2 Replies Latest reply on Feb 3, 2009 11:44 AM by fober1
    new update query?
    newchickinCF Level 1
      I am trying to update a record but i have one unique things in my update statement.
      I have the link name which is unique. if i disable the link name to not to be updated then my update works fine.
      What if i want to also change the link.
      if i enter new link and that new link also exists in other record, then it should throw an error. if i keep the same link and update otehr values, then it should update the record.
      Hope u guys under stand what i am trying to do..
      it is something usage of If Exists but i don't know the exact way to do it.
      Please guide me
      Cheers
        • 1. Re: new update query?
          Level 7
          assuming col2 is set up with UNIQUE index option, and 'newvalue' is not
          same as in some other row in the table, this should work just fine:
          UPDATE mytable
          SET
          col1 = 'someting',
          col2 = 'newvalue'
          WHERE col2 = 'oldvalue'
          this should also work fine, if you need to update other columns, but not
          col2:
          UPDATE mytable
          SET col1 = 'someting'
          are you sure you don;t have some other constraints, maybe on some other
          columns, interfering with your update?
          posting your code may help...
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com/
          • 2. Re: new update query?
            fober1 Level 1
            There's no single SQL function that allows you to do that, you have to build the logic in ColdFusion.
            To make that work you need to first query if there is already a record with that link in the DB and a different key then your current record.
            If yes, then throw a CF error message, if not then do the db update.
            I don't think this question should be listed in the "Advanced Techniques" forum.
            cheers,
            fober
