When i try to open my doc, "activation server error - code E_ADEPT_INTERNAL" appears, saying that Digital Editions encounter an error on the activation server. On the Help page, it is suggested that I deactivate it, but when I type in my (correct) password, it says that my password is wrong! I have even tried changing my password and typing in the new one. Same problem occurs.
I am unsure why I cannot access my document. Previously I was on a Macbook Pro and it worked perfectly fine. Since, I have changed to a Macbook Pro with Retina display. I have entered the product key/code, but it will not open.
What do I do??
Thanks for your reply!
I cannot even get to step #3, because it will not accept my password. It says "unable to erase authorization. please try after some time." i have tried this for days.
Do you have further advice?
Thanks so much again.
Hi Jordyn,
You need to manually deactivate ADE. Please follow these instructions:
On Mac it can be found here:
In Finder, find the 'Go' option on the menu bar and click 'Go to folder' and type the following in:
~/Library/Application Support/Adobe/Digital Editions/
Delete the activation.dat file within the 'Digital Editions' folder.
Restart ADE and it should be deactivated at this point. You should be good to sign back in.
If step 3 not work can you skip this point and proceed to step 4.
This did work for me.
Thank you.
Joe
