1 Reply Latest reply on Feb 5, 2009 1:33 PM by Michael Thornburgh
    connection problem
    Suat Sahin
      hi, my problem is the following:
      when client_1 receives a stream that is published by client_2 everything seems to be ok.... but when the clients close the application and then reopen it, a problem occurs when they try to create and connect new streams: they can't see the streams published by the other client. What kind of problem could this be? I am wondering if there is a stratus's cache.
      thank you for your help.
        • 1. Re: connection problem
          Michael Thornburgh Adobe Employee
          if you are using a web service to coordinate/communicate/look up the peerIDs, perhaps you are getting cached responses instead of fresh ones. we have seen that behavior in our development; our sample app inserts a timestamp into the request to make each one unique specifically to avoid cached results.
          -mike
