly what I'm saying. The reason why Leo's suggestion to TMP's initial question works is b/c TMP is outputting Presenter 7 content. In that environment, P7 publishes to a more recent version of the flash player. Not so with P6. As a result, if you publish Captivate content targeting the newer flash player, P6 won't be able to keep up with that.
The result: an inoperable Captivate file.
Setting your Captivate going back to player 8 *should* work b/c P6 will only output the earlier versions of the flash player.
Rob
