5 Replies Latest reply on Jan 8, 2016 3:24 AM by Garethbird
    how to host assets on a different server and banner on a website now nor preload file is provided
    Garethbird
      Hi i use to insert a banner i made into a website but has to store the assets else where, this was relatively easy as when you published you go the assets and a _preLoad file which you could chnage the src path like :
      <div id="Stage" class="trucks" style="text-align: right;"></div>
      <!--Adobe Edge Runtime--><script src="http://www.mydomain.co.uk/trucks/trucks_edgePreload.js" type="text/javascript" charset="utf-8"></script><!--Adobe Edge Runtime End-->
      But in 2015 they have changed the format and you do not get a preload file so how can i still creat the same.  I did try to import in to dreamweaver as I thought i would get all the assest a dn I could changethe path easily but it imports as an objetc :
      <object id="EdgeID" type="text/html" width="828" height="280" data-dw-widget="Edge" data="/../../../../1 dreamwever edge aniamte/Edge-Master/used--trucks-deploy/Assets/used-trucks-deploy.html">
      </object>
      Any ideas how I can change th epaths etc and make this work?
        • 1. Re: how to host assets on a different server and banner on a website now nor preload file is provided
          joel_pau Level 5
          hi,
          You have to use the root html option with latest versions.
          • 2. Re: how to host assets on a different server and banner on a website now nor preload file is provided
            joel_pau Level 5
            Here is a case: Bug. Can't put two Edge Animate animations on same page
            Look at  these lines:
            var custHtmlRoot="edgeanimate_assets/new_indigo_logo/Assets/";
            opts.htmlRoot =custHtmlRoot;
            AdobeEdge.loadComposition('new_indigo_logo', 'EDGE-826742', opts,
            • 3. Re: how to host assets on a different server and banner on a website now nor preload file is provided
              Garethbird Level 1
              Hi thanks for the reply, sorry I dont fully understand,
              so now the html file looks like this :
              So what do I change now so I can install the code in one website and then have it pulling all the assets from a nother server.  Thanks for looking ;-)
              <head>
                  <script type="text/javascript" charset="utf-8" src="http://animate.adobe.com/runtime/6.0.0/edge.6.0.0.min.js"></script>
                  <style>
                      .edgeLoad-used-scania-trucks { visibility:hidden; }
                  </style>
              <script>
                 AdobeEdge.loadComposition('used-trucks', 'used-trucks', {
                  scaleToFit: "none",
                  centerStage: "none",
                  minW: "0px",
                  maxW: "undefined",
                  width: "808px",
                  height: "260px"
              }, {"dom":{}}, {"dom":{}});
              </script>
              </head>
              <body style="margin:0;padding:0;">
                  <div id="Stage" class="used-trucks">
                      <div id="Stage_Rectangle" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-1" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-2" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-3" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-4" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-53" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_used-truck-62" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_Logo_SlvPrtH2" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_transparent_text_box_bottom" class="edgeLoad-used-trucks"></div>
                      <div id="Stage_haydocks-logo-large" class="edgeLoad-used-scania-trucks"></div>
                      <div id="Stage_a_good_quality_used_trucks" class="edgeLoad-used-trucks"> Quality Used Scania Trucks</div>
                      <div id="Stage_b_Quality_Ex-Contract_Scania_Trucks" class="edgeLoad-used-trucks">Quality Ex-Contract Scania Trucks</div>
                      <div id="Stage_c_Specialist__Solution_Scania_Trucks" class="edgeLoad-used-trucks">Specialist  Solution Trucks</div>
                      <div id="Stage_d_truck_Dealer_Assistance__Services" class="edgeLoad-used-trucks">Dealer Assistance &amp; Services</div>
                      <div id="Stage_f_lorry_Dealer_Assistance__Services" class="edgeLoad-used-trucks">Scania Dealer Assistance &amp; Services</div>
                      <div id="Stage_e_Attractive_Finance_Packages" class="edgeLoad-used-trucks">Attractive Finance Packages</div>
                      <div id="Stage_Scania-Logo_WhtPrtV" class="edgeLoad-used-scania-trucks"></div>
                  </div>
              • 4. Re: how to host assets on a different server and banner on a website now nor preload file is provided
                joel_pau Level 5
                I read again and i saw: " I did try to import in to dreamweaver ".
                Your answer is here: Using responsive Edge Animate compositions in Dreamweaver « Adobe Edge Animate Team Blog. There is a demo file at the bottom of the page.
                It runs with latest versions (Edge 5 and 6).
                • 5. Re: how to host assets on a different server and banner on a website now nor preload file is provided
                  Garethbird Level 1
                  Thanks for you r reply.
                  I do not want to use in dream weaver that is just a goose chase support put me on. I can make it work in dreamweaver no problem.
                  I just want the comp to show on one website and the assets stored on a different server so I need to know how I now write the html code to insert into the web page and how and what I have to change the path addresses of which will then be on another server.
                  Support have since come back and said that if i change to version 2014.0.1 which fixes the problem with comps not working with IE 11 and has seperate pre load files so I can do it as i use to do it.
                  However I would still like to know how to do it with the latest version!
                  Appriciate any help you can give.
