2 Replies Latest reply on Jan 5, 2016 9:49 AM by H2O4
    How do you place transitions
    H2O4
      I have several hundred images that would present better with transitions. How do I place a standard
      transition for each image without having to do it manually for each?
      I am running Windows 10 and elements 13
      Thank you,
      Robert
        • 1. Re: How do you place transitions
          A.T. Romano Level 7
          Robert
          Select all at one time the images that will be involved in getting the same transition, then Timeline Menu/Apply Default Transition.
          For selecting all at one time, consider
          a. As you hold down the Shift key, click on each of the images involved
          or
          b. With the mouse cursor, draw a rectangle around the involved clips to select them
          or
          c. Edit Menu/Select All (or Ctrt+A) if you want all on the Timeline selected for this.
          Please consider. Any questions or need clarification on the Adobe, please do not hesitate to ask.
          Thank you.
          ATR
          Add on....for selecting the Default Transition...Transitions Tab, just right click the transition to be set as the default, select Set Selected As Default Transition from the pop up tab.
          • 2. Re: How do you place transitions
            H2O4 Level 1
            Thank you
            Robert
