• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Format of breadcrumb link when hovering
Guest
Feb 03, 2009 Feb 03, 2009
In my style sheet, I specified that an active hyperlink is blue, and a hovered hyperlink is blue and underlined.
My breadcrumb links are blue, but I don't see where I can make them underlined when hovered.
Is there any way to do this within the RoboHelp application? (I'd rather not mess with code.)
Thank you.
Views
828
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 04, 2009 Feb 04, 2009
I think you need to define a visited hyperlink style.
See http://www.grainge.org/pages/snippets/snippets.htm item 27
Maybe just a.visited. Look in the RH style editor, it may be an option there.
Votes
Translate
Translate
Community Expert ,
Welcome to the forum.
Look in the wizard when you generate. There is a button that enables you to format the breadcrumbs.
Votes
Translate
Translate
Report
Report
Guest
Thank you. I do see the format function for breadcrumbs when generating the layout, but it does not handle the particular format I described, i.e., underlining when hovering.
Votes
Translate
Translate
Report
Report
LEGEND ,
Welcome to our community, AbigailAnn
Normally the default setting is to adhere to whatever is specified in your topic styles. Are you finding that's not the case?
Cheers... Rick
Votes
Translate
Translate
Report
Report
Guest
Thanks, Rick. My breadcrumbs are the same color as links in the topic style, but in the topic style I specified that a 'Hyperlink (hovered)' would be underlined, and that's the part that's not working in breadcrumbs. The hover-underlining is working well in the topics, but not in the breadcrumbs. -- Abbie
Votes
Translate
Translate
Report
Report
LEGEND ,
Hmmm, how odd
I just tested by editing my style sheet so that upon hovering I saw a background change (Red with Yellow text) and that part worked. Perhaps it's an issue with underlining. I'll see if that works too.
Hmmm, the underlining worked on mine.
Maybe Peter can think of what's happening. My mind is a bit of mush at the moment.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Guest
If it worked for you, that's encouraging. I'll try re-defining the topic style and see if it takes.
Votes
Translate
Translate
Report
Report
Guest
Votes
Translate
Translate
Report
Report
Guest
I've discovered that the nature of my problem is not the breadcrumbs, but rather the fact that the underlining when hovering does not show for links that have been visited. I want underlining to show whenever I hover over a hyperlink, whether or not it has been visited. The style sheet tool in RoboHelp doesn't offer the ability to distinguish between a hyperlink (visited) and a hyperlink (visited & hovered). I have defined the hyperlink (hovered) as underlined, which works well until the link has been visited -- then the underline doesn't appear when hovering. Is there a work-around?
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Guest
LATEST
Thank you, Peter. The information in item 27 of your snippets list gave the answer I needed. I changed the order of style definitions within my style sheet, putting the A:hover style after the other A: styles, and this gave me what I wanted. Thanks!!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
