I've built a quiz using only CP quiz slides - nothing custom. I have reviewed all of my quiz settings and from what I can see it should be reporting, but my scores are always 0. When I look at the Advanced Interaction tab, every question is set to 0 points and the Report Answers column has NO for every question. I cannot find how to fix these settings and am stumped. I've built enough quizzes to know that there's probably one checkbox buried somewhere I failed to check.
I have LMS selected, but that is not my issue. I can't even get the score to display during testing.
I do have a couple questions about the quiz settings though. Why wouldn't quiz questions default to at least 1 point per question? Why doesn't the "Enable reporting for this project" trigger the "Report Answers" setting that I'm trying to find?
I included a couple image examples. The first one has been truncated.
It is not a normal Quiz slide, it is a Knowledge Check slide. If you want a scored Quiz slide, use the option Quiz, Question slide instead of Quiz, Knowledge Check slide.
Could you show the Quiz Properties of a slide?
Good catch. The prompt/options for inserting a Question slide an Knowledge Check are the same, so I didn't recognize a difference (apart from selecting the wrong option from the list). Looking forward to rebuilding those slides... unless there's a way to convert a KC to a Quiz?
I suspected it, but wanted to confirm. It is very clear in the Quiz Properties (KC in the top).
Converting is not possible, AFAIK. Sorry
