0 Replies Latest reply on Jan 7, 2016 11:04 AM by DrDaveJ
    Renaming bookmarks in Acrobat with JS
    DrDaveJ Level 1
      Running Acrobat XI Pro on Win7 pc.
      I want test all Bookmarks in a pdf file for ones that are named (for sake of this discussion), "xxx", and then rename them to "yyy".
      My code starts at top of visible tree, var bm = this.bookmarkRoot.children[0]; // Ignoring hidden bookmark, "Root".
      It works here, but code will not iterate to that bookmark's children. And I need to go another level in after that.
      How to get the code to test additional [visible] levels of bookmark tree? Hoping not to presume upon any of you for help, and having removed many lines that print to console for tracking/debugging, here is my code.
      function RenameTITLEbookmarks()
          // Set start point to top of visible Tree (Ignoring "Root")
          // Number of BMs in current tree level. Any of these could also have
          // Children I also want to rename, but cannot seem to get to with Code.
          var nChildNum = this.bookmarkRoot.children[0].children.length;
          // Bookmark level in Tree. Could be 1, since I am ignoring the "Root"?
          var nLevel = 0;
      //** Use of nLevel is where I'm stuck. I think. It's commented out here because
          // it's not working while it's active.
      // for (var i = 0; i < nLevel; i++)
          for (var j = 0; j <= nChildNum; j++)  //** Using a counters and print to console, I can see that
        //  j  increments, but code keeps testing var bm.
           // Am not sure I even need this next line. It comes from
                // Code I've found online.
              if (bm.children != null)
                    if (bm.name == "xxxx")
                         bm.name = "yyyy";
      app.alert("End");
      Thank you,
      Dave
