4 Replies Latest reply on Jan 12, 2016 12:01 PM by chmaster
    Olympus raw (.orf) support in lightroom for OM-D E-M5
    chmaster
      Hi everyone
      I have a Olympus OM-D E-M5 for about two years now. Since now I was happy with the Olympus Viewer 3 to develop my raw files (*.orf) because of its great and smooth Color Rendering.
      As now, I am testing around with timelapse sequences. To be able to change certain Parameters in developing, I Need to shoot the pics in raw. Because I want to use LRTimelapse for doing this, I Need lightroom.
      So now to my Problem.
      I am able to import all raw files from SD Card into lightroom. Camera profile for Olympus is loaded and they can be opened and edited. Even if I reset all Picture settings to default, there are some Pictures in the sequence, which have wrong Colors!!!
      So, I tried to convert the original files to dng and import them into lightroom, but same behavior. Searched the web for others having this Problem, but did not find anything. If I develop the same raw files in Olympus Viewer 3, everything is fine!!!
      Anyone any Idea? Geting crazy about this.............
      Same files in Olympus Viewer 3:
      lightroom Version:
      Version von Lightroom: CC 2015.3 [ 1052427 ]
      Lizenz: Testversion
      Betriebssystem: Windows 10
      Version: 10.0
      Anwendungsarchitektur: x64
      Systemarchitektur: x64
      Anzahl logischer Prozessoren: 4
      Prozessorgeschwindigkeit: 2.0 GHz
      Integrierter Speicher: 16319.8 MB
      Für Lightroom verfügbarer phys. Speicher: 16319.8 MB
      Von Lightroom verwendeter phys. Speicher: 362.5 MB (2.2%)
      Von Lightroom verwendeter virtueller Speicher: 325.3 MB
      Cache-Speichergröße: 169.7 MB
      Maximale Anzahl Threads, die Camera Raw verwendet: 4
      Camera Raw SIMD-Optimierung: SSE2,AVX,AVX2
      DPI-Einstellung des Systems: 96 DPI
      Desktop-Komposition aktiviert: Ja
      Monitore/Anzeigegeräte: 1) 1680x1050
      Eingabetypen: Multitouch: Nein, integrierte Toucheingabe: Nein, integrierter Stift: Nein, externe Toucheingabe: Nein, externer Stift: Nein, Tastatur: Nein
      Informationen zum Grafikprozessor:
      GeForce GTX 750 Ti/PCIe/SSE2
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 3.3.0 NVIDIA 358.50
      Renderer: GeForce GTX 750 Ti/PCIe/SSE2
      LanguageVersion: 3.30 NVIDIA via Cg compiler
      Anwendungsordner: C:\Program Files\Adobe\Adobe Lightroom
      Bibliothekspfad: E:\Files Simon&Annie\Pictures\Lightroom\Lightroom Catalog.lrcat
      Einstellungen-Ordner: C:\Users\Simon&Annie\AppData\Roaming\Adobe\Lightroom
      Installierte Zusatzmodule:
      1) Canon Tether-Zusatzmodul
      2) Facebook
      3) Flickr
      4) Leica Tether-Zusatzmodul
      5) LRT Export 4
      6) Nikon Tether-Zusatzmodul
      Config.lua-Flags: None
      Audio- und Videoinformationen: Ladevorgang läuft
      DNG-Converter Version:
      9.3.0.506
        • 1. Re: Olympus raw (.orf) support in lightroom for OM-D E-M5
          chmaster Level 1
          In my view this is the most useless forum I've ever seen.
          No topic structure, everyone has to open a new thread for their own issues because ist impossible to find any related Posts....
          Most non-profit forums are made much better than the Adobe one !!!!!!!!
          • 2. Re: Olympus raw (.orf) support in lightroom for OM-D E-M5
            99jon Adobe Community Professional & MVP
            I’m not really sure the reasons why, but assume you are using the same manual camera settings for every time-lapse shot.
            The only suggestion is to select the photo before the problem image in the film strip and then select the subsequent (rogue image) and click the button Sync Settings. Does that fix it?
            • 3. Re: Olympus raw (.orf) support in lightroom for OM-D E-M5
              F. McLion Adobe Community Professional & MVP
              Hmmm .. was soll man da sagen.
              - Hier findest Du eine Suchfunktion.
              - Ein neuer Thread für ein neues Problem finde ich richtig.
              - Du kannst aber auch jederzeit in einen bestehenden Thread einsteigen.
              Aber zurück zu Deinem Problem.
              Dass die Resultate mit DNG identisch sind liegt daran, dass der DNG Konverter und LR denselben Code benutzen.
              Dass die Bilder anders aussehen als mit dem Original Olympus Tool oder wenn Du direkt jpg machst ist auch normal. Einen RAW datei wird immer erst im "Entwicklungsprogramm" interpretiert wodurch je nach Hersteller des Programms ganz unterschiedliche Bilder entstehen können. Der Vorteil des Olympus tools ist, dass es alle von der Kamera abgespeicherten Infos zur Aufnahmesituation kennt und auswerten kann. LR kann das nicht da die Hersteller die Formate und Infos in den RAW files nicht vollständig offenlegen.
              Mit der Kamerakalibrierung im LR Entwicklungsmodul kannst Du eine Grundanpassung an die bei vielen Kameras verschiedenen Stile vornehmen, oder als Empfehlung einfach Adobe Standard verwenden.
              • 4. Re: Olympus raw (.orf) support in lightroom for OM-D E-M5
                chmaster Level 1
                I shot a sequence with 400 pics. All in manual mode (aperture, exposure, focus, white balance, ...). So in color and brightness they should only have minimal change from one to the next Picture.
                First I importet all of them into lightroom. When I rialized, that there is a Color Problem with some pics, I tried to synchronize all to the settings of a correct Picture. That did not make it better, even more worse!
                I had uploaded some examples for others to test that behavior in their version of lightroom and other programs.
                It seems like all other raw software can read them correct exept lightroom
                Link to the <examples.zip>
                FileNurse | examples.zip
