6 Replies Latest reply on Jan 7, 2016 11:12 AM by Jump_Over
    How to check if a file is already open
    McShaman Level 1
      My question is about the local file system object `File`. I am writing a function that reads the contents of a text file. The function is passed a `File` object as an argument and then reads the content before some other logic.
      Before you can read a `File` object it needs to be open. The Adobe JavaScript documentation has the following warning around opening files:
      NOTE: Be careful about opening a file more than once. The operating system usually permits you to do so, but if you start writing to the file using two different File objects, you can destroy your data.
      So my question is... How do I tell if a File object is already open? There doesn't appear to be a property or method that simply tells me this.
        • 1. Re: How to check if a file is already open
          TᴀW Adobe Community Professional & MVP
          Just a thought: Perhaps you can try reading from the file first without opening it. If this fails, it's closed. If it succeeds, that would mean it's already open.
          I do not know if this approach works though -- haven't tested it.
          • 2. Re: How to check if a file is already open
            McShaman Level 1
            Well something like this seems to work. But it seems a little hacky:
            function fileIsOpen(fl) {
              fl.error = '';
              fl.readch();
              if(fl.error) {
              return false;
              } else {
              return true;
            • 3. Re: How to check if a file is already open
              Jump_Over Level 5
              Suggest to use method file.tell() ==> which returns "-1" if current position cant be retrieved.
              If file is opened it returns number >=0 .
              Jarek
              • 4. Re: How to check if a file is already open
                McShaman Level 1
                Great! Thanks for that!
                • 5. Re: How to check if a file is already open
                  Trevorׅ Adobe Community Professional
                  Hi
                  I am not sure that the answers here are correct.
                  A file could be opened by an external process and show that it's closed using the described methods.
                  The snippet below demonstrates this.
                  var fName, aFile, theSameFile;
                  fName = Folder.temp + "/" + +(new Date) + ".txt";
                  aFile = new File(fName);
                  aFile.open("w");
                  aFile.write('hello');
                  theSameFile = new File(fName);
                  // Shows the theSameFile as not open even though the actual file is open with a different reference
                  // The warning "NOTE: Be careful about opening a file more than once.
                  // The operating system usually permits you to do so,
                  // but if you start writing to the file using two different File objects,
                  // you can destroy your data."
                  // Still applies
                  alert("aFile.tell(): " + aFile.tell() + "\ntheSameFile.tell(): " + theSameFile.tell());
                  aFile.close();
                  Sorry to be a party pooper.
                  Trevor
                  • 6. Re: How to check if a file is already open
                    Jump_Over Level 5
                    HiTrevorׅ,
                    I have to agree and have to cancel pyrotechnic on my party.
                    Mentioned method tells only about THIS - created by javascript - object, which in fact can be multiplied with the same path.
                    So the same OS file can be accessed by many file-objects created by javascript or even other processes.
                    However opening objects with "a" (instead of "w") mode should protect file contents applied by other processes.
                    ...or I am completely wrong...
                    Jarek
