2 Replies Latest reply on Feb 10, 2009 7:17 PM by Tones411
    Insert a page of code into db with quotes
    DettCom Level 1
      Hello,
      I am hitting a webservice that replies with a ton of information based on a VIN. However, there is a fee everytime I do it so I would like to store this code into a database. What I would like to do is set all of the code to a variable using cfset and then insert into a database. However, I would also like to insert the populated variable (Ford), not the variable representation (#vehicleinfo.make#). I assume that I should be using the evaluate function for each variable???
      The code is attached...
      So the code is breaking where I encounter the first quote in this line: onClick="document.getElementById('options').style.display =''"
      Can someone help??? Thanks
        • 1. Insert a page of code into db with quotes
          Dan Bracuk Level 5
          quote:
          Originally posted by: DettCom
          Hello,
          Depending on what code you are getting, and what you want to store, you might want to check out cfsavecontent instead of cfset. If quotes are causing you a problem, that should sort itself out if you use cfqueryparam.
          • 2. Re: Insert a page of code into db with quotes
            Tones411
            I was thinking along the same lines ad DettCom.
            > 1. Use cfsavecontent to save your large text data. Example below.
            <cfsavecontent variable="VinCode">
            <cfoutput>
            ... Your VIN code here.
            </cfoutput>
            </cfsavecontent>
            > 2. In your query, use cfqueryparam. Example below.
            <cfquery name="qInsert" datasource="mydsn">
            INSERT INTO
            Vins(Vin, VinCode)
            VALUES(<cfqueryparam value="#URL.VIN#" cfsqltype="CF_SQL_VARCHAR">, <cfqueryparam value="#URL.VIN#" cfsqltype="#VinCode#">
            </cfquery>
