3 Replies Latest reply on Jan 6, 2016 5:33 PM by nezarov
    Having problems comparing with If statement (Basic)
    Natex300 Level 1
      Hi, at school we are learning to use Flash and we are using AS2, and I was working on an example code, but it doesn't seem to want to work. Here is the code:
      var money:Number=0;
      dollar_btn.onPress=function()
      money+=1;
      box_txt.text=money;
      if(money>5){
      check_btn.onPress=function()
      box2_txt.text="Yay!";
      As you can see, all I want to do is have a button, that once pressed, adds 1 to the money counter, and one it is higher than 5, I can press the next button and have it display "Yay!". The problem is, the if doesn't seem to work, even if the money variable is way above 5. I don't think it's a problem with the buttons, because I have tried changing the code to declare the variable with a starting value of 6, and the If works. Any ideas? It would be greatly appreciated !
      Thanks in advance
