0 Replies Latest reply on Jan 4, 2016 3:49 PM by wyll44
    [Coldfusion 9.0.1] Error HTTP 401.3 - Access is denied
    wyll44 Level 1
      Hello,
      "Beginner" in Coldfusion , I made an installation at the request of a third person.
      Here are the tech. specs of the server :
      - OS : Windows 2008R2
      - IIS 7.0
      - Coldfusion 9.0.1 + hotfix
      - JRE 7u51
      According to the documentation, no problem : everything works, I can go to Coldfusion admin page, type password, create instances etc.
      But... I had to take the document root (wwwroot) of a previous IIS web server (sick !) and then apply the same configurations (other server will be deleted). So I made a backup (wwwroot.bak) following the CF clean installation on the new server. Then import the doc. root of other server (NTFS permissions also replicated) . In this folder "wwwroot", I had a CFIDE directory because CF was also installed on the previous server.
      I do all IIS configurations and...
      This is where the problem occurs : I can't access to the CF administration page located in "wwwroot\CFIDE\administrator\index.cfm"
      => HTTP Error 401.3 - Unauthorized: Access is denied due to an ACL set on the requested resource.
      I check the NTFS permissions : all is OK. Even if I put "everyone" read / write on the folder wwroot (for testing) and restart IIS + CF services the problem is still present
      => I can't access on CF administration page or also my CF instances. But, In the "old" server everything is OK and configurations are indentical.
      I check IIS various configurations (mime type, default document etc.) = all is OK
      Also, I've created a IIS "testwebsite" pointing to wwwroot.bak directory (that containing my clean working installation of CF) : same problem appears now...
      Any idea ?
      Is the problem is located on IIS or on CF ?
      Do you think that I have to reinstall ColdFusion and overwriting the CFIDE directory and CF instances already in the wwwroot directory ?
      Thank a lot for your help !
      W.
      Sorry for my bad English, I'm French
